[AG-TECH] Cert Request Server Problem?
Rhys Hawkins
Rhys.Hawkins at anu.edu.au
Tue Mar 21 23:41:48 CST 2006
I can't seem to create anonymous certs on a fresh install and I get
the following error (outputted to console) when trying to check the
status of a cert reques (see below).
Is the server just down? (Note the 500 reply)
Cheers,
Rhys
connect: (www-unix.mcs.anl.gov, 80)
send: 'POST /fl/research/accessgrid/ca/agdev/certReqServer.cgi HTTP/1.0
\r\nHost: www-unix.mcs.anl.gov\r\nUser-Agent: xmlrpclib.py/1.0.1 (by
www.pythonware.com)\r\nContent-Type: text/xml\r\nContent-Length: 195\r\n
\r\n'
send: "<?xml
version='1.0'?>\n<methodCall>\n<methodName>RetrieveCertificate</methodName>\n<params>\n<param>\n<value><string>**deleted**</string></value>\n</param>\n</params>\n</methodCall>\n"
reply: 'HTTP/1.1 500 Internal Server Error\r\n'
header: Date: Wed, 22 Mar 2006 05:37:41 GMT
header: Server: Apache
header: Last-Modified: Thu, 04 Mar 1999 16:41:56 GMT
header: ETag: "74112-127e-36deb7d4"
header: Accept-Ranges: bytes
header: Content-Length: 4734
header: Connection: close
header: Content-Type: text/html
Format
<AccessGrid.Security.wxgui.CertificateStatusBrowser.CertRequestWrapper
instance at 0x2aaab4af1fc8>
