[AG-TECH] AG 2.4 and 3.0 servers
Andrew A Rowley
Andrew.Rowley at manchester.ac.uk
Thu Sep 28 02:56:04 CDT 2006
This is odd - this suggests that you cannot connect to the jabber server from your client (I am fairly sure this is all done on the client side now). It is worth logging on to the ANL server with another jabber client and seeing if you can see any rooms for your server in the service discovery. Room names are the venue name with the spaces removed with your server hostname appended in brackets (take a look and you should see what I mean).
Andrew :)
Access Grid Support Centre,
RSS Group,
Manchester Computing,
Kilburn Building,
University of Manchester,
Oxford Road,
Manchester,
M13 9PL,
UK
Tel: +44(0)161-275 0685
Email: Andrew.Rowley at manchester.ac.uk
> -----Original Message-----
> From: Jeremy Mann [mailto:jeremymann at gmail.com]
> Sent: 27 September 2006 20:00
> To: Andrew Rowley
> Cc: ag-tech at mcs.anl.gov
> Subject: Re: [AG-TECH] AG 2.4 and 3.0 servers
> On 9/27/06, Andrew Rowley <Andrew.Rowley at manchester.ac.uk> wrote:
> > Hi,
> > If you copied your old server config, you will need to change the
> textPort to
> > 5223 (it is probably 8002 or something like that just now). You can run
> your
> > own Jabber server, but anl host one that seems stable (plus there are
> > loads out
> > there) at jabber.mcs.anl.gov. This should be set by default as your
> textHost
> > in your VenueServer.cfg file.
> Thanks Andrew. I have changed textPort to 5223 and left the address to
> the ANL jabber server. However, when I enter my Lobby and type
> something it says:
> You have to be connected to a venue to send a text message
> Jeremy
