[AG-TECH] video consumer vic not always receive feeds... the video producer vic does instead
Natalia Costas
natalia at cesga.es
Mon May 8 10:39:16 CDT 2006
I cant tell for sure right now.. but i thought the feeds where delivered
to both instances of vic when using video service instead of video
producers and videoconsumer services...
I'll check it tomorrow.
Natalia Costas escribió:
> Ah, yes.. i forgot to tell about the bridge...
> We will use our "workaround" meanwhile it is not solved.
> Thax a lot Tom!
> Thomas D. Uram escribió:
>> Natalia:
>> It sounds like you are using a bridge. If so, the problem is that
>> the bridge only
>> sends data to a single application per machine, so only one of your
>> vic instances
>> will get video data from the bridge. This is a known bug in our
>> bugzilla.
>> If you are not using a bridge, please let us know, as this would be some
>> strange behavior.
>> Thanks,
>> Tom
>> Natalia Costas wrote:
>>> Hi everybody,
>>> Giving a hand to our collegues at the University of Extremadura, we
>>> found a problem. Maybe someone knows the solution. The problem
>>> arises with a one machine node with two capture cards:
>>> They have 2 videoproducer services + 1 videoconsumer. The problem is
>>> that the videofeeds go to any of the vics (video producer of
>>> videoconsumer) randomly... so.. sometimes the videoconsumer vic
>>> receives nothing (but the videoproducer vic does), and it starts
>>> receiving the feeds only when i close one of the video producer vics.
>>> The only workaround i've found is to add 2 video services (so any of
>>> them receive the feeds and are unmuted). Both receive all the feeds,
>>> but i dont like that solution very much. I am afraid it might have
>>> some impact on performance (the videostreams are delivered to two
>>> different applications...)
>>> Thanx a lot in advance,
>>> Kind regards.
Natalia Costas Lago
E-mail: natalia at cesga.es
Centro de Supercomputacion de Galicia (CESGA)
Avenida de Vigo, s/n (Campus Sur)
15705 Santiago de Compostela - SPAIN
Tel: +34 981 56 98 10
Fax: +34 981 59 46 16
http://www.cesga.es/
