[AG-TECH] AG3 add service manager
Douglas Kosovic
douglask at itee.uq.edu.au
Thu May 18 20:08:22 CDT 2006
Hi George,
> I'm setting up a multi-machine AG3 node, display and audio on XP and
> video capture on Linux. I have tried repeatedly and cannot get the venue
> client to add a service manager for the linux machine. The venue client
> displays this error "Can not add service manager to node service: get
> addrinfo failed". I've tried all the fixes I remember from the 2 version
> with no luck.
Sounds as though DNS isn't setup correctly somewhere, on WinXP in a
command-line console, does 'nslookup your_linuxPC_name' work?
If you are running Fedora Core linux, here are a few suggestions:
If you are running kernel 2.6.16-1.2107_FC5, upgrade to another kernel, see:
https://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=190644
If you aren't using DHCP, you may need to fix your /etc/hosts file, see:
https://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=72594
http://agcentral.org/help/tutorial/aginstallonfc5/beforeinstall
If you had the AG3 beta2 RPMs installed, make certain you do a 'yum update'
to get all of the latest AG3 RPM dependencies.
Cheers,
Doug
