[AG-TECH] AG3.02 WINNOV 440
Mike Daley
Mike.W.Daley at cs.cardiff.ac.uk
Wed Sep 6 02:45:40 CDT 2006
Many thanks to Cindy and Mike
It now works OK.
I had not thought to look at the Config program that came with the card.
Just assumed it was only needed if you were using WINNOV's own software.
Did not need to terminate any video sources on the card. I'm using the
DirectShow driver.
Thanks once again
Mike
Cindy Sievers wrote:
> Yes, you do need to configure your Winnov card in the winnov software
> configure program. Simply make sure each source is different (I
> believe it defaults to the same source). I didn't need to terminate
> any video sources on the card, just set the sources in the Videum
> configure program. I also didn't need to alter my registry (whew)......
> At 12:16 PM 9/5/2006, Michael Elmore wrote:
>> Mike,
>> I just got this card too. When the card was initially installed we
>> used the software for direct show. This software looks very good.
>> However, we had the problem you describe when we tried to use the AG
>> software. I uninstalled the directshow software and reinstalled the
>> VFW software. We had to reconfigure the video after doing this. We
>> have also had some javascript errors. I haven't gotten back to this to
>> check out the errors. The video did work though. We have separate
>> selectable inputs for the producer service. I have found in the
>> documentation that the video sources can be terminated on the card:
>> video source1 J10
>> video source2 J12
>> video source3 J9
>> video source4 J13
>> If it is possible, could you terminate these sources and let me know
>> if the direct show software works with the terminations?
>> Thank you,
>> Mike
>> Mike Daley wrote:
>>> Hi
>>> Has anyone got four separate video streams from a WINNOV 440 card ?
>>> I can see 4 VideoProducerServices listed with 4 separate channels
>>> labelled
>>> Videum-4 Chnl 1 Standard VidCap etc up to Chnl 4
>>> But I get one video stream replicated on all the channels.
>>> I'm sure I've seen other people with the same problem and I thought
>>> there was a fix.
>>> Can anyone help
>>> Current Driver is 3.1 release (3.1.316.1)
>>> Card is WINNOV Videum 440 VO
>>> Running XP Pro full Service pack with latest updates.
>>> AG 3.0.2 (build 1)
>>> All the best
>>> Mike
> Cindy Sievers Los Alamos National Laboratory
> sievers at lanl.gov Group CCS-1 MS B287
> tel:505.665.6602 Advanced Computing
> fax:505.665.4939 Los Alamos, NM 87544
