[AG-TECH] AG 2.4 and 3.0 servers
Jeremy Mann
jeremymann at gmail.com
Wed Sep 27 13:59:51 CDT 2006
On 9/27/06, Andrew Rowley <Andrew.Rowley at manchester.ac.uk> wrote:
> Hi,
> If you copied your old server config, you will need to change the textPort to
> 5223 (it is probably 8002 or something like that just now). You can run your
> own Jabber server, but anl host one that seems stable (plus there are
> loads out
> there) at jabber.mcs.anl.gov. This should be set by default as your textHost
> in your VenueServer.cfg file.
Thanks Andrew. I have changed textPort to 5223 and left the address to
the ANL jabber server. However, when I enter my Lobby and type
something it says:
You have to be connected to a venue to send a text message
Jeremy
