[AG-TECH] Windows XP dual Hauppauge Registry hack
Adam Taylor
accessgrid at ulm.edu
Tue Apr 10 16:01:06 CDT 2007
Either...
Just look for the two capture cards in the device manager. Then search for
those names in the registry. They have always been right next together in
the registry when I have had to use this.
Adam
-----Original Message-----
Sent: Tuesday, April 10, 2007 1:26 PM
To: Adam Taylor
Subject: Re: [AG-TECH] Windows XP dual Hauppauge Registry hack
Adam, is this using the Hauppauge drivers or btwincap? I think the
btwincap drivers show up as Conexant something.
On 4/10/07, Adam Taylor <accessgrid at ulm.edu> wrote:
> You have to do a find/replace in the window's registry.
> You should have something like this in device manager:
> Hauppauge WinTV
> Hauppauge WinTV
> Each card has it's own registry entry. Search for whatever the card says
in
> the device manager. You should see two right next to each other while
> searching in the registry. For every two you see change them to read
> something like:
> Hauppauge WinTV #1
> Hauppauge WinTV #2
> Make sure you just change the labels, not the actual data in the keys.
> Once you run through the registry and changed them all, reboot, and they
> should show up in device manager now as:
> Hauppauge WinTV #1
> Hauppauge WinTV #2
> You should then be able to use both of them with the AG.
> Hope this helps.
> Adam Taylor
> Computing Center
> University of Louisiana Monroe
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
Behalf
> Of Jeremy Mann
> Sent: Tuesday, April 10, 2007 12:29 PM
> To: ag-tech
> Subject: [AG-TECH] Windows XP dual Hauppauge Registry hack
> I've been googling for a few days trying to find the registry hack to
> enable 2 Hauppauge WinTV cards to be used in an XP based system. A few
> threads ago somebody replied saying they got it to work. Could that
> person privately reply with what the registry hack entails?
> Jeremy Mann
> jeremy at biochem.uthscsa.edu
> University of Texas Health Science Center
> Bioinformatics Core Facility
> http://www.bioinformatics.uthscsa.edu
> Phone: (210) 567-2672
Jeremy Mann
