[AG-TECH] Re: [AG-L] AG3 for Debian/Ubuntu
Christoph Willing
willing at vislab.uq.edu.au
Fri Apr 6 20:37:40 CDT 2007
On 06/04/2007, at 5:23 AM, Christoph Willing wrote:
> On 05/04/2007, at 11:25 PM, Derek Piper wrote:
[snip]
>> Also, I was wondering if these packages play nice with the
>> AccessGrid 2.4 release from Steve Smith? I have those installed
>> too and I'd like to be able to run both, but I'm not seeing any
>> sort of indiciation of a compatibility add-on like there is for
>> the RedHat/Fedora packages.
> I hadn't tried that, but did so just now (is it really 2.4? I could
> only find 2.3). It looks like there's a name clash for Quickbridge,
> so its probably easiest if I make a change in the AG3 packaging -
> later on today. I was hoping to to avoid an extra compat package
> but ...
> Until then you'd have to deinstall your AG2 package to try the AG3
> package.
Derek,
I've just updated the accessgrid & pyopensslag packages to remove the
namespace clashes with the AG2.3 package (turned out to be several
apart from QuickBridge). After an apt-get update or a Synaptic
"Reload", the AG3 package will install alongside a pre-existing 2.3
installation. Please note that the order is important - if you must
have both versions installed, the AG2.3 package should be installed
first, then the AG3 package.
_However_, the AG3 version will not run now due to the presence of 2
versions wxgtk - wxgtk2.4 is a dependency of AG2.3 and wxgtk2.6 is a
dependency of AG3 and they won't work together properly (looks like
AG2 still runs OK though).
A possible solution is to rebuild the AG2.3 version to use wxgtk2.6
and I've emailed the AG2.3 maintainer Steve Smith about this
possibility. Unfortunately, he's left USydney so may not see the
email and AFAIK is not involved in AG anymore anyway so ....
BTW, to properly deinstall the AG2.3 package, the packages:
accessgrid2.3
wxgtk2.4
wxgtk2.4-python
globusdatamanaggcc32gcc32dbgpthr3.0.2
should all be removed. Then, AG3 can be installed (with better
features anyway)
chris
Christoph Willing +61 7 3365 8350
QCIF Access Grid Manager
University of Queensland
