[AG-TECH] compat 2.4
George Estes
gestes at ncsa.uiuc.edu
Thu Feb 8 14:14:31 CST 2007
It's been awhile but I remember fc5 defaulting to "enforcing". Maybe I'm wrong. But anyway I have at least two machines running with selinux set to "enforcing" that have compat 2.4 installed and everything worked fine. So something must have changed somewhere.
At 02:12 PM 2/8/2007 -0500, you wrote:
>In earlier versions of Fedora, SELinux defaulted to disabled.
>-----Original Message-----
>From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
>Behalf Of George Estes
>Sent: Thursday, February 08, 2007 13:09
>To: ag-tech at mcs.anl.gov
>Subject: RE: [AG-TECH] compat 2.4
>Thanks Mike. That was the problem. It had not been a problem in
>earlier versions of Fedora. Although there is still an issue with the
>anonymous cert in the fc6 version of compat 2.4.
>Thanks again,
>George
>At 11:05 AM 2/8/2007 -0500, Mike Weaver wrote:
>>More than likely, this is due to the default state of SELinux. You can
>>disable SELinux altogether by setting the line
>>SELINUX=disabled
>>in your /etc/sysconfig/selinux file and rebooting.
>>Mike
>>Sent: Wednesday, February 07, 2007 22:18
>>Subject: [AG-TECH] compat 2.4
>>I've just built a Fedora Core 6 machine and installed 3.0 and compat
>>2.4. The 3.0 version runs fine but when I run the AGServiceManager24 I
>>get this error?
>>George
>>Traceback (most recent call last):
>> File "/usr/bin/AGServiceManager24", line 25, in ?
>> from AccessGrid.hosting import SecureServer, InsecureServer
>> File
>>"/usr/lib/python2.4/site-packages/AccessGrid2/AccessGrid/hosting/__init
>_
>>_.py", line 120, in ?
>> SetHostingImpl(__hostingImpl)
>> File
>_
>>_.py", line 62, in SetHostingImpl
>> s = __import__(nis, globals(), locals(), ["SecureServer",
>> File
>>"/usr/lib/python2.4/site-packages/AccessGrid2/AccessGrid/hosting/SOAPpy
>>Server.py", line 20, in ?
>> from SOAPpy.GSIServer import ThreadingGSISOAPServer, GSIConfig
>> File "/usr/lib/python2.4/site-packages/SOAPpy/GSIServer.py", line 74,
>>in ?
>> from pyGlobus.io import GSITCPSocketServer,
>>ThreadingGSITCPSocketServer
>> File "/usr/lib/python2.4/site-packages/pyGlobus/io.py", line 14, in ?
>> import ioc
>>ImportError: /usr/lib/globus/lib/libcrypto_gcc32pthr.so.0: cannot
>>restore segment prot after reloc: Permission denied
