[AG-TECH] new AG3 install on FC5 hangs during Node Setup Wizard
Jason Bell
j.bell at cqu.edu.au
Tue Oct 17 19:20:31 CDT 2006
Jim
Have you tried to install the AG software from Doug's yum repository???
My install guide may help: http://www.accessgrid.org/node/280
Particularly:
* Before Installation Configuration
(http://www.accessgrid.org/node/297)
And
* Installation of the Access Grid software
(http://www.accessgrid.org/node/298)
sections.
I would suggestion installing the AG software from the
ag-fedora-stable.repo repository, as I haven't had any problems what so
ever.
Hope this possibly helps. If you are still having problems, give me a
yell.
Cheers,
Jason.
-----Original Message-----
Sent: Wednesday, 18 October 2006 4:30 AM
To: ag-tech at mcs.anl.gov
Subject: [AG-TECH] new AG3 install on FC5 hangs during Node Setup Wizard
I just installed the AG 3.0.2 RPM's on a brand new FC5 box. When I try
to launch the Node Setup Wizard, the splash screen hangs at "Start the
Node Service." The machine is not currently using DHCP. I have seen
some info regarding something about the /etc/hosts, but can't get to the
link where the solution was posted. I'm really not sure if this is
indeed my issue, though I thought it a good place to start.
-Jim
