[AG-TECH] Re: AGVCR problem
Derek Piper
dcpiper at indiana.edu
Thu Sep 7 07:53:41 CDT 2006
Any old GTK runtime would be listed in the 'Add/Remove Programs'
dialog of Windows.
I really don't think that any of it is related to VIC and RAT not
working since they don't even use GTK.
To clear some things up about the installer. It's not doing anything
'weird' behind the scenes, it's just copying the program files, the
standalone runtime (the same as the contents of the .zip file that
people have been using for ages, e.g. GTK and VIC and RAT). It does NOT
alter the PATH of the system, but instead makes an AGVCR_PATH
environment variable that the batch file to run AGVCR looks at to see if
the DLLs are there. IF the GTK DLLs are installed on the system
'globally', then the bundled runtime is not used.
If it sounds defensive, I guess I'm just concerned that people are
going to blame the AGVCR installer for messing up their machine when it
didn't.
Now, as to your problem, I can only assume that Windows is just being
difficult. :/
Derek
Cindy Sievers wrote:
> Hi Paul
> Seems like I have the same error, only it hosed my vic and rat.....do
> you know how to get rid of the old DLLs? Upgrading to the newest GTK
> created a problem on my machine!!! And I have a big seminar tomorrow
> morning at 9:00.....oh woe is me....
> Cindy
> At 02:19 PM 9/6/2006, Derek Piper wrote:
>> Paul,
>> Do you have an old GTK runtime installation on the machine
>> you're testing on? References to that message indicate it was a known
>> bug in GTK around March time. The runtime included with AGVCR has the
>> most recent Windows build of GTK. So, I'm guessing some old DLLs are
>> being found on the system and causing things to break.
>> Derek
>> Paul Mercer wrote:
>>> Derek/AG community
>>> I used the Windows installer, typical installation, to install AGVCR.
>>> After starting AG2.4 and entering a venue, I added AGVCR to the
>>> Shared Applications and when starting it I see..
>>> connecting to venue
>>> getting venue url
>>> getting venue streams
>>> generate command line
>>> and then the error The procedure entry point g_intern_static_string
>>> could not be located in the dynamic link library libglib-2.0-0.dll
>>> I have reinstalled twice and rebooted after the install.
>>> any help would be appreciated.
>>> thanks
>>> Paul
>>> Paul Mercer
>>> Arctic Region Supercomputing Center
>>> 907 450 8649
>> Derek Piper - dcpiper at indiana.edu - (812) 856 0111
>> IRI 323, School of Informatics
>> Indiana University, Bloomington, Indiana
> Cindy Sievers Los Alamos National Laboratory
> sievers at lanl.gov Group CCS-1 MS B287
> tel:505.665.6602 Advanced Computing
> fax:505.665.4939 Los Alamos, NM 87544
