[AG-TECH] AG3 and bridge server?
Fabrizio.Berdondini at prototipo.it
Wed May 17 08:25:01 CDT 2006
Hi G.T. Chiang, hi all,
we are trying to set up an AG3 bridge for our VenueServer. I looked to the
py code inside Bridge3.py and Bridge.py under the bin folder, but I wasn't
able to understand how to launch it. In fact, uder Windows XP I get an
error about an import error related to module Registry.RegistryClient.
Unfortunately I wasn't able to find any information about how to set
up/install the RegistryClient module, thus I saw it's required before
launching the bridge. Anyone could help?
Thank you,
Faber B.
owner-ag-tech at mcs.anl.gov scritti il 16/02/2006 16.02.47
> Dear All
> it seems that AG3 is using different Bridge server. it can not use
-c
> and config files? i try to run brigde under linux AG3 version and got
the
> following errors?
> [root at agorilla gtniees]# Bridge.py -p 56428 56429 51748 51749 -u
> https://128.232.232.9:8000/Venues/80e8e8090bf00b6beb139475854a1725 -r
30000
> 30010 -q /usr/bin/QuickBridge -n NIEeS-AG3 -l Cambridge sh: -c: line 0:
> syntax error near unexpected token `newline' sh: -c: line 0: `ping -c 1
-w
> 1 <head>' sh: title: No such file or directory sh: -c: line 0: syntax
error
> near unexpected token `newline' sh: -c: line 0: `ping -c 1 -w 1
> response</title>' sh: -c: line 0: syntax error near unexpected token
> `newline' sh: -c: line 0: `ping -c 1 -w 1 </head>' sh: -c: line 0:
syntax
> error near unexpected token `newline' sh: -c: line 0: `ping -c 1 -w 1
> <body>' sh: h1: No such file or directory sh: -c: line 0: syntax error
near
response</h1>'
> sh: p: No such file or directory ping: unknown host code ping: unknown
host
> 404. sh: p: No such file or directory ping: unknown host Service ping:
> unknown host not ping: unknown host found ping: unknown host
> [/Venues/80e8e8090bf00b6beb139475854a1725].. sh: p: No such file or
> directory ping: unknown host code ping: unknown host explanation
connect:
> Invalid argument ping: unknown host = ping: unknown host Nothing ping:
> unknown host matches ping: unknown host the ping: unknown host given
ping:
> unknown host URI. sh: -c: line 0: syntax error near unexpected token
> `newline' sh: -c: line 0: `ping -c 1 -w 1 </body>' Traceback (most
recent
> call last):
> File "/usr/bin/Bridge.py", line 170, in ?
> main()
> File "/usr/bin/Bridge.py", line 165, in main
> bridgeServer = QuickBridgeServer(name=options.name,
> location=options.location, listenPort=options.listenPort,
> qbexec=options.qbexec, portRange=options.portRange,
> registryUrl=options.registryUrl)
> File "/usr/bin/Bridge.py", line 46, in __init__
> self._RegisterWithRegistry()
> File "/usr/bin/Bridge.py", line 68, in _RegisterWithRegistry
> self.validSecs =
> self.registryClient.RegisterBridge(self.bridgeDescription)
> File
> "/usr/lib/python2.4/site-
> packages/AccessGrid3/AccessGrid/Registry/RegistryClient.py",
> line 46, in RegisterBridge return
> self.serverProxy.RegisterBridge(registeredServerInfo) AttributeError:
> 'NoneType' object has no attribute 'RegisterBridge'
> is the sybntex wrong?
> is there anyway can run bride either in Windows or Linux for AG3?
> thank you very much!!
> gen-tao
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20060517/4cfdb3b2/attachment.htm>
