[AG-TECH] Cert Request Server Problem?
Rhys Hawkins
Rhys.Hawkins at anu.edu.au
Tue Mar 21 23:57:50 CST 2006
It just started working again :)
Cheers,
Rhys
On Wed, 2006-03-22 at 16:41 +1100, Rhys Hawkins wrote:
> Hi,
> I can't seem to create anonymous certs on a fresh install and I get
> the following error (outputted to console) when trying to check the
> status of a cert reques (see below).
> Is the server just down? (Note the 500 reply)
> Cheers,
> Rhys
> connect: (www-unix.mcs.anl.gov, 80)
> send: 'POST /fl/research/accessgrid/ca/agdev/certReqServer.cgi HTTP/1.0
> \r\nHost: www-unix.mcs.anl.gov\r\nUser-Agent: xmlrpclib.py/1.0.1 (by
> www.pythonware.com)\r\nContent-Type: text/xml\r\nContent-Length: 195\r\n
> \r\n'
> send: "<?xml
> version='1.0'?>\n<methodCall>\n<methodName>RetrieveCertificate</methodName>\n<params>\n<param>\n<value><string>**deleted**</string></value>\n</param>\n</params>\n</methodCall>\n"
> reply: 'HTTP/1.1 500 Internal Server Error\r\n'
> header: Date: Wed, 22 Mar 2006 05:37:41 GMT
> header: Server: Apache
> header: Last-Modified: Thu, 04 Mar 1999 16:41:56 GMT
> header: ETag: "74112-127e-36deb7d4"
> header: Accept-Ranges: bytes
> header: Content-Length: 4734
> header: Connection: close
> header: Content-Type: text/html
> Format
> <AccessGrid.Security.wxgui.CertificateStatusBrowser.CertRequestWrapper
> instance at 0x2aaab4af1fc8>
