[AG-TECH] cannot connect to venue on new PIG
Thomas D. Uram
turam at mcs.anl.gov
Wed May 10 15:10:12 CDT 2006
I expect that certificates are not to blame for the problems you're having.
You could look in the VenueClient.log file for an indication of the
problem. It is often due to a time skew on the machine, so make sure
the clock is set accurately. If you don't see anything clear in the log
file,
you can send it to me to have a look.
Tom
P.S. You'll find the VenueClient.log file in these locations:
Linux: ~/.AccessGrid/Logs
Windows: C:\Documents and Settings\<you>\Application Data\AccessGrid\Logs
Michael A Gideon wrote:
> So does it seem to be python that was causing this? I am having the
> same error but different circumstances. I just rebuilt a dell machine,
> dual boot -XP and Suse 10. I requested a new certificate on the XP
> side. Got it, installed it. Only after making it default ( anonymous
> was default ) could I connect. Prior to making it default I got the
> same error "Can not enter venue located at
> https://vv2.mcs.anl.gov:9000/Venues/default".
> I finished the linux install, exported my certificate from the XP side
> and imported it to my linux certificate manager. Now I get that same
> error on both platforms. I'm probably wrong, but I could have sworn
> that as soon as I imported it to linux, I got connected with no errors.
> Either way I did connect from one platform yesterday. I can't connect
> with either today. Can I not use the same certificate? Now I am
> flipping back and forth testing. Should I just request a certificate
> for each platform? Should it really matter? Why would it stop working?
> Any help would be appreciated.
> Mike Gideon
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
> Behalf Of Thomas D. Uram
> Sent: Wednesday, March 15, 2006 8:59 AM
> To: Jennifer Teig von Hoffman
> Cc: 'ag-tech at mcs.anl.gov'
> Subject: Re: [AG-TECH] cannot connect to venue on new PIG
> The TupleType problem that appears in the log is well-known on
> new IBM machines with the IBM support tools installed. The
> problem, and some means of resolving it, are described here:
> http://bugzilla.mcs.anl.gov/accessgrid/show_bug.cgi?id=1208
> I have seen this problem persist despite the fixes outlined in
> that bug report. If yours is one of these cases, I'd like to track it
> down.
> Tom
> On 3/15/06 10:46 AM, Jennifer Teig von Hoffman wrote:
>> Hi all,
>> I've just migrated to a new laptop and installed AG 2.4. I've imported
>> my (valid) certificate, and can successfully make a proxy. However, I
>> cannot connect to a venue. When I try to connect, I get the standard
>> "Can not connect to venue located at
>> https://vvw.mcs.anl.gov:9000/Venues/default. Please try again." error
>> message. I've tried to connect to both the address above, and
>> venues.ncsa.uiuc.edu.
>> I wonder if my laptop may be in a strange state -- I used the Lenovo
>> migration assistant when switching over to the new hardware, and
>> generally speaking it has been inconsistent about what settings/etc
> it's
>> carried over from the old machine. I installed AG 2.4 *after*
> migration,
>> so theoretically it shouldn't have taken any of the AG-related
> settings,
>> but nonetheless the Lenovo experience has overall been quite mixed and
> I
>> wonder if it may be the issue here.
>> My entire VenueClient.log is below. Any suggestions?
>> Cheers,
>> Jennifer
>> 03/14/06 15:43:06 824 Toolkit config.py:364 ERROR Couldn't
> retrieve
>> globus key from registry.
>> Traceback (most recent call last):
>> File
>> "C:\Python23\Lib\site-packages\AccessGrid\Platform\win32\Config.py",
>> line 362, in GetGlobusKey
>> "Software\Globus", 0, _winreg.KEY_SET_VALUE)
>> WindowsError: [Errno 2] The system cannot find the file specified
>> 03/14/06 15:43:06 824 Toolkit config.py:214 DEBUG System hostname
> of
>> SCV-BADTZ.ad.bu.edu is valid
>> 03/14/06 15:44:45 2840 Toolkit config.py:381 ERROR Couldn't
> retrieve
>> gsi key from registry.
>> File
>> line 378, in GetGlobusKey
>> gsikey = _winreg.OpenKey(gkey, "GSI", 0, _winreg.KEY_SET_VALUE)
>> 03/14/06 15:44:45 2840 Toolkit config.py:214 DEBUG System hostname
>> of SCV-BADTZ.ad.bu.edu is valid
>> 03/14/06 15:44:45 2840 CertificateManager
> certificatemanager.py:297
>> DEBUG initializing repository
> certificatemanager.py:327
>> DEBUG Initializing from C:\Program
> Files\AGTk-2.4\Config\CAcertificates
> certificatemanager.py:340
>> WARNING Didn't find certficate in old globus path: C:\Documents and
>> Settings\jtvh\Application Data\globus\usercert.pem
> certificatemanager.py:416
>> INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\1c3f2ca8.0 might
>> be a cert
>> 03/14/06 15:44:45 2840 CertificateRepository
>> certificaterepository.py:889 DEBUG _ImportCertificate: create
>> C:\Documents and Settings\jtvh\Application
> Data\AccessGrid\Config\certRepo\certificates\a82c3f1c4b096b896061778ee79
> efeff\9c8df64aa35ebf832613413527bc073d
>> 03/14/06 15:44:46 2840 CertificateRepository
>> certificaterepository.py:1615 DEBUG GetFilePath: create C:\Documents
> and
> efeff\9c8df64aa35ebf832613413527bc073d\user_files
>> 03/14/06 15:44:46 2840 CertificateManager
> certificatemanager.py:441
>> INFO Imported cert as 1c3f2ca8.0
>> INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\45cc9e80.0 might
>> be a cert
> Data\AccessGrid\Config\certRepo\certificates\809ecc45460c1482e61e26bdfbf
> 9e18c\9f380c9a586af2bb913ace809d5badfe
> and
> 9e18c\9f380c9a586af2bb913ace809d5badfe\user_files
>> INFO Imported cert as 45cc9e80.0
>> INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\d1b603c3.0 might
>> be a cert
> Data\AccessGrid\Config\certRepo\certificates\c303b6d10c962b37482e68ca64d
> 383a0\05a2039fe10ed1b4195d9f9d35b32c68
> and
> 383a0\05a2039fe10ed1b4195d9f9d35b32c68\user_files
>> INFO Imported cert as d1b603c3.0
>> INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\f18fa857.0 might
>> be a cert
> Data\AccessGrid\Config\certRepo\certificates\57a88ff1707d87e926f2287c702
> a8466\eff65f03366cb8e20247f831ccc87fd5
> and
> a8466\eff65f03366cb8e20247f831ccc87fd5\user_files
>> INFO Imported cert as f18fa857.0
> certificatemanager.py:1198
>> WARNING No identity certs found
> certificatemanager.py:1209
>> WARNING No default identity certificate found
>> 03/14/06 15:44:46 2840 Toolkit toolkit.py:404 DEBUG looking in
>> system ca dir: C:\Program Files\AGTk-2.4\Config\CAcertificates
>> 03/14/06 15:44:46 2840 Toolkit toolkit.py:418 INFO C:\Program
>> Files\AGTk-2.4\Config\CAcertificates\1c3f2ca8.0 might be a cert
>> 03/14/06 15:44:46 2840 Toolkit toolkit.py:440 INFO Certificate
>> 1c3f2ca8.0 already in repository
>> 03/14/06 15:44:46 2840 Toolkit toolkit.py:456 INFO Marking cert
> as
>> CA cert
>> 03/14/06 15:44:46 2840 Toolkit toolkit.py:469 INFO Imported
> signing
>> policy as C:\Documents and Settings\jtvh\Application
> efeff\9c8df64aa35ebf832613413527bc073d\user_files\signing_policy
>> Files\AGTk-2.4\Config\CAcertificates\45cc9e80.0 might be a cert
>> 45cc9e80.0 already in repository
> as
>> CA cert
> signing
> 9e18c\9f380c9a586af2bb913ace809d5badfe\user_files\signing_policy
>> Files\AGTk-2.4\Config\CAcertificates\d1b603c3.0 might be a cert
>> d1b603c3.0 already in repository
> as
>> CA cert
> signing
> 383a0\05a2039fe10ed1b4195d9f9d35b32c68\user_files\signing_policy
>> Files\AGTk-2.4\Config\CAcertificates\f18fa857.0 might be a cert
>> f18fa857.0 already in repository
> as
>> CA cert
>> 03/14/06 15:44:47 2840 Toolkit toolkit.py:469 INFO Imported
> signing
> a8466\eff65f03366cb8e20247f831ccc87fd5\user_files\signing_policy
>> 03/14/06 15:44:47 2840 Toolkit toolkit.py:478 DEBUG Init'ing
> globus.
>> 03/14/06 15:44:47 2840 CertificateManager
> certificatemanager.py:759
>> DEBUG Configuring standard environment
> certificatemanager.py:829
>> DEBUG No default identity found <type 'NoneType'> None
>> 03/14/06 15:44:47 2840 CertificateRepository
>> certificaterepository.py:952 INFO _ImportPrivateKey importing pkey to
> Data\AccessGrid\Config\certRepo\privatekeys\b82eff976e60282028802c8814e2
> 3901.pem
>> certificaterepository.py:918 INFO _ImportCertificateRequest writing
> to
> Data\AccessGrid\Config\certRepo\requests\b82eff976e60282028802c8814e2390
> 1.pem
>> 03/14/06 15:44:47 2840 CRSClient crsclient.py:40 DEBUG create
> client
>> 03/14/06 15:44:47 2840 CRSClient crsclient.py:73 DEBUG request
>> certificate
>> 03/14/06 15:44:49 2840 CertificateManager
> certificatemanager.py:1275
>> DEBUG CheckRequestedCertificate:
> req=<AccessGrid.Security.CertificateRepository.CertificateRequestDescrip
> tor
>> instance at 0x01F892D8>, token=267d22fbd98fcbd8bca067f7148e034a,
> server=http://www-unix.mcs.anl.gov/fl/research/accessgrid/ca/anonymous/a
> nonReqServer.cgi
>> 03/14/06 15:44:49 2840 CRSClient crsclient.py:40 DEBUG create
> client
>> 03/14/06 15:44:49 2840 CRSClient crsclient.py:104 DEBUG retrieve
>> certificate for token 267d22fbd98fcbd8bca067f7148e034a
>> 03/14/06 15:44:49 2840 CRSClient crsclient.py:115 DEBUG retrieved
>> certificate [1, '-----BEGIN
> CERTIFICATE-----\nMIIDhzCCAm+gAwIBAgIERBcrQTANBgkqhkiG9w0BAQQFADCBkDEUMB
> IGA1UEChML\nQWNjZXNzIEdyaWQxJDAiBgNVBAoTG0FyZ29ubmUgTmF0aW9uYWwgTGFib3Jh
> dG9y\neTEoMCYGA1UECxMfRnV0dXJlcyBMYWIgQW5vbnltb3VzIEF1dGhvcml0eTEoMCYG\n
> A1UEAxMfQW5vbnltb3VzIENlcnRpZmljYXRlIEF1dGhvcml0eTAeFw0wNjAzMTQx\nOTQ0ND
> laFw0wNzAzMTQyMDQ0NDlaMIGgMRQwEgYDVQQKEwtBY2Nlc3MgR3JpZDEk\nMCIGA1UEChMb
> QXJnb25uZSBOYXRpb25hbCBMYWJvcmF0b3J5MSgwJgYDVQQLEx9G\ndXR1cmVzIExhYiBBbm
> 9ueW1vdXMgQXV0aG9yaXR5MTgwNgYDVQQDEy9Bbm9ueW1v\ndXMgVXNlciA0YTI1MGViNGUz
> MjMxZjJhYmJlM2Q0MDIxYzMzMDY0NjCBnzANBgkq\nhkiG9w0BAQEFAAOBjQAwgYkCgYEA3s
> yI5qYAOvg9161DkKgx30GidmZNOxq3HEbB\ngsW88zY1dpbE1fbkN+7ejbbfbvdtkXwGS2YU
> zSe+hpHTn/AUVyy53cBCLxQ0fLyj\n4QaTiHXqDCAtY5b+EK3z5BwrLyWO4+/sYuysLAkf6Z
> v+DW+vXNxkqZ0TtzbGePaM\nD6KpdzECAwEAAaNbMFkwEQYJYIZIAYb4QgEBBAQDAgTwMAwG
> A1UdEwEB/wQCMAAw\nNgYJYIZIAYb4QgENBCkWJ0dlbmVyYXRlZCBieSBwYXNzd2QgY2hlY2
> sgYXV0aGVu\ndGljYXRvcjANBgk
> qhkiG9w0BAQQFAAOCAQEALmC3il6vFPYI1PERDado53isFC8R\n0w1SXWv8skr9XZWw/Gbc2
> Lms9MgVn5PxN6aeSoRr30M0IOk/xYAObNWKRbyzTaaE\nle7xuILHPwEB7GaeHDr11gcRCU6
> cs1a+DwMEXTWb9nTyK3w6yYvE4ZuGaqJDnFFc\n4YCqiDx0XmJjqz5YDp7l6tn5j2PLF1WW3
> rGWATBAo+jjcGrCu/KzlI0RFAXANPWg\npTj/pOprcOinLUWr7XXos90NY91/vHmvFVP2mQq
> QPI7OwbqFiviAo8+dcC2/ozDj\nJkECJYzHJrYQFu5udPHajE2wTaYP7R6Nhn20D9PvD3cgS
> Bv/AXXKSk0bwQ==\n-----END
>> CERTIFICATE-----\n\n']
> certificatemanager.py:1280
>> DEBUG Retrieve returns [1, '-----BEGIN
> sgYXV0aGVu\nd
> GljYXRvcjANBgkqhkiG9w0BAQQFAAOCAQEALmC3il6vFPYI1PERDado53isFC8R\n0w1SXWv
> 8skr9XZWw/Gbc2Lms9MgVn5PxN6aeSoRr30M0IOk/xYAObNWKRbyzTaaE\nle7xuILHPwEB7
> GaeHDr11gcRCU6cs1a+DwMEXTWb9nTyK3w6yYvE4ZuGaqJDnFFc\n4YCqiDx0XmJjqz5YDp7
> l6tn5j2PLF1WW3rGWATBAo+jjcGrCu/KzlI0RFAXANPWg\npTj/pOprcOinLUWr7XXos90NY
> 91/vHmvFVP2mQqQPI7OwbqFiviAo8+dcC2/ozDj\nJkECJYzHJrYQFu5udPHajE2wTaYP7R6
> Nhn20D9PvD3cgSBv/AXXKSk0bwQ==\n-----END
>> 03/14/06 15:44:49 2840 CertificateRepository
>> certificaterepository.py:866 DEBUG Importing requested certificate
>> subj=/O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab
>> Anonymous Authority/CN=Anonymous User 4a250eb4e3231f2abbe3d4021c330646
>> path=C:\Documents and Settings\jtvh\Application
> Data\AccessGrid\Config\certRepo\certificates\5cf11fcf8b5d698d7eb3ccdba19
> 80efb\99514c538e7a32167c1699b16c025df4
>> certificaterepository.py:867 DEBUG Modulus hash is
>> b82eff976e60282028802c8814e23901
>> 03/14/06 15:44:50 2840 CertificateManager
> certificatemanager.py:453
>> DEBUG imported requested cert /O=Access Grid/O=Argonne National
>> Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User
> certificatemanager.py:827
>> DEBUG Using default identity /O=Access Grid/O=Argonne National
> certificatemanager.py:1083
>> DEBUG Initializing environment with unencrypted cert /O=Access
>> Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous
> certificatemanager.py:1098
>> INFO Setting permissions on certificate C:\Documents and
> 80efb\99514c538e7a32167c1699b16c025df4\cert.pem
>> to 644
> certificatemanager.py:1109
> 3901.pem
>> to 600
>> 03/14/06 15:44:50 2840 CertificateManagerWXGUI
>> certificatemanagerwxgui.py:422 DEBUG done, success=1
>> 03/14/06 15:44:50 2840 Toolkit toolkit.py:482 DEBUG Done with
> globus.
>> 03/14/06 15:44:50 2840 Toolkit venueclient.py:83 INFO wx version
>> is: 2.5.1.5
>> 03/14/06 15:44:50 2840 VenueClient venueclient.py:287 DEBUG
>> __StartWebService: venueclient:
>> https://SCV-BADTZ.ad.bu.edu:11000/VenueClient
>> 03/14/06 15:44:50 2840 ServiceManager agservicemanager.py:68 INFO
>> Creating user services directory C:\Documents and
>> Settings\jtvh\Application Data\AccessGrid\local_services
>> 03/14/06 15:44:50 2840 ServiceManager agservicemanager.py:424 INFO
>> __DiscoverResources
>> 03/14/06 15:44:50 2840 Toolkit config.py:997 INFO Using vfwscan
> to
>> get devices
>> 03/14/06 15:44:50 2840 Toolkit config.py:998 DEBUG vfwscanexe =
>> C:\PROGRA~1\AGTk-2.4\bin\vfwscan.exe
>> 03/14/06 15:44:51 2840 Toolkit config.py:1003 DEBUG filelines =
>> ['Microsoft WDM Image Capture (Win32)\n']
>> 03/14/06 15:44:51 2840 Toolkit config.py:1031 INFO GetResources:
>> ['Microsoft WDM Image Capture (Win32)']
>> 03/14/06 15:44:51 2840 VenueClient venueclient.py:296 DEBUG
>> __StartWebService: service manager:
>> https://SCV-BADTZ.ad.bu.edu:11000/ServiceManager
>> 03/14/06 15:44:51 2840 NodeService agnodeservice.py:115 INFO
>> Copying system node configs to user node config dir
>> 03/14/06 15:44:51 2840 NodeService agnodeservice.py:116 INFO
>> system node config = C:\Program Files\AGTk-2.4\Config\nodeConfig
>> 03/14/06 15:44:51 2840 NodeService agnodeservice.py:117 INFO
> user
>> node config = C:\Documents and Settings\jtvh\Application
>> Data\AccessGrid\Config\nodeConfig
>> 03/14/06 15:44:51 2840 NodeService agnodeservice.py:120 INFO
> node
>> config: defaultWindows
>> 03/14/06 15:44:51 2840 NodeService agnodeservice.py:756 INFO
>> NodeService.__ReadConfigFile
>> 03/14/06 15:44:51 2840 Toolkit toolkit.py:335 DEBUG Looking for:
>> Data\AccessGrid\Config\AGNodeService.cfg
>> 03/14/06 15:44:51 2840 Toolkit toolkit.py:340 DEBUG Looking for:
>> C:\Program Files\AGTk-2.4\Config\AGNodeService.cfg
>> 03/14/06 15:44:51 2840 NodeService agnodeservice.py:764 DEBUG
>> DEFAULT NODE SERVICE CONFIG: C:\Program
>> 03/14/06 15:44:51 2840 NodeService agnodeservice.py:768 INFO
>> Reading node service config file: C:\Program
>> 03/14/06 15:44:51 2840 VenueClient venueclient.py:302 DEBUG
>> __StartWebService: node service:
>> https://SCV-BADTZ.ad.bu.edu:11000/NodeService
>> 03/14/06 15:44:51 2840 VenueClient venueclient.py:1328 DEBUG
>> SerNodeUrl: Set node service url:
>> 03/14/06 15:44:51 2840 NodeService agnodeservice.py:698 INFO
>> NodeService.GetDefaultConfiguration
>> 03/14/06 15:44:51 2840 NodeService agnodeservice.py:581 INFO
>> Migration unnecessary
>> 03/14/06 15:44:51 2840 NodeService agnodeservice.py:374 INFO
>> NodeService.LoadDefaultConfig
>> 03/14/06 15:44:51 2840 NodeService agnodeservice.py:378 INFO
>> Loading default node configuration: defaultWindows
>> 03/14/06 15:44:51 2840 NodeService agnodeservice.py:392 INFO
>> NodeService.LoadConfiguration
>> 03/14/06 15:44:51 2840 NodeService agnodeservice.py:407 INFO
> Trying
>> to load node configuration from: C:\Documents and
> Data\AccessGrid\Config\nodeConfig\defaultWindows
>> 03/14/06 15:44:51 2840 NodeService agnodeservice.py:480 INFO
>> AddServiceManager: Invalid service manager url
>> (https://localhost:11000/ServiceManager)
>> 03/14/06 15:44:51 2840 NodeService agnodeservice.py:381 ERROR
>> Exception loading default configuration.
>> File "C:\Python23\Lib\site-packages\AccessGrid\AGNodeService.py",
> line
>> 379, in LoadDefaultConfig
>> self.LoadConfiguration( self.defaultConfig )
> line
>> 523, in LoadConfiguration
>> raise Exception(exceptionText)
>> Exception: Couldn't reach service manager: localhost:11000
>> 03/14/06 15:44:51 2840 VenueClient venueclient.py:313 ERROR Error
>> File "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line
>> 311, in __StartWebService
>> self.ns.LoadDefaultConfig()
> line
>> 382, in LoadDefaultConfig
>> raise Exception("Failed to load default configuration <%s>" %
>> Exception: Failed to load default configuration <defaultWindows>
>> 03/14/06 15:44:51 2840 VenueClient venueclient.py:185 DEBUG
>> __createPersonalDataStore: Creating personal datastore at C:\Documents
>> and Settings\jtvh\Application Data\AccessGrid\Config\personalDataStore
>> using prefix personalDataStore and port 0
>> 03/14/06 15:44:51 2840 DataStore datastore.py:1537 DEBUG Creating
>> thread 0
>> 03/14/06 15:44:51 2840 DataStore datastore.py:1542 DEBUG Starting
>> thread 0
>> 03/14/06 15:44:51 3284 DataStore datastore.py:1550 DEBUG Worker 0
>> starting
>> 03/14/06 15:44:51 2840 DataStore datastore.py:1544 DEBUG Waiting
>> thread 0
>> 03/14/06 15:44:51 2840 DataStore datastore.py:1547 DEBUG Done
>> creating workers
>> 03/14/06 15:45:17 2840 DataStore datastore.py:278 DEBUG Reading
>> persisted data from: C:\Documents and Settings\jtvh\Application
>> Data\AccessGrid\Config\personalDataStore\DataStore.dat
>> 03/14/06 15:45:17 2840 VenueClient venueclient.py:210 DEBUG
>> __createPersonalDataStore: Load personal data from file
>> 03/14/06 15:45:17 2840 VenueClientController
>> venueclientcontroller.py:1255 DEBUG There is no personal venues file
> to
>> load.
>> 03/14/06 15:45:17 2840 VenueClient venueclientui.py:188 DEBUG the
>> profile is the default profile - open profile dialog
>> 03/14/06 15:45:17 2840 VenueClient venueclientui.py:3871 DEBUG
>> VenueClientUI.py: Set editable in successfully dialog
>> 03/14/06 15:45:17 2840 VenueClient venueclientui.py:3942 DEBUG
>> ProfileDialog.SetProfile: Set profile information successfully in
> dialog
>> 03/14/06 15:45:42 2840 VenueClient venueclientui.py:3924 DEBUG
>> ProfileDialog.GetNewProfile: Got profile information from dialog
>> 03/14/06 15:45:42 2840 VenueClientController
>> venueclientcontroller.py:624 DEBUG Can not update client profile in
>> venue - not connected
>> 03/14/06 15:49:19 2840 VenueClient venueclientui.py:1565 INFO
>> --------- END VenueClient
>> 03/14/06 15:49:19 2840 DataStore datastore.py:1614 DEBUG Quitting
>> thread 0
>> 03/14/06 15:49:19 3284 DataStore datastore.py:1555 DEBUG Worker 0
>> gets cmd quit
>> 03/14/06 15:49:19 3284 DataStore datastore.py:1568 DEBUG Worker 0
>> exiting
>> 03/14/06 15:49:19 3076 DataStore datastore.py:1627 INFO
>> GSIHTTPTransferServer: GSITCPSocket, interrupted I/O operation, most
>> likely shutting down. 03/14/06 15:49:19 2840 NodeService
>> agnodeservice.py:136 INFO NodeService.Stop
>> 03/14/06 15:49:19 2840 ServiceManager agservicemanager.py:84 INFO
>> AGServiceManager.Shutdown
>> 03/14/06 15:49:19 2840 ServiceManager agservicemanager.py:85 INFO
>> Remove services
>> 03/14/06 15:49:19 2840 ServiceManager agservicemanager.py:389 INFO
>> AGServiceManager.RemoveServices
>> 03/14/06 15:49:19 2840 ServiceManager agservicemanager.py:87 INFO
>> Stop network interface
>> 03/14/06 15:49:19 3924 Hosting server.py:65 ERROR Exception in
> SOAP
>> server main loop
>> File
>> "C:\Python23\Lib\site-packages\AccessGrid\hosting\SOAPpy\Server.py",
>> line 63, in Run
>> self._server.handle_request()
>> File "C:\Python23\lib\SocketServer.py", line 217, in handle_request
>> request, client_address = self.get_request()
>> File "C:\Python23\Lib\site-packages\SOAPpy\GSIServer.py", line 140,
> in
>> get_request
>> sock, addr = ThreadingGSITCPSocketServer.get_request(self)
>> File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 525, in
>> get_request
>> self.socket.listen()
>> File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 857, in
> listen
>> raise ex
>> GSITCPSocketException: an I/O operation was cancelled
>> 03/14/06 15:49:19 2840 Hosting server.py:97 ERROR server_close()
> failed
>> File
>> line 95, in Stop
>> self._server.server_close()
>> File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1043, in
>> server_close
>> self.socket.close()
>> File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1020, in
> close
>> IOBase.close(self)
>> File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 176, in
> close
>> raise ex
>> IOBaseException: an uninitialied data structure was passed as argument
> 1
>> to globus_io_register_close
> failed
>> File
>> line 95, in Stop
>> server_close
>> self.socket.close()
> close
>> IOBase.close(self)
> close
>> raise ex
> 1
>> 03/14/06 15:49:32 2580 Toolkit config.py:214 DEBUG System hostname
>> 03/14/06 15:49:32 2580 CertificateManager
> certificatemanager.py:269
>> DEBUG Opened repository C:\Documents and Settings\jtvh\Application
>> 03/14/06 15:49:32 2580 Toolkit toolkit.py:404 DEBUG looking in
>> 03/14/06 15:49:32 2580 Toolkit toolkit.py:418 INFO C:\Program
>> 03/14/06 15:49:32 2580 Toolkit toolkit.py:440 INFO Certificate
>> 03/14/06 15:49:32 2580 Toolkit toolkit.py:456 INFO Marking cert
> as
>> CA cert
>> 03/14/06 15:49:32 2580 Toolkit toolkit.py:469 INFO Imported
> signing
> as
>> CA cert
> signing
> as
>> CA cert
> signing
> as
>> CA cert
>> 03/14/06 15:49:33 2580 Toolkit toolkit.py:469 INFO Imported
> signing
>> 03/14/06 15:49:33 2580 Toolkit toolkit.py:478 DEBUG Init'ing
> globus.
>> 03/14/06 15:49:33 2580 CertificateManager
>> to 644
> 3901.pem
>> to 600
>> 03/14/06 15:49:33 2580 CertificateManagerWXGUI
>> 03/14/06 15:49:33 2580 Toolkit toolkit.py:482 DEBUG Done with
> globus.
>> 03/14/06 15:49:33 2580 Toolkit venueclient.py:83 INFO wx version
>> is: 2.5.1.5
>> 03/14/06 15:49:33 2580 VenueClient venueclient.py:287 DEBUG
>> 03/14/06 15:49:33 2580 ServiceManager agservicemanager.py:75 INFO
>> Using services dir: C:\Documents and Settings\jtvh\Application
>> 03/14/06 15:49:33 2580 ServiceManager agservicemanager.py:424 INFO
>> __DiscoverResources
>> 03/14/06 15:49:33 2580 Toolkit config.py:997 INFO Using vfwscan
> to
>> get devices
>> 03/14/06 15:49:33 2580 Toolkit config.py:998 DEBUG vfwscanexe =
>> 03/14/06 15:49:33 2580 Toolkit config.py:1003 DEBUG filelines =
>> 03/14/06 15:49:33 2580 Toolkit config.py:1031 INFO GetResources:
>> 03/14/06 15:49:33 2580 VenueClient venueclient.py:296 DEBUG
>> 03/14/06 15:49:33 2580 NodeService agnodeservice.py:756 INFO
>> 03/14/06 15:49:33 2580 Toolkit toolkit.py:335 DEBUG Looking for:
>> 03/14/06 15:49:33 2580 Toolkit toolkit.py:340 DEBUG Looking for:
>> 03/14/06 15:49:33 2580 NodeService agnodeservice.py:764 DEBUG
>> 03/14/06 15:49:33 2580 NodeService agnodeservice.py:768 INFO
>> 03/14/06 15:49:33 2580 VenueClient venueclient.py:302 DEBUG
>> 03/14/06 15:49:33 2580 VenueClient venueclient.py:1328 DEBUG
>> 03/14/06 15:49:33 2580 NodeService agnodeservice.py:698 INFO
>> 03/14/06 15:49:33 2580 NodeService agnodeservice.py:581 INFO
>> 03/14/06 15:49:33 2580 NodeService agnodeservice.py:374 INFO
>> 03/14/06 15:49:33 2580 NodeService agnodeservice.py:378 INFO
>> 03/14/06 15:49:33 2580 NodeService agnodeservice.py:392 INFO
>> 03/14/06 15:49:33 2580 NodeService agnodeservice.py:407 INFO
> Trying
>> 03/14/06 15:49:33 2580 NodeService agnodeservice.py:480 INFO
>> 03/14/06 15:49:33 2580 NodeService agnodeservice.py:381 ERROR
> line
> line
>> 03/14/06 15:49:33 2580 VenueClient venueclient.py:313 ERROR Error
> line
>> 03/14/06 15:49:33 2580 VenueClient venueclient.py:185 DEBUG
>> 03/14/06 15:49:33 2580 DataStore datastore.py:1537 DEBUG Creating
>> thread 0
>> 03/14/06 15:49:33 2580 DataStore datastore.py:1542 DEBUG Starting
>> thread 0
>> 03/14/06 15:49:33 2256 DataStore datastore.py:1550 DEBUG Worker 0
>> starting
>> 03/14/06 15:49:33 2580 DataStore datastore.py:1544 DEBUG Waiting
>> thread 0
>> 03/14/06 15:49:33 2580 DataStore datastore.py:1547 DEBUG Done
>> creating workers
>> 03/14/06 15:49:33 2580 DataStore datastore.py:278 DEBUG Reading
>> 03/14/06 15:49:33 2580 VenueClient venueclient.py:210 DEBUG
>> 03/14/06 15:49:33 2580 VenueClientController
> to
>> load.
>> 03/14/06 15:49:49 2580 VenueClient venueclient.py:805 DEBUG
>> EnterVenue; url=https://vv2.mcs.anl.gov:9000/Venues/default
>> 03/14/06 15:49:49 2580 VenueClient venueclient.py:833 INFO
>> EnterVenue: Error getting node capabilities
>> 03/14/06 15:49:49 2580 VenueClient venueclient.py:705 DEBUG
>> EnterVenue: Invoke venue enter
>> 03/14/06 15:49:49 2580 VenueClient venueclient.py:866 ERROR
>> EnterVenue: failed
>> 837, in EnterVenue
>> self.__EnterVenue(URL)
>> 706, in __EnterVenue
>> (venueState, self.privateId, self.streamDescList ) =
>> self.__venueProxy.Enter( self.profile )
>> File "C:\Python23\Lib\site-packages\AccessGrid\Venue.py", line 3499,
> in
>> Enter
>> (r1, r2, r3) = self.proxy.Enter(profile)
>> File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 453, in
>> __call__
>> return self.__r_call(*args, **kw)
>> File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 475, in
>> __r_call
>> self.__hd, self.__ma)
>> File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 338, in
> __call
>> config = self.config, noroot = self.noroot)
>> File "C:\Python23\Lib\site-packages\SOAPpy\SOAPBuilder.py", line 620,
>> in buildSOAP
>> return t.build()
>> File "C:\Python23\Lib\site-packages\SOAPpy\SOAPBuilder.py", line 118,
>> in build
>> body_ns = self.genns(ns_map, NS.ENV)[0]
>> File "C:\Python23\Lib\site-packages\SOAPpy\SOAPBuilder.py", line 204,
>> in genns
>> if type(nsURI) == TupleType: # already a tuple
>> NameError: global name 'TupleType' is not defined
>> 03/14/06 15:49:49 2580 VenueClient venueclientui.py:1925 DEBUG
>> bin.VenueClient::EnterVenue: Enter venue with url:
>> 03/14/06 15:49:49 2580 VenueClient venueclientui.py:1938 DEBUG
>> warningString: 03/14/06 15:49:55 2580 CertificateRepository
>> certificaterepository.py:592 DEBUG Register observer <bound method
>> ProxyBrowser.OnRepoUpdate of
>> <AccessGrid.Security.wxgui.ProxyBrowser.ProxyBrowser; proxy of C++
>> wxPanel instance at _c04ed701_p_wxPanel>>
>> certificaterepository.py:594 DEBUG Adding <weakref at 0212F1B0; to
>> 'instancemethod' at 020D8E40 (OnRepoUpdate)>
>> IdentityBrowser.OnRepoUpdate of
>> <AccessGrid.Security.wxgui.IdentityBrowser.IdentityBrowser; proxy of
> C++
>> wxPanel instance at _b073e301_p_wxPanel>>
>> certificaterepository.py:594 DEBUG Adding <weakref at 0212F480; to
>> 'instancemethod' at 020D8D28 (OnRepoUpdate)>
>> CABrowser.OnRepoUpdate of
>> <AccessGrid.Security.wxgui.CABrowser.CABrowser; proxy of C++ wxPanel
>> instance at _90c10f02_p_wxPanel>>
>> certificaterepository.py:594 DEBUG Adding <weakref at 0212F690; to
>> 'instancemethod' at 0211BF08 (OnRepoUpdate)>
>> CertificateStatusBrowser.OnRepoUpdate of
> <AccessGrid.Security.wxgui.CertificateStatusBrowser.CertificateStatusBro
> wser;
>> proxy of C++ wxPanel instance at _18fe0f02_p_wxPanel>>
>> certificaterepository.py:594 DEBUG Adding <weakref at 0212FA50; to
>> 'instancemethod' at 02131260 (OnRepoUpdate)>
>> 03/14/06 16:07:01 2428 Toolkit config.py:214 DEBUG System hostname
>> 03/14/06 16:07:01 2428 CertificateManager
>> 03/14/06 16:07:02 2428 Toolkit toolkit.py:404 DEBUG looking in
>> 03/14/06 16:07:02 2428 Toolkit toolkit.py:418 INFO C:\Program
>> 03/14/06 16:07:02 2428 Toolkit toolkit.py:440 INFO Certificate
>> 03/14/06 16:07:02 2428 Toolkit toolkit.py:456 INFO Marking cert
> as
>> CA cert
>> 03/14/06 16:07:02 2428 Toolkit toolkit.py:469 INFO Imported
> signing
> as
>> CA cert
> signing
> as
>> CA cert
> signing
> as
>> CA cert
>> 03/14/06 16:07:03 2428 Toolkit toolkit.py:469 INFO Imported
> signing
>> 03/14/06 16:07:03 2428 Toolkit toolkit.py:478 DEBUG Init'ing
> globus.
>> 03/14/06 16:07:03 2428 CertificateManager
>> to 644
> 3901.pem
>> to 600
>> 03/14/06 16:07:03 2428 CertificateManagerWXGUI
>> 03/14/06 16:07:03 2428 Toolkit toolkit.py:482 DEBUG Done with
> globus.
>> 03/14/06 16:07:03 2428 Toolkit venueclient.py:83 INFO wx version
>> is: 2.5.1.5
>> 03/14/06 16:07:03 2428 VenueClient venueclient.py:287 DEBUG
>> 03/14/06 16:07:03 2428 ServiceManager agservicemanager.py:75 INFO
>> 03/14/06 16:07:03 2428 ServiceManager agservicemanager.py:424 INFO
>> __DiscoverResources
>> 03/14/06 16:07:03 2428 Toolkit config.py:997 INFO Using vfwscan
> to
>> get devices
>> 03/14/06 16:07:03 2428 Toolkit config.py:998 DEBUG vfwscanexe =
>> 03/14/06 16:07:05 2428 Toolkit config.py:1003 DEBUG filelines =
>> 03/14/06 16:07:05 2428 Toolkit config.py:1031 INFO GetResources:
>> 03/14/06 16:07:05 2428 VenueClient venueclient.py:296 DEBUG
>> 03/14/06 16:07:05 2428 NodeService agnodeservice.py:756 INFO
>> 03/14/06 16:07:05 2428 Toolkit toolkit.py:335 DEBUG Looking for:
>> 03/14/06 16:07:05 2428 Toolkit toolkit.py:340 DEBUG Looking for:
>> 03/14/06 16:07:05 2428 NodeService agnodeservice.py:764 DEBUG
>> 03/14/06 16:07:05 2428 NodeService agnodeservice.py:768 INFO
>> 03/14/06 16:07:05 2428 VenueClient venueclient.py:302 DEBUG
>> 03/14/06 16:07:05 2428 VenueClient venueclient.py:1328 DEBUG
>> 03/14/06 16:07:05 2428 NodeService agnodeservice.py:698 INFO
>> 03/14/06 16:07:05 2428 NodeService agnodeservice.py:581 INFO
>> 03/14/06 16:07:05 2428 NodeService agnodeservice.py:374 INFO
>> 03/14/06 16:07:05 2428 NodeService agnodeservice.py:378 INFO
>> 03/14/06 16:07:05 2428 NodeService agnodeservice.py:392 INFO
>> 03/14/06 16:07:05 2428 NodeService agnodeservice.py:407 INFO
> Trying
>> 03/14/06 16:07:05 2428 NodeService agnodeservice.py:480 INFO
>> 03/14/06 16:07:05 2428 NodeService agnodeservice.py:381 ERROR
> line
> line
>> 03/14/06 16:07:05 2428 VenueClient venueclient.py:313 ERROR Error
> line
>> 03/14/06 16:07:05 2428 VenueClient venueclient.py:185 DEBUG
>> 03/14/06 16:07:05 2428 DataStore datastore.py:1537 DEBUG Creating
>> thread 0
>> 03/14/06 16:07:05 2428 DataStore datastore.py:1542 DEBUG Starting
>> thread 0
>> 03/14/06 16:07:05 4036 DataStore datastore.py:1550 DEBUG Worker 0
>> starting
>> 03/14/06 16:07:05 2428 DataStore datastore.py:1544 DEBUG Waiting
>> thread 0
>> 03/14/06 16:07:05 2428 DataStore datastore.py:1547 DEBUG Done
>> creating workers
>> 03/14/06 16:07:05 2428 DataStore datastore.py:278 DEBUG Reading
>> 03/14/06 16:07:05 2428 VenueClient venueclient.py:210 DEBUG
>> 03/14/06 16:07:05 2428 VenueClientController
> to
>> load.
>> 03/14/06 16:07:15 2428 CertificateRepository
>> certificaterepository.py:594 DEBUG Adding <weakref at 020DA2D0; to
>> 'instancemethod' at 020D8A30 (OnRepoUpdate)>
> C++
>> wxPanel instance at _18dd1002_p_wxPanel>>
>> certificaterepository.py:594 DEBUG Adding <weakref at 020DA5A0; to
>> 'instancemethod' at 020D8B98 (OnRepoUpdate)>
>> instance at _28c9f001_p_wxPanel>>
>> certificaterepository.py:594 DEBUG Adding <weakref at 020DA7B0; to
>> 'instancemethod' at 020D8D78 (OnRepoUpdate)>
> wser;
>> proxy of C++ wxPanel instance at _d009f101_p_wxPanel>>
>> certificaterepository.py:594 DEBUG Adding <weakref at 020DAB70; to
>> 'instancemethod' at 020D8FA8 (OnRepoUpdate)>
>> 03/14/06 16:14:47 2428 CertificateRepository
>> certificaterepository.py:129 ERROR Could not open certificate file
>> 03/14/06 16:15:06 2428 CertificateRepository
>> certificaterepository.py:133 INFO Found valid cert, validKey=1
>> 03/14/06 16:15:07 2428 CertificateRepository
>> 03/14/06 16:15:11 2428 CertificateRepository
>> certificaterepository.py:741 ERROR load error
>> File
> "C:\Python23\Lib\site-packages\AccessGrid\Security\CertificateRepository
> .py",
>> line 738, in ImportCertificatePEM
>> passphrase)
>> Error: [('digital envelope routines', 'EVP_DecryptFinal', 'bad
>> decrypt'), ('PEM routines', 'PEM_do_header', 'bad decrypt')]
>> 03/14/06 16:15:11 2428 CertificateManagerWXGUI
>> importexportutils.py:792 ERROR Import fails: Incorrect passphrase.
> cert
>> file S:\AG\jtvh\cert-exp-12-2006.pem keyfile
>> File
> "C:\Python23\Lib\site-packages\AccessGrid\Security\wxgui\ImportExportUti
> ls.py",
>> line 775, in ImportPEMIdentityCertificate
>> certFile, keyFile, cb)
>> File
> "C:\Python23\Lib\site-packages\AccessGrid\Security\CertificateManager.py
>> line 465, in ImportIdentityCertificatePEM
>> impCert = repo.ImportCertificatePEM(userCert, userKey,
> passphraseCB)
>> File
> .py",
>> line 742, in ImportCertificatePEM
>> raise RepoBadPassphrase
>> RepoBadPassphrase
>> 03/14/06 16:15:16 2428 CertificateRepository
>> 03/14/06 16:15:19 2428 CertificateRepository
>> 03/14/06 16:15:21 2428 CertificateRepository
>> 03/14/06 16:15:24 2428 CertificateRepository
> Data\AccessGrid\Config\certRepo\privatekeys\b6ea2d1e21eb850bef7b799ce043
> d5e9.pem
> Data\AccessGrid\Config\certRepo\certificates\9469dc4861d79549ca6a9e6a2ed
> 4909f\7fd839972fa295d09928e28808b848ea
>> 03/14/06 16:15:25 2428 CertificateManagerWXGUI
>> importexportutils.py:776 DEBUG Imported identity /O=Access
>> Grid/OU=agdev-ca.mcs.anl.gov/OU=bu.edu/CN=Jennifer Teig von Hoffman
>> importexportutils.py:834 DEBUG ID certs:
>> [<AccessGrid.Security.CertificateRepository.CertificateDescriptor
>> instance at 0x02132918>]
>> to 644
> 3901.pem
>> to 600
>> 03/14/06 16:15:30 2428 CertificateManager
> certificatemanager.py:902
>> DEBUG Initializing environment with proxy cert for /O=Access
> certificatemanager.py:968
>> DEBUG _VerifyGlobusProxy: file C:\DOCUME~1\jtvh\LOCALS~1\Temp\proxy
> not
>> found
>> 03/14/06 16:15:40 2428 CertificateManagerWXGUI
>> certificatemanagerwxgui.py:550 DEBUG Proxy successfully created
> certificatemanager.py:1011
>> INFO Verifying local proxy cert
> certificatemanager.py:921
>> DEBUG Configuring for user proxy issued from /O=Access
> certificatemanager.py:924
>> DEBUG Proxy C:\DOCUME~1\jtvh\LOCALS~1\Temp\proxy will expire 03/15/06
>> 05:15:40
>> 05:15:40
>> 03/14/06 16:18:36 2428 VenueClient venueclient.py:805 DEBUG
>> 03/14/06 16:18:36 2428 CertificateManager
> certificatemanager.py:663
>> DEBUG HaveValidProxy: found proxy ident /O=Access
>> Hoffman/CN=proxy
>> Hoffman/CN=proxy
>> 03/14/06 16:18:36 2428 VenueClient venueclient.py:833 INFO
>> 03/14/06 16:18:36 2428 VenueClient venueclient.py:705 DEBUG
>> 03/14/06 16:18:36 2428 VenueClient venueclient.py:866 ERROR
>> EnterVenue: failed
>> 837, in EnterVenue
> in
>> Enter
>> __call__
>> __r_call
> __call
>> in buildSOAP
>> return t.build()
>> in build
>> in genns
>> 03/14/06 16:18:36 2428 VenueClient venueclientui.py:1925 DEBUG
>> 03/14/06 16:18:36 2428 VenueClient venueclientui.py:1938 DEBUG
>> warningString: 03/14/06 16:18:42 2428 VenueClient
>> venueclient.py:1343 INFO Error enabling video
>> 03/14/06 16:18:44 2428 VenueClient venueclient.py:1349 INFO Error
>> enabling audio
>> 03/14/06 16:19:06 2428 VenueClient venueclientui.py:1565 INFO
>> 03/14/06 16:19:06 2428 DataStore datastore.py:1614 DEBUG Quitting
>> thread 0
>> 03/14/06 16:19:06 4036 DataStore datastore.py:1555 DEBUG Worker 0
>> gets cmd quit
>> 03/14/06 16:19:06 4036 DataStore datastore.py:1568 DEBUG Worker 0
>> exiting
>> 03/14/06 16:19:06 4032 DataStore datastore.py:1627 INFO
>> likely shutting down. 03/14/06 16:19:06 2428 NodeService
>> 03/14/06 16:19:06 2428 ServiceManager agservicemanager.py:84 INFO
>> 03/14/06 16:19:06 2428 ServiceManager agservicemanager.py:85 INFO
>> Remove services
>> 03/14/06 16:19:06 2428 ServiceManager agservicemanager.py:389 INFO
>> 03/14/06 16:19:06 2428 ServiceManager agservicemanager.py:87 INFO
>> 03/14/06 16:19:06 2084 Hosting server.py:65 ERROR Exception in
> SOAP
>> server main loop
>> File
>> line 63, in Run
> in
>> get_request
>> get_request
> listen
>> raise ex
>> 03/14/06 16:19:06 2428 Hosting server.py:97 ERROR server_close()
> failed
>> File
>> line 95, in Stop
>> server_close
>> self.socket.close()
> close
>> IOBase.close(self)
> close
>> raise ex
> 1
> failed
>> File
>> line 95, in Stop
>> server_close
>> self.socket.close()
> close
>> IOBase.close(self)
> close
>> raise ex
> 1
>> 03/15/06 11:34:51 444 Toolkit config.py:214 DEBUG System hostname
> of
>> 03/15/06 11:34:51 444 CertificateManager certificatemanager.py:269
>> 03/15/06 11:34:52 444 Toolkit toolkit.py:404 DEBUG looking in
> system
>> 03/15/06 11:34:52 444 Toolkit toolkit.py:418 INFO C:\Program
>> 03/15/06 11:34:52 444 Toolkit toolkit.py:440 INFO Certificate
>> 03/15/06 11:34:52 444 Toolkit toolkit.py:456 INFO Marking cert as
>> CA cert
>> 03/15/06 11:34:52 444 Toolkit toolkit.py:469 INFO Imported
> signing
>> CA cert
> signing
>> CA cert
> signing
>> CA cert
> signing
>> 03/15/06 11:34:52 444 Toolkit toolkit.py:478 DEBUG Init'ing
> globus.
>> 03/15/06 11:34:53 444 CertificateManager certificatemanager.py:759
>> 03/15/06 11:34:53 444 CertificateManager certificatemanager.py:827
>> 03/15/06 11:34:53 444 CertificateManager certificatemanager.py:902
> certificatemanager.py:1024
>> DEBUG _VerifyGlobusProxy: proxy C:\DOCUME~1\jtvh\LOCALS~1\Temp\proxy
>> expired
>> 03/15/06 11:35:01 444 CertificateManagerWXGUI
>> 03/15/06 11:35:01 444 CertificateManager certificatemanager.py:759
>> 03/15/06 11:35:01 444 CertificateManager certificatemanager.py:827
>> 03/15/06 11:35:01 444 CertificateManager certificatemanager.py:902
>> 03/15/06 11:35:01 444 CertificateManager certificatemanager.py:921
>> 03/15/06 11:35:01 444 CertificateManager certificatemanager.py:924
>> DEBUG Proxy C:\DOCUME~1\jtvh\LOCALS~1\Temp\proxy will expire 03/16/06
>> 00:35:01
>> 00:35:01
>> 03/15/06 11:35:01 444 Toolkit toolkit.py:482 DEBUG Done with
> globus.
>> 03/15/06 11:35:01 444 Toolkit venueclient.py:83 INFO wx version
> is:
>> 2.5.1.5
>> 03/15/06 11:35:01 444 VenueClient venueclient.py:287 DEBUG
>> 03/15/06 11:35:01 444 ServiceManager agservicemanager.py:75 INFO
>> 03/15/06 11:35:01 444 ServiceManager agservicemanager.py:424 INFO
>> __DiscoverResources
>> 03/15/06 11:35:01 444 Toolkit config.py:997 INFO Using vfwscan to
>> get devices
>> 03/15/06 11:35:01 444 Toolkit config.py:998 DEBUG vfwscanexe =
>> 03/15/06 11:35:01 444 Toolkit config.py:1003 DEBUG filelines =
>> 03/15/06 11:35:01 444 Toolkit config.py:1031 INFO GetResources:
>> 03/15/06 11:35:01 444 VenueClient venueclient.py:296 DEBUG
>> 03/15/06 11:35:01 444 NodeService agnodeservice.py:756 INFO
>> 03/15/06 11:35:01 444 Toolkit toolkit.py:335 DEBUG Looking for:
>> 03/15/06 11:35:01 444 Toolkit toolkit.py:340 DEBUG Looking for:
>> 03/15/06 11:35:01 444 NodeService agnodeservice.py:764 DEBUG
> DEFAULT
>> 03/15/06 11:35:01 444 NodeService agnodeservice.py:768 INFO
> Reading
>> 03/15/06 11:35:01 444 VenueClient venueclient.py:302 DEBUG
>> 03/15/06 11:35:01 444 VenueClient venueclient.py:1328 DEBUG
>> 03/15/06 11:35:01 444 NodeService agnodeservice.py:698 INFO
>> 03/15/06 11:35:02 444 NodeService agnodeservice.py:581 INFO
>> 03/15/06 11:35:02 444 NodeService agnodeservice.py:374 INFO
>> 03/15/06 11:35:02 444 NodeService agnodeservice.py:378 INFO
> Loading
>> 03/15/06 11:35:02 444 NodeService agnodeservice.py:392 INFO
>> 03/15/06 11:35:02 444 NodeService agnodeservice.py:407 INFO
> Trying
>> 03/15/06 11:35:02 444 NodeService agnodeservice.py:480 INFO
>> 03/15/06 11:35:02 444 NodeService agnodeservice.py:381 ERROR
> line
> line
>> 03/15/06 11:35:02 444 VenueClient venueclient.py:313 ERROR Error
> line
>> 03/15/06 11:35:02 444 VenueClient venueclient.py:185 DEBUG
>> 03/15/06 11:35:02 444 DataStore datastore.py:1537 DEBUG Creating
>> thread 0
>> 03/15/06 11:35:02 444 DataStore datastore.py:1542 DEBUG Starting
>> thread 0
>> 03/15/06 11:35:02 284 DataStore datastore.py:1550 DEBUG Worker 0
>> starting
>> 03/15/06 11:35:02 444 DataStore datastore.py:1544 DEBUG Waiting
>> thread 0
>> 03/15/06 11:35:02 444 DataStore datastore.py:1547 DEBUG Done
>> creating workers
>> 03/15/06 11:35:02 444 DataStore datastore.py:278 DEBUG Reading
>> 03/15/06 11:35:02 444 VenueClient venueclient.py:210 DEBUG
>> 03/15/06 11:35:02 444 VenueClientController
> to
>> load.
>> 03/15/06 11:35:22 444 CertificateRepository
>> certificaterepository.py:594 DEBUG Adding <weakref at 020DB270; to
>> 'instancemethod' at 020D6A58 (OnRepoUpdate)>
> C++
>> wxPanel instance at _d028de01_p_wxPanel>>
>> certificaterepository.py:594 DEBUG Adding <weakref at 020DB540; to
>> 'instancemethod' at 020D6AD0 (OnRepoUpdate)>
>> instance at _6886e301_p_wxPanel>>
>> certificaterepository.py:594 DEBUG Adding <weakref at 020DB750; to
>> 'instancemethod' at 020D6C38 (OnRepoUpdate)>
> wser;
>> proxy of C++ wxPanel instance at _f003ef01_p_wxPanel>>
>> certificaterepository.py:594 DEBUG Adding <weakref at 020DBB10; to
>> 'instancemethod' at 020DF030 (OnRepoUpdate)>
>> 03/15/06 11:35:43 444 VenueClient venueclient.py:805 DEBUG
>> 03/15/06 11:35:43 444 CertificateManager
>> 03/15/06 11:35:43 444 CertificateManager certificatemanager.py:663
>> Hoffman/CN=proxy
>> Hoffman/CN=proxy
>> 03/15/06 11:35:43 444 VenueClient venueclient.py:833 INFO
>> 03/15/06 11:35:43 444 VenueClient venueclient.py:705 DEBUG
>> 03/15/06 11:35:43 444 VenueClient venueclient.py:866 ERROR
>> EnterVenue: failed
>> 837, in EnterVenue
> in
>> Enter
>> __call__
>> __r_call
> __call
>> in buildSOAP
>> return t.build()
>> in build
>> in genns
>> 03/15/06 11:35:43 444 VenueClient venueclientui.py:1925 DEBUG
>> 03/15/06 11:35:43 444 VenueClient venueclientui.py:1938 DEBUG
>> warningString: 03/15/06 11:37:41 444 VenueClient
> venueclient.py:805
>> DEBUG EnterVenue; url=https://venues.ncsa.uiuc.edu:9000/Venues/default
>> 03/15/06 11:37:41 444 CertificateManager
>> 03/15/06 11:37:41 444 CertificateManager certificatemanager.py:663
>> Hoffman/CN=proxy
>> Hoffman/CN=proxy
>> 03/15/06 11:37:41 444 VenueClient venueclient.py:833 INFO
>> 03/15/06 11:37:41 444 VenueClient venueclient.py:705 DEBUG
>> 03/15/06 11:37:41 444 VenueClient venueclient.py:866 ERROR
>> EnterVenue: failed
>> 837, in EnterVenue
> in
>> Enter
>> __call__
>> __r_call
> __call
>> in buildSOAP
>> return t.build()
>> in build
>> in genns
>> 03/15/06 11:37:41 444 VenueClient venueclientui.py:1925 DEBUG
>> 03/15/06 11:37:41 444 VenueClient venueclientui.py:1938 DEBUG
>> warningString: 03/15/06 11:39:38 444 VenueClient
>> venueclientui.py:1565 INFO --------- END VenueClient
>> 03/15/06 11:39:38 444 DataStore datastore.py:1614 DEBUG Quitting
>> thread 0
>> 03/15/06 11:39:38 284 DataStore datastore.py:1555 DEBUG Worker 0
>> gets cmd quit
>> 03/15/06 11:39:38 284 DataStore datastore.py:1568 DEBUG Worker 0
>> exiting
>> 03/15/06 11:39:38 444 NodeService agnodeservice.py:136 INFO
>> NodeService.Stop
>> 03/15/06 11:39:38 444 ServiceManager agservicemanager.py:84 INFO
>> 03/15/06 11:39:38 444 ServiceManager agservicemanager.py:85 INFO
>> Remove services
>> 03/15/06 11:39:38 444 ServiceManager agservicemanager.py:389 INFO
>> 03/15/06 11:39:38 444 ServiceManager agservicemanager.py:87 INFO
>> 03/15/06 11:39:38 1732 DataStore datastore.py:1627 INFO
>> likely shutting down. 03/15/06 11:39:38 3836 Hosting server.py:65
>> ERROR Exception in SOAP server main loop
>> File
>> line 63, in Run
> in
>> get_request
>> get_request
> listen
>> raise ex
>> 03/15/06 11:39:38 444 Hosting server.py:97 ERROR server_close()
> failed
>> File
>> line 95, in Stop
>> server_close
>> self.socket.close()
> close
>> IOBase.close(self)
> close
>> raise ex
> 1
> failed
>> File
>> line 95, in Stop
>> server_close
>> self.socket.close()
> close
>> IOBase.close(self)
> close
>> raise ex
> 1
>> 03/15/06 11:40:54 240 Toolkit toolkit.py:96 DEBUG Initializing AG
>> Toolkit version 2.4 (build 1)
>> 03/15/06 11:40:54 240 Toolkit toolkit.py:138 INFO Logfile Name:
>> VenueClient.log
>> 03/15/06 11:40:54 240 Toolkit config.py:196 DEBUG Using
>> GLOBUS_HOSTNAME=SCV-BADTZ.ad.bu.edu as set in the environment
>> 03/15/06 11:40:54 240 CertificateManager certificatemanager.py:269
>> 03/15/06 11:40:54 240 Toolkit toolkit.py:404 DEBUG looking in
> system
>> 03/15/06 11:40:54 240 Toolkit toolkit.py:418 INFO C:\Program
>> 03/15/06 11:40:54 240 Toolkit toolkit.py:440 INFO Certificate
>> 03/15/06 11:40:54 240 Toolkit toolkit.py:456 INFO Marking cert as
>> CA cert
>> 03/15/06 11:40:54 240 Toolkit toolkit.py:469 INFO Imported
> signing
>> CA cert
> signing
>> CA cert
> signing
>> CA cert
> signing
>> 03/15/06 11:40:54 240 Toolkit toolkit.py:478 DEBUG Init'ing
> globus.
>> 03/15/06 11:40:54 240 CertificateManager certificatemanager.py:759
>> 03/15/06 11:40:54 240 CertificateManager certificatemanager.py:827
>> 03/15/06 11:40:54 240 CertificateManager certificatemanager.py:902
>> 03/15/06 11:40:54 240 CertificateManager certificatemanager.py:921
>> 03/15/06 11:40:54 240 CertificateManager certificatemanager.py:924
>> 00:35:01
>> 03/15/06 11:40:54 240 CertificateManagerWXGUI
>> 03/15/06 11:40:54 240 Toolkit toolkit.py:482 DEBUG Done with
> globus.
>> 03/15/06 11:40:54 240 Toolkit venueclient.py:83 INFO wx version
> is:
>> 2.5.1.5
>> 03/15/06 11:40:55 240 VenueClient venueclient.py:287 DEBUG
>> 03/15/06 11:40:55 240 ServiceManager agservicemanager.py:75 INFO
>> 03/15/06 11:40:55 240 ServiceManager agservicemanager.py:424 INFO
>> __DiscoverResources
>> 03/15/06 11:40:55 240 Toolkit config.py:997 INFO Using vfwscan to
>> get devices
>> 03/15/06 11:40:55 240 Toolkit config.py:998 DEBUG vfwscanexe =
>> 03/15/06 11:40:55 240 Toolkit config.py:1003 DEBUG filelines =
>> 03/15/06 11:40:55 240 Toolkit config.py:1031 INFO GetResources:
>> 03/15/06 11:40:55 240 VenueClient venueclient.py:296 DEBUG
>> 03/15/06 11:40:55 240 NodeService agnodeservice.py:756 INFO
>> 03/15/06 11:40:55 240 Toolkit toolkit.py:335 DEBUG Looking for:
>> 03/15/06 11:40:55 240 Toolkit toolkit.py:340 DEBUG Looking for:
>> 03/15/06 11:40:55 240 NodeService agnodeservice.py:764 DEBUG
> DEFAULT
>> 03/15/06 11:40:55 240 NodeService agnodeservice.py:768 INFO
> Reading
>> 03/15/06 11:40:55 240 VenueClient venueclient.py:302 DEBUG
>> 03/15/06 11:40:55 240 VenueClient venueclient.py:1328 DEBUG
>> 03/15/06 11:40:55 240 NodeService agnodeservice.py:698 INFO
>> 03/15/06 11:40:55 240 NodeService agnodeservice.py:581 INFO
>> 03/15/06 11:40:55 240 NodeService agnodeservice.py:374 INFO
>> 03/15/06 11:40:55 240 NodeService agnodeservice.py:378 INFO
> Loading
>> 03/15/06 11:40:55 240 NodeService agnodeservice.py:392 INFO
>> 03/15/06 11:40:55 240 NodeService agnodeservice.py:407 INFO
> Trying
>> 03/15/06 11:40:55 240 NodeService agnodeservice.py:480 INFO
>> 03/15/06 11:40:55 240 NodeService agnodeservice.py:381 ERROR
> line
> line
>> 03/15/06 11:40:55 240 VenueClient venueclient.py:313 ERROR Error
> line
>> 03/15/06 11:40:55 240 VenueClient venueclient.py:185 DEBUG
>> 03/15/06 11:40:55 240 DataStore datastore.py:1537 DEBUG Creating
>> thread 0
>> 03/15/06 11:40:55 240 DataStore datastore.py:1542 DEBUG Starting
>> thread 0
>> 03/15/06 11:40:55 2996 DataStore datastore.py:1550 DEBUG Worker 0
>> starting
>> 03/15/06 11:40:55 240 DataStore datastore.py:1544 DEBUG Waiting
>> thread 0
>> 03/15/06 11:40:55 240 DataStore datastore.py:1547 DEBUG Done
>> creating workers
>> 03/15/06 11:40:55 240 DataStore datastore.py:278 DEBUG Reading
>> 03/15/06 11:40:55 240 VenueClient venueclient.py:210 DEBUG
>> 03/15/06 11:40:55 240 VenueClientController
> to
>> load.
>> 03/15/06 11:40:55 240 VenueClient venueclient.py:805 DEBUG
>> 03/15/06 11:40:55 240 CertificateManager
>> 03/15/06 11:40:55 240 CertificateManager certificatemanager.py:663
>> Hoffman/CN=proxy
>> Hoffman/CN=proxy
>> 03/15/06 11:40:55 240 VenueClient venueclient.py:833 INFO
>> 03/15/06 11:40:55 240 VenueClient venueclient.py:705 DEBUG
>> 03/15/06 11:40:55 240 VenueClient venueclient.py:866 ERROR
>> EnterVenue: failed
>> 837, in EnterVenue
> in
>> Enter
>> __call__
>> __r_call
> __call
>> in buildSOAP
>> return t.build()
>> in build
>> in genns
>> 03/15/06 11:40:55 240 VenueClient venueclientui.py:1925 DEBUG
>> 03/15/06 11:40:55 240 VenueClient venueclientui.py:1938 DEBUG
>> warningString: 03/15/06 11:41:01 240 VenueClient
>> 03/15/06 11:41:01 240 DataStore datastore.py:1614 DEBUG Quitting
>> thread 0
>> 03/15/06 11:41:01 2996 DataStore datastore.py:1555 DEBUG Worker 0
>> gets cmd quit
>> 03/15/06 11:41:01 2996 DataStore datastore.py:1568 DEBUG Worker 0
>> exiting
>> 03/15/06 11:41:01 3376 DataStore datastore.py:1627 INFO
>> likely shutting down. 03/15/06 11:41:01 240 NodeService
>> 03/15/06 11:41:01 240 ServiceManager agservicemanager.py:84 INFO
>> 03/15/06 11:41:01 240 ServiceManager agservicemanager.py:85 INFO
>> Remove services
>> 03/15/06 11:41:01 240 ServiceManager agservicemanager.py:389 INFO
>> 03/15/06 11:41:01 240 ServiceManager agservicemanager.py:87 INFO
>> 03/15/06 11:41:01 1340 Hosting server.py:65 ERROR Exception in
> SOAP
>> server main loop
>> File
>> line 63, in Run
> in
>> get_request
>> get_request
> listen
>> raise ex
>> 03/15/06 11:41:01 240 Hosting server.py:97 ERROR server_close()
> failed
>> File
>> line 95, in Stop
>> server_close
>> self.socket.close()
> close
>> IOBase.close(self)
> close
>> raise ex
> 1
> failed
>> File
>> line 95, in Stop
>> server_close
>> self.socket.close()
> close
>> IOBase.close(self)
> close
>> raise ex
> 1
>> 03/15/06 11:42:29 2300 Toolkit config.py:214 DEBUG System hostname
>> 03/15/06 11:42:29 2300 CertificateManager
>> 03/15/06 11:42:29 2300 Toolkit toolkit.py:404 DEBUG looking in
>> 03/15/06 11:42:29 2300 Toolkit toolkit.py:418 INFO C:\Program
>> 03/15/06 11:42:29 2300 Toolkit toolkit.py:440 INFO Certificate
>> 03/15/06 11:42:29 2300 Toolkit toolkit.py:456 INFO Marking cert
> as
>> CA cert
>> 03/15/06 11:42:29 2300 Toolkit toolkit.py:469 INFO Imported
> signing
> as
>> CA cert
> signing
> as
>> CA cert
> signing
> as
>> CA cert
> signing
>> 03/15/06 11:42:29 2300 Toolkit toolkit.py:478 DEBUG Init'ing
> globus.
>> 00:35:01
>> 03/15/06 11:42:29 2300 CertificateManagerWXGUI
>> 03/15/06 11:42:29 2300 Toolkit toolkit.py:482 DEBUG Done with
> globus.
>> 03/15/06 11:42:29 2300 Toolkit venueclient.py:83 INFO wx version
>> is: 2.5.1.5
>> 03/15/06 11:42:29 2300 VenueClient venueclient.py:287 DEBUG
>> 03/15/06 11:42:29 2300 ServiceManager agservicemanager.py:75 INFO
>> 03/15/06 11:42:29 2300 ServiceManager agservicemanager.py:424 INFO
>> __DiscoverResources
>> 03/15/06 11:42:29 2300 Toolkit config.py:997 INFO Using vfwscan
> to
>> get devices
>> 03/15/06 11:42:29 2300 Toolkit config.py:998 DEBUG vfwscanexe =
>> 03/15/06 11:42:30 2300 Toolkit config.py:1003 DEBUG filelines =
>> 03/15/06 11:42:30 2300 Toolkit config.py:1031 INFO GetResources:
>> 03/15/06 11:42:30 2300 VenueClient venueclient.py:296 DEBUG
>> 03/15/06 11:42:30 2300 NodeService agnodeservice.py:756 INFO
>> 03/15/06 11:42:30 2300 Toolkit toolkit.py:335 DEBUG Looking for:
>> 03/15/06 11:42:30 2300 Toolkit toolkit.py:340 DEBUG Looking for:
>> 03/15/06 11:42:30 2300 NodeService agnodeservice.py:764 DEBUG
>> 03/15/06 11:42:30 2300 NodeService agnodeservice.py:768 INFO
>> 03/15/06 11:42:30 2300 VenueClient venueclient.py:302 DEBUG
>> 03/15/06 11:42:30 2300 VenueClient venueclient.py:1328 DEBUG
>> 03/15/06 11:42:30 2300 NodeService agnodeservice.py:698 INFO
>> 03/15/06 11:42:30 2300 NodeService agnodeservice.py:581 INFO
>> 03/15/06 11:42:30 2300 NodeService agnodeservice.py:374 INFO
>> 03/15/06 11:42:30 2300 NodeService agnodeservice.py:378 INFO
>> 03/15/06 11:42:30 2300 NodeService agnodeservice.py:392 INFO
>> 03/15/06 11:42:30 2300 NodeService agnodeservice.py:407 INFO
> Trying
>> 03/15/06 11:42:30 2300 NodeService agnodeservice.py:480 INFO
>> 03/15/06 11:42:30 2300 NodeService agnodeservice.py:381 ERROR
> line
> line
>> 03/15/06 11:42:30 2300 VenueClient venueclient.py:313 ERROR Error
> line
>> 03/15/06 11:42:30 2300 VenueClient venueclient.py:185 DEBUG
>> 03/15/06 11:42:30 2300 DataStore datastore.py:1537 DEBUG Creating
>> thread 0
>> 03/15/06 11:42:30 2300 DataStore datastore.py:1542 DEBUG Starting
>> thread 0
>> 03/15/06 11:42:30 1608 DataStore datastore.py:1550 DEBUG Worker 0
>> starting
>> 03/15/06 11:42:30 2300 DataStore datastore.py:1544 DEBUG Waiting
>> thread 0
>> 03/15/06 11:42:30 2300 DataStore datastore.py:1547 DEBUG Done
>> creating workers
>> 03/15/06 11:42:30 2300 DataStore datastore.py:278 DEBUG Reading
>> 03/15/06 11:42:30 2300 VenueClient venueclient.py:210 DEBUG
>> 03/15/06 11:42:30 2300 VenueClientController
> to
>> load.
>> 03/15/06 11:42:37 2300 VenueClient venueclient.py:805 DEBUG
>> 03/15/06 11:42:37 2300 CertificateManager
>> Hoffman/CN=proxy
>> Hoffman/CN=proxy
>> 03/15/06 11:42:37 2300 VenueClient venueclient.py:833 INFO
>> 03/15/06 11:42:37 2300 VenueClient venueclient.py:705 DEBUG
>> 03/15/06 11:42:37 2300 VenueClient venueclient.py:866 ERROR
>> EnterVenue: failed
>> 837, in EnterVenue
> in
>> Enter
>> __call__
>> __r_call
> __call
>> in buildSOAP
>> return t.build()
>> in build
>> in genns
>> 03/15/06 11:42:37 2300 VenueClient venueclientui.py:1925 DEBUG
>> 03/15/06 11:42:37 2300 VenueClient venueclientui.py:1938 DEBUG
>> warningString: 03/15/06 11:45:42 2300 VenueClient
>> 03/15/06 11:45:42 2300 DataStore datastore.py:1614 DEBUG Quitting
>> thread 0
>> 03/15/06 11:45:42 1608 DataStore datastore.py:1555 DEBUG Worker 0
>> gets cmd quit
>> 03/15/06 11:45:42 1608 DataStore datastore.py:1568 DEBUG Worker 0
>> exiting
>> 03/15/06 11:45:42 3752 DataStore datastore.py:1627 INFO
>> likely shutting down. 03/15/06 11:45:42 2300 NodeService
>> 03/15/06 11:45:42 2300 ServiceManager agservicemanager.py:84 INFO
>> 03/15/06 11:45:42 2300 ServiceManager agservicemanager.py:85 INFO
>> Remove services
>> 03/15/06 11:45:42 2300 ServiceManager agservicemanager.py:389 INFO
>> 03/15/06 11:45:42 2300 ServiceManager agservicemanager.py:87 INFO
>> 03/15/06 11:45:42 1120 Hosting server.py:65 ERROR Exception in
> SOAP
>> server main loop
>> File
>> line 63, in Run
> in
>> get_request
>> get_request
> listen
>> raise ex
>> 03/15/06 11:45:42 2300 Hosting server.py:97 ERROR server_close()
> failed
>> File
>> line 95, in Stop
>> server_close
>> self.socket.close()
> close
>> IOBase.close(self)
> close
>> raise ex
> 1
> failed
>> File
>> line 95, in Stop
>> server_close
>> self.socket.close()
> close
>> IOBase.close(self)
> close
>> raise ex
> 1
