[AG-TECH] Is there a Venue Client time out?
    Andrew A Rowley
    Andrew.Rowley at manchester.ac.uk
    Wed Oct  4 08:38:43 CDT 2006
I expect that the timeout on the client is likely to be an inactivity timeout on the Jabber server (suggested by the fact that the video and audio were still running in the morning).  This is a sort of bug in that the Jabber client probably should send keep-alive messages to the server (or the timeout should be disabled on the Jabber server).
Andrew :)
Access Grid Support Centre,
RSS Group,
Manchester Computing,
Kilburn Building,
University of Manchester,
Oxford Road,
Manchester,
M13 9PL,
UK
Tel: +44(0)161-275 0685
Email: Andrew.Rowley at manchester.ac.uk
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
> Behalf Of Daniel Eiland
> Sent: 04 October 2006 13:55
> To: Bonnett, PG (Paul)
> Cc: Jimmy Miklavcic; ag-tech at mcs.anl.gov
> Subject: Re: [AG-TECH] Is there a Venue Client time out?
> Hi all,
> I would agree with the need to have a continual setting for the VC. What
> may work better is to have the time-out setting something that is
> something set on the Venue Server instead of the client. We are looking
> at having extended sessions also and if there is a time out on the VC
> then we will have to find a workaround.
> Best Regards -
> Daniel L. Eiland
> IT Analyst, A/V Support
> The Center for Computation and Technology
> Louisiana State University
> deilands at cct.lsu.edu
> IM: cctdeilands
> Bonnett, PG (Paul) wrote:
> > Jimmy,
> > You make an interesting point, however I would make the opposing
> > argument that we have in past had occasion where certain operators
> > have forgotten to shut down their VC after a meeting and the following
> > day we go to setup a meeting only to find their audio & video still
> > sitting in our venue.
> > I  would like to see a 12 hour timeout for the 'normal' VC which
> > perhaps could be overridden (by changing a setting in preferences
> > perhaps) to allow you to run your extended sessions.
> > Paul Bonnett
> > Access Grid Videoconference Support & Development
> > Rutherford Appleton Labs
> > e-Science Centre
> > R1 Room 2.21
> > Tel: 01235 778329
> > P.Bonnett at rl.ac.uk <mailto:P.Bonnett at rl.ac.uk>
> > *From:* owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]
> > *On Behalf Of *Jimmy Miklavcic
> > *Sent:* 03 October 2006 17:56
> > *To:* ag-tech at mcs.anl.gov
> > *Subject:* [AG-TECH] Is there a Venue Client time out?
> > Does the AGtk3.0.x Venue Client have a time-out? I have parked my PIG
> > in the Argonne Lobby over night and in the morning when I type into
> > the jabber client, it tells by that I have to be connected to a venue;
> > video and audio appears to still be working. I'm curious because I'd
> > like initiate an "always on" scenario with the grid but if the system
> > times out at some point that can be problematic. Any insights?
> > Jimmy
> > Jimmy Miklavcic
> > Multimedia Specialist
> > Jimmy.Miklavcic at utah.edu
> > UNIVERSITY OF UTAH
> > CTR FOR HIGH PERFORM COMPUTING
> > 155 SOUTH 1452 EAST RM 405
> > SALT LAKE CITY, UT 84112-0190
> > Office: 801.585.9335
> >  Fax: 801.585.5366
> > http://www.anotherlanguage.org
