[AG-TECH] Troubles entering the venues...
Thomas D. Uram
turam at mcs.anl.gov
Mon May 22 12:51:20 CDT 2006
Did you set the GLOBUS_HOSTNAME variable in the shell, and then run the
VenueServer in
that same shell? If you set it interactively, it will only affect the
shell in which it is set.
To set it permanently, you would have to include the export command in
the .bashrc of the
user running the venue server.
Tom
Fabrizio.Berdondini at prototipo.it wrote:
> The solution of setting the GLOBUS_HOSTNAME variable solved the
> problem for the WindowsXP VenueServer but not for the SUSE 10 one. I
> tried to set it for the bash (opening a konsole and typing the
> "export" command) but nothing changed.
> Is there some other way to set that system var that I could try?
> Thanx,
> Faber B.
> > "Thomas D. Uram" <turam at mcs.anl.gov> scritti il 08/05/2006 19.05.53
> > > You can also use the IP address. How you set it depends on the shell
> > > you use:
> > > For bash:
> > > export GLOBUS_HOSTNAME=140.10.10.10
> > > For csh:
> > > set GLOBUS_HOSTNAME 140.10.10.10
> > > Tom
> > > > Thank you Thomas, just 2 questions: our server machine as far as
> now
> > > > doesn't have a public hostname, just a public IP. Could this be a
> > > > problem? Second: how can I set the globus_hostname variable for
> a SUSE
> > > > 10 machine?
> > > > Thank you as always for your help.
> > > > Bye,
> > > > Faber B.
> > > > "Thomas D. Uram" <turam at mcs.anl.gov> scritti il 08/05/2006 18.50.55
> > > > > Entering a venue requires a SOAP call and an event client
> > > > connection. I
> > > > > expect that the
> > > > > SOAP call is being made to the public hsotname, but the event
> client
> > > > > connection is
> > > > > being attempted on the internal hostname. You can force the
> use of a
> > > > > particular hostname
> > > > > by setting the GLOBUS_HOSTNAME environment variable before
> running the
> > > > > VenueServer. In your case, I would set it to the public hostname.
> > > > > If problems persist, let us know.
> > > > > Tom
> > > > > > Hello all,
> > > > > > i'm having some problems with permissions (i guess so) while
> > > > trying to
> > > > > > enter the venues on a AG 2.4 VenueServer. I'm going to
> explain better
> > > > > > what's happening. We had first configurated the venue
> server/clients
> > > > > > inside our LAN and tested it for quite two months. After
> that we put
> > > > > > our server onto a public IP (without changing anything in
> the server
> > > > > > configuration). From this moment onwards we are no more able
> to reach
> > > > > > the venues: on the client we receive a message saying that
> we are not
> > > > > > able to connect to the lobby venue. We tried to launch a
> venue client
> > > > > > onto the same machine running the venueserver and we
> successfully
> > > > > > connected it to the lobby venue on the server. After this we
> tried
> > > > > > again to connect the other clients to the lobby on the venue
> server:
> > > > > > we received the same error, but looking inside the venue
> with the
> > > > only
> > > > > > venueclient connected to it (the one running on the same
> machine that
> > > > > > runs the venueserver) we saw as many instances of the client
> as the
> > > > > > number of trials we did to log to that venue.
> > > > > > How could we solve this problem?
> > > > > > Thank you in advance,
> > > > > > Faber B.
> > ______________________________________________________________________
> > This email has been scanned by the MessageLabs Email Security System.
> > For more information please visit http://www.messagelabs.com/email
