[AG-TECH] macbook pro video (vic) troubles
Enrique Terrazas
Enrique.Terrazas at ucsf.edu
Wed Feb 7 09:57:01 CST 2007
I'm having the same problem in a firewall situation myself. In the
VIC window I can see the port assigned and verify that it is within
the allowable range on the firewall. From the explanation below, it
would appear the the port on the VIC window is the sending port. Is
there an easy way to verify which is the receiving port to make sure
that it is within the allowable range?
Enrique Terrazas
On Feb 7, 2007, at 3:01 AM, Andrew A Rowley wrote:
> Hi,
> This kind of sounds like a firewall problem. RAT uses the same
> port for send and receive and so may poke a return path on the
> firewall for incoming traffic. Vic uses different ports for
> sending from receiving, and so doesn't do this. The odd thing
> about this is that it works when you close the video consumer
> service - I have never known that to work, but maybe it sends out a
> packet from the receive socket as it closes?
> Andrew :)
> Access Grid Support Centre,
> RSS Group,
> Manchester Computing,
> Kilburn Building,
> University of Manchester,
> Oxford Road,
> Manchester,
> M13 9PL,
> UK
> Tel: +44(0)161-275 0685
> Email: Andrew.Rowley at manchester.ac.uk
>> -----Original Message-----
>> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
>> Behalf Of Matthew Clarkson
>> Sent: 06 February 2007 21:34
>> To: ag-tech at mcs.anl.gov
>> Cc: kdhewitt at netera.ca
>> Subject: [AG-TECH] macbook pro video (vic) troubles
>> I'm have 2 of the newer macbook pro's (core 2 duo) which are
>> causing me
>> video problems. These are both being run off a unicast network and
>> using a bridge for the connection.
>> I can configure the the hardware and software which runs properly
>> locally. However I can't view other peoples video in vic (I
>> can hear and see them in rat, but their video does not show up in
>> vic).
>> I have tried using a single VideoService like most of my other
>> personal
>> nodes, but this only displays the capture source, I have then
>> setup both
>> VideoConumerService & VideoProducerService, but the
>> VideoConsumerService
>> instance of vic stays blank. It is only when I remove
>> VideoConsumerService from my node that the VideoProducerService
>> displays
>> all offsite video streams, which I then have to unmute to view. This
>> setup is, however, not stable and does not work all the time.
>> Has anyone else experienced any problems similar to this, and if
>> so, is
>> there a solution to it at this time?
>> Matthew Clarkson
>> Netera Alliance Inc.
Enrique Terrazas, MD, MS
Director, Laboratory Medicine Residency Program
Chief, Laboratory Information Systems
HS Associate Clinical Professor
University of California, San Francisco
Clinical Laboratories, Box 0100
415.353.1375(UCSF/China Basin phone)
415.353.1620(UCSF/Parnassus phone)
415.353.4826(fax)
415.443.0913(pager)
CONFIDENTIALITY NOTICE: The information contained in this
transmission, including any enclosed files, is confidential and
intended solely for the addressee. If you are not the intended
recipient, you are hereby notified that any distribution, copying,
disclosure and use of, the contents of this transmission is strictly
prohibited. If you have received this communication in error, please
notify the sender immediately by reply email and permanently delete
this message, enclosures and all copies.
