[AG-TECH] Re: AGVCR problem
Derek Piper
dcpiper at indiana.edu
Thu Sep 7 15:44:17 CDT 2006
Very strange you've both had problems regarding running AGVCR and VIC
and RAT ... I happened to install AGVCR today on a machine with a clean
install of AGTk 2.4 and AGTk3.0.2 and both worked fine. AGVCR_Launcher
was automatically registered on both AGTk's and able to be run by
double-clicking an Application Session. Record a file, stop. Got to
other venues and VIC and RAT still load fine.
Curious.
Incidentally, something I did today was change AGVCR_Launcher so you
have to browse to a directory (or create one through a dialog) to record
AGVCR files in. It'll be out soon.
Derek
Paul Mercer wrote:
> All
> After getting AGVCR to work with help from Derek, thanks, my vic and
> rat also wouldn't start. I applied the fix from bugzilla and all is
> fine again.
> thank you all for your help
> Paul
> On Sep 7, 2006, at 5:33 AM, Cindy Sievers wrote:
>> My apologies, Derek is right, please don't blame the AGVCR installer,
>> it works great! And furthermore, both Derek and AGVCR are awesome!
>> The problem I had, as Tom pointed out, was related to this bug (and
>> not to the GTK as I had thought):
>> http://bugzilla.mcs.anl.gov/accessgrid/show_bug.cgi?id=1571
>> Tom wrote, "The problem is, I believe, the existence of some file or
>> directory that begins with "Program" in the C:\ directory,so you could
>> alternatively just remove that file/dir."
>> I had specified a directory in the C:\ directory for AGVCR to write
>> the recorded files to, this in turn, triggered the above mentioned
>> AGtk bug.....once I removed this directory, everything worked fine.
>> whew....
>> Many thanks to Tom and Derek!
>> Cindy
>> At 06:53 AM 9/7/2006, Derek Piper wrote:
>>> Any old GTK runtime would be listed in the 'Add/Remove
>>> Programs' dialog of Windows.
>>> I really don't think that any of it is related to VIC and RAT
>>> not working since they don't even use GTK.
>>> To clear some things up about the installer. It's not doing
>>> anything 'weird' behind the scenes, it's just copying the program
>>> files, the standalone runtime (the same as the contents of the .zip
>>> file that people have been using for ages, e.g. GTK and VIC and RAT).
>>> It does NOT alter the PATH of the system, but instead makes an
>>> AGVCR_PATH environment variable that the batch file to run AGVCR
>>> looks at to see if the DLLs are there. IF the GTK DLLs are installed
>>> on the system 'globally', then the bundled runtime is not used.
>>> If it sounds defensive, I guess I'm just concerned that
>>> people are going to blame the AGVCR installer for messing up their
>>> machine when it didn't.
>>> Now, as to your problem, I can only assume that Windows is
>>> just being difficult. :/
>>> Derek
>>>> Hi Paul
>>>> Seems like I have the same error, only it hosed my vic and
>>>> rat.....do you know how to get rid of the old DLLs? Upgrading to
>>>> the newest GTK created a problem on my machine!!! And I have a big
>>>> seminar tomorrow morning at 9:00.....oh woe is me....
>>>> Cindy
>>>> At 02:19 PM 9/6/2006, Derek Piper wrote:
>>>>> Paul,
>>>>> Do you have an old GTK runtime installation on the machine
>>>>> you're testing on? References to that message indicate it was a
>>>>> known bug in GTK around March time. The runtime included with AGVCR
>>>>> has the most recent Windows build of GTK. So, I'm guessing some old
>>>>> DLLs are being found on the system and causing things to break.
>>>>> Derek
>>>>> Paul Mercer wrote:
>>>>>> Derek/AG community
>>>>>> I used the Windows installer, typical installation, to install AGVCR.
>>>>>> After starting AG2.4 and entering a venue, I added AGVCR to the
>>>>>> Shared Applications and when starting it I see..
>>>>>> connecting to venue
>>>>>> getting venue url
>>>>>> getting venue streams
>>>>>> generate command line
>>>>>> and then the error The procedure entry point
>>>>>> g_intern_static_string could not be located in the dynamic link
>>>>>> library libglib-2.0-0.dll
>>>>>> I have reinstalled twice and rebooted after the install.
>>>>>> any help would be appreciated.
>>>>>> thanks
>>>>>> Paul
>>>>>> Paul Mercer
>>>>>> Arctic Region Supercomputing Center
>>>>>> 907 450 8649
>>>>> Derek Piper - dcpiper at indiana.edu <mailto:dcpiper at indiana.edu> -
>>>>> (812) 856 0111
>>>>> IRI 323, School of Informatics
>>>>> Indiana University, Bloomington, Indiana
>>>> Cindy Sievers Los Alamos National Laboratory
>>>> sievers at lanl.gov <mailto:sievers at lanl.gov> Group CCS-1 MS B287
>>>> tel:505.665.6602 Advanced Computing
>>>> fax:505.665.4939 Los Alamos, NM 87544
>>> (812) 856 0111
> Paul Mercer
> 907 450 8649
Derek Piper - dcpiper at indiana.edu - (812) 856 0111
