[AG-TECH] AG3 Bridge issue
Eddy Diaz
edd-diaz at uniandes.edu.co
Thu Apr 26 12:00:50 CDT 2007
I have the same problem with fedora core 4 and 6
Eddy Johel Diaz Murcia edd-diaz at uniandes.edu.co
Estudiante de Maestría en Ingeniería de Sistemas y computación
Asistente graduado del Grupo IMAGINE Universidad de los Andes
Carrera 1 N° 18A-10 Bloque W, Bogotá, Colombia
Laboratorio de Informática Gráfica Teléfono: +57(1) 339 4949 Extensión 3462
-----Mensaje original-----
De: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] En nombre
de Fred Dech
Enviado el: Jueves, 26 de Abril de 2007 10:36 a.m.
Para: AG TECH
Asunto: [AG-TECH] AG3 Bridge issue
Hi.
I've been running a bridge on and off for some time and still run into
the same annoying issue. After the Bridge process runs for some period of
time and the amount of activity (Quickbridge processes spawned and
destroyed)
goes past a certain point, the Bridge stops functioning properly. It no
longer identifies itself to the registry and no new entries are added
to the log file. I've tried different FC5 and FC6 platforms, assuming that
this problem was machine specific, but this behavior has not changed. I
also tried running Bridge as root, thinking that I was running into some
kind
of restricted buffer limit. No difference.
The last thing normally logged is some attempts to create new bridges:
04/25/07 14:26:31 -1208707392 Toolkit Bridge:57 INFO Bridge request:
mcast 224.2.207.27 59822
04/25/07 14:26:31 -1208707392 Toolkit BridgeFactory.py:110 INFO Method
CreateBridge called
04/25/07 14:26:31 -1208707392 Toolkit BridgeFactory.py:116 INFO
Allocated port = 50076
04/25/07 14:26:31 -1208707392 Toolkit BridgeFactory.py:123 INFO - using
existing bridge
and the BridgeFactory uses an existing bridge.
Then the last item in the log is usually the destruction of all the bridges.
After that the Bridge might as well not be running, because it doesn't show
up in the registry.
The only think to do at this point is to kill and restart the bridge.
Does this sound familiar to anyone?
I'd appreciate any comments or suggestions.
Thanks.
--fred
