[AG-TECH] Hardware concern ...
Claus Endres
claus at endresconsulting.com
Mon May 22 18:55:32 CDT 2006
Hi Tom,
The hardware encoder is not full resolution, it is 2CIF only.
Claus.
Tom Oinn wrote:
> Claus Endres wrote:
>> Due to the very high CPU demands, H.264 cannot be used at full
>> resolution at frame rates greater than about 5 fps. This is a
>> single CPU limitation, having multiple CPUs will not help with
>> the current X264 encoder. H.264 works very well at 2 fps or so
>> for a document camera where motion is not an issue but high
>> resolution is required. Using H.264 at 20 fps and PAL resolution
>> is a while away.
> http://www.dspr.com/www/products/video/compression/pci_encoder/4_channel_h264_pci_encoder.htm
> Hardware accelerated realtime h.264 encoder with support for 4 30fps
> streams, sounds promising for this kind of setup. This is a google
> search rather than a personal recommendation though, anyone played with
> something like this?
> Tom
Claus Endres | Phone: +61-3-5998 2310
Endres Consulting Pty. Ltd. | Mobile: +61-418-595 136
10 Facey Road | Fax: +61-3-5998 2540
Devon Meadows, VIC 3977 | claus at endresconsulting.com
