[AG-TECH] Autoplace
Robert Olson
olson at mcs.anl.gov
Tue May 16 09:53:55 CDT 2006
(wow, that code is really old now :-). I wrote the original version
of it way back when).
You're exactly correct on #1 and #2, but wrt #3, there should be a
button that saves the current autoplace settings as the default.
--bob
On May 15, 2006, at 3:20 AM, Breuer, Roman wrote:
> Tom,
> I think that the policy autoplace uses is not that, what I want. I
> don't
> know how much work it will be, but the points I don't like are:
> 1) When you draw the placing area, the resulting placing grid is
> computed with respect to the selected window size. When you the select
> an other window size the grid is not computed again.
> 2) The placing grid does not consider the display borders. So windows
> are sometimes shown half on one display and half on the other display.
> That's not acceptable especially when the displays are surrounded with
> frames such as rear projections or SMARTboards.
> 3) The placing area has to be shown everytime. Even if you close and
> reopen autoplace.
> That are some points I would like to change. I hope it is OK, that I
> will so this. Or are there any restrictions in changing the code?
> Or are
> there already any attempts for those changes?
> Regards and good luck for the AG-Retreat2006. Unfortunately I could
> not
> come :(
> Roman
> Dipl.-Inform. Roman Breuer
> Multimedia und Video
> Rechen- und Kommunikationszentrum der RWTH Aachen
> Seffenter Weg 23
> 52074 Aachen
> Germany
> Tel.: +49 (0) 241 / 80 29247
> Fax: +49 (0) 241 / 80 6 29247
> Web: http://www.rz.rwth-aachen.de
>> -----Original Message-----
>> From: Thomas D. Uram [mailto:turam at mcs.anl.gov]
>> Sent: Friday, May 12, 2006 5:54 PM
>> To: Breuer, Roman
>> Cc: ag-tech at mcs.anl.gov
>> Subject: Re: [AG-TECH] Autoplace
>> Hi Roman:
>> That functionality is only in the AccessGrid vic, in the
>> autoplace_ui.tcl file,
>> in the ag-media cvs module. You can view the file online here:
>> http://fl-cvs.mcs.anl.gov/viewcvs/viewcvs.cgi/ag-
>> media/vic/tcl/autoplace_ui.tcl
>> If you're building on Linux, I'd recommend that you use the vic-build
>> script.
>> On Windows, we use something like this:
>> cd ag-media
>> devenv vic\vic.sln /build "DDraw Release"
>> Can you say more about the changes you plan for autoplace?
>> Tom
>>> Hi everyone,
>>> I think my last mail was somehow not delivered to this list (or
> maybe I
>>> wrote to the wrong list ...), but can anyone tell me where I can
> find
>>> the sources of the vic-autoplace functionality. And how to rebuild
> vic
>>> for AG, after changing a few things? Maybe there are websites I have
> not
>>> discovered yet, with this info I need.
>>> Best Regards,
>>> Roman
>>> Seffenter Weg 23
>>> 52074 Aachen
>>> Germany
