[AG-TECH] AG3 add service manager
Thomas D. Uram
turam at mcs.anl.gov
Mon May 22 14:46:08 CDT 2006
Can you send the ServiceManager.log file? It's in ~/.AccessGrid3/Logs on
the linux box.
Tom
George Estes wrote:
> At 01:27 PM 5/22/2006 -0500, you wrote:
>> Are you using a hostname that resolves on the Windows machine?
> Yes
>> Are you typing the hostname yourself, or has it been discovered (using bonjour)?
> I typed the hostname myself. Bonjour did not discover the other service manager running on the same subnet, even with the XP machine that worked.
>> Can you detail the steps you took, so we can try to understand the problem better
> I started the service manager on the linux machine. On the display machine I opened the Node Management window and selected ServiceManager add, the service manager dialog box came up and I typed http://test-video3.ncsa.uiuc.edu:11000/ServiceManager. That's when I get the error.
> Sorry I don't have more information but that's all I see in the logs that looks relevant.
> George
>> (for example, what exactly do you type in for the hostname)?
>> Tom
>> George Estes wrote:
>>> Thanks Doug,
>>> The problem is not with the Linux machine. I've since built a clean XP machine and it connects fine with the Linux machine. The problem is somewhere with the first XP display machine. The first display machine is one that has had many different AG versions installed on it so maybe it's something left over from a previous version that's causing the problem.
>>> George
>>> At 11:08 AM 5/19/2006 +1000, Douglas Kosovic wrote:
>>>> Hi George,
>>>>> I'm setting up a multi-machine AG3 node, display and audio on XP and video capture on Linux. I have tried repeatedly and cannot get the venue client to add a service manager for the linux machine. The venue client displays this error "Can not add service manager to node service: get addrinfo failed". I've tried all the fixes I remember from the 2 version with no luck.
>>>> Sounds as though DNS isn't setup correctly somewhere, on WinXP in a command-line console, does 'nslookup your_linuxPC_name' work?
>>>> If you are running Fedora Core linux, here are a few suggestions:
>>>> If you are running kernel 2.6.16-1.2107_FC5, upgrade to another kernel, see:
>>>> https://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=190644
>>>> If you aren't using DHCP, you may need to fix your /etc/hosts file, see:
>>>> https://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=72594
>>>> http://agcentral.org/help/tutorial/aginstallonfc5/beforeinstall
>>>> If you had the AG3 beta2 RPMs installed, make certain you do a 'yum update' to get all of the latest AG3 RPM dependencies.
>>>> Cheers,
>>>> Doug
