[AG-TECH] Problems connecting to AGServiceManager on capture node
Douglas Kosovic
douglask at itee.uq.edu.au
Wed May 10 01:54:45 CDT 2006
Hi Michael:
Thomas D. Uram wrote:
> The combo box should be populated with service managers discovered on the
> local network. If you don't see this initially, it may be a problem
> particular to FC or the FC packaging. Doug will be able to speak to that.
FC3 uses Apple's mDNSresponder and python-bonjour. At a minimum, you should
be seeing it's own service manager entry in the combo-box, so suspect
/etc/hosts is partly broken, mdnsd daemon isn't running, or you have an
older python-bonjour RPM installed.
See the following regarding /etc/hosts (appears to happen with
configurations not using DHCP) :
http://agcentral.org/help/tutorial/aginstallonfc5/beforeinstall
To check that mdnsd is running, issue:
/etc/init.d/mdnsd status
if it's not running, issue as root:
/etc/init.d/mdnsd start
To check you have the latest python-bonjour, issue the following:
$ rpm -qa python-bonjour
python-bonjour-0.1-2.fc3
or do a 'yum update python-bonjour' to get the latest.
Cheers,
Doug
