[AG-TECH] AG 2.4 and 3.0 servers
Thomas D. Uram
turam at mcs.anl.gov
Thu Sep 28 10:10:13 CDT 2006
I'd be curious to see a VenueClient.log from the client that displays
that error.
So far, reports like this have been related to server configuration. In
any case,
I'd like to do whatever possible to avoid the problem and inform the
user or
server admin about the problem when it can't be avoided.
Tom
On 9/27/06 1:59 PM, Jeremy Mann wrote:
> On 9/27/06, Andrew Rowley <Andrew.Rowley at manchester.ac.uk> wrote:
>> Hi,
>> If you copied your old server config, you will need to change the
>> textPort to
>> 5223 (it is probably 8002 or something like that just now). You can
>> run your
>> own Jabber server, but anl host one that seems stable (plus there are
>> loads out
>> there) at jabber.mcs.anl.gov. This should be set by default as your
>> textHost
>> in your VenueServer.cfg file.
> Thanks Andrew. I have changed textPort to 5223 and left the address to
> the ANL jabber server. However, when I enter my Lobby and type
> something it says:
> You have to be connected to a venue to send a text message
