[AG-TECH] cannot connect to venue on new PIG
Michael A Gideon
mike at unr.edu
Wed May 10 14:30:16 CDT 2006
So does it seem to be python that was causing this? I am having the
same error but different circumstances. I just rebuilt a dell machine,
dual boot -XP and Suse 10. I requested a new certificate on the XP
side. Got it, installed it. Only after making it default ( anonymous
was default ) could I connect. Prior to making it default I got the
same error "Can not enter venue located at
https://vv2.mcs.anl.gov:9000/Venues/default".
I finished the linux install, exported my certificate from the XP side
and imported it to my linux certificate manager. Now I get that same
error on both platforms. I'm probably wrong, but I could have sworn
that as soon as I imported it to linux, I got connected with no errors.
Either way I did connect from one platform yesterday. I can't connect
with either today. Can I not use the same certificate? Now I am
flipping back and forth testing. Should I just request a certificate
for each platform? Should it really matter? Why would it stop working?
Any help would be appreciated.
Mike Gideon
-----Original Message-----
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
Behalf Of Thomas D. Uram
Sent: Wednesday, March 15, 2006 8:59 AM
To: Jennifer Teig von Hoffman
Cc: 'ag-tech at mcs.anl.gov'
Subject: Re: [AG-TECH] cannot connect to venue on new PIG
The TupleType problem that appears in the log is well-known on
new IBM machines with the IBM support tools installed. The
problem, and some means of resolving it, are described here:
http://bugzilla.mcs.anl.gov/accessgrid/show_bug.cgi?id=1208
I have seen this problem persist despite the fixes outlined in
that bug report. If yours is one of these cases, I'd like to track it
down.
Tom
On 3/15/06 10:46 AM, Jennifer Teig von Hoffman wrote:
> Hi all,
> I've just migrated to a new laptop and installed AG 2.4. I've imported
> my (valid) certificate, and can successfully make a proxy. However, I
> cannot connect to a venue. When I try to connect, I get the standard
> "Can not connect to venue located at
> https://vvw.mcs.anl.gov:9000/Venues/default. Please try again." error
> message. I've tried to connect to both the address above, and
> venues.ncsa.uiuc.edu.
> I wonder if my laptop may be in a strange state -- I used the Lenovo
> migration assistant when switching over to the new hardware, and
> generally speaking it has been inconsistent about what settings/etc
it's
> carried over from the old machine. I installed AG 2.4 *after*
migration,
> so theoretically it shouldn't have taken any of the AG-related
settings,
> but nonetheless the Lenovo experience has overall been quite mixed and
I
> wonder if it may be the issue here.
> My entire VenueClient.log is below. Any suggestions?
> Cheers,
> Jennifer
> 03/14/06 15:43:06 824 Toolkit config.py:364 ERROR Couldn't
retrieve
> globus key from registry.
> Traceback (most recent call last):
> File
> "C:\Python23\Lib\site-packages\AccessGrid\Platform\win32\Config.py",
> line 362, in GetGlobusKey
> "Software\Globus", 0, _winreg.KEY_SET_VALUE)
> WindowsError: [Errno 2] The system cannot find the file specified
> 03/14/06 15:43:06 824 Toolkit config.py:214 DEBUG System hostname
of
> SCV-BADTZ.ad.bu.edu is valid
> 03/14/06 15:44:45 2840 Toolkit config.py:381 ERROR Couldn't
retrieve
> gsi key from registry.
> File
> line 378, in GetGlobusKey
> gsikey = _winreg.OpenKey(gkey, "GSI", 0, _winreg.KEY_SET_VALUE)
> 03/14/06 15:44:45 2840 Toolkit config.py:214 DEBUG System hostname
> of SCV-BADTZ.ad.bu.edu is valid
> 03/14/06 15:44:45 2840 CertificateManager
certificatemanager.py:297
> DEBUG initializing repository
certificatemanager.py:327
> DEBUG Initializing from C:\Program
Files\AGTk-2.4\Config\CAcertificates
certificatemanager.py:340
> WARNING Didn't find certficate in old globus path: C:\Documents and
> Settings\jtvh\Application Data\globus\usercert.pem
certificatemanager.py:416
> INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\1c3f2ca8.0 might
> be a cert
> 03/14/06 15:44:45 2840 CertificateRepository
> certificaterepository.py:889 DEBUG _ImportCertificate: create
> C:\Documents and Settings\jtvh\Application
Data\AccessGrid\Config\certRepo\certificates\a82c3f1c4b096b896061778ee79
efeff\9c8df64aa35ebf832613413527bc073d
> 03/14/06 15:44:46 2840 CertificateRepository
> certificaterepository.py:1615 DEBUG GetFilePath: create C:\Documents
and
efeff\9c8df64aa35ebf832613413527bc073d\user_files
> 03/14/06 15:44:46 2840 CertificateManager
certificatemanager.py:441
> INFO Imported cert as 1c3f2ca8.0
> INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\45cc9e80.0 might
> be a cert
Data\AccessGrid\Config\certRepo\certificates\809ecc45460c1482e61e26bdfbf
9e18c\9f380c9a586af2bb913ace809d5badfe
and
9e18c\9f380c9a586af2bb913ace809d5badfe\user_files
> INFO Imported cert as 45cc9e80.0
> INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\d1b603c3.0 might
> be a cert
Data\AccessGrid\Config\certRepo\certificates\c303b6d10c962b37482e68ca64d
383a0\05a2039fe10ed1b4195d9f9d35b32c68
and
383a0\05a2039fe10ed1b4195d9f9d35b32c68\user_files
> INFO Imported cert as d1b603c3.0
> INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\f18fa857.0 might
> be a cert
Data\AccessGrid\Config\certRepo\certificates\57a88ff1707d87e926f2287c702
a8466\eff65f03366cb8e20247f831ccc87fd5
and
a8466\eff65f03366cb8e20247f831ccc87fd5\user_files
> INFO Imported cert as f18fa857.0
certificatemanager.py:1198
> WARNING No identity certs found
certificatemanager.py:1209
> WARNING No default identity certificate found
> 03/14/06 15:44:46 2840 Toolkit toolkit.py:404 DEBUG looking in
> system ca dir: C:\Program Files\AGTk-2.4\Config\CAcertificates
> 03/14/06 15:44:46 2840 Toolkit toolkit.py:418 INFO C:\Program
> Files\AGTk-2.4\Config\CAcertificates\1c3f2ca8.0 might be a cert
> 03/14/06 15:44:46 2840 Toolkit toolkit.py:440 INFO Certificate
> 1c3f2ca8.0 already in repository
> 03/14/06 15:44:46 2840 Toolkit toolkit.py:456 INFO Marking cert
as
> CA cert
> 03/14/06 15:44:46 2840 Toolkit toolkit.py:469 INFO Imported
signing
> policy as C:\Documents and Settings\jtvh\Application
efeff\9c8df64aa35ebf832613413527bc073d\user_files\signing_policy
> Files\AGTk-2.4\Config\CAcertificates\45cc9e80.0 might be a cert
> 45cc9e80.0 already in repository
as
> CA cert
signing
9e18c\9f380c9a586af2bb913ace809d5badfe\user_files\signing_policy
> Files\AGTk-2.4\Config\CAcertificates\d1b603c3.0 might be a cert
> d1b603c3.0 already in repository
as
> CA cert
signing
383a0\05a2039fe10ed1b4195d9f9d35b32c68\user_files\signing_policy
> Files\AGTk-2.4\Config\CAcertificates\f18fa857.0 might be a cert
> f18fa857.0 already in repository
as
> CA cert
> 03/14/06 15:44:47 2840 Toolkit toolkit.py:469 INFO Imported
signing
a8466\eff65f03366cb8e20247f831ccc87fd5\user_files\signing_policy
> 03/14/06 15:44:47 2840 Toolkit toolkit.py:478 DEBUG Init'ing
globus.
> 03/14/06 15:44:47 2840 CertificateManager
certificatemanager.py:759
> DEBUG Configuring standard environment
certificatemanager.py:829
> DEBUG No default identity found <type 'NoneType'> None
> 03/14/06 15:44:47 2840 CertificateRepository
> certificaterepository.py:952 INFO _ImportPrivateKey importing pkey to
Data\AccessGrid\Config\certRepo\privatekeys\b82eff976e60282028802c8814e2
3901.pem
> certificaterepository.py:918 INFO _ImportCertificateRequest writing
to
Data\AccessGrid\Config\certRepo\requests\b82eff976e60282028802c8814e2390
1.pem
> 03/14/06 15:44:47 2840 CRSClient crsclient.py:40 DEBUG create
client
> 03/14/06 15:44:47 2840 CRSClient crsclient.py:73 DEBUG request
> certificate
> 03/14/06 15:44:49 2840 CertificateManager
certificatemanager.py:1275
> DEBUG CheckRequestedCertificate:
req=<AccessGrid.Security.CertificateRepository.CertificateRequestDescrip
tor
> instance at 0x01F892D8>, token=267d22fbd98fcbd8bca067f7148e034a,
server=http://www-unix.mcs.anl.gov/fl/research/accessgrid/ca/anonymous/a
nonReqServer.cgi
> 03/14/06 15:44:49 2840 CRSClient crsclient.py:40 DEBUG create
client
> 03/14/06 15:44:49 2840 CRSClient crsclient.py:104 DEBUG retrieve
> certificate for token 267d22fbd98fcbd8bca067f7148e034a
> 03/14/06 15:44:49 2840 CRSClient crsclient.py:115 DEBUG retrieved
> certificate [1, '-----BEGIN
CERTIFICATE-----\nMIIDhzCCAm+gAwIBAgIERBcrQTANBgkqhkiG9w0BAQQFADCBkDEUMB
IGA1UEChML\nQWNjZXNzIEdyaWQxJDAiBgNVBAoTG0FyZ29ubmUgTmF0aW9uYWwgTGFib3Jh
dG9y\neTEoMCYGA1UECxMfRnV0dXJlcyBMYWIgQW5vbnltb3VzIEF1dGhvcml0eTEoMCYG\n
A1UEAxMfQW5vbnltb3VzIENlcnRpZmljYXRlIEF1dGhvcml0eTAeFw0wNjAzMTQx\nOTQ0ND
laFw0wNzAzMTQyMDQ0NDlaMIGgMRQwEgYDVQQKEwtBY2Nlc3MgR3JpZDEk\nMCIGA1UEChMb
QXJnb25uZSBOYXRpb25hbCBMYWJvcmF0b3J5MSgwJgYDVQQLEx9G\ndXR1cmVzIExhYiBBbm
9ueW1vdXMgQXV0aG9yaXR5MTgwNgYDVQQDEy9Bbm9ueW1v\ndXMgVXNlciA0YTI1MGViNGUz
MjMxZjJhYmJlM2Q0MDIxYzMzMDY0NjCBnzANBgkq\nhkiG9w0BAQEFAAOBjQAwgYkCgYEA3s
yI5qYAOvg9161DkKgx30GidmZNOxq3HEbB\ngsW88zY1dpbE1fbkN+7ejbbfbvdtkXwGS2YU
zSe+hpHTn/AUVyy53cBCLxQ0fLyj\n4QaTiHXqDCAtY5b+EK3z5BwrLyWO4+/sYuysLAkf6Z
v+DW+vXNxkqZ0TtzbGePaM\nD6KpdzECAwEAAaNbMFkwEQYJYIZIAYb4QgEBBAQDAgTwMAwG
A1UdEwEB/wQCMAAw\nNgYJYIZIAYb4QgENBCkWJ0dlbmVyYXRlZCBieSBwYXNzd2QgY2hlY2
sgYXV0aGVu\ndGljYXRvcjANBgk
qhkiG9w0BAQQFAAOCAQEALmC3il6vFPYI1PERDado53isFC8R\n0w1SXWv8skr9XZWw/Gbc2
Lms9MgVn5PxN6aeSoRr30M0IOk/xYAObNWKRbyzTaaE\nle7xuILHPwEB7GaeHDr11gcRCU6
cs1a+DwMEXTWb9nTyK3w6yYvE4ZuGaqJDnFFc\n4YCqiDx0XmJjqz5YDp7l6tn5j2PLF1WW3
rGWATBAo+jjcGrCu/KzlI0RFAXANPWg\npTj/pOprcOinLUWr7XXos90NY91/vHmvFVP2mQq
QPI7OwbqFiviAo8+dcC2/ozDj\nJkECJYzHJrYQFu5udPHajE2wTaYP7R6Nhn20D9PvD3cgS
Bv/AXXKSk0bwQ==\n-----END
> CERTIFICATE-----\n\n']
certificatemanager.py:1280
> DEBUG Retrieve returns [1, '-----BEGIN
sgYXV0aGVu\nd
GljYXRvcjANBgkqhkiG9w0BAQQFAAOCAQEALmC3il6vFPYI1PERDado53isFC8R\n0w1SXWv
8skr9XZWw/Gbc2Lms9MgVn5PxN6aeSoRr30M0IOk/xYAObNWKRbyzTaaE\nle7xuILHPwEB7
GaeHDr11gcRCU6cs1a+DwMEXTWb9nTyK3w6yYvE4ZuGaqJDnFFc\n4YCqiDx0XmJjqz5YDp7
l6tn5j2PLF1WW3rGWATBAo+jjcGrCu/KzlI0RFAXANPWg\npTj/pOprcOinLUWr7XXos90NY
91/vHmvFVP2mQqQPI7OwbqFiviAo8+dcC2/ozDj\nJkECJYzHJrYQFu5udPHajE2wTaYP7R6
Nhn20D9PvD3cgSBv/AXXKSk0bwQ==\n-----END
> 03/14/06 15:44:49 2840 CertificateRepository
> certificaterepository.py:866 DEBUG Importing requested certificate
> subj=/O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab
> Anonymous Authority/CN=Anonymous User 4a250eb4e3231f2abbe3d4021c330646
> path=C:\Documents and Settings\jtvh\Application
Data\AccessGrid\Config\certRepo\certificates\5cf11fcf8b5d698d7eb3ccdba19
80efb\99514c538e7a32167c1699b16c025df4
> certificaterepository.py:867 DEBUG Modulus hash is
> b82eff976e60282028802c8814e23901
> 03/14/06 15:44:50 2840 CertificateManager
certificatemanager.py:453
> DEBUG imported requested cert /O=Access Grid/O=Argonne National
> Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User
certificatemanager.py:827
> DEBUG Using default identity /O=Access Grid/O=Argonne National
certificatemanager.py:1083
> DEBUG Initializing environment with unencrypted cert /O=Access
> Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous
certificatemanager.py:1098
> INFO Setting permissions on certificate C:\Documents and
80efb\99514c538e7a32167c1699b16c025df4\cert.pem
> to 644
certificatemanager.py:1109
3901.pem
> to 600
> 03/14/06 15:44:50 2840 CertificateManagerWXGUI
> certificatemanagerwxgui.py:422 DEBUG done, success=1
> 03/14/06 15:44:50 2840 Toolkit toolkit.py:482 DEBUG Done with
globus.
> 03/14/06 15:44:50 2840 Toolkit venueclient.py:83 INFO wx version
> is: 2.5.1.5
> 03/14/06 15:44:50 2840 VenueClient venueclient.py:287 DEBUG
> __StartWebService: venueclient:
> https://SCV-BADTZ.ad.bu.edu:11000/VenueClient
> 03/14/06 15:44:50 2840 ServiceManager agservicemanager.py:68 INFO
> Creating user services directory C:\Documents and
> Settings\jtvh\Application Data\AccessGrid\local_services
> 03/14/06 15:44:50 2840 ServiceManager agservicemanager.py:424 INFO
> __DiscoverResources
> 03/14/06 15:44:50 2840 Toolkit config.py:997 INFO Using vfwscan
to
> get devices
> 03/14/06 15:44:50 2840 Toolkit config.py:998 DEBUG vfwscanexe =
> C:\PROGRA~1\AGTk-2.4\bin\vfwscan.exe
> 03/14/06 15:44:51 2840 Toolkit config.py:1003 DEBUG filelines =
> ['Microsoft WDM Image Capture (Win32)\n']
> 03/14/06 15:44:51 2840 Toolkit config.py:1031 INFO GetResources:
> ['Microsoft WDM Image Capture (Win32)']
> 03/14/06 15:44:51 2840 VenueClient venueclient.py:296 DEBUG
> __StartWebService: service manager:
> https://SCV-BADTZ.ad.bu.edu:11000/ServiceManager
> 03/14/06 15:44:51 2840 NodeService agnodeservice.py:115 INFO
> Copying system node configs to user node config dir
> 03/14/06 15:44:51 2840 NodeService agnodeservice.py:116 INFO
> system node config = C:\Program Files\AGTk-2.4\Config\nodeConfig
> 03/14/06 15:44:51 2840 NodeService agnodeservice.py:117 INFO
user
> node config = C:\Documents and Settings\jtvh\Application
> Data\AccessGrid\Config\nodeConfig
> 03/14/06 15:44:51 2840 NodeService agnodeservice.py:120 INFO
node
> config: defaultWindows
> 03/14/06 15:44:51 2840 NodeService agnodeservice.py:756 INFO
> NodeService.__ReadConfigFile
> 03/14/06 15:44:51 2840 Toolkit toolkit.py:335 DEBUG Looking for:
> Data\AccessGrid\Config\AGNodeService.cfg
> 03/14/06 15:44:51 2840 Toolkit toolkit.py:340 DEBUG Looking for:
> C:\Program Files\AGTk-2.4\Config\AGNodeService.cfg
> 03/14/06 15:44:51 2840 NodeService agnodeservice.py:764 DEBUG
> DEFAULT NODE SERVICE CONFIG: C:\Program
> 03/14/06 15:44:51 2840 NodeService agnodeservice.py:768 INFO
> Reading node service config file: C:\Program
> 03/14/06 15:44:51 2840 VenueClient venueclient.py:302 DEBUG
> __StartWebService: node service:
> https://SCV-BADTZ.ad.bu.edu:11000/NodeService
> 03/14/06 15:44:51 2840 VenueClient venueclient.py:1328 DEBUG
> SerNodeUrl: Set node service url:
> 03/14/06 15:44:51 2840 NodeService agnodeservice.py:698 INFO
> NodeService.GetDefaultConfiguration
> 03/14/06 15:44:51 2840 NodeService agnodeservice.py:581 INFO
> Migration unnecessary
> 03/14/06 15:44:51 2840 NodeService agnodeservice.py:374 INFO
> NodeService.LoadDefaultConfig
> 03/14/06 15:44:51 2840 NodeService agnodeservice.py:378 INFO
> Loading default node configuration: defaultWindows
> 03/14/06 15:44:51 2840 NodeService agnodeservice.py:392 INFO
> NodeService.LoadConfiguration
> 03/14/06 15:44:51 2840 NodeService agnodeservice.py:407 INFO
Trying
> to load node configuration from: C:\Documents and
Data\AccessGrid\Config\nodeConfig\defaultWindows
> 03/14/06 15:44:51 2840 NodeService agnodeservice.py:480 INFO
> AddServiceManager: Invalid service manager url
> (https://localhost:11000/ServiceManager)
> 03/14/06 15:44:51 2840 NodeService agnodeservice.py:381 ERROR
> Exception loading default configuration.
> File "C:\Python23\Lib\site-packages\AccessGrid\AGNodeService.py",
line
> 379, in LoadDefaultConfig
> self.LoadConfiguration( self.defaultConfig )
line
> 523, in LoadConfiguration
> raise Exception(exceptionText)
> Exception: Couldn't reach service manager: localhost:11000
> 03/14/06 15:44:51 2840 VenueClient venueclient.py:313 ERROR Error
> File "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line
> 311, in __StartWebService
> self.ns.LoadDefaultConfig()
line
> 382, in LoadDefaultConfig
> raise Exception("Failed to load default configuration <%s>" %
> Exception: Failed to load default configuration <defaultWindows>
> 03/14/06 15:44:51 2840 VenueClient venueclient.py:185 DEBUG
> __createPersonalDataStore: Creating personal datastore at C:\Documents
> and Settings\jtvh\Application Data\AccessGrid\Config\personalDataStore
> using prefix personalDataStore and port 0
> 03/14/06 15:44:51 2840 DataStore datastore.py:1537 DEBUG Creating
> thread 0
> 03/14/06 15:44:51 2840 DataStore datastore.py:1542 DEBUG Starting
> thread 0
> 03/14/06 15:44:51 3284 DataStore datastore.py:1550 DEBUG Worker 0
> starting
> 03/14/06 15:44:51 2840 DataStore datastore.py:1544 DEBUG Waiting
> thread 0
> 03/14/06 15:44:51 2840 DataStore datastore.py:1547 DEBUG Done
> creating workers
> 03/14/06 15:45:17 2840 DataStore datastore.py:278 DEBUG Reading
> persisted data from: C:\Documents and Settings\jtvh\Application
> Data\AccessGrid\Config\personalDataStore\DataStore.dat
> 03/14/06 15:45:17 2840 VenueClient venueclient.py:210 DEBUG
> __createPersonalDataStore: Load personal data from file
> 03/14/06 15:45:17 2840 VenueClientController
> venueclientcontroller.py:1255 DEBUG There is no personal venues file
to
> load.
> 03/14/06 15:45:17 2840 VenueClient venueclientui.py:188 DEBUG the
> profile is the default profile - open profile dialog
> 03/14/06 15:45:17 2840 VenueClient venueclientui.py:3871 DEBUG
> VenueClientUI.py: Set editable in successfully dialog
> 03/14/06 15:45:17 2840 VenueClient venueclientui.py:3942 DEBUG
> ProfileDialog.SetProfile: Set profile information successfully in
dialog
> 03/14/06 15:45:42 2840 VenueClient venueclientui.py:3924 DEBUG
> ProfileDialog.GetNewProfile: Got profile information from dialog
> 03/14/06 15:45:42 2840 VenueClientController
> venueclientcontroller.py:624 DEBUG Can not update client profile in
> venue - not connected
> 03/14/06 15:49:19 2840 VenueClient venueclientui.py:1565 INFO
> --------- END VenueClient
> 03/14/06 15:49:19 2840 DataStore datastore.py:1614 DEBUG Quitting
> thread 0
> 03/14/06 15:49:19 3284 DataStore datastore.py:1555 DEBUG Worker 0
> gets cmd quit
> 03/14/06 15:49:19 3284 DataStore datastore.py:1568 DEBUG Worker 0
> exiting
> 03/14/06 15:49:19 3076 DataStore datastore.py:1627 INFO
> GSIHTTPTransferServer: GSITCPSocket, interrupted I/O operation, most
> likely shutting down. 03/14/06 15:49:19 2840 NodeService
> agnodeservice.py:136 INFO NodeService.Stop
> 03/14/06 15:49:19 2840 ServiceManager agservicemanager.py:84 INFO
> AGServiceManager.Shutdown
> 03/14/06 15:49:19 2840 ServiceManager agservicemanager.py:85 INFO
> Remove services
> 03/14/06 15:49:19 2840 ServiceManager agservicemanager.py:389 INFO
> AGServiceManager.RemoveServices
> 03/14/06 15:49:19 2840 ServiceManager agservicemanager.py:87 INFO
> Stop network interface
> 03/14/06 15:49:19 3924 Hosting server.py:65 ERROR Exception in
SOAP
> server main loop
> File
> "C:\Python23\Lib\site-packages\AccessGrid\hosting\SOAPpy\Server.py",
> line 63, in Run
> self._server.handle_request()
> File "C:\Python23\lib\SocketServer.py", line 217, in handle_request
> request, client_address = self.get_request()
> File "C:\Python23\Lib\site-packages\SOAPpy\GSIServer.py", line 140,
in
> get_request
> sock, addr = ThreadingGSITCPSocketServer.get_request(self)
> File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 525, in
> get_request
> self.socket.listen()
> File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 857, in
listen
> raise ex
> GSITCPSocketException: an I/O operation was cancelled
> 03/14/06 15:49:19 2840 Hosting server.py:97 ERROR server_close()
failed
> File
> line 95, in Stop
> self._server.server_close()
> File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1043, in
> server_close
> self.socket.close()
> File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1020, in
close
> IOBase.close(self)
> File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 176, in
close
> raise ex
> IOBaseException: an uninitialied data structure was passed as argument
1
> to globus_io_register_close
failed
> File
> line 95, in Stop
> server_close
> self.socket.close()
close
> IOBase.close(self)
close
> raise ex
1
> 03/14/06 15:49:32 2580 Toolkit config.py:214 DEBUG System hostname
> 03/14/06 15:49:32 2580 CertificateManager
certificatemanager.py:269
> DEBUG Opened repository C:\Documents and Settings\jtvh\Application
> 03/14/06 15:49:32 2580 Toolkit toolkit.py:404 DEBUG looking in
> 03/14/06 15:49:32 2580 Toolkit toolkit.py:418 INFO C:\Program
> 03/14/06 15:49:32 2580 Toolkit toolkit.py:440 INFO Certificate
> 03/14/06 15:49:32 2580 Toolkit toolkit.py:456 INFO Marking cert
as
> CA cert
> 03/14/06 15:49:32 2580 Toolkit toolkit.py:469 INFO Imported
signing
as
> CA cert
signing
as
> CA cert
signing
as
> CA cert
> 03/14/06 15:49:33 2580 Toolkit toolkit.py:469 INFO Imported
signing
> 03/14/06 15:49:33 2580 Toolkit toolkit.py:478 DEBUG Init'ing
globus.
> 03/14/06 15:49:33 2580 CertificateManager
> to 644
3901.pem
> to 600
> 03/14/06 15:49:33 2580 CertificateManagerWXGUI
> 03/14/06 15:49:33 2580 Toolkit toolkit.py:482 DEBUG Done with
globus.
> 03/14/06 15:49:33 2580 Toolkit venueclient.py:83 INFO wx version
> is: 2.5.1.5
> 03/14/06 15:49:33 2580 VenueClient venueclient.py:287 DEBUG
> 03/14/06 15:49:33 2580 ServiceManager agservicemanager.py:75 INFO
> Using services dir: C:\Documents and Settings\jtvh\Application
> 03/14/06 15:49:33 2580 ServiceManager agservicemanager.py:424 INFO
> __DiscoverResources
> 03/14/06 15:49:33 2580 Toolkit config.py:997 INFO Using vfwscan
to
> get devices
> 03/14/06 15:49:33 2580 Toolkit config.py:998 DEBUG vfwscanexe =
> 03/14/06 15:49:33 2580 Toolkit config.py:1003 DEBUG filelines =
> 03/14/06 15:49:33 2580 Toolkit config.py:1031 INFO GetResources:
> 03/14/06 15:49:33 2580 VenueClient venueclient.py:296 DEBUG
> 03/14/06 15:49:33 2580 NodeService agnodeservice.py:756 INFO
> 03/14/06 15:49:33 2580 Toolkit toolkit.py:335 DEBUG Looking for:
> 03/14/06 15:49:33 2580 Toolkit toolkit.py:340 DEBUG Looking for:
> 03/14/06 15:49:33 2580 NodeService agnodeservice.py:764 DEBUG
> 03/14/06 15:49:33 2580 NodeService agnodeservice.py:768 INFO
> 03/14/06 15:49:33 2580 VenueClient venueclient.py:302 DEBUG
> 03/14/06 15:49:33 2580 VenueClient venueclient.py:1328 DEBUG
> 03/14/06 15:49:33 2580 NodeService agnodeservice.py:698 INFO
> 03/14/06 15:49:33 2580 NodeService agnodeservice.py:581 INFO
> 03/14/06 15:49:33 2580 NodeService agnodeservice.py:374 INFO
> 03/14/06 15:49:33 2580 NodeService agnodeservice.py:378 INFO
> 03/14/06 15:49:33 2580 NodeService agnodeservice.py:392 INFO
> 03/14/06 15:49:33 2580 NodeService agnodeservice.py:407 INFO
Trying
> 03/14/06 15:49:33 2580 NodeService agnodeservice.py:480 INFO
> 03/14/06 15:49:33 2580 NodeService agnodeservice.py:381 ERROR
line
line
> 03/14/06 15:49:33 2580 VenueClient venueclient.py:313 ERROR Error
line
> 03/14/06 15:49:33 2580 VenueClient venueclient.py:185 DEBUG
> 03/14/06 15:49:33 2580 DataStore datastore.py:1537 DEBUG Creating
> thread 0
> 03/14/06 15:49:33 2580 DataStore datastore.py:1542 DEBUG Starting
> thread 0
> 03/14/06 15:49:33 2256 DataStore datastore.py:1550 DEBUG Worker 0
> starting
> 03/14/06 15:49:33 2580 DataStore datastore.py:1544 DEBUG Waiting
> thread 0
> 03/14/06 15:49:33 2580 DataStore datastore.py:1547 DEBUG Done
> creating workers
> 03/14/06 15:49:33 2580 DataStore datastore.py:278 DEBUG Reading
> 03/14/06 15:49:33 2580 VenueClient venueclient.py:210 DEBUG
> 03/14/06 15:49:33 2580 VenueClientController
to
> load.
> 03/14/06 15:49:49 2580 VenueClient venueclient.py:805 DEBUG
> EnterVenue; url=https://vv2.mcs.anl.gov:9000/Venues/default
> 03/14/06 15:49:49 2580 VenueClient venueclient.py:833 INFO
> EnterVenue: Error getting node capabilities
> 03/14/06 15:49:49 2580 VenueClient venueclient.py:705 DEBUG
> EnterVenue: Invoke venue enter
> 03/14/06 15:49:49 2580 VenueClient venueclient.py:866 ERROR
> EnterVenue: failed
> 837, in EnterVenue
> self.__EnterVenue(URL)
> 706, in __EnterVenue
> (venueState, self.privateId, self.streamDescList ) =
> self.__venueProxy.Enter( self.profile )
> File "C:\Python23\Lib\site-packages\AccessGrid\Venue.py", line 3499,
in
> Enter
> (r1, r2, r3) = self.proxy.Enter(profile)
> File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 453, in
> __call__
> return self.__r_call(*args, **kw)
> File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 475, in
> __r_call
> self.__hd, self.__ma)
> File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 338, in
__call
> config = self.config, noroot = self.noroot)
> File "C:\Python23\Lib\site-packages\SOAPpy\SOAPBuilder.py", line 620,
> in buildSOAP
> return t.build()
> File "C:\Python23\Lib\site-packages\SOAPpy\SOAPBuilder.py", line 118,
> in build
> body_ns = self.genns(ns_map, NS.ENV)[0]
> File "C:\Python23\Lib\site-packages\SOAPpy\SOAPBuilder.py", line 204,
> in genns
> if type(nsURI) == TupleType: # already a tuple
> NameError: global name 'TupleType' is not defined
> 03/14/06 15:49:49 2580 VenueClient venueclientui.py:1925 DEBUG
> bin.VenueClient::EnterVenue: Enter venue with url:
> 03/14/06 15:49:49 2580 VenueClient venueclientui.py:1938 DEBUG
> warningString: 03/14/06 15:49:55 2580 CertificateRepository
> certificaterepository.py:592 DEBUG Register observer <bound method
> ProxyBrowser.OnRepoUpdate of
> <AccessGrid.Security.wxgui.ProxyBrowser.ProxyBrowser; proxy of C++
> wxPanel instance at _c04ed701_p_wxPanel>>
> certificaterepository.py:594 DEBUG Adding <weakref at 0212F1B0; to
> 'instancemethod' at 020D8E40 (OnRepoUpdate)>
> IdentityBrowser.OnRepoUpdate of
> <AccessGrid.Security.wxgui.IdentityBrowser.IdentityBrowser; proxy of
C++
> wxPanel instance at _b073e301_p_wxPanel>>
> certificaterepository.py:594 DEBUG Adding <weakref at 0212F480; to
> 'instancemethod' at 020D8D28 (OnRepoUpdate)>
> CABrowser.OnRepoUpdate of
> <AccessGrid.Security.wxgui.CABrowser.CABrowser; proxy of C++ wxPanel
> instance at _90c10f02_p_wxPanel>>
> certificaterepository.py:594 DEBUG Adding <weakref at 0212F690; to
> 'instancemethod' at 0211BF08 (OnRepoUpdate)>
> CertificateStatusBrowser.OnRepoUpdate of
<AccessGrid.Security.wxgui.CertificateStatusBrowser.CertificateStatusBro
wser;
> proxy of C++ wxPanel instance at _18fe0f02_p_wxPanel>>
> certificaterepository.py:594 DEBUG Adding <weakref at 0212FA50; to
> 'instancemethod' at 02131260 (OnRepoUpdate)>
> 03/14/06 16:07:01 2428 Toolkit config.py:214 DEBUG System hostname
> 03/14/06 16:07:01 2428 CertificateManager
> 03/14/06 16:07:02 2428 Toolkit toolkit.py:404 DEBUG looking in
> 03/14/06 16:07:02 2428 Toolkit toolkit.py:418 INFO C:\Program
> 03/14/06 16:07:02 2428 Toolkit toolkit.py:440 INFO Certificate
> 03/14/06 16:07:02 2428 Toolkit toolkit.py:456 INFO Marking cert
as
> CA cert
> 03/14/06 16:07:02 2428 Toolkit toolkit.py:469 INFO Imported
signing
as
> CA cert
signing
as
> CA cert
signing
as
> CA cert
> 03/14/06 16:07:03 2428 Toolkit toolkit.py:469 INFO Imported
signing
> 03/14/06 16:07:03 2428 Toolkit toolkit.py:478 DEBUG Init'ing
globus.
> 03/14/06 16:07:03 2428 CertificateManager
> to 644
3901.pem
> to 600
> 03/14/06 16:07:03 2428 CertificateManagerWXGUI
> 03/14/06 16:07:03 2428 Toolkit toolkit.py:482 DEBUG Done with
globus.
> 03/14/06 16:07:03 2428 Toolkit venueclient.py:83 INFO wx version
> is: 2.5.1.5
> 03/14/06 16:07:03 2428 VenueClient venueclient.py:287 DEBUG
> 03/14/06 16:07:03 2428 ServiceManager agservicemanager.py:75 INFO
> 03/14/06 16:07:03 2428 ServiceManager agservicemanager.py:424 INFO
> __DiscoverResources
> 03/14/06 16:07:03 2428 Toolkit config.py:997 INFO Using vfwscan
to
> get devices
> 03/14/06 16:07:03 2428 Toolkit config.py:998 DEBUG vfwscanexe =
> 03/14/06 16:07:05 2428 Toolkit config.py:1003 DEBUG filelines =
> 03/14/06 16:07:05 2428 Toolkit config.py:1031 INFO GetResources:
> 03/14/06 16:07:05 2428 VenueClient venueclient.py:296 DEBUG
> 03/14/06 16:07:05 2428 NodeService agnodeservice.py:756 INFO
> 03/14/06 16:07:05 2428 Toolkit toolkit.py:335 DEBUG Looking for:
> 03/14/06 16:07:05 2428 Toolkit toolkit.py:340 DEBUG Looking for:
> 03/14/06 16:07:05 2428 NodeService agnodeservice.py:764 DEBUG
> 03/14/06 16:07:05 2428 NodeService agnodeservice.py:768 INFO
> 03/14/06 16:07:05 2428 VenueClient venueclient.py:302 DEBUG
> 03/14/06 16:07:05 2428 VenueClient venueclient.py:1328 DEBUG
> 03/14/06 16:07:05 2428 NodeService agnodeservice.py:698 INFO
> 03/14/06 16:07:05 2428 NodeService agnodeservice.py:581 INFO
> 03/14/06 16:07:05 2428 NodeService agnodeservice.py:374 INFO
> 03/14/06 16:07:05 2428 NodeService agnodeservice.py:378 INFO
> 03/14/06 16:07:05 2428 NodeService agnodeservice.py:392 INFO
> 03/14/06 16:07:05 2428 NodeService agnodeservice.py:407 INFO
Trying
> 03/14/06 16:07:05 2428 NodeService agnodeservice.py:480 INFO
> 03/14/06 16:07:05 2428 NodeService agnodeservice.py:381 ERROR
line
line
> 03/14/06 16:07:05 2428 VenueClient venueclient.py:313 ERROR Error
line
> 03/14/06 16:07:05 2428 VenueClient venueclient.py:185 DEBUG
> 03/14/06 16:07:05 2428 DataStore datastore.py:1537 DEBUG Creating
> thread 0
> 03/14/06 16:07:05 2428 DataStore datastore.py:1542 DEBUG Starting
> thread 0
> 03/14/06 16:07:05 4036 DataStore datastore.py:1550 DEBUG Worker 0
> starting
> 03/14/06 16:07:05 2428 DataStore datastore.py:1544 DEBUG Waiting
> thread 0
> 03/14/06 16:07:05 2428 DataStore datastore.py:1547 DEBUG Done
> creating workers
> 03/14/06 16:07:05 2428 DataStore datastore.py:278 DEBUG Reading
> 03/14/06 16:07:05 2428 VenueClient venueclient.py:210 DEBUG
> 03/14/06 16:07:05 2428 VenueClientController
to
> load.
> 03/14/06 16:07:15 2428 CertificateRepository
> certificaterepository.py:594 DEBUG Adding <weakref at 020DA2D0; to
> 'instancemethod' at 020D8A30 (OnRepoUpdate)>
C++
> wxPanel instance at _18dd1002_p_wxPanel>>
> certificaterepository.py:594 DEBUG Adding <weakref at 020DA5A0; to
> 'instancemethod' at 020D8B98 (OnRepoUpdate)>
> instance at _28c9f001_p_wxPanel>>
> certificaterepository.py:594 DEBUG Adding <weakref at 020DA7B0; to
> 'instancemethod' at 020D8D78 (OnRepoUpdate)>
wser;
> proxy of C++ wxPanel instance at _d009f101_p_wxPanel>>
> certificaterepository.py:594 DEBUG Adding <weakref at 020DAB70; to
> 'instancemethod' at 020D8FA8 (OnRepoUpdate)>
> 03/14/06 16:14:47 2428 CertificateRepository
> certificaterepository.py:129 ERROR Could not open certificate file
> 03/14/06 16:15:06 2428 CertificateRepository
> certificaterepository.py:133 INFO Found valid cert, validKey=1
> 03/14/06 16:15:07 2428 CertificateRepository
> 03/14/06 16:15:11 2428 CertificateRepository
> certificaterepository.py:741 ERROR load error
> File
"C:\Python23\Lib\site-packages\AccessGrid\Security\CertificateRepository
.py",
> line 738, in ImportCertificatePEM
> passphrase)
> Error: [('digital envelope routines', 'EVP_DecryptFinal', 'bad
> decrypt'), ('PEM routines', 'PEM_do_header', 'bad decrypt')]
> 03/14/06 16:15:11 2428 CertificateManagerWXGUI
> importexportutils.py:792 ERROR Import fails: Incorrect passphrase.
cert
> file S:\AG\jtvh\cert-exp-12-2006.pem keyfile
> File
"C:\Python23\Lib\site-packages\AccessGrid\Security\wxgui\ImportExportUti
ls.py",
> line 775, in ImportPEMIdentityCertificate
> certFile, keyFile, cb)
> File
"C:\Python23\Lib\site-packages\AccessGrid\Security\CertificateManager.py
> line 465, in ImportIdentityCertificatePEM
> impCert = repo.ImportCertificatePEM(userCert, userKey,
passphraseCB)
> File
.py",
> line 742, in ImportCertificatePEM
> raise RepoBadPassphrase
> RepoBadPassphrase
> 03/14/06 16:15:16 2428 CertificateRepository
> 03/14/06 16:15:19 2428 CertificateRepository
> 03/14/06 16:15:21 2428 CertificateRepository
> 03/14/06 16:15:24 2428 CertificateRepository
Data\AccessGrid\Config\certRepo\privatekeys\b6ea2d1e21eb850bef7b799ce043
d5e9.pem
Data\AccessGrid\Config\certRepo\certificates\9469dc4861d79549ca6a9e6a2ed
4909f\7fd839972fa295d09928e28808b848ea
> 03/14/06 16:15:25 2428 CertificateManagerWXGUI
> importexportutils.py:776 DEBUG Imported identity /O=Access
> Grid/OU=agdev-ca.mcs.anl.gov/OU=bu.edu/CN=Jennifer Teig von Hoffman
> importexportutils.py:834 DEBUG ID certs:
> [<AccessGrid.Security.CertificateRepository.CertificateDescriptor
> instance at 0x02132918>]
> to 644
3901.pem
> to 600
> 03/14/06 16:15:30 2428 CertificateManager
certificatemanager.py:902
> DEBUG Initializing environment with proxy cert for /O=Access
certificatemanager.py:968
> DEBUG _VerifyGlobusProxy: file C:\DOCUME~1\jtvh\LOCALS~1\Temp\proxy
not
> found
> 03/14/06 16:15:40 2428 CertificateManagerWXGUI
> certificatemanagerwxgui.py:550 DEBUG Proxy successfully created
certificatemanager.py:1011
> INFO Verifying local proxy cert
certificatemanager.py:921
> DEBUG Configuring for user proxy issued from /O=Access
certificatemanager.py:924
> DEBUG Proxy C:\DOCUME~1\jtvh\LOCALS~1\Temp\proxy will expire 03/15/06
> 05:15:40
> 05:15:40
> 03/14/06 16:18:36 2428 VenueClient venueclient.py:805 DEBUG
> 03/14/06 16:18:36 2428 CertificateManager
certificatemanager.py:663
> DEBUG HaveValidProxy: found proxy ident /O=Access
> Hoffman/CN=proxy
> Hoffman/CN=proxy
> 03/14/06 16:18:36 2428 VenueClient venueclient.py:833 INFO
> 03/14/06 16:18:36 2428 VenueClient venueclient.py:705 DEBUG
> 03/14/06 16:18:36 2428 VenueClient venueclient.py:866 ERROR
> EnterVenue: failed
> 837, in EnterVenue
in
> Enter
> __call__
> __r_call
__call
> in buildSOAP
> return t.build()
> in build
> in genns
> 03/14/06 16:18:36 2428 VenueClient venueclientui.py:1925 DEBUG
> 03/14/06 16:18:36 2428 VenueClient venueclientui.py:1938 DEBUG
> warningString: 03/14/06 16:18:42 2428 VenueClient
> venueclient.py:1343 INFO Error enabling video
> 03/14/06 16:18:44 2428 VenueClient venueclient.py:1349 INFO Error
> enabling audio
> 03/14/06 16:19:06 2428 VenueClient venueclientui.py:1565 INFO
> 03/14/06 16:19:06 2428 DataStore datastore.py:1614 DEBUG Quitting
> thread 0
> 03/14/06 16:19:06 4036 DataStore datastore.py:1555 DEBUG Worker 0
> gets cmd quit
> 03/14/06 16:19:06 4036 DataStore datastore.py:1568 DEBUG Worker 0
> exiting
> 03/14/06 16:19:06 4032 DataStore datastore.py:1627 INFO
> likely shutting down. 03/14/06 16:19:06 2428 NodeService
> 03/14/06 16:19:06 2428 ServiceManager agservicemanager.py:84 INFO
> 03/14/06 16:19:06 2428 ServiceManager agservicemanager.py:85 INFO
> Remove services
> 03/14/06 16:19:06 2428 ServiceManager agservicemanager.py:389 INFO
> 03/14/06 16:19:06 2428 ServiceManager agservicemanager.py:87 INFO
> 03/14/06 16:19:06 2084 Hosting server.py:65 ERROR Exception in
SOAP
> server main loop
> File
> line 63, in Run
in
> get_request
> get_request
listen
> raise ex
> 03/14/06 16:19:06 2428 Hosting server.py:97 ERROR server_close()
failed
> File
> line 95, in Stop
> server_close
> self.socket.close()
close
> IOBase.close(self)
close
> raise ex
1
failed
> File
> line 95, in Stop
> server_close
> self.socket.close()
close
> IOBase.close(self)
close
> raise ex
1
> 03/15/06 11:34:51 444 Toolkit config.py:214 DEBUG System hostname
of
> 03/15/06 11:34:51 444 CertificateManager certificatemanager.py:269
> 03/15/06 11:34:52 444 Toolkit toolkit.py:404 DEBUG looking in
system
> 03/15/06 11:34:52 444 Toolkit toolkit.py:418 INFO C:\Program
> 03/15/06 11:34:52 444 Toolkit toolkit.py:440 INFO Certificate
> 03/15/06 11:34:52 444 Toolkit toolkit.py:456 INFO Marking cert as
> CA cert
> 03/15/06 11:34:52 444 Toolkit toolkit.py:469 INFO Imported
signing
> CA cert
signing
> CA cert
signing
> CA cert
signing
> 03/15/06 11:34:52 444 Toolkit toolkit.py:478 DEBUG Init'ing
globus.
> 03/15/06 11:34:53 444 CertificateManager certificatemanager.py:759
> 03/15/06 11:34:53 444 CertificateManager certificatemanager.py:827
> 03/15/06 11:34:53 444 CertificateManager certificatemanager.py:902
certificatemanager.py:1024
> DEBUG _VerifyGlobusProxy: proxy C:\DOCUME~1\jtvh\LOCALS~1\Temp\proxy
> expired
> 03/15/06 11:35:01 444 CertificateManagerWXGUI
> 03/15/06 11:35:01 444 CertificateManager certificatemanager.py:759
> 03/15/06 11:35:01 444 CertificateManager certificatemanager.py:827
> 03/15/06 11:35:01 444 CertificateManager certificatemanager.py:902
> 03/15/06 11:35:01 444 CertificateManager certificatemanager.py:921
> 03/15/06 11:35:01 444 CertificateManager certificatemanager.py:924
> DEBUG Proxy C:\DOCUME~1\jtvh\LOCALS~1\Temp\proxy will expire 03/16/06
> 00:35:01
> 00:35:01
> 03/15/06 11:35:01 444 Toolkit toolkit.py:482 DEBUG Done with
globus.
> 03/15/06 11:35:01 444 Toolkit venueclient.py:83 INFO wx version
is:
> 2.5.1.5
> 03/15/06 11:35:01 444 VenueClient venueclient.py:287 DEBUG
> 03/15/06 11:35:01 444 ServiceManager agservicemanager.py:75 INFO
> 03/15/06 11:35:01 444 ServiceManager agservicemanager.py:424 INFO
> __DiscoverResources
> 03/15/06 11:35:01 444 Toolkit config.py:997 INFO Using vfwscan to
> get devices
> 03/15/06 11:35:01 444 Toolkit config.py:998 DEBUG vfwscanexe =
> 03/15/06 11:35:01 444 Toolkit config.py:1003 DEBUG filelines =
> 03/15/06 11:35:01 444 Toolkit config.py:1031 INFO GetResources:
> 03/15/06 11:35:01 444 VenueClient venueclient.py:296 DEBUG
> 03/15/06 11:35:01 444 NodeService agnodeservice.py:756 INFO
> 03/15/06 11:35:01 444 Toolkit toolkit.py:335 DEBUG Looking for:
> 03/15/06 11:35:01 444 Toolkit toolkit.py:340 DEBUG Looking for:
> 03/15/06 11:35:01 444 NodeService agnodeservice.py:764 DEBUG
DEFAULT
> 03/15/06 11:35:01 444 NodeService agnodeservice.py:768 INFO
Reading
> 03/15/06 11:35:01 444 VenueClient venueclient.py:302 DEBUG
> 03/15/06 11:35:01 444 VenueClient venueclient.py:1328 DEBUG
> 03/15/06 11:35:01 444 NodeService agnodeservice.py:698 INFO
> 03/15/06 11:35:02 444 NodeService agnodeservice.py:581 INFO
> 03/15/06 11:35:02 444 NodeService agnodeservice.py:374 INFO
> 03/15/06 11:35:02 444 NodeService agnodeservice.py:378 INFO
Loading
> 03/15/06 11:35:02 444 NodeService agnodeservice.py:392 INFO
> 03/15/06 11:35:02 444 NodeService agnodeservice.py:407 INFO
Trying
> 03/15/06 11:35:02 444 NodeService agnodeservice.py:480 INFO
> 03/15/06 11:35:02 444 NodeService agnodeservice.py:381 ERROR
line
line
> 03/15/06 11:35:02 444 VenueClient venueclient.py:313 ERROR Error
line
> 03/15/06 11:35:02 444 VenueClient venueclient.py:185 DEBUG
> 03/15/06 11:35:02 444 DataStore datastore.py:1537 DEBUG Creating
> thread 0
> 03/15/06 11:35:02 444 DataStore datastore.py:1542 DEBUG Starting
> thread 0
> 03/15/06 11:35:02 284 DataStore datastore.py:1550 DEBUG Worker 0
> starting
> 03/15/06 11:35:02 444 DataStore datastore.py:1544 DEBUG Waiting
> thread 0
> 03/15/06 11:35:02 444 DataStore datastore.py:1547 DEBUG Done
> creating workers
> 03/15/06 11:35:02 444 DataStore datastore.py:278 DEBUG Reading
> 03/15/06 11:35:02 444 VenueClient venueclient.py:210 DEBUG
> 03/15/06 11:35:02 444 VenueClientController
to
> load.
> 03/15/06 11:35:22 444 CertificateRepository
> certificaterepository.py:594 DEBUG Adding <weakref at 020DB270; to
> 'instancemethod' at 020D6A58 (OnRepoUpdate)>
C++
> wxPanel instance at _d028de01_p_wxPanel>>
> certificaterepository.py:594 DEBUG Adding <weakref at 020DB540; to
> 'instancemethod' at 020D6AD0 (OnRepoUpdate)>
> instance at _6886e301_p_wxPanel>>
> certificaterepository.py:594 DEBUG Adding <weakref at 020DB750; to
> 'instancemethod' at 020D6C38 (OnRepoUpdate)>
wser;
> proxy of C++ wxPanel instance at _f003ef01_p_wxPanel>>
> certificaterepository.py:594 DEBUG Adding <weakref at 020DBB10; to
> 'instancemethod' at 020DF030 (OnRepoUpdate)>
> 03/15/06 11:35:43 444 VenueClient venueclient.py:805 DEBUG
> 03/15/06 11:35:43 444 CertificateManager
> 03/15/06 11:35:43 444 CertificateManager certificatemanager.py:663
> Hoffman/CN=proxy
> Hoffman/CN=proxy
> 03/15/06 11:35:43 444 VenueClient venueclient.py:833 INFO
> 03/15/06 11:35:43 444 VenueClient venueclient.py:705 DEBUG
> 03/15/06 11:35:43 444 VenueClient venueclient.py:866 ERROR
> EnterVenue: failed
> 837, in EnterVenue
in
> Enter
> __call__
> __r_call
__call
> in buildSOAP
> return t.build()
> in build
> in genns
> 03/15/06 11:35:43 444 VenueClient venueclientui.py:1925 DEBUG
> 03/15/06 11:35:43 444 VenueClient venueclientui.py:1938 DEBUG
> warningString: 03/15/06 11:37:41 444 VenueClient
venueclient.py:805
> DEBUG EnterVenue; url=https://venues.ncsa.uiuc.edu:9000/Venues/default
> 03/15/06 11:37:41 444 CertificateManager
> 03/15/06 11:37:41 444 CertificateManager certificatemanager.py:663
> Hoffman/CN=proxy
> Hoffman/CN=proxy
> 03/15/06 11:37:41 444 VenueClient venueclient.py:833 INFO
> 03/15/06 11:37:41 444 VenueClient venueclient.py:705 DEBUG
> 03/15/06 11:37:41 444 VenueClient venueclient.py:866 ERROR
> EnterVenue: failed
> 837, in EnterVenue
in
> Enter
> __call__
> __r_call
__call
> in buildSOAP
> return t.build()
> in build
> in genns
> 03/15/06 11:37:41 444 VenueClient venueclientui.py:1925 DEBUG
> 03/15/06 11:37:41 444 VenueClient venueclientui.py:1938 DEBUG
> warningString: 03/15/06 11:39:38 444 VenueClient
> venueclientui.py:1565 INFO --------- END VenueClient
> 03/15/06 11:39:38 444 DataStore datastore.py:1614 DEBUG Quitting
> thread 0
> 03/15/06 11:39:38 284 DataStore datastore.py:1555 DEBUG Worker 0
> gets cmd quit
> 03/15/06 11:39:38 284 DataStore datastore.py:1568 DEBUG Worker 0
> exiting
> 03/15/06 11:39:38 444 NodeService agnodeservice.py:136 INFO
> NodeService.Stop
> 03/15/06 11:39:38 444 ServiceManager agservicemanager.py:84 INFO
> 03/15/06 11:39:38 444 ServiceManager agservicemanager.py:85 INFO
> Remove services
> 03/15/06 11:39:38 444 ServiceManager agservicemanager.py:389 INFO
> 03/15/06 11:39:38 444 ServiceManager agservicemanager.py:87 INFO
> 03/15/06 11:39:38 1732 DataStore datastore.py:1627 INFO
> likely shutting down. 03/15/06 11:39:38 3836 Hosting server.py:65
> ERROR Exception in SOAP server main loop
> File
> line 63, in Run
in
> get_request
> get_request
listen
> raise ex
> 03/15/06 11:39:38 444 Hosting server.py:97 ERROR server_close()
failed
> File
> line 95, in Stop
> server_close
> self.socket.close()
close
> IOBase.close(self)
close
> raise ex
1
failed
> File
> line 95, in Stop
> server_close
> self.socket.close()
close
> IOBase.close(self)
close
> raise ex
1
> 03/15/06 11:40:54 240 Toolkit toolkit.py:96 DEBUG Initializing AG
> Toolkit version 2.4 (build 1)
> 03/15/06 11:40:54 240 Toolkit toolkit.py:138 INFO Logfile Name:
> VenueClient.log
> 03/15/06 11:40:54 240 Toolkit config.py:196 DEBUG Using
> GLOBUS_HOSTNAME=SCV-BADTZ.ad.bu.edu as set in the environment
> 03/15/06 11:40:54 240 CertificateManager certificatemanager.py:269
> 03/15/06 11:40:54 240 Toolkit toolkit.py:404 DEBUG looking in
system
> 03/15/06 11:40:54 240 Toolkit toolkit.py:418 INFO C:\Program
> 03/15/06 11:40:54 240 Toolkit toolkit.py:440 INFO Certificate
> 03/15/06 11:40:54 240 Toolkit toolkit.py:456 INFO Marking cert as
> CA cert
> 03/15/06 11:40:54 240 Toolkit toolkit.py:469 INFO Imported
signing
> CA cert
signing
> CA cert
signing
> CA cert
signing
> 03/15/06 11:40:54 240 Toolkit toolkit.py:478 DEBUG Init'ing
globus.
> 03/15/06 11:40:54 240 CertificateManager certificatemanager.py:759
> 03/15/06 11:40:54 240 CertificateManager certificatemanager.py:827
> 03/15/06 11:40:54 240 CertificateManager certificatemanager.py:902
> 03/15/06 11:40:54 240 CertificateManager certificatemanager.py:921
> 03/15/06 11:40:54 240 CertificateManager certificatemanager.py:924
> 00:35:01
> 03/15/06 11:40:54 240 CertificateManagerWXGUI
> 03/15/06 11:40:54 240 Toolkit toolkit.py:482 DEBUG Done with
globus.
> 03/15/06 11:40:54 240 Toolkit venueclient.py:83 INFO wx version
is:
> 2.5.1.5
> 03/15/06 11:40:55 240 VenueClient venueclient.py:287 DEBUG
> 03/15/06 11:40:55 240 ServiceManager agservicemanager.py:75 INFO
> 03/15/06 11:40:55 240 ServiceManager agservicemanager.py:424 INFO
> __DiscoverResources
> 03/15/06 11:40:55 240 Toolkit config.py:997 INFO Using vfwscan to
> get devices
> 03/15/06 11:40:55 240 Toolkit config.py:998 DEBUG vfwscanexe =
> 03/15/06 11:40:55 240 Toolkit config.py:1003 DEBUG filelines =
> 03/15/06 11:40:55 240 Toolkit config.py:1031 INFO GetResources:
> 03/15/06 11:40:55 240 VenueClient venueclient.py:296 DEBUG
> 03/15/06 11:40:55 240 NodeService agnodeservice.py:756 INFO
> 03/15/06 11:40:55 240 Toolkit toolkit.py:335 DEBUG Looking for:
> 03/15/06 11:40:55 240 Toolkit toolkit.py:340 DEBUG Looking for:
> 03/15/06 11:40:55 240 NodeService agnodeservice.py:764 DEBUG
DEFAULT
> 03/15/06 11:40:55 240 NodeService agnodeservice.py:768 INFO
Reading
> 03/15/06 11:40:55 240 VenueClient venueclient.py:302 DEBUG
> 03/15/06 11:40:55 240 VenueClient venueclient.py:1328 DEBUG
> 03/15/06 11:40:55 240 NodeService agnodeservice.py:698 INFO
> 03/15/06 11:40:55 240 NodeService agnodeservice.py:581 INFO
> 03/15/06 11:40:55 240 NodeService agnodeservice.py:374 INFO
> 03/15/06 11:40:55 240 NodeService agnodeservice.py:378 INFO
Loading
> 03/15/06 11:40:55 240 NodeService agnodeservice.py:392 INFO
> 03/15/06 11:40:55 240 NodeService agnodeservice.py:407 INFO
Trying
> 03/15/06 11:40:55 240 NodeService agnodeservice.py:480 INFO
> 03/15/06 11:40:55 240 NodeService agnodeservice.py:381 ERROR
line
line
> 03/15/06 11:40:55 240 VenueClient venueclient.py:313 ERROR Error
line
> 03/15/06 11:40:55 240 VenueClient venueclient.py:185 DEBUG
> 03/15/06 11:40:55 240 DataStore datastore.py:1537 DEBUG Creating
> thread 0
> 03/15/06 11:40:55 240 DataStore datastore.py:1542 DEBUG Starting
> thread 0
> 03/15/06 11:40:55 2996 DataStore datastore.py:1550 DEBUG Worker 0
> starting
> 03/15/06 11:40:55 240 DataStore datastore.py:1544 DEBUG Waiting
> thread 0
> 03/15/06 11:40:55 240 DataStore datastore.py:1547 DEBUG Done
> creating workers
> 03/15/06 11:40:55 240 DataStore datastore.py:278 DEBUG Reading
> 03/15/06 11:40:55 240 VenueClient venueclient.py:210 DEBUG
> 03/15/06 11:40:55 240 VenueClientController
to
> load.
> 03/15/06 11:40:55 240 VenueClient venueclient.py:805 DEBUG
> 03/15/06 11:40:55 240 CertificateManager
> 03/15/06 11:40:55 240 CertificateManager certificatemanager.py:663
> Hoffman/CN=proxy
> Hoffman/CN=proxy
> 03/15/06 11:40:55 240 VenueClient venueclient.py:833 INFO
> 03/15/06 11:40:55 240 VenueClient venueclient.py:705 DEBUG
> 03/15/06 11:40:55 240 VenueClient venueclient.py:866 ERROR
> EnterVenue: failed
> 837, in EnterVenue
in
> Enter
> __call__
> __r_call
__call
> in buildSOAP
> return t.build()
> in build
> in genns
> 03/15/06 11:40:55 240 VenueClient venueclientui.py:1925 DEBUG
> 03/15/06 11:40:55 240 VenueClient venueclientui.py:1938 DEBUG
> warningString: 03/15/06 11:41:01 240 VenueClient
> 03/15/06 11:41:01 240 DataStore datastore.py:1614 DEBUG Quitting
> thread 0
> 03/15/06 11:41:01 2996 DataStore datastore.py:1555 DEBUG Worker 0
> gets cmd quit
> 03/15/06 11:41:01 2996 DataStore datastore.py:1568 DEBUG Worker 0
> exiting
> 03/15/06 11:41:01 3376 DataStore datastore.py:1627 INFO
> likely shutting down. 03/15/06 11:41:01 240 NodeService
> 03/15/06 11:41:01 240 ServiceManager agservicemanager.py:84 INFO
> 03/15/06 11:41:01 240 ServiceManager agservicemanager.py:85 INFO
> Remove services
> 03/15/06 11:41:01 240 ServiceManager agservicemanager.py:389 INFO
> 03/15/06 11:41:01 240 ServiceManager agservicemanager.py:87 INFO
> 03/15/06 11:41:01 1340 Hosting server.py:65 ERROR Exception in
SOAP
> server main loop
> File
> line 63, in Run
in
> get_request
> get_request
listen
> raise ex
> 03/15/06 11:41:01 240 Hosting server.py:97 ERROR server_close()
failed
> File
> line 95, in Stop
> server_close
> self.socket.close()
close
> IOBase.close(self)
close
> raise ex
1
failed
> File
> line 95, in Stop
> server_close
> self.socket.close()
close
> IOBase.close(self)
close
> raise ex
1
> 03/15/06 11:42:29 2300 Toolkit config.py:214 DEBUG System hostname
> 03/15/06 11:42:29 2300 CertificateManager
> 03/15/06 11:42:29 2300 Toolkit toolkit.py:404 DEBUG looking in
> 03/15/06 11:42:29 2300 Toolkit toolkit.py:418 INFO C:\Program
> 03/15/06 11:42:29 2300 Toolkit toolkit.py:440 INFO Certificate
> 03/15/06 11:42:29 2300 Toolkit toolkit.py:456 INFO Marking cert
as
> CA cert
> 03/15/06 11:42:29 2300 Toolkit toolkit.py:469 INFO Imported
signing
as
> CA cert
signing
as
> CA cert
signing
as
> CA cert
signing
> 03/15/06 11:42:29 2300 Toolkit toolkit.py:478 DEBUG Init'ing
globus.
> 00:35:01
> 03/15/06 11:42:29 2300 CertificateManagerWXGUI
> 03/15/06 11:42:29 2300 Toolkit toolkit.py:482 DEBUG Done with
globus.
> 03/15/06 11:42:29 2300 Toolkit venueclient.py:83 INFO wx version
> is: 2.5.1.5
> 03/15/06 11:42:29 2300 VenueClient venueclient.py:287 DEBUG
> 03/15/06 11:42:29 2300 ServiceManager agservicemanager.py:75 INFO
> 03/15/06 11:42:29 2300 ServiceManager agservicemanager.py:424 INFO
> __DiscoverResources
> 03/15/06 11:42:29 2300 Toolkit config.py:997 INFO Using vfwscan
to
> get devices
> 03/15/06 11:42:29 2300 Toolkit config.py:998 DEBUG vfwscanexe =
> 03/15/06 11:42:30 2300 Toolkit config.py:1003 DEBUG filelines =
> 03/15/06 11:42:30 2300 Toolkit config.py:1031 INFO GetResources:
> 03/15/06 11:42:30 2300 VenueClient venueclient.py:296 DEBUG
> 03/15/06 11:42:30 2300 NodeService agnodeservice.py:756 INFO
> 03/15/06 11:42:30 2300 Toolkit toolkit.py:335 DEBUG Looking for:
> 03/15/06 11:42:30 2300 Toolkit toolkit.py:340 DEBUG Looking for:
> 03/15/06 11:42:30 2300 NodeService agnodeservice.py:764 DEBUG
> 03/15/06 11:42:30 2300 NodeService agnodeservice.py:768 INFO
> 03/15/06 11:42:30 2300 VenueClient venueclient.py:302 DEBUG
> 03/15/06 11:42:30 2300 VenueClient venueclient.py:1328 DEBUG
> 03/15/06 11:42:30 2300 NodeService agnodeservice.py:698 INFO
> 03/15/06 11:42:30 2300 NodeService agnodeservice.py:581 INFO
> 03/15/06 11:42:30 2300 NodeService agnodeservice.py:374 INFO
> 03/15/06 11:42:30 2300 NodeService agnodeservice.py:378 INFO
> 03/15/06 11:42:30 2300 NodeService agnodeservice.py:392 INFO
> 03/15/06 11:42:30 2300 NodeService agnodeservice.py:407 INFO
Trying
> 03/15/06 11:42:30 2300 NodeService agnodeservice.py:480 INFO
> 03/15/06 11:42:30 2300 NodeService agnodeservice.py:381 ERROR
line
line
> 03/15/06 11:42:30 2300 VenueClient venueclient.py:313 ERROR Error
line
> 03/15/06 11:42:30 2300 VenueClient venueclient.py:185 DEBUG
> 03/15/06 11:42:30 2300 DataStore datastore.py:1537 DEBUG Creating
> thread 0
> 03/15/06 11:42:30 2300 DataStore datastore.py:1542 DEBUG Starting
> thread 0
> 03/15/06 11:42:30 1608 DataStore datastore.py:1550 DEBUG Worker 0
> starting
> 03/15/06 11:42:30 2300 DataStore datastore.py:1544 DEBUG Waiting
> thread 0
> 03/15/06 11:42:30 2300 DataStore datastore.py:1547 DEBUG Done
> creating workers
> 03/15/06 11:42:30 2300 DataStore datastore.py:278 DEBUG Reading
> 03/15/06 11:42:30 2300 VenueClient venueclient.py:210 DEBUG
> 03/15/06 11:42:30 2300 VenueClientController
to
> load.
> 03/15/06 11:42:37 2300 VenueClient venueclient.py:805 DEBUG
> 03/15/06 11:42:37 2300 CertificateManager
> Hoffman/CN=proxy
> Hoffman/CN=proxy
> 03/15/06 11:42:37 2300 VenueClient venueclient.py:833 INFO
> 03/15/06 11:42:37 2300 VenueClient venueclient.py:705 DEBUG
> 03/15/06 11:42:37 2300 VenueClient venueclient.py:866 ERROR
> EnterVenue: failed
> 837, in EnterVenue
in
> Enter
> __call__
> __r_call
__call
> in buildSOAP
> return t.build()
> in build
> in genns
> 03/15/06 11:42:37 2300 VenueClient venueclientui.py:1925 DEBUG
> 03/15/06 11:42:37 2300 VenueClient venueclientui.py:1938 DEBUG
> warningString: 03/15/06 11:45:42 2300 VenueClient
> 03/15/06 11:45:42 2300 DataStore datastore.py:1614 DEBUG Quitting
> thread 0
> 03/15/06 11:45:42 1608 DataStore datastore.py:1555 DEBUG Worker 0
> gets cmd quit
> 03/15/06 11:45:42 1608 DataStore datastore.py:1568 DEBUG Worker 0
> exiting
> 03/15/06 11:45:42 3752 DataStore datastore.py:1627 INFO
> likely shutting down. 03/15/06 11:45:42 2300 NodeService
> 03/15/06 11:45:42 2300 ServiceManager agservicemanager.py:84 INFO
> 03/15/06 11:45:42 2300 ServiceManager agservicemanager.py:85 INFO
> Remove services
> 03/15/06 11:45:42 2300 ServiceManager agservicemanager.py:389 INFO
> 03/15/06 11:45:42 2300 ServiceManager agservicemanager.py:87 INFO
> 03/15/06 11:45:42 1120 Hosting server.py:65 ERROR Exception in
SOAP
> server main loop
> File
> line 63, in Run
in
> get_request
> get_request
listen
> raise ex
> 03/15/06 11:45:42 2300 Hosting server.py:97 ERROR server_close()
failed
> File
> line 95, in Stop
> server_close
> self.socket.close()
close
> IOBase.close(self)
close
> raise ex
1
failed
> File
> line 95, in Stop
> server_close
> self.socket.close()
close
> IOBase.close(self)
close
> raise ex
1
