[AG-TECH] Re: AGVCR problem
Paul Mercer
mercer at arsc.edu
Thu Sep 7 14:18:53 CDT 2006
All
After getting AGVCR to work with help from Derek, thanks, my vic and
rat also wouldn't start. I applied the fix from bugzilla and all is
fine again.
thank you all for your help
Paul
On Sep 7, 2006, at 5:33 AM, Cindy Sievers wrote:
> My apologies, Derek is right, please don't blame the AGVCR
> installer, it works great! And furthermore, both Derek and AGVCR
> are awesome!
> The problem I had, as Tom pointed out, was related to this bug (and
> not to the GTK as I had thought):
> http://bugzilla.mcs.anl.gov/accessgrid/show_bug.cgi?id=1571
> Tom wrote, "The problem is, I believe, the existence of some file
> or directory that begins with "Program" in the C:\ directory,so you
> could alternatively just remove that file/dir."
> I had specified a directory in the C:\ directory for AGVCR to write
> the recorded files to, this in turn, triggered the above mentioned
> AGtk bug.....once I removed this directory, everything worked fine.
> whew....
> Many thanks to Tom and Derek!
> Cindy
> At 06:53 AM 9/7/2006, Derek Piper wrote:
>> Any old GTK runtime would be listed in the 'Add/Remove
>> Programs' dialog of Windows.
>> I really don't think that any of it is related to VIC and
>> RAT not working since they don't even use GTK.
>> To clear some things up about the installer. It's not
>> doing anything 'weird' behind the scenes, it's just copying the
>> program files, the standalone runtime (the same as the contents of
>> the .zip file that people have been using for ages, e.g. GTK and
>> VIC and RAT). It does NOT alter the PATH of the system, but
>> instead makes an AGVCR_PATH environment variable that the batch
>> file to run AGVCR looks at to see if the DLLs are there. IF the
>> GTK DLLs are installed on the system 'globally', then the bundled
>> runtime is not used.
>> If it sounds defensive, I guess I'm just concerned that
>> people are going to blame the AGVCR installer for messing up their
>> machine when it didn't.
>> Now, as to your problem, I can only assume that Windows is
>> just being difficult. :/
>> Derek
>>> Hi Paul
>>> Seems like I have the same error, only it hosed my vic and
>>> rat.....do you know how to get rid of the old DLLs? Upgrading to
>>> the newest GTK created a problem on my machine!!! And I have a
>>> big seminar tomorrow morning at 9:00.....oh woe is me....
>>> Cindy
>>> At 02:19 PM 9/6/2006, Derek Piper wrote:
>>>> Paul,
>>>> Do you have an old GTK runtime installation on the
>>>> machine you're testing on? References to that message indicate
>>>> it was a known bug in GTK around March time. The runtime
>>>> included with AGVCR has the most recent Windows build of GTK.
>>>> So, I'm guessing some old DLLs are being found on the system and
>>>> causing things to break.
>>>> Derek
>>>> Paul Mercer wrote:
>>>>> Derek/AG community
>>>>> I used the Windows installer, typical installation, to install
>>>>> AGVCR.
>>>>> After starting AG2.4 and entering a venue, I added AGVCR to the
>>>>> Shared Applications and when starting it I see..
>>>>> connecting to venue
>>>>> getting venue url
>>>>> getting venue streams
>>>>> generate command line
>>>>> and then the error The procedure entry point
>>>>> g_intern_static_string could not be located in the dynamic
>>>>> link library libglib-2.0-0.dll
>>>>> I have reinstalled twice and rebooted after the install.
>>>>> any help would be appreciated.
>>>>> thanks
>>>>> Paul
>>>>> Paul Mercer
>>>>> Arctic Region Supercomputing Center
>>>>> 907 450 8649
>>>> Derek Piper - dcpiper at indiana.edu - (812) 856 0111
>>>> IRI 323, School of Informatics
>>>> Indiana University, Bloomington, Indiana
>>> Cindy Sievers Los Alamos National Laboratory
>>> sievers at lanl.gov Group CCS-1 MS B287
>>> tel:505.665.6602 Advanced Computing
>>> fax:505.665.4939 Los Alamos, NM 87544
Paul Mercer
907 450 8649
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20060907/ac181156/attachment.htm>
