[AG-TECH] AG3 VenueServer
Douglas Kosovic
douglask at itee.uq.edu.au
Thu May 18 19:45:52 CDT 2006
Hi Javi,
> I have installed AG 3.0.1 in two different computers running Fedora Core 5
> and living in the same network segment. The configuration files
> VenueServer.cfg and VenueServer.dat and the Data folder are exactly the
> same in both computers. However, in one machine I can connect from the
> local machine and from external computers, but the other does not accept
> any external connections. External client get the "Error entering venue:
> connection refused" message. There is no firewall running in any of the
> computers. I attach the VenueServer.log. I have had a look and I cannot
> see anything obvious. Any help and ideas will be appreciated. Cheers,
Just a few suggestions.
If you are running kernel 2.6.16-1.2107_FC5, upgrade to another kernel, see:
https://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=190644
If you aren't using DHCP, you may need to fix your /etc/hosts file, see:
https://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=72594
http://agcentral.org/help/tutorial/aginstallonfc5/beforeinstall
If you had the AG3 beta2 RPMs installed, make certain you do a 'yum update'
to get all of the latest AG3 RPM dependencies.
Cheers,
Doug
