[AG-TECH] AG 2.4 and 3.0 servers
Andrew A Rowley
Andrew.Rowley at manchester.ac.uk
Fri Sep 29 08:57:52 CDT 2006
The issue may be with your AG3 Client rather than your server (the server just tells the client where to connect in AG3 - the client connects to the Jabber server).
To test the client side connection with Psi:
1) Open Psi but don't connect.
2) Go to the Psi menu and click on "Account Setup".
3) Select your jabber.mcs.anl.gov account and click on "Modify".
4) Select the "Connection" Tab.
5) Tick the box labelled "Use SSL Encryption". The "Port" at the bottom should become 5223.
6) Click on "Save" to save this.
7) Try to set your status to "Online". You should get a message about the server having a self-signed certificate. Click on "Continue" to get past this.
If this doesn't work, this is probably the problem. If this does work, it still does not guarantee that your AG3 client can talk on this port. If the above does work, try disabling any firewalls on your computer temporarily (but remember to turn them back on!). This will verify if it is a firewall or not.
Andrew :)
Access Grid Support Centre,
RSS Group,
Manchester Computing,
Kilburn Building,
University of Manchester,
Oxford Road,
Manchester,
M13 9PL,
UK
Tel: +44(0)161-275 0685
Email: Andrew.Rowley at manchester.ac.uk
> -----Original Message-----
> From: Jeremy Mann [mailto:jeremymann at gmail.com]
> Sent: 29 September 2006 14:49
> To: Andrew.Rowley at manchester.ac.uk
> Cc: ag-tech at mcs.anl.gov
> Subject: Re: [AG-TECH] AG 2.4 and 3.0 servers
> Andrew, thanks for the reply. No, to my knowledge everything is opened
> from our venue server. I connected with PSI from the Venue server to
> check my outbound connection and it connected. I chatted for awhile
> with Cindy who helped me browse the active group chats.
> On 9/29/06, Andrew A Rowley <Andrew.Rowley at manchester.ac.uk> wrote:
> > Hi,
> > It looks to me like your client hasn't managed to connect to the jabber
> server. It also looks like it is still waiting to connect since in the
> code there would be an exception displayed in the log if it had failed.
> > Could there be something that is blocking the outgoing connection from
> your client to the Jabber server (note that it is using the secure port
> 5223 rather than the insecure 5222, which you may have opened already for
> using Psi)?
> > Andrew :)
> > RSS Group,
> > Kilburn Building,
> > Oxford Road,
> > Manchester,
> > M13 9PL,
> > UK
> > > Sent: 28 September 2006 16:53
> > > The VenueClient log shows:
> > > 09/28/06 10:17:37 28510208 JabberClient JabberClient.py:33 INFO
> > > Connecting to Jabber Server 'jabber.mcs.anl.gov' ...
> > > 09/28/06 10:17:37 -1610567004 VenueClient VenueClientUI.py:3333
> > > DEBUG ContentListPanel.AddParticipant:: AddParticipant Jeremy Mann
> > > (Mac) (called from
> > > ('//Library/Python/2.3/wx-2.6-mac-unicode/wx/_core.py', 13465,
> > > '<lambda>', 'lambda event: event.callable(*event.args, **event.kw)
> > > (XP) (called from
> > > 09/28/06 10:17:37 -1610567004 GroupMsgClient GroupMsgClient.py:112
> > > INFO Connected. Connection ID: 816f45a75edf7ee69b0637cfe6bf6f7d
> > > 09/28/06 10:17:37 -1610567004 EventClient
> > > InsecureVenueEventClient.py:60 INFO BaseVenueEventClient made
> > > connection.
> > > 09/28/06 10:18:08 -1610567004 JabberClient JabberClient.py:55
> > > DEBUG currentRoom inside sendMessage(): ''
> > > 09/28/06 10:18:08 -1610567004 JabberClient JabberClient.py:59
> > > ERROR No venue is selected
> > > On 9/28/06, Andrew A Rowley <Andrew.Rowley at manchester.ac.uk> wrote:
> > > > Hi,
> > > > In Psi, once you are connected (Online) select "Service Discovery"
> from
> > > the "Psi" menu. There should then be an "AG Text Chats" list
> containing
> > > all the current chats. If your client is connecting then your venue
> will
> > > be listed here.
> > > > As Tom states, there might be something in the VenueClient.log file
> to
> > > suggest what is going wrong.
> > > > Andrew :)
> > > > RSS Group,
> > > > Kilburn Building,
> > > > Oxford Road,
> > > > Manchester,
> > > > M13 9PL,
> > > > UK
> > > > > From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]
> On
> > > > > Behalf Of Jeremy Mann
> > > > > Sent: 28 September 2006 15:36
> > > > > How do I browse the group chats? I have PSI installed and I'm
> > > > > connected to jabber.mcs.anl.gov. I go to Join Group Chat and it
> asks
> > > > > me for host, room and nickname. There is no way, that I can tell,
> to
> > > > > browse the group chats.
> wrote:
> > > > > > Hi,
> > > > > > This is odd - this suggests that you cannot connect to the
> jabber
> > > server
> > > > > from your client (I am fairly sure this is all done on the client
> side
> > > > > now). It is worth logging on to the ANL server with another
> jabber
> > > client
> > > > > and seeing if you can see any rooms for your server in the service
> > > > > discovery. Room names are the venue name with the spaces removed
> with
> > > > > your server hostname appended in brackets (take a look and you
> should
> > > see
> > > > > what I mean).
> > > > > > Andrew :)
> > > > > > RSS Group,
> > > > > > Kilburn Building,
> > > > > > Oxford Road,
> > > > > > Manchester,
> > > > > > M13 9PL,
> > > > > > UK
> > > > > > > Sent: 27 September 2006 20:00
> > > > > > > To: Andrew Rowley
> > > > > > > On 9/27/06, Andrew Rowley <Andrew.Rowley at manchester.ac.uk>
> wrote:
> > > > > > > > Hi,
> > > > > > > > If you copied your old server config, you will need to
> change
> > > the
> > > > > > > textPort to
> > > > > > > > 5223 (it is probably 8002 or something like that just now).
> You
> > > can
> > > > > run
> > > > > > > your
> > > > > > > > own Jabber server, but anl host one that seems stable (plus
> > > there
> > > > > are
> > > > > > > > loads out
> > > > > > > > there) at jabber.mcs.anl.gov. This should be set by default
> as
> > > your
> > > > > > > textHost
> > > > > > > > in your VenueServer.cfg file.
> > > > > > > Thanks Andrew. I have changed textPort to 5223 and left the
> > > address to
> > > > > > > the ANL jabber server. However, when I enter my Lobby and type
> > > > > > > something it says:
> > > > > > > You have to be connected to a venue to send a text message
> > > > > > > Jeremy
> > > > > Jeremy
> > > Jeremy
> Jeremy
