[AG-TECH] Re: cannot connect to venue on new PIG
Andrew Patrick
Andrew.Patrick at nrc-cnrc.gc.ca
Thu Mar 16 11:07:19 CST 2006
To add to this, it is my experience that if you do run some of the IBM support
tools, it is likely that your PYTHON variables will be changed and you will have
to start again.
That being said, I do have AG 2.3 and 3 Beta 2 running fine on my Thinkpad T42
after making the fixes.
Jennifer Teig von Hoffman wrote:
> Tom Uram worked with me yesterday, and here are the steps we took to
> resolve the issue (summarized here to reduce your spam burden):
> * I removed the PYTHONCASEOK environment variable
> * I discovered that another version of ActivePython was installed in
> addition to the appropriate ActivePython AG prerequisite, so I removed
> all versions of ActivePython and re-installed only the one I needed
> * We determined that I can run the VenueClient from the command line in
> a command window in which the PYTHONPATH variable has been set to null.
> So, quoting from Tom, here are my options:
>> - unset the PYTHONPATH env var in the control panel, System, Env
>> Vars., which will likely prevent the IBM support tools from running.
>> - each time you want to use the AG, unset the PYTHONPATH env var in a
>> command window, and then run the VenueClient as you did just now.
> I plan to use the second option.
> - Jennifer
>> Hi all,
>> I've just migrated to a new laptop and installed AG 2.4. I've
>> imported my (valid) certificate, and can successfully make a proxy.
>> However, I cannot connect to a venue. When I try to connect, I get
>> the standard "Can not connect to venue located at
>> https://vvw.mcs.anl.gov:9000/Venues/default. Please try again." error
>> message. I've tried to connect to both the address above, and
>> venues.ncsa.uiuc.edu.
>> I wonder if my laptop may be in a strange state -- I used the Lenovo
>> migration assistant when switching over to the new hardware, and
>> generally speaking it has been inconsistent about what settings/etc
>> it's carried over from the old machine. I installed AG 2.4 *after*
>> migration, so theoretically it shouldn't have taken any of the
>> AG-related settings, but nonetheless the Lenovo experience has
>> overall been quite mixed and I wonder if it may be the issue here.
>> My entire VenueClient.log is below. Any suggestions?
>> Cheers, Jennifer
>> 03/14/06 15:43:06 824 Toolkit config.py:364 ERROR Couldn't
>> retrieve globus key from registry. Traceback (most recent call last):
>> File
>> "C:\Python23\Lib\site-packages\AccessGrid\Platform\win32\Config.py",
>> line 362, in GetGlobusKey "Software\Globus", 0,
>> _winreg.KEY_SET_VALUE) WindowsError: [Errno 2] The system cannot find
>> the file specified 03/14/06 15:43:06 824 Toolkit config.py:214
>> DEBUG System hostname of SCV-BADTZ.ad.bu.edu is valid 03/14/06
>> 15:44:45 2840 Toolkit config.py:381 ERROR Couldn't retrieve gsi
>> key from registry. Traceback (most recent call last): File
>> line 378, in GetGlobusKey gsikey = _winreg.OpenKey(gkey, "GSI", 0,
>> the file specified 03/14/06 15:44:45 2840 Toolkit config.py:214
>> 15:44:45 2840 CertificateManager certificatemanager.py:297 DEBUG
>> initializing repository 03/14/06 15:44:45 2840 CertificateManager
>> certificatemanager.py:327 DEBUG Initializing from C:\Program
>> Files\AGTk-2.4\Config\CAcertificates 03/14/06 15:44:45 2840
>> CertificateManager certificatemanager.py:340 WARNING Didn't find
>> certficate in old globus path: C:\Documents and
>> Settings\jtvh\Application Data\globus\usercert.pem 03/14/06 15:44:45
>> 2840 CertificateManager certificatemanager.py:416 INFO
>> C:\Program Files\AGTk-2.4\Config\CAcertificates\1c3f2ca8.0 might be a
>> cert 03/14/06 15:44:45 2840 CertificateRepository
>> certificaterepository.py:889 DEBUG _ImportCertificate: create
>> C:\Documents and Settings\jtvh\Application
>> Data\AccessGrid\Config\certRepo\certificates\a82c3f1c4b096b896061778ee79efeff\9c8df64aa35ebf832613413527bc073d
>> 03/14/06 15:44:46 2840 CertificateRepository
>> certificaterepository.py:1615 DEBUG GetFilePath: create C:\Documents
>> Data\AccessGrid\Config\certRepo\certificates\a82c3f1c4b096b896061778ee79efeff\9c8df64aa35ebf832613413527bc073d\user_files
>> 03/14/06 15:44:46 2840 CertificateManager
>> certificatemanager.py:441 INFO Imported cert as 1c3f2ca8.0 03/14/06
>> 15:44:46 2840 CertificateManager certificatemanager.py:416 INFO
>> C:\Program Files\AGTk-2.4\Config\CAcertificates\45cc9e80.0 might be a
>> cert 03/14/06 15:44:46 2840 CertificateRepository
>> Data\AccessGrid\Config\certRepo\certificates\809ecc45460c1482e61e26bdfbf9e18c\9f380c9a586af2bb913ace809d5badfe
>> Data\AccessGrid\Config\certRepo\certificates\809ecc45460c1482e61e26bdfbf9e18c\9f380c9a586af2bb913ace809d5badfe\user_files
>> certificatemanager.py:441 INFO Imported cert as 45cc9e80.0 03/14/06
>> C:\Program Files\AGTk-2.4\Config\CAcertificates\d1b603c3.0 might be a
>> Data\AccessGrid\Config\certRepo\certificates\c303b6d10c962b37482e68ca64d383a0\05a2039fe10ed1b4195d9f9d35b32c68
>> Data\AccessGrid\Config\certRepo\certificates\c303b6d10c962b37482e68ca64d383a0\05a2039fe10ed1b4195d9f9d35b32c68\user_files
>> certificatemanager.py:441 INFO Imported cert as d1b603c3.0 03/14/06
>> C:\Program Files\AGTk-2.4\Config\CAcertificates\f18fa857.0 might be a
>> Data\AccessGrid\Config\certRepo\certificates\57a88ff1707d87e926f2287c702a8466\eff65f03366cb8e20247f831ccc87fd5
>> Data\AccessGrid\Config\certRepo\certificates\57a88ff1707d87e926f2287c702a8466\eff65f03366cb8e20247f831ccc87fd5\user_files
>> certificatemanager.py:441 INFO Imported cert as f18fa857.0 03/14/06
>> 15:44:46 2840 CertificateManager certificatemanager.py:1198
>> WARNING No identity certs found 03/14/06 15:44:46 2840
>> CertificateManager certificatemanager.py:1209 WARNING No default
>> identity certificate found 03/14/06 15:44:46 2840 Toolkit
>> toolkit.py:404 DEBUG looking in system ca dir: C:\Program
>> Files\AGTk-2.4\Config\CAcertificates 03/14/06 15:44:46 2840 Toolkit
>> toolkit.py:418 INFO C:\Program
>> Files\AGTk-2.4\Config\CAcertificates\1c3f2ca8.0 might be a cert
>> 03/14/06 15:44:46 2840 Toolkit toolkit.py:440 INFO Certificate
>> 1c3f2ca8.0 already in repository 03/14/06 15:44:46 2840 Toolkit
>> toolkit.py:456 INFO Marking cert as CA cert 03/14/06 15:44:46 2840
>> Toolkit toolkit.py:469 INFO Imported signing policy as
>> Data\AccessGrid\Config\certRepo\certificates\a82c3f1c4b096b896061778ee79efeff\9c8df64aa35ebf832613413527bc073d\user_files\signing_policy
>> 03/14/06 15:44:46 2840 Toolkit toolkit.py:418 INFO C:\Program
>> Files\AGTk-2.4\Config\CAcertificates\45cc9e80.0 might be a cert
>> 45cc9e80.0 already in repository 03/14/06 15:44:46 2840 Toolkit
>> Data\AccessGrid\Config\certRepo\certificates\809ecc45460c1482e61e26bdfbf9e18c\9f380c9a586af2bb913ace809d5badfe\user_files\signing_policy
>> Files\AGTk-2.4\Config\CAcertificates\d1b603c3.0 might be a cert
>> d1b603c3.0 already in repository 03/14/06 15:44:46 2840 Toolkit
>> Data\AccessGrid\Config\certRepo\certificates\c303b6d10c962b37482e68ca64d383a0\05a2039fe10ed1b4195d9f9d35b32c68\user_files\signing_policy
>> Files\AGTk-2.4\Config\CAcertificates\f18fa857.0 might be a cert
>> f18fa857.0 already in repository 03/14/06 15:44:46 2840 Toolkit
>> toolkit.py:456 INFO Marking cert as CA cert 03/14/06 15:44:47 2840
>> Data\AccessGrid\Config\certRepo\certificates\57a88ff1707d87e926f2287c702a8466\eff65f03366cb8e20247f831ccc87fd5\user_files\signing_policy
>> 03/14/06 15:44:47 2840 Toolkit toolkit.py:478 DEBUG Init'ing
>> globus. 03/14/06 15:44:47 2840 CertificateManager
>> certificatemanager.py:759 DEBUG Configuring standard environment
>> certificatemanager.py:1198 WARNING No identity certs found 03/14/06
>> 15:44:47 2840 CertificateManager certificatemanager.py:1209
>> WARNING No default identity certificate found 03/14/06 15:44:47 2840
>> CertificateManager certificatemanager.py:829 DEBUG No default
>> identity found <type 'NoneType'> None 03/14/06 15:44:47 2840
>> CertificateRepository certificaterepository.py:952 INFO
>> _ImportPrivateKey importing pkey to C:\Documents and
>> Data\AccessGrid\Config\certRepo\privatekeys\b82eff976e60282028802c8814e23901.pem
>> 03/14/06 15:44:47 2840 CertificateRepository
>> certificaterepository.py:918 INFO _ImportCertificateRequest writing
>> to C:\Documents and Settings\jtvh\Application
>> Data\AccessGrid\Config\certRepo\requests\b82eff976e60282028802c8814e23901.pem
>> 03/14/06 15:44:47 2840 CRSClient crsclient.py:40 DEBUG create
>> client 03/14/06 15:44:47 2840 CRSClient crsclient.py:73 DEBUG
>> request certificate 03/14/06 15:44:49 2840 CertificateManager
>> certificatemanager.py:1275 DEBUG CheckRequestedCertificate:
>> req=<AccessGrid.Security.CertificateRepository.CertificateRequestDescriptor
>> instance at 0x01F892D8>, token=267d22fbd98fcbd8bca067f7148e034a,
>> server=http://www-unix.mcs.anl.gov/fl/research/accessgrid/ca/anonymous/anonReqServer.cgi
>> 03/14/06 15:44:49 2840 CRSClient crsclient.py:40 DEBUG create
>> client 03/14/06 15:44:49 2840 CRSClient crsclient.py:104 DEBUG
>> retrieve certificate for token 267d22fbd98fcbd8bca067f7148e034a
>> 03/14/06 15:44:49 2840 CRSClient crsclient.py:115 DEBUG retrieved
>> certificate [1, '-----BEGIN
>> CERTIFICATE-----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\ndGljYXRvcjANBgk
>> qhkiG9w0BAQQFAAOCAQEALmC3il6vFPYI1PERDado53isFC8R\n0w1SXWv8skr9XZWw/Gbc2Lms9MgVn5PxN6aeSoRr30M0IOk/xYAObNWKRbyzTaaE\nle7xuILHPwEB7GaeHDr11gcRCU6cs1a+DwMEXTWb9nTyK3w6yYvE4ZuGaqJDnFFc\n4YCqiDx0XmJjqz5YDp7l6tn5j2PLF1WW3rGWATBAo+jjcGrCu/KzlI0RFAXANPWg\npTj/pOprcOinLUWr7XXos90NY91/vHmvFVP2mQqQPI7OwbqFiviAo8+dcC2/ozDj\nJkECJYzHJrYQFu5udPHajE2wTaYP7R6Nhn20D9PvD3cgSBv/AXXKSk0bwQ==\n-----END
>> CERTIFICATE-----\n\n'] 03/14/06 15:44:49 2840 CertificateManager
>> certificatemanager.py:1280 DEBUG Retrieve returns [1, '-----BEGIN
>> GljYXRvcjANBgkqhkiG9w0BAQQFAAOCAQEALmC3il6vFPYI1PERDado53isFC8R\n0w1SXWv8skr9XZWw/Gbc2Lms9MgVn5PxN6aeSoRr30M0IOk/xYAObNWKRbyzTaaE\nle7xuILHPwEB7GaeHDr11gcRCU6cs1a+DwMEXTWb9nTyK3w6yYvE4ZuGaqJDnFFc\n4YCqiDx0XmJjqz5YDp7l6tn5j2PLF1WW3rGWATBAo+jjcGrCu/KzlI0RFAXANPWg\npTj/pOprcOinLUWr7XXos90NY91/vHmvFVP2mQqQPI7OwbqFiviAo8+dcC2/ozDj\nJkECJYzHJrYQFu5udPHajE2wTaYP7R6Nhn20D9PvD3cgSBv/AXXKSk0bwQ==\n-----END
>> CERTIFICATE-----\n\n'] 03/14/06 15:44:49 2840 CertificateRepository
>> certificaterepository.py:866 DEBUG Importing requested certificate
>> subj=/O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab
>> Anonymous Authority/CN=Anonymous User
>> 4a250eb4e3231f2abbe3d4021c330646 path=C:\Documents and
>> Data\AccessGrid\Config\certRepo\certificates\5cf11fcf8b5d698d7eb3ccdba1980efb\99514c538e7a32167c1699b16c025df4
>> certificaterepository.py:867 DEBUG Modulus hash is
>> b82eff976e60282028802c8814e23901 03/14/06 15:44:49 2840
>> CertificateRepository certificaterepository.py:889 DEBUG
>> _ImportCertificate: create C:\Documents and Settings\jtvh\Application
>> 03/14/06 15:44:50 2840 CertificateManager
>> certificatemanager.py:453 DEBUG imported requested cert /O=Access
>> Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous
>> Authority/CN=Anonymous User 4a250eb4e3231f2abbe3d4021c330646 03/14/06
>> 15:44:50 2840 CertificateManager certificatemanager.py:759 DEBUG
>> Configuring standard environment 03/14/06 15:44:50 2840
>> CertificateManager certificatemanager.py:827 DEBUG Using default
>> identity /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab
>> Anonymous Authority/CN=Anonymous User 4a250eb4e3231f2abbe3d4021c330646
>> CertificateManager certificatemanager.py:1083 DEBUG Initializing
>> environment with unencrypted cert /O=Access Grid/O=Argonne National
>> Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User
>> 4a250eb4e3231f2abbe3d4021c330646 03/14/06 15:44:50 2840
>> CertificateManager certificatemanager.py:1098 INFO Setting
>> permissions on certificate C:\Documents and Settings\jtvh\Application
>> Data\AccessGrid\Config\certRepo\certificates\5cf11fcf8b5d698d7eb3ccdba1980efb\99514c538e7a32167c1699b16c025df4\cert.pem
>> to 644 03/14/06 15:44:50 2840 CertificateManager
>> certificatemanager.py:1109 INFO Setting permissions on certificate
>> to 600 03/14/06 15:44:50 2840 CertificateManagerWXGUI
>> certificatemanagerwxgui.py:422 DEBUG done, success=1 03/14/06
>> 15:44:50 2840 CertificateManagerWXGUI certificatemanagerwxgui.py:422
>> DEBUG done, success=1 03/14/06 15:44:50 2840 Toolkit
>> toolkit.py:482 DEBUG Done with globus. 03/14/06 15:44:50 2840 Toolkit
>> venueclient.py:83 INFO wx version is: 2.5.1.5 03/14/06 15:44:50 2840
>> VenueClient venueclient.py:287 DEBUG __StartWebService:
>> venueclient: https://SCV-BADTZ.ad.bu.edu:11000/VenueClient 03/14/06
>> 15:44:50 2840 ServiceManager agservicemanager.py:68 INFO Creating
>> user services directory C:\Documents and Settings\jtvh\Application
>> Data\AccessGrid\local_services 03/14/06 15:44:50 2840 ServiceManager
>> agservicemanager.py:424 INFO __DiscoverResources 03/14/06 15:44:50
>> 2840 Toolkit config.py:997 INFO Using vfwscan to get devices
>> 03/14/06 15:44:50 2840 Toolkit config.py:998 DEBUG vfwscanexe =
>> C:\PROGRA~1\AGTk-2.4\bin\vfwscan.exe 03/14/06 15:44:51 2840 Toolkit
>> config.py:1003 DEBUG filelines = ['Microsoft WDM Image Capture
>> (Win32)\n'] 03/14/06 15:44:51 2840 Toolkit config.py:1031 INFO
>> GetResources: ['Microsoft WDM Image Capture (Win32)'] 03/14/06
>> 15:44:51 2840 VenueClient venueclient.py:296 DEBUG
>> __StartWebService: service manager:
>> https://SCV-BADTZ.ad.bu.edu:11000/ServiceManager 03/14/06 15:44:51
>> 2840 NodeService agnodeservice.py:115 INFO Copying system node
>> configs to user node config dir 03/14/06 15:44:51 2840 NodeService
>> agnodeservice.py:116 INFO system node config = C:\Program
>> Files\AGTk-2.4\Config\nodeConfig 03/14/06 15:44:51 2840 NodeService
>> agnodeservice.py:117 INFO user node config = C:\Documents and
>> Settings\jtvh\Application Data\AccessGrid\Config\nodeConfig 03/14/06
>> 15:44:51 2840 NodeService agnodeservice.py:120 INFO node
>> config: defaultWindows 03/14/06 15:44:51 2840 NodeService
>> agnodeservice.py:756 INFO NodeService.__ReadConfigFile 03/14/06
>> 15:44:51 2840 Toolkit toolkit.py:335 DEBUG Looking for:
>> Data\AccessGrid\Config\AGNodeService.cfg 03/14/06 15:44:51 2840
>> Toolkit toolkit.py:340 DEBUG Looking for: C:\Program
>> Files\AGTk-2.4\Config\AGNodeService.cfg 03/14/06 15:44:51 2840
>> NodeService agnodeservice.py:764 DEBUG DEFAULT NODE SERVICE
>> CONFIG: C:\Program Files\AGTk-2.4\Config\AGNodeService.cfg 03/14/06
>> 15:44:51 2840 NodeService agnodeservice.py:768 INFO Reading node
>> service config file: C:\Program
>> VenueClient venueclient.py:302 DEBUG __StartWebService: node
>> service: https://SCV-BADTZ.ad.bu.edu:11000/NodeService 03/14/06
>> 15:44:51 2840 VenueClient venueclient.py:1328 DEBUG SerNodeUrl:
>> Set node service url: https://SCV-BADTZ.ad.bu.edu:11000/NodeService
>> 03/14/06 15:44:51 2840 NodeService agnodeservice.py:698 INFO
>> NodeService.GetDefaultConfiguration 03/14/06 15:44:51 2840
>> NodeService agnodeservice.py:581 INFO Migration unnecessary
>> 03/14/06 15:44:51 2840 NodeService agnodeservice.py:374 INFO
>> NodeService.LoadDefaultConfig 03/14/06 15:44:51 2840 NodeService
>> agnodeservice.py:378 INFO Loading default node configuration:
>> agnodeservice.py:392 INFO NodeService.LoadConfiguration 03/14/06
>> 15:44:51 2840 NodeService agnodeservice.py:407 INFO Trying to
>> load node configuration from: C:\Documents and Settings\jtvh\Application
>> Data\AccessGrid\Config\nodeConfig\defaultWindows 03/14/06 15:44:51
>> 2840 NodeService agnodeservice.py:480 INFO AddServiceManager:
>> Invalid service manager url (https://localhost:11000/ServiceManager)
>> 03/14/06 15:44:51 2840 NodeService agnodeservice.py:381 ERROR
>> Exception loading default configuration. Traceback (most recent call
>> last): File
>> "C:\Python23\Lib\site-packages\AccessGrid\AGNodeService.py", line 379,
>> in LoadDefaultConfig self.LoadConfiguration( self.defaultConfig
>> ) File "C:\Python23\Lib\site-packages\AccessGrid\AGNodeService.py",
>> line 523, in LoadConfiguration raise Exception(exceptionText)
>> Exception: Couldn't reach service manager: localhost:11000 03/14/06
>> 15:44:51 2840 VenueClient venueclient.py:313 ERROR Error loading
>> default configuration Traceback (most recent call last): File
>> "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line 311,
>> in __StartWebService self.ns.LoadDefaultConfig() File
>> "C:\Python23\Lib\site-packages\AccessGrid\AGNodeService.py", line 382,
>> in LoadDefaultConfig raise Exception("Failed to load default
>> configuration <%s>" % Exception: Failed to load default configuration
>> <defaultWindows> 03/14/06 15:44:51 2840 VenueClient
>> venueclient.py:185 DEBUG __createPersonalDataStore: Creating personal
>> datastore at C:\Documents and Settings\jtvh\Application
>> Data\AccessGrid\Config\personalDataStore using prefix
>> personalDataStore and port 0 03/14/06 15:44:51 2840 DataStore
>> datastore.py:1537 DEBUG Creating thread 0 03/14/06 15:44:51 2840
>> DataStore datastore.py:1542 DEBUG Starting thread 0 03/14/06
>> 15:44:51 3284 DataStore datastore.py:1550 DEBUG Worker 0 starting
>> 03/14/06 15:44:51 2840 DataStore datastore.py:1544 DEBUG Waiting
>> thread 0 03/14/06 15:44:51 2840 DataStore datastore.py:1547
>> DEBUG Done creating workers 03/14/06 15:45:17 2840 DataStore
>> datastore.py:278 DEBUG Reading persisted data from: C:\Documents and
>> Data\AccessGrid\Config\personalDataStore\DataStore.dat 03/14/06
>> 15:45:17 2840 VenueClient venueclient.py:210 DEBUG
>> __createPersonalDataStore: Load personal data from file 03/14/06
>> 15:45:17 2840 VenueClientController venueclientcontroller.py:1255
>> DEBUG There is no personal venues file to load. 03/14/06 15:45:17
>> 2840 VenueClient venueclientui.py:188 DEBUG the profile is the
>> default profile - open profile dialog 03/14/06 15:45:17 2840
>> VenueClient venueclientui.py:3871 DEBUG VenueClientUI.py: Set
>> editable in successfully dialog 03/14/06 15:45:17 2840 VenueClient
>> venueclientui.py:3942 DEBUG ProfileDialog.SetProfile: Set profile
>> information successfully in dialog 03/14/06 15:45:42 2840 VenueClient
>> venueclientui.py:3924 DEBUG ProfileDialog.GetNewProfile: Got profile
>> information from dialog 03/14/06 15:45:42 2840 VenueClient
>> information from dialog 03/14/06 15:45:42 2840 VenueClientController
>> venueclientcontroller.py:624 DEBUG Can not update client profile in
>> venue - not connected 03/14/06 15:49:19 2840 VenueClient
>> venueclientui.py:1565 INFO --------- END VenueClient 03/14/06
>> 15:49:19 2840 DataStore datastore.py:1614 DEBUG Quitting thread 0
>> 03/14/06 15:49:19 3284 DataStore datastore.py:1555 DEBUG Worker
>> 0 gets cmd quit 03/14/06 15:49:19 3284 DataStore
>> datastore.py:1568 DEBUG Worker 0 exiting 03/14/06 15:49:19 3076
>> DataStore datastore.py:1627 INFO GSIHTTPTransferServer:
>> GSITCPSocket, interrupted I/O operation, most likely shutting down.
>> 03/14/06 15:49:19 2840 NodeService agnodeservice.py:136 INFO
>> NodeService.Stop 03/14/06 15:49:19 2840 ServiceManager
>> agservicemanager.py:84 INFO AGServiceManager.Shutdown 03/14/06
>> 15:49:19 2840 ServiceManager agservicemanager.py:85 INFO Remove
>> services 03/14/06 15:49:19 2840 ServiceManager
>> agservicemanager.py:389 INFO AGServiceManager.RemoveServices 03/14/06
>> 15:49:19 2840 ServiceManager agservicemanager.py:87 INFO Stop
>> network interface 03/14/06 15:49:19 3924 Hosting server.py:65
>> ERROR Exception in SOAP server main loop Traceback (most recent call
>> last): File
>> "C:\Python23\Lib\site-packages\AccessGrid\hosting\SOAPpy\Server.py",
>> line 63, in Run self._server.handle_request() File
>> "C:\Python23\lib\SocketServer.py", line 217, in handle_request
>> request, client_address = self.get_request() File
>> "C:\Python23\Lib\site-packages\SOAPpy\GSIServer.py", line 140, in
>> get_request sock, addr =
>> ThreadingGSITCPSocketServer.get_request(self) File
>> "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 525, in
>> get_request self.socket.listen() File
>> "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 857, in listen
>> raise ex GSITCPSocketException: an I/O operation was cancelled
>> 03/14/06 15:49:19 2840 Hosting server.py:97 ERROR server_close()
>> failed Traceback (most recent call last): File
>> line 95, in Stop self._server.server_close() File
>> "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1043, in
>> server_close self.socket.close() File
>> "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1020, in close
>> IOBase.close(self) File
>> "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 176, in close
>> raise ex IOBaseException: an uninitialied data structure was passed
>> as argument 1 to globus_io_register_close 03/14/06 15:49:19 2840
>> Hosting server.py:97 ERROR server_close() failed Traceback (most
>> as argument 1 to globus_io_register_close 03/14/06 15:49:32 2580
>> Toolkit config.py:214 DEBUG System hostname of
>> SCV-BADTZ.ad.bu.edu is valid 03/14/06 15:49:32 2580
>> CertificateManager certificatemanager.py:269 DEBUG Opened
>> repository C:\Documents and Settings\jtvh\Application
>> Data\AccessGrid\Config\certRepo 03/14/06 15:49:32 2580 Toolkit
>> Files\AGTk-2.4\Config\CAcertificates 03/14/06 15:49:32 2580 Toolkit
>> 03/14/06 15:49:32 2580 Toolkit toolkit.py:440 INFO Certificate
>> 1c3f2ca8.0 already in repository 03/14/06 15:49:32 2580 Toolkit
>> toolkit.py:456 INFO Marking cert as CA cert 03/14/06 15:49:32 2580
>> 03/14/06 15:49:32 2580 Toolkit toolkit.py:418 INFO C:\Program
>> 45cc9e80.0 already in repository 03/14/06 15:49:32 2580 Toolkit
>> d1b603c3.0 already in repository 03/14/06 15:49:32 2580 Toolkit
>> f18fa857.0 already in repository 03/14/06 15:49:32 2580 Toolkit
>> toolkit.py:456 INFO Marking cert as CA cert 03/14/06 15:49:33 2580
>> 03/14/06 15:49:33 2580 Toolkit toolkit.py:478 DEBUG Init'ing
>> globus. 03/14/06 15:49:33 2580 CertificateManager
>> certificatemanager.py:827 DEBUG Using default identity /O=Access
>> 15:49:33 2580 CertificateManager certificatemanager.py:1083 DEBUG
>> Initializing environment with unencrypted cert /O=Access
>> 15:49:33 2580 CertificateManager certificatemanager.py:1098 INFO
>> Setting permissions on certificate C:\Documents and
>> to 644 03/14/06 15:49:33 2580 CertificateManager
>> to 600 03/14/06 15:49:33 2580 CertificateManagerWXGUI
>> 15:49:33 2580 Toolkit toolkit.py:482 DEBUG Done with globus.
>> 03/14/06 15:49:33 2580 Toolkit venueclient.py:83 INFO wx version
>> is: 2.5.1.5 03/14/06 15:49:33 2580 VenueClient
>> venueclient.py:287 DEBUG __StartWebService: venueclient:
>> https://SCV-BADTZ.ad.bu.edu:11000/VenueClient 03/14/06 15:49:33 2580
>> ServiceManager agservicemanager.py:75 INFO Using services dir:
>> Data\AccessGrid\local_services 03/14/06 15:49:33 2580 ServiceManager
>> agservicemanager.py:424 INFO __DiscoverResources 03/14/06 15:49:33
>> 2580 Toolkit config.py:997 INFO Using vfwscan to get devices
>> 03/14/06 15:49:33 2580 Toolkit config.py:998 DEBUG vfwscanexe =
>> C:\PROGRA~1\AGTk-2.4\bin\vfwscan.exe 03/14/06 15:49:33 2580 Toolkit
>> (Win32)\n'] 03/14/06 15:49:33 2580 Toolkit config.py:1031 INFO
>> 15:49:33 2580 VenueClient venueclient.py:296 DEBUG
>> https://SCV-BADTZ.ad.bu.edu:11000/ServiceManager 03/14/06 15:49:33
>> 2580 NodeService agnodeservice.py:756 INFO
>> NodeService.__ReadConfigFile 03/14/06 15:49:33 2580 Toolkit
>> toolkit.py:335 DEBUG Looking for: C:\Documents and
>> Settings\jtvh\Application Data\AccessGrid\Config\AGNodeService.cfg
>> 03/14/06 15:49:33 2580 Toolkit toolkit.py:340 DEBUG Looking for:
>> C:\Program Files\AGTk-2.4\Config\AGNodeService.cfg 03/14/06 15:49:33
>> 2580 NodeService agnodeservice.py:764 DEBUG DEFAULT NODE SERVICE
>> 15:49:33 2580 NodeService agnodeservice.py:768 INFO Reading node
>> Files\AGTk-2.4\Config\AGNodeService.cfg 03/14/06 15:49:33 2580
>> 15:49:33 2580 VenueClient venueclient.py:1328 DEBUG SerNodeUrl:
>> 03/14/06 15:49:33 2580 NodeService agnodeservice.py:698 INFO
>> NodeService.GetDefaultConfiguration 03/14/06 15:49:33 2580
>> 03/14/06 15:49:33 2580 NodeService agnodeservice.py:374 INFO
>> NodeService.LoadDefaultConfig 03/14/06 15:49:33 2580 NodeService
>> defaultWindows 03/14/06 15:49:33 2580 NodeService
>> 15:49:33 2580 NodeService agnodeservice.py:407 INFO Trying to
>> Data\AccessGrid\Config\nodeConfig\defaultWindows 03/14/06 15:49:33
>> 2580 NodeService agnodeservice.py:480 INFO AddServiceManager:
>> 03/14/06 15:49:33 2580 NodeService agnodeservice.py:381 ERROR
>> last): File
>> 15:49:33 2580 VenueClient venueclient.py:313 ERROR Error loading
>> <defaultWindows> 03/14/06 15:49:33 2580 VenueClient
>> personalDataStore and port 0 03/14/06 15:49:33 2580 DataStore
>> datastore.py:1537 DEBUG Creating thread 0 03/14/06 15:49:33 2580
>> 15:49:33 2256 DataStore datastore.py:1550 DEBUG Worker 0 starting
>> 03/14/06 15:49:33 2580 DataStore datastore.py:1544 DEBUG Waiting
>> thread 0 03/14/06 15:49:33 2580 DataStore datastore.py:1547
>> DEBUG Done creating workers 03/14/06 15:49:33 2580 DataStore
>> 15:49:33 2580 VenueClient venueclient.py:210 DEBUG
>> 15:49:33 2580 VenueClientController venueclientcontroller.py:1255
>> DEBUG There is no personal venues file to load. 03/14/06 15:49:49
>> 2580 VenueClient venueclient.py:805 DEBUG EnterVenue;
>> url=https://vv2.mcs.anl.gov:9000/Venues/default 03/14/06 15:49:49
>> 2580 VenueClient venueclient.py:833 INFO EnterVenue: Error
>> getting node capabilities 03/14/06 15:49:49 2580 VenueClient
>> venueclient.py:705 DEBUG EnterVenue: Invoke venue enter 03/14/06
>> 15:49:49 2580 VenueClient venueclient.py:866 ERROR EnterVenue:
>> "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line 837,
>> in EnterVenue self.__EnterVenue(URL) File
>> "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line 706,
>> in __EnterVenue (venueState, self.privateId, self.streamDescList ) =
>> self.__venueProxy.Enter( self.profile ) File
>> "C:\Python23\Lib\site-packages\AccessGrid\Venue.py", line 3499, in
>> Enter (r1, r2, r3) = self.proxy.Enter(profile) File
>> "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 453, in
>> __call__ return self.__r_call(*args, **kw) File
>> "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 475, in
>> __r_call self.__hd, self.__ma) File
>> "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 338, in __call
>> config = self.config, noroot = self.noroot) File
>> "C:\Python23\Lib\site-packages\SOAPpy\SOAPBuilder.py", line 620, in
>> buildSOAP return t.build() File
>> "C:\Python23\Lib\site-packages\SOAPpy\SOAPBuilder.py", line 118, in
>> build body_ns = self.genns(ns_map, NS.ENV)[0] File
>> "C:\Python23\Lib\site-packages\SOAPpy\SOAPBuilder.py", line 204, in
>> genns if type(nsURI) == TupleType: # already a tuple NameError:
>> global name 'TupleType' is not defined 03/14/06 15:49:49 2580
>> VenueClient venueclientui.py:1925 DEBUG
>> bin.VenueClient::EnterVenue: Enter venue with url:
>> https://vv2.mcs.anl.gov:9000/Venues/default 03/14/06 15:49:49 2580
>> VenueClient venueclientui.py:1938 DEBUG warningString: 03/14/06
>> 15:49:55 2580 CertificateRepository certificaterepository.py:592
>> DEBUG Register observer <bound method ProxyBrowser.OnRepoUpdate of
>> <AccessGrid.Security.wxgui.ProxyBrowser.ProxyBrowser; proxy of C++
>> wxPanel instance at _c04ed701_p_wxPanel>> 03/14/06 15:49:55 2580
>> CertificateRepository certificaterepository.py:594 DEBUG Adding
>> <weakref at 0212F1B0; to 'instancemethod' at 020D8E40 (OnRepoUpdate)>
>> 03/14/06 15:49:55 2580 CertificateRepository
>> certificaterepository.py:592 DEBUG Register observer <bound method
>> IdentityBrowser.OnRepoUpdate of
>> <AccessGrid.Security.wxgui.IdentityBrowser.IdentityBrowser; proxy of
>> C++ wxPanel instance at _b073e301_p_wxPanel>> 03/14/06 15:49:55 2580
>> <weakref at 0212F480; to 'instancemethod' at 020D8D28 (OnRepoUpdate)>
>> CABrowser.OnRepoUpdate of
>> <AccessGrid.Security.wxgui.CABrowser.CABrowser; proxy of C++ wxPanel
>> instance at _90c10f02_p_wxPanel>> 03/14/06 15:49:55 2580
>> <weakref at 0212F690; to 'instancemethod' at 0211BF08 (OnRepoUpdate)>
>> CertificateStatusBrowser.OnRepoUpdate of
>> <AccessGrid.Security.wxgui.CertificateStatusBrowser.CertificateStatusBrowser;
>> proxy of C++ wxPanel instance at _18fe0f02_p_wxPanel>> 03/14/06
>> 15:49:55 2580 CertificateRepository certificaterepository.py:594
>> DEBUG Adding <weakref at 0212FA50; to 'instancemethod' at 02131260
>> (OnRepoUpdate)> 03/14/06 16:07:01 2428 Toolkit config.py:214
>> 16:07:01 2428 CertificateManager certificatemanager.py:269 DEBUG
>> Opened repository C:\Documents and Settings\jtvh\Application
>> Data\AccessGrid\Config\certRepo 03/14/06 16:07:02 2428 Toolkit
>> Files\AGTk-2.4\Config\CAcertificates 03/14/06 16:07:02 2428 Toolkit
>> 03/14/06 16:07:02 2428 Toolkit toolkit.py:440 INFO Certificate
>> 1c3f2ca8.0 already in repository 03/14/06 16:07:02 2428 Toolkit
>> toolkit.py:456 INFO Marking cert as CA cert 03/14/06 16:07:02 2428
>> 03/14/06 16:07:02 2428 Toolkit toolkit.py:418 INFO C:\Program
>> 45cc9e80.0 already in repository 03/14/06 16:07:02 2428 Toolkit
>> d1b603c3.0 already in repository 03/14/06 16:07:02 2428 Toolkit
>> f18fa857.0 already in repository 03/14/06 16:07:02 2428 Toolkit
>> toolkit.py:456 INFO Marking cert as CA cert 03/14/06 16:07:03 2428
>> 03/14/06 16:07:03 2428 Toolkit toolkit.py:478 DEBUG Init'ing
>> globus. 03/14/06 16:07:03 2428 CertificateManager
>> 16:07:03 2428 CertificateManager certificatemanager.py:1083 DEBUG
>> 16:07:03 2428 CertificateManager certificatemanager.py:1098 INFO
>> to 644 03/14/06 16:07:03 2428 CertificateManager
>> to 600 03/14/06 16:07:03 2428 CertificateManagerWXGUI
>> 16:07:03 2428 Toolkit toolkit.py:482 DEBUG Done with globus.
>> 03/14/06 16:07:03 2428 Toolkit venueclient.py:83 INFO wx version
>> is: 2.5.1.5 03/14/06 16:07:03 2428 VenueClient
>> https://SCV-BADTZ.ad.bu.edu:11000/VenueClient 03/14/06 16:07:03 2428
>> Data\AccessGrid\local_services 03/14/06 16:07:03 2428 ServiceManager
>> agservicemanager.py:424 INFO __DiscoverResources 03/14/06 16:07:03
>> 2428 Toolkit config.py:997 INFO Using vfwscan to get devices
>> 03/14/06 16:07:03 2428 Toolkit config.py:998 DEBUG vfwscanexe =
>> C:\PROGRA~1\AGTk-2.4\bin\vfwscan.exe 03/14/06 16:07:05 2428 Toolkit
>> (Win32)\n'] 03/14/06 16:07:05 2428 Toolkit config.py:1031 INFO
>> 16:07:05 2428 VenueClient venueclient.py:296 DEBUG
>> https://SCV-BADTZ.ad.bu.edu:11000/ServiceManager 03/14/06 16:07:05
>> 2428 NodeService agnodeservice.py:756 INFO
>> NodeService.__ReadConfigFile 03/14/06 16:07:05 2428 Toolkit
>> 03/14/06 16:07:05 2428 Toolkit toolkit.py:340 DEBUG Looking for:
>> C:\Program Files\AGTk-2.4\Config\AGNodeService.cfg 03/14/06 16:07:05
>> 2428 NodeService agnodeservice.py:764 DEBUG DEFAULT NODE SERVICE
>> 16:07:05 2428 NodeService agnodeservice.py:768 INFO Reading node
>> Files\AGTk-2.4\Config\AGNodeService.cfg 03/14/06 16:07:05 2428
>> 16:07:05 2428 VenueClient venueclient.py:1328 DEBUG SerNodeUrl:
>> 03/14/06 16:07:05 2428 NodeService agnodeservice.py:698 INFO
>> NodeService.GetDefaultConfiguration 03/14/06 16:07:05 2428
>> 03/14/06 16:07:05 2428 NodeService agnodeservice.py:374 INFO
>> NodeService.LoadDefaultConfig 03/14/06 16:07:05 2428 NodeService
>> defaultWindows 03/14/06 16:07:05 2428 NodeService
>> 16:07:05 2428 NodeService agnodeservice.py:407 INFO Trying to
>> Data\AccessGrid\Config\nodeConfig\defaultWindows 03/14/06 16:07:05
>> 2428 NodeService agnodeservice.py:480 INFO AddServiceManager:
>> 03/14/06 16:07:05 2428 NodeService agnodeservice.py:381 ERROR
>> last): File
>> 16:07:05 2428 VenueClient venueclient.py:313 ERROR Error loading
>> <defaultWindows> 03/14/06 16:07:05 2428 VenueClient
>> personalDataStore and port 0 03/14/06 16:07:05 2428 DataStore
>> datastore.py:1537 DEBUG Creating thread 0 03/14/06 16:07:05 2428
>> 16:07:05 4036 DataStore datastore.py:1550 DEBUG Worker 0 starting
>> 03/14/06 16:07:05 2428 DataStore datastore.py:1544 DEBUG Waiting
>> thread 0 03/14/06 16:07:05 2428 DataStore datastore.py:1547
>> DEBUG Done creating workers 03/14/06 16:07:05 2428 DataStore
>> 16:07:05 2428 VenueClient venueclient.py:210 DEBUG
>> 16:07:05 2428 VenueClientController venueclientcontroller.py:1255
>> DEBUG There is no personal venues file to load. 03/14/06 16:07:15
>> 2428 CertificateRepository certificaterepository.py:592 DEBUG
>> wxPanel instance at _c04ed701_p_wxPanel>> 03/14/06 16:07:15 2428
>> <weakref at 020DA2D0; to 'instancemethod' at 020D8A30 (OnRepoUpdate)>
>> 03/14/06 16:07:15 2428 CertificateRepository
>> C++ wxPanel instance at _18dd1002_p_wxPanel>> 03/14/06 16:07:15 2428
>> <weakref at 020DA5A0; to 'instancemethod' at 020D8B98 (OnRepoUpdate)>
>> instance at _28c9f001_p_wxPanel>> 03/14/06 16:07:15 2428
>> <weakref at 020DA7B0; to 'instancemethod' at 020D8D78 (OnRepoUpdate)>
>> proxy of C++ wxPanel instance at _d009f101_p_wxPanel>> 03/14/06
>> 16:07:15 2428 CertificateRepository certificaterepository.py:594
>> DEBUG Adding <weakref at 020DAB70; to 'instancemethod' at 020D8FA8
>> (OnRepoUpdate)> 03/14/06 16:14:47 2428 CertificateRepository
>> certificaterepository.py:129 ERROR Could not open certificate file
>> 03/14/06 16:15:06 2428 CertificateRepository
>> certificaterepository.py:133 INFO Found valid cert, validKey=1
>> 03/14/06 16:15:07 2428 CertificateRepository
>> 03/14/06 16:15:11 2428 CertificateRepository
>> certificaterepository.py:741 ERROR load error Traceback (most recent
>> call last): File
>> "C:\Python23\Lib\site-packages\AccessGrid\Security\CertificateRepository.py",
>> line 738, in ImportCertificatePEM passphrase) Error: [('digital
>> envelope routines', 'EVP_DecryptFinal', 'bad decrypt'), ('PEM
>> routines', 'PEM_do_header', 'bad decrypt')] 03/14/06 16:15:11 2428
>> CertificateManagerWXGUI importexportutils.py:792 ERROR Import fails:
>> Incorrect passphrase. cert file S:\AG\jtvh\cert-exp-12-2006.pem
>> keyfile S:\AG\jtvh\cert-exp-12-2006.pem Traceback (most recent call
>> last): File
>> "C:\Python23\Lib\site-packages\AccessGrid\Security\wxgui\ImportExportUtils.py",
>> line 775, in ImportPEMIdentityCertificate certFile, keyFile, cb) File
>> "C:\Python23\Lib\site-packages\AccessGrid\Security\CertificateManager.py",
>> line 465, in ImportIdentityCertificatePEM impCert =
>> repo.ImportCertificatePEM(userCert, userKey, passphraseCB) File
>> line 742, in ImportCertificatePEM raise RepoBadPassphrase
>> RepoBadPassphrase 03/14/06 16:15:16 2428 CertificateRepository
>> 03/14/06 16:15:19 2428 CertificateRepository
>> 03/14/06 16:15:21 2428 CertificateRepository
>> 03/14/06 16:15:24 2428 CertificateRepository
>> certificaterepository.py:952 INFO _ImportPrivateKey importing pkey
>> Data\AccessGrid\Config\certRepo\privatekeys\b6ea2d1e21eb850bef7b799ce043d5e9.pem
>> Data\AccessGrid\Config\certRepo\certificates\9469dc4861d79549ca6a9e6a2ed4909f\7fd839972fa295d09928e28808b848ea
>> 03/14/06 16:15:25 2428 CertificateManagerWXGUI
>> importexportutils.py:776 DEBUG Imported identity /O=Access
>> Grid/OU=agdev-ca.mcs.anl.gov/OU=bu.edu/CN=Jennifer Teig von Hoffman
>> importexportutils.py:834 DEBUG ID certs:
>> [<AccessGrid.Security.CertificateRepository.CertificateDescriptor
>> instance at 0x02132918>] 03/14/06 16:15:25 2428 CertificateManager
>> 16:15:25 2428 CertificateManager certificatemanager.py:1083 DEBUG
>> 16:15:25 2428 CertificateManager certificatemanager.py:1098 INFO
>> to 644 03/14/06 16:15:25 2428 CertificateManager
>> to 600 03/14/06 16:15:30 2428 CertificateManager
>> certificatemanager.py:902 DEBUG Initializing environment with proxy
>> cert for /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=bu.edu/CN=Jennifer
>> Teig von Hoffman 03/14/06 16:15:30 2428 CertificateManager
>> certificatemanager.py:968 DEBUG _VerifyGlobusProxy: file
>> C:\DOCUME~1\jtvh\LOCALS~1\Temp\proxy not found 03/14/06 16:15:40 2428
>> CertificateManagerWXGUI certificatemanagerwxgui.py:550 DEBUG Proxy
>> successfully created 03/14/06 16:15:40 2428 CertificateManager
>> Teig von Hoffman 03/14/06 16:15:40 2428 CertificateManager
>> certificatemanager.py:1011 INFO Verifying local proxy cert 03/14/06
>> 16:15:40 2428 CertificateManager certificatemanager.py:921 DEBUG
>> Configuring for user proxy issued from /O=Access
>> certificatemanager.py:924 DEBUG Proxy
>> C:\DOCUME~1\jtvh\LOCALS~1\Temp\proxy will expire 03/15/06 05:15:40
>> 03/14/06 16:15:40 2428 CertificateManagerWXGUI
>> 16:18:36 2428 VenueClient venueclient.py:805 DEBUG EnterVenue;
>> url=https://vv2.mcs.anl.gov:9000/Venues/default 03/14/06 16:18:36
>> 2428 CertificateManager certificatemanager.py:1011 INFO
>> Verifying local proxy cert 03/14/06 16:18:36 2428 CertificateManager
>> certificatemanager.py:663 DEBUG HaveValidProxy: found proxy ident
>> /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=bu.edu/CN=Jennifer Teig von
>> Hoffman/CN=proxy 03/14/06 16:18:36 2428 CertificateManager
>> 16:18:36 2428 CertificateManager certificatemanager.py:663 DEBUG
>> HaveValidProxy: found proxy ident /O=Access
>> Hoffman/CN=proxy 03/14/06 16:18:36 2428 VenueClient
>> venueclient.py:833 INFO EnterVenue: Error getting node capabilities
>> 03/14/06 16:18:36 2428 VenueClient venueclient.py:705 DEBUG
>> EnterVenue: Invoke venue enter 03/14/06 16:18:36 2428 VenueClient
>> venueclient.py:866 ERROR EnterVenue: failed Traceback (most recent
>> call last): File
>> global name 'TupleType' is not defined 03/14/06 16:18:36 2428
>> https://vv2.mcs.anl.gov:9000/Venues/default 03/14/06 16:18:36 2428
>> 16:18:42 2428 VenueClient venueclient.py:1343 INFO Error enabling
>> video 03/14/06 16:18:44 2428 VenueClient venueclient.py:1349 INFO
>> Error enabling audio 03/14/06 16:19:06 2428 VenueClient
>> 16:19:06 2428 DataStore datastore.py:1614 DEBUG Quitting thread 0
>> 03/14/06 16:19:06 4036 DataStore datastore.py:1555 DEBUG Worker
>> 0 gets cmd quit 03/14/06 16:19:06 4036 DataStore
>> datastore.py:1568 DEBUG Worker 0 exiting 03/14/06 16:19:06 4032
>> 03/14/06 16:19:06 2428 NodeService agnodeservice.py:136 INFO
>> NodeService.Stop 03/14/06 16:19:06 2428 ServiceManager
>> 16:19:06 2428 ServiceManager agservicemanager.py:85 INFO Remove
>> services 03/14/06 16:19:06 2428 ServiceManager
>> 16:19:06 2428 ServiceManager agservicemanager.py:87 INFO Stop
>> network interface 03/14/06 16:19:06 2084 Hosting server.py:65
>> last): File
>> 03/14/06 16:19:06 2428 Hosting server.py:97 ERROR server_close()
>> as argument 1 to globus_io_register_close 03/14/06 16:19:06 2428
>> as argument 1 to globus_io_register_close 03/15/06 11:34:51 444
>> Toolkit config.py:214 DEBUG System hostname of SCV-BADTZ.ad.bu.edu
>> is valid 03/15/06 11:34:51 444 CertificateManager
>> certificatemanager.py:269 DEBUG Opened repository C:\Documents and
>> Settings\jtvh\Application Data\AccessGrid\Config\certRepo 03/15/06
>> 11:34:52 444 Toolkit toolkit.py:404 DEBUG looking in system ca
>> dir: C:\Program Files\AGTk-2.4\Config\CAcertificates 03/15/06
>> 11:34:52 444 Toolkit toolkit.py:418 INFO C:\Program
>> 03/15/06 11:34:52 444 Toolkit toolkit.py:440 INFO Certificate
>> 1c3f2ca8.0 already in repository 03/15/06 11:34:52 444 Toolkit
>> toolkit.py:456 INFO Marking cert as CA cert 03/15/06 11:34:52 444
>> 03/15/06 11:34:52 444 Toolkit toolkit.py:418 INFO C:\Program
>> 45cc9e80.0 already in repository 03/15/06 11:34:52 444 Toolkit
>> d1b603c3.0 already in repository 03/15/06 11:34:52 444 Toolkit
>> f18fa857.0 already in repository 03/15/06 11:34:52 444 Toolkit
>> 03/15/06 11:34:52 444 Toolkit toolkit.py:478 DEBUG Init'ing
>> globus. 03/15/06 11:34:53 444 CertificateManager
>> Teig von Hoffman 03/15/06 11:34:53 444 CertificateManager
>> certificatemanager.py:1011 INFO Verifying local proxy cert 03/15/06
>> 11:34:53 444 CertificateManager certificatemanager.py:1024 DEBUG
>> _VerifyGlobusProxy: proxy C:\DOCUME~1\jtvh\LOCALS~1\Temp\proxy expired
>> 03/15/06 11:35:01 444 CertificateManagerWXGUI
>> certificatemanagerwxgui.py:550 DEBUG Proxy successfully created
>> Teig von Hoffman 03/15/06 11:35:01 444 CertificateManager
>> 11:35:01 444 CertificateManager certificatemanager.py:921 DEBUG
>> C:\DOCUME~1\jtvh\LOCALS~1\Temp\proxy will expire 03/16/06 00:35:01
>> certificatemanagerwxgui.py:422 DEBUG done, success=1 03/15/06
>> 11:35:01 444 Toolkit toolkit.py:482 DEBUG Done with globus.
>> 03/15/06 11:35:01 444 Toolkit venueclient.py:83 INFO wx version
>> is: 2.5.1.5 03/15/06 11:35:01 444 VenueClient venueclient.py:287
>> https://SCV-BADTZ.ad.bu.edu:11000/VenueClient 03/15/06 11:35:01 444
>> Data\AccessGrid\local_services 03/15/06 11:35:01 444 ServiceManager
>> agservicemanager.py:424 INFO __DiscoverResources 03/15/06 11:35:01
>> 444 Toolkit config.py:997 INFO Using vfwscan to get devices
>> 03/15/06 11:35:01 444 Toolkit config.py:998 DEBUG vfwscanexe =
>> C:\PROGRA~1\AGTk-2.4\bin\vfwscan.exe 03/15/06 11:35:01 444 Toolkit
>> (Win32)\n'] 03/15/06 11:35:01 444 Toolkit config.py:1031 INFO
>> GetResources: ['Microsoft WDM Image Capture (Win32)'] 03/15/06
>> 11:35:01 444 VenueClient venueclient.py:296 DEBUG
>> https://SCV-BADTZ.ad.bu.edu:11000/ServiceManager 03/15/06 11:35:01
>> 444 NodeService agnodeservice.py:756 INFO
>> NodeService.__ReadConfigFile 03/15/06 11:35:01 444 Toolkit
>> 03/15/06 11:35:01 444 Toolkit toolkit.py:340 DEBUG Looking for:
>> C:\Program Files\AGTk-2.4\Config\AGNodeService.cfg 03/15/06 11:35:01
>> 444 NodeService agnodeservice.py:764 DEBUG DEFAULT NODE SERVICE
>> CONFIG: C:\Program Files\AGTk-2.4\Config\AGNodeService.cfg 03/15/06
>> 11:35:01 444 NodeService agnodeservice.py:768 INFO Reading node
>> Files\AGTk-2.4\Config\AGNodeService.cfg 03/15/06 11:35:01 444
>> service: https://SCV-BADTZ.ad.bu.edu:11000/NodeService 03/15/06
>> 11:35:01 444 VenueClient venueclient.py:1328 DEBUG SerNodeUrl:
>> 03/15/06 11:35:01 444 NodeService agnodeservice.py:698 INFO
>> NodeService.GetDefaultConfiguration 03/15/06 11:35:02 444 NodeService
>> agnodeservice.py:581 INFO Migration unnecessary 03/15/06 11:35:02 444
>> NodeService.LoadDefaultConfig 03/15/06 11:35:02 444 NodeService
>> defaultWindows 03/15/06 11:35:02 444 NodeService
>> agnodeservice.py:392 INFO NodeService.LoadConfiguration 03/15/06
>> 11:35:02 444 NodeService agnodeservice.py:407 INFO Trying to
>> Data\AccessGrid\Config\nodeConfig\defaultWindows 03/15/06 11:35:02
>> 444 NodeService agnodeservice.py:480 INFO AddServiceManager:
>> 03/15/06 11:35:02 444 NodeService agnodeservice.py:381 ERROR
>> last): File
>> Exception: Couldn't reach service manager: localhost:11000 03/15/06
>> 11:35:02 444 VenueClient venueclient.py:313 ERROR Error loading
>> <defaultWindows> 03/15/06 11:35:02 444 VenueClient
>> personalDataStore and port 0 03/15/06 11:35:02 444 DataStore
>> datastore.py:1537 DEBUG Creating thread 0 03/15/06 11:35:02 444
>> DataStore datastore.py:1542 DEBUG Starting thread 0 03/15/06
>> 11:35:02 284 DataStore datastore.py:1550 DEBUG Worker 0 starting
>> 03/15/06 11:35:02 444 DataStore datastore.py:1544 DEBUG Waiting
>> thread 0 03/15/06 11:35:02 444 DataStore datastore.py:1547 DEBUG
>> Done creating workers 03/15/06 11:35:02 444 DataStore
>> Data\AccessGrid\Config\personalDataStore\DataStore.dat 03/15/06
>> 11:35:02 444 VenueClient venueclient.py:210 DEBUG
>> __createPersonalDataStore: Load personal data from file 03/15/06
>> 11:35:02 444 VenueClientController venueclientcontroller.py:1255
>> DEBUG There is no personal venues file to load. 03/15/06 11:35:22 444
>> CertificateRepository certificaterepository.py:592 DEBUG Register
>> wxPanel instance at _c04ed701_p_wxPanel>> 03/15/06 11:35:22 444
>> <weakref at 020DB270; to 'instancemethod' at 020D6A58 (OnRepoUpdate)>
>> 03/15/06 11:35:22 444 CertificateRepository
>> C++ wxPanel instance at _d028de01_p_wxPanel>> 03/15/06 11:35:22 444
>> <weakref at 020DB540; to 'instancemethod' at 020D6AD0 (OnRepoUpdate)>
>> instance at _6886e301_p_wxPanel>> 03/15/06 11:35:22 444
>> <weakref at 020DB750; to 'instancemethod' at 020D6C38 (OnRepoUpdate)>
>> proxy of C++ wxPanel instance at _f003ef01_p_wxPanel>> 03/15/06
>> 11:35:22 444 CertificateRepository certificaterepository.py:594 DEBUG
>> Adding <weakref at 020DBB10; to 'instancemethod' at 020DF030
>> (OnRepoUpdate)> 03/15/06 11:35:43 444 VenueClient
>> url=https://vv2.mcs.anl.gov:9000/Venues/default 03/15/06 11:35:43 444
>> CertificateManager certificatemanager.py:1011 INFO Verifying
>> local proxy cert 03/15/06 11:35:43 444 CertificateManager
>> Hoffman/CN=proxy 03/15/06 11:35:43 444 CertificateManager
>> 11:35:43 444 CertificateManager certificatemanager.py:663 DEBUG
>> Hoffman/CN=proxy 03/15/06 11:35:43 444 VenueClient
>> 03/15/06 11:35:43 444 VenueClient venueclient.py:705 DEBUG
>> EnterVenue: Invoke venue enter 03/15/06 11:35:43 444 VenueClient
>> call last): File
>> global name 'TupleType' is not defined 03/15/06 11:35:43 444
>> VenueClient venueclientui.py:1938 DEBUG warningString: 03/15/06
>> 11:37:41 444 VenueClient venueclient.py:805 DEBUG EnterVenue;
>> url=https://venues.ncsa.uiuc.edu:9000/Venues/default 03/15/06
>> 11:37:41 444 CertificateManager certificatemanager.py:1011 INFO
>> Verifying local proxy cert 03/15/06 11:37:41 444 CertificateManager
>> Hoffman/CN=proxy 03/15/06 11:37:41 444 CertificateManager
>> 11:37:41 444 CertificateManager certificatemanager.py:663 DEBUG
>> Hoffman/CN=proxy 03/15/06 11:37:41 444 VenueClient
>> 03/15/06 11:37:41 444 VenueClient venueclient.py:705 DEBUG
>> EnterVenue: Invoke venue enter 03/15/06 11:37:41 444 VenueClient
>> call last): File
>> global name 'TupleType' is not defined 03/15/06 11:37:41 444
>> https://venues.ncsa.uiuc.edu:9000/Venues/default 03/15/06 11:37:41
>> 444 VenueClient venueclientui.py:1938 DEBUG warningString:
>> 03/15/06 11:39:38 444 VenueClient venueclientui.py:1565 INFO
>> --------- END VenueClient 03/15/06 11:39:38 444 DataStore
>> datastore.py:1614 DEBUG Quitting thread 0 03/15/06 11:39:38 284
>> DataStore datastore.py:1555 DEBUG Worker 0 gets cmd quit 03/15/06
>> 11:39:38 284 DataStore datastore.py:1568 DEBUG Worker 0 exiting
>> 03/15/06 11:39:38 444 NodeService agnodeservice.py:136 INFO
>> NodeService.Stop 03/15/06 11:39:38 444 ServiceManager
>> agservicemanager.py:84 INFO AGServiceManager.Shutdown 03/15/06
>> 11:39:38 444 ServiceManager agservicemanager.py:85 INFO Remove
>> services 03/15/06 11:39:38 444 ServiceManager
>> agservicemanager.py:389 INFO AGServiceManager.RemoveServices 03/15/06
>> 11:39:38 444 ServiceManager agservicemanager.py:87 INFO Stop
>> network interface 03/15/06 11:39:38 1732 DataStore
>> datastore.py:1627 INFO GSIHTTPTransferServer: GSITCPSocket,
>> interrupted I/O operation, most likely shutting down. 03/15/06
>> 11:39:38 3836 Hosting server.py:65 ERROR Exception in SOAP server
>> main loop Traceback (most recent call last): File
>> 03/15/06 11:39:38 444 Hosting server.py:97 ERROR server_close()
>> as argument 1 to globus_io_register_close 03/15/06 11:39:38 444
>> as argument 1 to globus_io_register_close 03/15/06 11:40:54 240
>> Toolkit toolkit.py:96 DEBUG Initializing AG Toolkit version 2.4
>> (build 1) 03/15/06 11:40:54 240 Toolkit toolkit.py:138 INFO
>> Logfile Name: VenueClient.log 03/15/06 11:40:54 240 Toolkit
>> config.py:196 DEBUG Using GLOBUS_HOSTNAME=SCV-BADTZ.ad.bu.edu as set
>> in the environment 03/15/06 11:40:54 240 CertificateManager
>> 11:40:54 240 Toolkit toolkit.py:404 DEBUG looking in system ca
>> 11:40:54 240 Toolkit toolkit.py:418 INFO C:\Program
>> 03/15/06 11:40:54 240 Toolkit toolkit.py:440 INFO Certificate
>> 1c3f2ca8.0 already in repository 03/15/06 11:40:54 240 Toolkit
>> toolkit.py:456 INFO Marking cert as CA cert 03/15/06 11:40:54 240
>> 03/15/06 11:40:54 240 Toolkit toolkit.py:418 INFO C:\Program
>> 45cc9e80.0 already in repository 03/15/06 11:40:54 240 Toolkit
>> d1b603c3.0 already in repository 03/15/06 11:40:54 240 Toolkit
>> f18fa857.0 already in repository 03/15/06 11:40:54 240 Toolkit
>> 03/15/06 11:40:54 240 Toolkit toolkit.py:478 DEBUG Init'ing
>> globus. 03/15/06 11:40:54 240 CertificateManager
>> Teig von Hoffman 03/15/06 11:40:54 240 CertificateManager
>> 11:40:54 240 CertificateManager certificatemanager.py:921 DEBUG
>> 03/15/06 11:40:54 240 CertificateManagerWXGUI
>> 11:40:54 240 Toolkit toolkit.py:482 DEBUG Done with globus.
>> 03/15/06 11:40:54 240 Toolkit venueclient.py:83 INFO wx version
>> is: 2.5.1.5 03/15/06 11:40:55 240 VenueClient venueclient.py:287
>> https://SCV-BADTZ.ad.bu.edu:11000/VenueClient 03/15/06 11:40:55 240
>> Data\AccessGrid\local_services 03/15/06 11:40:55 240 ServiceManager
>> agservicemanager.py:424 INFO __DiscoverResources 03/15/06 11:40:55
>> 240 Toolkit config.py:997 INFO Using vfwscan to get devices
>> 03/15/06 11:40:55 240 Toolkit config.py:998 DEBUG vfwscanexe =
>> C:\PROGRA~1\AGTk-2.4\bin\vfwscan.exe 03/15/06 11:40:55 240 Toolkit
>> (Win32)\n'] 03/15/06 11:40:55 240 Toolkit config.py:1031 INFO
>> 11:40:55 240 VenueClient venueclient.py:296 DEBUG
>> https://SCV-BADTZ.ad.bu.edu:11000/ServiceManager 03/15/06 11:40:55
>> 240 NodeService agnodeservice.py:756 INFO
>> NodeService.__ReadConfigFile 03/15/06 11:40:55 240 Toolkit
>> 03/15/06 11:40:55 240 Toolkit toolkit.py:340 DEBUG Looking for:
>> C:\Program Files\AGTk-2.4\Config\AGNodeService.cfg 03/15/06 11:40:55
>> 240 NodeService agnodeservice.py:764 DEBUG DEFAULT NODE SERVICE
>> 11:40:55 240 NodeService agnodeservice.py:768 INFO Reading node
>> Files\AGTk-2.4\Config\AGNodeService.cfg 03/15/06 11:40:55 240
>> 11:40:55 240 VenueClient venueclient.py:1328 DEBUG SerNodeUrl:
>> 03/15/06 11:40:55 240 NodeService agnodeservice.py:698 INFO
>> NodeService.GetDefaultConfiguration 03/15/06 11:40:55 240 NodeService
>> agnodeservice.py:581 INFO Migration unnecessary 03/15/06 11:40:55 240
>> NodeService.LoadDefaultConfig 03/15/06 11:40:55 240 NodeService
>> defaultWindows 03/15/06 11:40:55 240 NodeService
>> 11:40:55 240 NodeService agnodeservice.py:407 INFO Trying to
>> Data\AccessGrid\Config\nodeConfig\defaultWindows 03/15/06 11:40:55
>> 240 NodeService agnodeservice.py:480 INFO AddServiceManager:
>> 03/15/06 11:40:55 240 NodeService agnodeservice.py:381 ERROR
>> last): File
>> 11:40:55 240 VenueClient venueclient.py:313 ERROR Error loading
>> <defaultWindows> 03/15/06 11:40:55 240 VenueClient
>> personalDataStore and port 0 03/15/06 11:40:55 240 DataStore
>> datastore.py:1537 DEBUG Creating thread 0 03/15/06 11:40:55 240
>> 11:40:55 2996 DataStore datastore.py:1550 DEBUG Worker 0 starting
>> 03/15/06 11:40:55 240 DataStore datastore.py:1544 DEBUG Waiting
>> thread 0 03/15/06 11:40:55 240 DataStore datastore.py:1547 DEBUG
>> Done creating workers 03/15/06 11:40:55 240 DataStore
>> 11:40:55 240 VenueClient venueclient.py:210 DEBUG
>> 11:40:55 240 VenueClientController venueclientcontroller.py:1255
>> DEBUG There is no personal venues file to load. 03/15/06 11:40:55 240
>> 11:40:55 240 CertificateManager certificatemanager.py:1011 INFO
>> Verifying local proxy cert 03/15/06 11:40:55 240 CertificateManager
>> Hoffman/CN=proxy 03/15/06 11:40:55 240 CertificateManager
>> 11:40:55 240 CertificateManager certificatemanager.py:663 DEBUG
>> Hoffman/CN=proxy 03/15/06 11:40:55 240 VenueClient
>> 03/15/06 11:40:55 240 VenueClient venueclient.py:705 DEBUG
>> EnterVenue: Invoke venue enter 03/15/06 11:40:55 240 VenueClient
>> call last): File
>> global name 'TupleType' is not defined 03/15/06 11:40:55 240
>> https://venues.ncsa.uiuc.edu:9000/Venues/default 03/15/06 11:40:55
>> 240 VenueClient venueclientui.py:1938 DEBUG warningString:
>> 03/15/06 11:41:01 240 VenueClient venueclientui.py:1565 INFO
>> --------- END VenueClient 03/15/06 11:41:01 240 DataStore
>> datastore.py:1614 DEBUG Quitting thread 0 03/15/06 11:41:01 2996
>> 11:41:01 2996 DataStore datastore.py:1568 DEBUG Worker 0 exiting
>> 03/15/06 11:41:01 3376 DataStore datastore.py:1627 INFO
>> GSIHTTPTransferServer: GSITCPSocket, interrupted I/O operation, most
>> likely shutting down. 03/15/06 11:41:01 240 NodeService
>> agnodeservice.py:136 INFO NodeService.Stop 03/15/06 11:41:01 240
>> ServiceManager agservicemanager.py:84 INFO
>> AGServiceManager.Shutdown 03/15/06 11:41:01 240 ServiceManager
>> agservicemanager.py:85 INFO Remove services 03/15/06 11:41:01 240
>> ServiceManager agservicemanager.py:389 INFO
>> AGServiceManager.RemoveServices 03/15/06 11:41:01 240 ServiceManager
>> agservicemanager.py:87 INFO Stop network interface 03/15/06 11:41:01
>> 1340 Hosting server.py:65 ERROR Exception in SOAP server main
>> 03/15/06 11:41:01 240 Hosting server.py:97 ERROR server_close()
>> as argument 1 to globus_io_register_close 03/15/06 11:41:01 240
>> as argument 1 to globus_io_register_close 03/15/06 11:42:29 2300
>> SCV-BADTZ.ad.bu.edu is valid 03/15/06 11:42:29 2300
>> Data\AccessGrid\Config\certRepo 03/15/06 11:42:29 2300 Toolkit
>> Files\AGTk-2.4\Config\CAcertificates 03/15/06 11:42:29 2300 Toolkit
>> 03/15/06 11:42:29 2300 Toolkit toolkit.py:440 INFO Certificate
>> 1c3f2ca8.0 already in repository 03/15/06 11:42:29 2300 Toolkit
>> toolkit.py:456 INFO Marking cert as CA cert 03/15/06 11:42:29 2300
>> 03/15/06 11:42:29 2300 Toolkit toolkit.py:418 INFO C:\Program
>> 45cc9e80.0 already in repository 03/15/06 11:42:29 2300 Toolkit
>> d1b603c3.0 already in repository 03/15/06 11:42:29 2300 Toolkit
>> f18fa857.0 already in repository 03/15/06 11:42:29 2300 Toolkit
>> 03/15/06 11:42:29 2300 Toolkit toolkit.py:478 DEBUG Init'ing
>> globus. 03/15/06 11:42:29 2300 CertificateManager
>> Teig von Hoffman 03/15/06 11:42:29 2300 CertificateManager
>> 11:42:29 2300 CertificateManager certificatemanager.py:921 DEBUG
>> 03/15/06 11:42:29 2300 CertificateManagerWXGUI
>> 11:42:29 2300 Toolkit toolkit.py:482 DEBUG Done with globus.
>> 03/15/06 11:42:29 2300 Toolkit venueclient.py:83 INFO wx version
>> is: 2.5.1.5 03/15/06 11:42:29 2300 VenueClient
>> https://SCV-BADTZ.ad.bu.edu:11000/VenueClient 03/15/06 11:42:29 2300
>> Data\AccessGrid\local_services 03/15/06 11:42:29 2300 ServiceManager
>> agservicemanager.py:424 INFO __DiscoverResources 03/15/06 11:42:29
>> 2300 Toolkit config.py:997 INFO Using vfwscan to get devices
>> 03/15/06 11:42:29 2300 Toolkit config.py:998 DEBUG vfwscanexe =
>> C:\PROGRA~1\AGTk-2.4\bin\vfwscan.exe 03/15/06 11:42:30 2300 Toolkit
>> (Win32)\n'] 03/15/06 11:42:30 2300 Toolkit config.py:1031 INFO
>> 11:42:30 2300 VenueClient venueclient.py:296 DEBUG
>> https://SCV-BADTZ.ad.bu.edu:11000/ServiceManager 03/15/06 11:42:30
>> 2300 NodeService agnodeservice.py:756 INFO
>> NodeService.__ReadConfigFile 03/15/06 11:42:30 2300 Toolkit
>> 03/15/06 11:42:30 2300 Toolkit toolkit.py:340 DEBUG Looking for:
>> C:\Program Files\AGTk-2.4\Config\AGNodeService.cfg 03/15/06 11:42:30
>> 2300 NodeService agnodeservice.py:764 DEBUG DEFAULT NODE SERVICE
>> 11:42:30 2300 NodeService agnodeservice.py:768 INFO Reading node
>> Files\AGTk-2.4\Config\AGNodeService.cfg 03/15/06 11:42:30 2300
>> 11:42:30 2300 VenueClient venueclient.py:1328 DEBUG SerNodeUrl:
>> 03/15/06 11:42:30 2300 NodeService agnodeservice.py:698 INFO
>> NodeService.GetDefaultConfiguration 03/15/06 11:42:30 2300
>> 03/15/06 11:42:30 2300 NodeService agnodeservice.py:374 INFO
>> NodeService.LoadDefaultConfig 03/15/06 11:42:30 2300 NodeService
>> defaultWindows 03/15/06 11:42:30 2300 NodeService
>> 11:42:30 2300 NodeService agnodeservice.py:407 INFO Trying to
>> Data\AccessGrid\Config\nodeConfig\defaultWindows 03/15/06 11:42:30
>> 2300 NodeService agnodeservice.py:480 INFO AddServiceManager:
>> 03/15/06 11:42:30 2300 NodeService agnodeservice.py:381 ERROR
>> last): File
>> 11:42:30 2300 VenueClient venueclient.py:313 ERROR Error loading
>> <defaultWindows> 03/15/06 11:42:30 2300 VenueClient
>> personalDataStore and port 0 03/15/06 11:42:30 2300 DataStore
>> datastore.py:1537 DEBUG Creating thread 0 03/15/06 11:42:30 2300
>> 11:42:30 1608 DataStore datastore.py:1550 DEBUG Worker 0 starting
>> 03/15/06 11:42:30 2300 DataStore datastore.py:1544 DEBUG Waiting
>> thread 0 03/15/06 11:42:30 2300 DataStore datastore.py:1547
>> DEBUG Done creating workers 03/15/06 11:42:30 2300 DataStore
>> 11:42:30 2300 VenueClient venueclient.py:210 DEBUG
>> 11:42:30 2300 VenueClientController venueclientcontroller.py:1255
>> DEBUG There is no personal venues file to load. 03/15/06 11:42:37
>> 2300 VenueClient venueclient.py:805 DEBUG EnterVenue;
>> url=https://vv2.mcs.anl.gov:9000/Venues/default 03/15/06 11:42:37
>> 2300 CertificateManager certificatemanager.py:1011 INFO
>> Verifying local proxy cert 03/15/06 11:42:37 2300 CertificateManager
>> Hoffman/CN=proxy 03/15/06 11:42:37 2300 CertificateManager
>> 11:42:37 2300 CertificateManager certificatemanager.py:663 DEBUG
>> Hoffman/CN=proxy 03/15/06 11:42:37 2300 VenueClient
>> 03/15/06 11:42:37 2300 VenueClient venueclient.py:705 DEBUG
>> EnterVenue: Invoke venue enter 03/15/06 11:42:37 2300 VenueClient
>> call last): File
>> global name 'TupleType' is not defined 03/15/06 11:42:37 2300
>> https://vv2.mcs.anl.gov:9000/Venues/default 03/15/06 11:42:37 2300
>> 11:45:42 2300 VenueClient venueclientui.py:1565 INFO --------- END
>> VenueClient 03/15/06 11:45:42 2300 DataStore datastore.py:1614
>> DEBUG Quitting thread 0 03/15/06 11:45:42 1608 DataStore
>> datastore.py:1555 DEBUG Worker 0 gets cmd quit 03/15/06 11:45:42 1608
>> DataStore datastore.py:1568 DEBUG Worker 0 exiting 03/15/06
>> 11:45:42 3752 DataStore datastore.py:1627 INFO
>> likely shutting down. 03/15/06 11:45:42 2300 NodeService
>> agnodeservice.py:136 INFO NodeService.Stop 03/15/06 11:45:42 2300
>> AGServiceManager.Shutdown 03/15/06 11:45:42 2300 ServiceManager
>> agservicemanager.py:85 INFO Remove services 03/15/06 11:45:42 2300
>> AGServiceManager.RemoveServices 03/15/06 11:45:42 2300 ServiceManager
>> agservicemanager.py:87 INFO Stop network interface 03/15/06 11:45:42
>> 1120 Hosting server.py:65 ERROR Exception in SOAP server main
>> 03/15/06 11:45:42 2300 Hosting server.py:97 ERROR server_close()
>> as argument 1 to globus_io_register_close 03/15/06 11:45:42 2300
Andrew Patrick, Ph.D.
Senior Scientist
Information Security Group, Institute for Information Technology
National Research Council (NRC), Ottawa, Canada
E-mail: Andrew.Patrick at nrc-cnrc.gc.ca
WWW - NRC: http://iit-iti.nrc-cnrc.gc.ca
WWW - Personal: http://www.andrewpatrick.ca
Phone: (613) 991-3374 Fax: (613) 952-7151 Cell/SMS: (613) 277-9211
