[AG-TECH] Re: AGVCR problem
Cindy Sievers
sievers at lanl.gov
Thu Sep 7 08:33:27 CDT 2006
My apologies, Derek is right, please don't blame the AGVCR installer, it
works great! And furthermore, both Derek and AGVCR are awesome!
The problem I had, as Tom pointed out, was related to this bug (and not to
the GTK as I had thought):
http://bugzilla.mcs.anl.gov/accessgrid/show_bug.cgi?id=1571
Tom wrote, "The problem is, I believe, the existence of some file or
directory that begins with "Program" in the C:\ directory,so you could
alternatively just remove that file/dir."
I had specified a directory in the C:\ directory for AGVCR to write the
recorded files to, this in turn, triggered the above mentioned AGtk
bug.....once I removed this directory, everything worked fine. whew....
Many thanks to Tom and Derek!
Cindy
At 06:53 AM 9/7/2006, Derek Piper wrote:
> Any old GTK runtime would be listed in the 'Add/Remove Programs'
> dialog of Windows.
> I really don't think that any of it is related to VIC and RAT not
> working since they don't even use GTK.
> To clear some things up about the installer. It's not doing
> anything 'weird' behind the scenes, it's just copying the program files,
> the standalone runtime (the same as the contents of the .zip file that
> people have been using for ages, e.g. GTK and VIC and RAT). It does NOT
> alter the PATH of the system, but instead makes an AGVCR_PATH environment
> variable that the batch file to run AGVCR looks at to see if the DLLs are
> there. IF the GTK DLLs are installed on the system 'globally', then the
> bundled runtime is not used.
> If it sounds defensive, I guess I'm just concerned that people
> are going to blame the AGVCR installer for messing up their machine when
> it didn't.
> Now, as to your problem, I can only assume that Windows is just
> being difficult. :/
> Derek
>Cindy Sievers wrote:
>>Hi Paul
>>Seems like I have the same error, only it hosed my vic and rat.....do you
>>know how to get rid of the old DLLs? Upgrading to the newest GTK created
>>a problem on my machine!!! And I have a big seminar tomorrow morning at
>>9:00.....oh woe is me....
>>Cindy
>>At 02:19 PM 9/6/2006, Derek Piper wrote:
>>> Paul,
>>> Do you have an old GTK runtime installation on the machine
>>> you're testing on? References to that message indicate it was a known
>>> bug in GTK around March time. The runtime included with AGVCR has the
>>> most recent Windows build of GTK. So, I'm guessing some old DLLs are
>>> being found on the system and causing things to break.
>>> Derek
>>>Paul Mercer wrote:
>>>>Derek/AG community
>>>>I used the Windows installer, typical installation, to install AGVCR.
>>>>After starting AG2.4 and entering a venue, I added AGVCR to the Shared
>>>>Applications and when starting it I see..
>>>>connecting to venue
>>>>getting venue url
>>>>getting venue streams
>>>>generate command line
>>>>and then the error The procedure entry point g_intern_static_string
>>>>could not be located in the dynamic link library libglib-2.0-0.dll
>>>>I have reinstalled twice and rebooted after the install.
>>>>any help would be appreciated.
>>>>thanks
>>>>Paul
>>>> Paul Mercer
>>>>Arctic Region Supercomputing Center
>>>>907 450 8649
>>>Derek Piper - dcpiper at indiana.edu - (812) 856 0111
>>>IRI 323, School of Informatics
>>>Indiana University, Bloomington, Indiana
>>Cindy Sievers Los Alamos National Laboratory
>>sievers at lanl.gov Group CCS-1 MS B287
>>tel:505.665.6602 Advanced Computing
>>fax:505.665.4939 Los Alamos, NM 87544
