[AG-TECH] Re: cannot connect to venue on new PIG
Jennifer Teig von Hoffman
jtvh at bu.edu
Thu Mar 16 09:56:39 CST 2006
Tom Uram worked with me yesterday, and here are the steps we took to resolve the issue (summarized here to reduce your spam burden):
* I removed the PYTHONCASEOK environment variable
* I discovered that another version of ActivePython was installed in addition to the appropriate ActivePython AG prerequisite, so I removed all versions of ActivePython and re-installed only the one I needed
* We determined that I can run the VenueClient from the command line in a command window in which the PYTHONPATH variable has been set to null.
So, quoting from Tom, here are my options:
> - unset the PYTHONPATH env var in the control panel, System, Env
> Vars., which will likely prevent the IBM support tools from running.
> - each time you want to use the AG, unset the PYTHONPATH env var in a
> command window, and then run the VenueClient as you did just now.
I plan to use the second option.
- Jennifer
Jennifer Teig von Hoffman wrote:
> Hi all,
> I've just migrated to a new laptop and installed AG 2.4. I've
> imported my (valid) certificate, and can successfully make a proxy.
> However, I cannot connect to a venue. When I try to connect, I get
> the standard "Can not connect to venue located at
> https://vvw.mcs.anl.gov:9000/Venues/default. Please try again." error
> message. I've tried to connect to both the address above, and
> venues.ncsa.uiuc.edu.
> I wonder if my laptop may be in a strange state -- I used the Lenovo
> migration assistant when switching over to the new hardware, and
> generally speaking it has been inconsistent about what settings/etc
> it's carried over from the old machine. I installed AG 2.4 *after*
> migration, so theoretically it shouldn't have taken any of the
> AG-related settings, but nonetheless the Lenovo experience has
> overall been quite mixed and I wonder if it may be the issue here.
> My entire VenueClient.log is below. Any suggestions?
> Cheers, Jennifer
> 03/14/06 15:43:06 824 Toolkit config.py:364 ERROR Couldn't
> retrieve globus key from registry. Traceback (most recent call last):
> File
> "C:\Python23\Lib\site-packages\AccessGrid\Platform\win32\Config.py",
> line 362, in GetGlobusKey "Software\Globus", 0,
> _winreg.KEY_SET_VALUE) WindowsError: [Errno 2] The system cannot find
> the file specified 03/14/06 15:43:06 824 Toolkit config.py:214
> DEBUG System hostname of SCV-BADTZ.ad.bu.edu is valid 03/14/06
> 15:44:45 2840 Toolkit config.py:381 ERROR Couldn't retrieve gsi
> key from registry. Traceback (most recent call last): File
> line 378, in GetGlobusKey gsikey = _winreg.OpenKey(gkey, "GSI", 0,
> the file specified 03/14/06 15:44:45 2840 Toolkit config.py:214
> 15:44:45 2840 CertificateManager certificatemanager.py:297 DEBUG
> initializing repository 03/14/06 15:44:45 2840 CertificateManager
> certificatemanager.py:327 DEBUG Initializing from C:\Program
> Files\AGTk-2.4\Config\CAcertificates 03/14/06 15:44:45 2840
> CertificateManager certificatemanager.py:340 WARNING Didn't find
> certficate in old globus path: C:\Documents and
> Settings\jtvh\Application Data\globus\usercert.pem 03/14/06 15:44:45
> 2840 CertificateManager certificatemanager.py:416 INFO
> C:\Program Files\AGTk-2.4\Config\CAcertificates\1c3f2ca8.0 might be a
> cert 03/14/06 15:44:45 2840 CertificateRepository
> certificaterepository.py:889 DEBUG _ImportCertificate: create
> C:\Documents and Settings\jtvh\Application
> Data\AccessGrid\Config\certRepo\certificates\a82c3f1c4b096b896061778ee79efeff\9c8df64aa35ebf832613413527bc073d
> 03/14/06 15:44:46 2840 CertificateRepository
> certificaterepository.py:1615 DEBUG GetFilePath: create C:\Documents
> Data\AccessGrid\Config\certRepo\certificates\a82c3f1c4b096b896061778ee79efeff\9c8df64aa35ebf832613413527bc073d\user_files
> 03/14/06 15:44:46 2840 CertificateManager
> certificatemanager.py:441 INFO Imported cert as 1c3f2ca8.0 03/14/06
> 15:44:46 2840 CertificateManager certificatemanager.py:416 INFO
> C:\Program Files\AGTk-2.4\Config\CAcertificates\45cc9e80.0 might be a
> cert 03/14/06 15:44:46 2840 CertificateRepository
> Data\AccessGrid\Config\certRepo\certificates\809ecc45460c1482e61e26bdfbf9e18c\9f380c9a586af2bb913ace809d5badfe
> Data\AccessGrid\Config\certRepo\certificates\809ecc45460c1482e61e26bdfbf9e18c\9f380c9a586af2bb913ace809d5badfe\user_files
> certificatemanager.py:441 INFO Imported cert as 45cc9e80.0 03/14/06
> C:\Program Files\AGTk-2.4\Config\CAcertificates\d1b603c3.0 might be a
> Data\AccessGrid\Config\certRepo\certificates\c303b6d10c962b37482e68ca64d383a0\05a2039fe10ed1b4195d9f9d35b32c68
> Data\AccessGrid\Config\certRepo\certificates\c303b6d10c962b37482e68ca64d383a0\05a2039fe10ed1b4195d9f9d35b32c68\user_files
> certificatemanager.py:441 INFO Imported cert as d1b603c3.0 03/14/06
> C:\Program Files\AGTk-2.4\Config\CAcertificates\f18fa857.0 might be a
> Data\AccessGrid\Config\certRepo\certificates\57a88ff1707d87e926f2287c702a8466\eff65f03366cb8e20247f831ccc87fd5
> Data\AccessGrid\Config\certRepo\certificates\57a88ff1707d87e926f2287c702a8466\eff65f03366cb8e20247f831ccc87fd5\user_files
> certificatemanager.py:441 INFO Imported cert as f18fa857.0 03/14/06
> 15:44:46 2840 CertificateManager certificatemanager.py:1198
> WARNING No identity certs found 03/14/06 15:44:46 2840
> CertificateManager certificatemanager.py:1209 WARNING No default
> identity certificate found 03/14/06 15:44:46 2840 Toolkit
> toolkit.py:404 DEBUG looking in system ca dir: C:\Program
> Files\AGTk-2.4\Config\CAcertificates 03/14/06 15:44:46 2840 Toolkit
> toolkit.py:418 INFO C:\Program
> Files\AGTk-2.4\Config\CAcertificates\1c3f2ca8.0 might be a cert
> 03/14/06 15:44:46 2840 Toolkit toolkit.py:440 INFO Certificate
> 1c3f2ca8.0 already in repository 03/14/06 15:44:46 2840 Toolkit
> toolkit.py:456 INFO Marking cert as CA cert 03/14/06 15:44:46 2840
> Toolkit toolkit.py:469 INFO Imported signing policy as
> Data\AccessGrid\Config\certRepo\certificates\a82c3f1c4b096b896061778ee79efeff\9c8df64aa35ebf832613413527bc073d\user_files\signing_policy
> 03/14/06 15:44:46 2840 Toolkit toolkit.py:418 INFO C:\Program
> Files\AGTk-2.4\Config\CAcertificates\45cc9e80.0 might be a cert
> 45cc9e80.0 already in repository 03/14/06 15:44:46 2840 Toolkit
> Data\AccessGrid\Config\certRepo\certificates\809ecc45460c1482e61e26bdfbf9e18c\9f380c9a586af2bb913ace809d5badfe\user_files\signing_policy
> Files\AGTk-2.4\Config\CAcertificates\d1b603c3.0 might be a cert
> d1b603c3.0 already in repository 03/14/06 15:44:46 2840 Toolkit
> Data\AccessGrid\Config\certRepo\certificates\c303b6d10c962b37482e68ca64d383a0\05a2039fe10ed1b4195d9f9d35b32c68\user_files\signing_policy
> Files\AGTk-2.4\Config\CAcertificates\f18fa857.0 might be a cert
> f18fa857.0 already in repository 03/14/06 15:44:46 2840 Toolkit
> toolkit.py:456 INFO Marking cert as CA cert 03/14/06 15:44:47 2840
> Data\AccessGrid\Config\certRepo\certificates\57a88ff1707d87e926f2287c702a8466\eff65f03366cb8e20247f831ccc87fd5\user_files\signing_policy
> 03/14/06 15:44:47 2840 Toolkit toolkit.py:478 DEBUG Init'ing
> globus. 03/14/06 15:44:47 2840 CertificateManager
> certificatemanager.py:759 DEBUG Configuring standard environment
> certificatemanager.py:1198 WARNING No identity certs found 03/14/06
> 15:44:47 2840 CertificateManager certificatemanager.py:1209
> WARNING No default identity certificate found 03/14/06 15:44:47 2840
> CertificateManager certificatemanager.py:829 DEBUG No default
> identity found <type 'NoneType'> None 03/14/06 15:44:47 2840
> CertificateRepository certificaterepository.py:952 INFO
> _ImportPrivateKey importing pkey to C:\Documents and
> Data\AccessGrid\Config\certRepo\privatekeys\b82eff976e60282028802c8814e23901.pem
> 03/14/06 15:44:47 2840 CertificateRepository
> certificaterepository.py:918 INFO _ImportCertificateRequest writing
> to C:\Documents and Settings\jtvh\Application
> Data\AccessGrid\Config\certRepo\requests\b82eff976e60282028802c8814e23901.pem
> 03/14/06 15:44:47 2840 CRSClient crsclient.py:40 DEBUG create
> client 03/14/06 15:44:47 2840 CRSClient crsclient.py:73 DEBUG
> request certificate 03/14/06 15:44:49 2840 CertificateManager
> certificatemanager.py:1275 DEBUG CheckRequestedCertificate:
> req=<AccessGrid.Security.CertificateRepository.CertificateRequestDescriptor
> instance at 0x01F892D8>, token=267d22fbd98fcbd8bca067f7148e034a,
> server=http://www-unix.mcs.anl.gov/fl/research/accessgrid/ca/anonymous/anonReqServer.cgi
> 03/14/06 15:44:49 2840 CRSClient crsclient.py:40 DEBUG create
> client 03/14/06 15:44:49 2840 CRSClient crsclient.py:104 DEBUG
> retrieve certificate for token 267d22fbd98fcbd8bca067f7148e034a
> 03/14/06 15:44:49 2840 CRSClient crsclient.py:115 DEBUG retrieved
> certificate [1, '-----BEGIN
> CERTIFICATE-----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\ndGljYXRvcjANBgk
> qhkiG9w0BAQQFAAOCAQEALmC3il6vFPYI1PERDado53isFC8R\n0w1SXWv8skr9XZWw/Gbc2Lms9MgVn5PxN6aeSoRr30M0IOk/xYAObNWKRbyzTaaE\nle7xuILHPwEB7GaeHDr11gcRCU6cs1a+DwMEXTWb9nTyK3w6yYvE4ZuGaqJDnFFc\n4YCqiDx0XmJjqz5YDp7l6tn5j2PLF1WW3rGWATBAo+jjcGrCu/KzlI0RFAXANPWg\npTj/pOprcOinLUWr7XXos90NY91/vHmvFVP2mQqQPI7OwbqFiviAo8+dcC2/ozDj\nJkECJYzHJrYQFu5udPHajE2wTaYP7R6Nhn20D9PvD3cgSBv/AXXKSk0bwQ==\n-----END
> CERTIFICATE-----\n\n'] 03/14/06 15:44:49 2840 CertificateManager
> certificatemanager.py:1280 DEBUG Retrieve returns [1, '-----BEGIN
> GljYXRvcjANBgkqhkiG9w0BAQQFAAOCAQEALmC3il6vFPYI1PERDado53isFC8R\n0w1SXWv8skr9XZWw/Gbc2Lms9MgVn5PxN6aeSoRr30M0IOk/xYAObNWKRbyzTaaE\nle7xuILHPwEB7GaeHDr11gcRCU6cs1a+DwMEXTWb9nTyK3w6yYvE4ZuGaqJDnFFc\n4YCqiDx0XmJjqz5YDp7l6tn5j2PLF1WW3rGWATBAo+jjcGrCu/KzlI0RFAXANPWg\npTj/pOprcOinLUWr7XXos90NY91/vHmvFVP2mQqQPI7OwbqFiviAo8+dcC2/ozDj\nJkECJYzHJrYQFu5udPHajE2wTaYP7R6Nhn20D9PvD3cgSBv/AXXKSk0bwQ==\n-----END
> CERTIFICATE-----\n\n'] 03/14/06 15:44:49 2840 CertificateRepository
> certificaterepository.py:866 DEBUG Importing requested certificate
> subj=/O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab
> Anonymous Authority/CN=Anonymous User
> 4a250eb4e3231f2abbe3d4021c330646 path=C:\Documents and
> Data\AccessGrid\Config\certRepo\certificates\5cf11fcf8b5d698d7eb3ccdba1980efb\99514c538e7a32167c1699b16c025df4
> certificaterepository.py:867 DEBUG Modulus hash is
> b82eff976e60282028802c8814e23901 03/14/06 15:44:49 2840
> CertificateRepository certificaterepository.py:889 DEBUG
> _ImportCertificate: create C:\Documents and Settings\jtvh\Application
> 03/14/06 15:44:50 2840 CertificateManager
> certificatemanager.py:453 DEBUG imported requested cert /O=Access
> Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous
> Authority/CN=Anonymous User 4a250eb4e3231f2abbe3d4021c330646 03/14/06
> 15:44:50 2840 CertificateManager certificatemanager.py:759 DEBUG
> Configuring standard environment 03/14/06 15:44:50 2840
> CertificateManager certificatemanager.py:827 DEBUG Using default
> identity /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab
> 4a250eb4e3231f2abbe3d4021c330646 03/14/06 15:44:50 2840
> CertificateManager certificatemanager.py:1083 DEBUG Initializing
> environment with unencrypted cert /O=Access Grid/O=Argonne National
> Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User
> CertificateManager certificatemanager.py:1098 INFO Setting
> permissions on certificate C:\Documents and Settings\jtvh\Application
> Data\AccessGrid\Config\certRepo\certificates\5cf11fcf8b5d698d7eb3ccdba1980efb\99514c538e7a32167c1699b16c025df4\cert.pem
> to 644 03/14/06 15:44:50 2840 CertificateManager
> certificatemanager.py:1109 INFO Setting permissions on certificate
> to 600 03/14/06 15:44:50 2840 CertificateManagerWXGUI
> certificatemanagerwxgui.py:422 DEBUG done, success=1 03/14/06
> 15:44:50 2840 CertificateManagerWXGUI certificatemanagerwxgui.py:422
> DEBUG done, success=1 03/14/06 15:44:50 2840 Toolkit
> toolkit.py:482 DEBUG Done with globus. 03/14/06 15:44:50 2840 Toolkit
> venueclient.py:83 INFO wx version is: 2.5.1.5 03/14/06 15:44:50 2840
> VenueClient venueclient.py:287 DEBUG __StartWebService:
> venueclient: https://SCV-BADTZ.ad.bu.edu:11000/VenueClient 03/14/06
> 15:44:50 2840 ServiceManager agservicemanager.py:68 INFO Creating
> user services directory C:\Documents and Settings\jtvh\Application
> Data\AccessGrid\local_services 03/14/06 15:44:50 2840 ServiceManager
> agservicemanager.py:424 INFO __DiscoverResources 03/14/06 15:44:50
> 2840 Toolkit config.py:997 INFO Using vfwscan to get devices
> 03/14/06 15:44:50 2840 Toolkit config.py:998 DEBUG vfwscanexe =
> C:\PROGRA~1\AGTk-2.4\bin\vfwscan.exe 03/14/06 15:44:51 2840 Toolkit
> config.py:1003 DEBUG filelines = ['Microsoft WDM Image Capture
> (Win32)\n'] 03/14/06 15:44:51 2840 Toolkit config.py:1031 INFO
> GetResources: ['Microsoft WDM Image Capture (Win32)'] 03/14/06
> 15:44:51 2840 VenueClient venueclient.py:296 DEBUG
> __StartWebService: service manager:
> https://SCV-BADTZ.ad.bu.edu:11000/ServiceManager 03/14/06 15:44:51
> 2840 NodeService agnodeservice.py:115 INFO Copying system node
> configs to user node config dir 03/14/06 15:44:51 2840 NodeService
> agnodeservice.py:116 INFO system node config = C:\Program
> Files\AGTk-2.4\Config\nodeConfig 03/14/06 15:44:51 2840 NodeService
> agnodeservice.py:117 INFO user node config = C:\Documents and
> Settings\jtvh\Application Data\AccessGrid\Config\nodeConfig 03/14/06
> 15:44:51 2840 NodeService agnodeservice.py:120 INFO node
> config: defaultWindows 03/14/06 15:44:51 2840 NodeService
> agnodeservice.py:756 INFO NodeService.__ReadConfigFile 03/14/06
> 15:44:51 2840 Toolkit toolkit.py:335 DEBUG Looking for:
> Data\AccessGrid\Config\AGNodeService.cfg 03/14/06 15:44:51 2840
> Toolkit toolkit.py:340 DEBUG Looking for: C:\Program
> Files\AGTk-2.4\Config\AGNodeService.cfg 03/14/06 15:44:51 2840
> NodeService agnodeservice.py:764 DEBUG DEFAULT NODE SERVICE
> CONFIG: C:\Program Files\AGTk-2.4\Config\AGNodeService.cfg 03/14/06
> 15:44:51 2840 NodeService agnodeservice.py:768 INFO Reading node
> service config file: C:\Program
> VenueClient venueclient.py:302 DEBUG __StartWebService: node
> service: https://SCV-BADTZ.ad.bu.edu:11000/NodeService 03/14/06
> 15:44:51 2840 VenueClient venueclient.py:1328 DEBUG SerNodeUrl:
> Set node service url: https://SCV-BADTZ.ad.bu.edu:11000/NodeService
> 03/14/06 15:44:51 2840 NodeService agnodeservice.py:698 INFO
> NodeService.GetDefaultConfiguration 03/14/06 15:44:51 2840
> NodeService agnodeservice.py:581 INFO Migration unnecessary
> 03/14/06 15:44:51 2840 NodeService agnodeservice.py:374 INFO
> NodeService.LoadDefaultConfig 03/14/06 15:44:51 2840 NodeService
> agnodeservice.py:378 INFO Loading default node configuration:
> agnodeservice.py:392 INFO NodeService.LoadConfiguration 03/14/06
> 15:44:51 2840 NodeService agnodeservice.py:407 INFO Trying to
> load node configuration from: C:\Documents and
> Data\AccessGrid\Config\nodeConfig\defaultWindows 03/14/06 15:44:51
> 2840 NodeService agnodeservice.py:480 INFO AddServiceManager:
> Invalid service manager url (https://localhost:11000/ServiceManager)
> 03/14/06 15:44:51 2840 NodeService agnodeservice.py:381 ERROR
> Exception loading default configuration. Traceback (most recent call
> last): File
> "C:\Python23\Lib\site-packages\AccessGrid\AGNodeService.py", line
> 379, in LoadDefaultConfig self.LoadConfiguration( self.defaultConfig
> ) File "C:\Python23\Lib\site-packages\AccessGrid\AGNodeService.py",
> line 523, in LoadConfiguration raise Exception(exceptionText)
> Exception: Couldn't reach service manager: localhost:11000 03/14/06
> 15:44:51 2840 VenueClient venueclient.py:313 ERROR Error loading
> default configuration Traceback (most recent call last): File
> "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line 311,
> in __StartWebService self.ns.LoadDefaultConfig() File
> 382, in LoadDefaultConfig raise Exception("Failed to load default
> configuration <%s>" % Exception: Failed to load default configuration
> <defaultWindows> 03/14/06 15:44:51 2840 VenueClient
> venueclient.py:185 DEBUG __createPersonalDataStore: Creating personal
> datastore at C:\Documents and Settings\jtvh\Application
> Data\AccessGrid\Config\personalDataStore using prefix
> personalDataStore and port 0 03/14/06 15:44:51 2840 DataStore
> datastore.py:1537 DEBUG Creating thread 0 03/14/06 15:44:51 2840
> DataStore datastore.py:1542 DEBUG Starting thread 0 03/14/06
> 15:44:51 3284 DataStore datastore.py:1550 DEBUG Worker 0 starting
> 03/14/06 15:44:51 2840 DataStore datastore.py:1544 DEBUG Waiting
> thread 0 03/14/06 15:44:51 2840 DataStore datastore.py:1547
> DEBUG Done creating workers 03/14/06 15:45:17 2840 DataStore
> datastore.py:278 DEBUG Reading persisted data from: C:\Documents and
> Data\AccessGrid\Config\personalDataStore\DataStore.dat 03/14/06
> 15:45:17 2840 VenueClient venueclient.py:210 DEBUG
> __createPersonalDataStore: Load personal data from file 03/14/06
> 15:45:17 2840 VenueClientController venueclientcontroller.py:1255
> DEBUG There is no personal venues file to load. 03/14/06 15:45:17
> 2840 VenueClient venueclientui.py:188 DEBUG the profile is the
> default profile - open profile dialog 03/14/06 15:45:17 2840
> VenueClient venueclientui.py:3871 DEBUG VenueClientUI.py: Set
> editable in successfully dialog 03/14/06 15:45:17 2840 VenueClient
> venueclientui.py:3942 DEBUG ProfileDialog.SetProfile: Set profile
> information successfully in dialog 03/14/06 15:45:42 2840 VenueClient
> venueclientui.py:3924 DEBUG ProfileDialog.GetNewProfile: Got profile
> information from dialog 03/14/06 15:45:42 2840 VenueClient
> information from dialog 03/14/06 15:45:42 2840 VenueClientController
> venueclientcontroller.py:624 DEBUG Can not update client profile in
> venue - not connected 03/14/06 15:49:19 2840 VenueClient
> venueclientui.py:1565 INFO --------- END VenueClient 03/14/06
> 15:49:19 2840 DataStore datastore.py:1614 DEBUG Quitting thread 0
> 03/14/06 15:49:19 3284 DataStore datastore.py:1555 DEBUG Worker
> 0 gets cmd quit 03/14/06 15:49:19 3284 DataStore
> datastore.py:1568 DEBUG Worker 0 exiting 03/14/06 15:49:19 3076
> DataStore datastore.py:1627 INFO GSIHTTPTransferServer:
> GSITCPSocket, interrupted I/O operation, most likely shutting down.
> 03/14/06 15:49:19 2840 NodeService agnodeservice.py:136 INFO
> NodeService.Stop 03/14/06 15:49:19 2840 ServiceManager
> agservicemanager.py:84 INFO AGServiceManager.Shutdown 03/14/06
> 15:49:19 2840 ServiceManager agservicemanager.py:85 INFO Remove
> services 03/14/06 15:49:19 2840 ServiceManager
> agservicemanager.py:389 INFO AGServiceManager.RemoveServices 03/14/06
> 15:49:19 2840 ServiceManager agservicemanager.py:87 INFO Stop
> network interface 03/14/06 15:49:19 3924 Hosting server.py:65
> ERROR Exception in SOAP server main loop Traceback (most recent call
> last): File
> "C:\Python23\Lib\site-packages\AccessGrid\hosting\SOAPpy\Server.py",
> line 63, in Run self._server.handle_request() File
> "C:\Python23\lib\SocketServer.py", line 217, in handle_request
> request, client_address = self.get_request() File
> "C:\Python23\Lib\site-packages\SOAPpy\GSIServer.py", line 140, in
> get_request sock, addr =
> ThreadingGSITCPSocketServer.get_request(self) File
> "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 525, in
> get_request self.socket.listen() File
> "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 857, in listen
> raise ex GSITCPSocketException: an I/O operation was cancelled
> 03/14/06 15:49:19 2840 Hosting server.py:97 ERROR server_close()
> failed Traceback (most recent call last): File
> line 95, in Stop self._server.server_close() File
> "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1043, in
> server_close self.socket.close() File
> "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1020, in close
> IOBase.close(self) File
> "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 176, in close
> raise ex IOBaseException: an uninitialied data structure was passed
> as argument 1 to globus_io_register_close 03/14/06 15:49:19 2840
> Hosting server.py:97 ERROR server_close() failed Traceback (most
> as argument 1 to globus_io_register_close 03/14/06 15:49:32 2580
> Toolkit config.py:214 DEBUG System hostname of
> SCV-BADTZ.ad.bu.edu is valid 03/14/06 15:49:32 2580
> CertificateManager certificatemanager.py:269 DEBUG Opened
> repository C:\Documents and Settings\jtvh\Application
> Data\AccessGrid\Config\certRepo 03/14/06 15:49:32 2580 Toolkit
> Files\AGTk-2.4\Config\CAcertificates 03/14/06 15:49:32 2580 Toolkit
> 03/14/06 15:49:32 2580 Toolkit toolkit.py:440 INFO Certificate
> 1c3f2ca8.0 already in repository 03/14/06 15:49:32 2580 Toolkit
> toolkit.py:456 INFO Marking cert as CA cert 03/14/06 15:49:32 2580
> 03/14/06 15:49:32 2580 Toolkit toolkit.py:418 INFO C:\Program
> 45cc9e80.0 already in repository 03/14/06 15:49:32 2580 Toolkit
> d1b603c3.0 already in repository 03/14/06 15:49:32 2580 Toolkit
> f18fa857.0 already in repository 03/14/06 15:49:32 2580 Toolkit
> toolkit.py:456 INFO Marking cert as CA cert 03/14/06 15:49:33 2580
> 03/14/06 15:49:33 2580 Toolkit toolkit.py:478 DEBUG Init'ing
> globus. 03/14/06 15:49:33 2580 CertificateManager
> certificatemanager.py:827 DEBUG Using default identity /O=Access
> 15:49:33 2580 CertificateManager certificatemanager.py:1083 DEBUG
> Initializing environment with unencrypted cert /O=Access
> 15:49:33 2580 CertificateManager certificatemanager.py:1098 INFO
> Setting permissions on certificate C:\Documents and
> to 644 03/14/06 15:49:33 2580 CertificateManager
> to 600 03/14/06 15:49:33 2580 CertificateManagerWXGUI
> 15:49:33 2580 Toolkit toolkit.py:482 DEBUG Done with globus.
> 03/14/06 15:49:33 2580 Toolkit venueclient.py:83 INFO wx version
> is: 2.5.1.5 03/14/06 15:49:33 2580 VenueClient
> venueclient.py:287 DEBUG __StartWebService: venueclient:
> https://SCV-BADTZ.ad.bu.edu:11000/VenueClient 03/14/06 15:49:33 2580
> ServiceManager agservicemanager.py:75 INFO Using services dir:
> Data\AccessGrid\local_services 03/14/06 15:49:33 2580 ServiceManager
> agservicemanager.py:424 INFO __DiscoverResources 03/14/06 15:49:33
> 2580 Toolkit config.py:997 INFO Using vfwscan to get devices
> 03/14/06 15:49:33 2580 Toolkit config.py:998 DEBUG vfwscanexe =
> C:\PROGRA~1\AGTk-2.4\bin\vfwscan.exe 03/14/06 15:49:33 2580 Toolkit
> (Win32)\n'] 03/14/06 15:49:33 2580 Toolkit config.py:1031 INFO
> 15:49:33 2580 VenueClient venueclient.py:296 DEBUG
> https://SCV-BADTZ.ad.bu.edu:11000/ServiceManager 03/14/06 15:49:33
> 2580 NodeService agnodeservice.py:756 INFO
> NodeService.__ReadConfigFile 03/14/06 15:49:33 2580 Toolkit
> toolkit.py:335 DEBUG Looking for: C:\Documents and
> Settings\jtvh\Application Data\AccessGrid\Config\AGNodeService.cfg
> 03/14/06 15:49:33 2580 Toolkit toolkit.py:340 DEBUG Looking for:
> C:\Program Files\AGTk-2.4\Config\AGNodeService.cfg 03/14/06 15:49:33
> 2580 NodeService agnodeservice.py:764 DEBUG DEFAULT NODE SERVICE
> 15:49:33 2580 NodeService agnodeservice.py:768 INFO Reading node
> Files\AGTk-2.4\Config\AGNodeService.cfg 03/14/06 15:49:33 2580
> 15:49:33 2580 VenueClient venueclient.py:1328 DEBUG SerNodeUrl:
> 03/14/06 15:49:33 2580 NodeService agnodeservice.py:698 INFO
> NodeService.GetDefaultConfiguration 03/14/06 15:49:33 2580
> 03/14/06 15:49:33 2580 NodeService agnodeservice.py:374 INFO
> NodeService.LoadDefaultConfig 03/14/06 15:49:33 2580 NodeService
> defaultWindows 03/14/06 15:49:33 2580 NodeService
> 15:49:33 2580 NodeService agnodeservice.py:407 INFO Trying to
> Data\AccessGrid\Config\nodeConfig\defaultWindows 03/14/06 15:49:33
> 2580 NodeService agnodeservice.py:480 INFO AddServiceManager:
> 03/14/06 15:49:33 2580 NodeService agnodeservice.py:381 ERROR
> last): File
> 15:49:33 2580 VenueClient venueclient.py:313 ERROR Error loading
> <defaultWindows> 03/14/06 15:49:33 2580 VenueClient
> personalDataStore and port 0 03/14/06 15:49:33 2580 DataStore
> datastore.py:1537 DEBUG Creating thread 0 03/14/06 15:49:33 2580
> 15:49:33 2256 DataStore datastore.py:1550 DEBUG Worker 0 starting
> 03/14/06 15:49:33 2580 DataStore datastore.py:1544 DEBUG Waiting
> thread 0 03/14/06 15:49:33 2580 DataStore datastore.py:1547
> DEBUG Done creating workers 03/14/06 15:49:33 2580 DataStore
> 15:49:33 2580 VenueClient venueclient.py:210 DEBUG
> 15:49:33 2580 VenueClientController venueclientcontroller.py:1255
> DEBUG There is no personal venues file to load. 03/14/06 15:49:49
> 2580 VenueClient venueclient.py:805 DEBUG EnterVenue;
> url=https://vv2.mcs.anl.gov:9000/Venues/default 03/14/06 15:49:49
> 2580 VenueClient venueclient.py:833 INFO EnterVenue: Error
> getting node capabilities 03/14/06 15:49:49 2580 VenueClient
> venueclient.py:705 DEBUG EnterVenue: Invoke venue enter 03/14/06
> 15:49:49 2580 VenueClient venueclient.py:866 ERROR EnterVenue:
> "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line 837,
> in EnterVenue self.__EnterVenue(URL) File
> "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line 706,
> in __EnterVenue (venueState, self.privateId, self.streamDescList ) =
> self.__venueProxy.Enter( self.profile ) File
> "C:\Python23\Lib\site-packages\AccessGrid\Venue.py", line 3499, in
> Enter (r1, r2, r3) = self.proxy.Enter(profile) File
> "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 453, in
> __call__ return self.__r_call(*args, **kw) File
> "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 475, in
> __r_call self.__hd, self.__ma) File
> "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 338, in __call
> config = self.config, noroot = self.noroot) File
> "C:\Python23\Lib\site-packages\SOAPpy\SOAPBuilder.py", line 620, in
> buildSOAP return t.build() File
> "C:\Python23\Lib\site-packages\SOAPpy\SOAPBuilder.py", line 118, in
> build body_ns = self.genns(ns_map, NS.ENV)[0] File
> "C:\Python23\Lib\site-packages\SOAPpy\SOAPBuilder.py", line 204, in
> genns if type(nsURI) == TupleType: # already a tuple NameError:
> global name 'TupleType' is not defined 03/14/06 15:49:49 2580
> VenueClient venueclientui.py:1925 DEBUG
> bin.VenueClient::EnterVenue: Enter venue with url:
> https://vv2.mcs.anl.gov:9000/Venues/default 03/14/06 15:49:49 2580
> VenueClient venueclientui.py:1938 DEBUG warningString: 03/14/06
> 15:49:55 2580 CertificateRepository certificaterepository.py:592
> DEBUG Register observer <bound method ProxyBrowser.OnRepoUpdate of
> <AccessGrid.Security.wxgui.ProxyBrowser.ProxyBrowser; proxy of C++
> wxPanel instance at _c04ed701_p_wxPanel>> 03/14/06 15:49:55 2580
> CertificateRepository certificaterepository.py:594 DEBUG Adding
> <weakref at 0212F1B0; to 'instancemethod' at 020D8E40 (OnRepoUpdate)>
> 03/14/06 15:49:55 2580 CertificateRepository
> certificaterepository.py:592 DEBUG Register observer <bound method
> IdentityBrowser.OnRepoUpdate of
> <AccessGrid.Security.wxgui.IdentityBrowser.IdentityBrowser; proxy of
> C++ wxPanel instance at _b073e301_p_wxPanel>> 03/14/06 15:49:55 2580
> <weakref at 0212F480; to 'instancemethod' at 020D8D28 (OnRepoUpdate)>
> CABrowser.OnRepoUpdate of
> <AccessGrid.Security.wxgui.CABrowser.CABrowser; proxy of C++ wxPanel
> instance at _90c10f02_p_wxPanel>> 03/14/06 15:49:55 2580
> <weakref at 0212F690; to 'instancemethod' at 0211BF08 (OnRepoUpdate)>
> CertificateStatusBrowser.OnRepoUpdate of
> <AccessGrid.Security.wxgui.CertificateStatusBrowser.CertificateStatusBrowser;
> proxy of C++ wxPanel instance at _18fe0f02_p_wxPanel>> 03/14/06
> 15:49:55 2580 CertificateRepository certificaterepository.py:594
> DEBUG Adding <weakref at 0212FA50; to 'instancemethod' at 02131260
> (OnRepoUpdate)> 03/14/06 16:07:01 2428 Toolkit config.py:214
> 16:07:01 2428 CertificateManager certificatemanager.py:269 DEBUG
> Opened repository C:\Documents and Settings\jtvh\Application
> Data\AccessGrid\Config\certRepo 03/14/06 16:07:02 2428 Toolkit
> Files\AGTk-2.4\Config\CAcertificates 03/14/06 16:07:02 2428 Toolkit
> 03/14/06 16:07:02 2428 Toolkit toolkit.py:440 INFO Certificate
> 1c3f2ca8.0 already in repository 03/14/06 16:07:02 2428 Toolkit
> toolkit.py:456 INFO Marking cert as CA cert 03/14/06 16:07:02 2428
> 03/14/06 16:07:02 2428 Toolkit toolkit.py:418 INFO C:\Program
> 45cc9e80.0 already in repository 03/14/06 16:07:02 2428 Toolkit
> d1b603c3.0 already in repository 03/14/06 16:07:02 2428 Toolkit
> f18fa857.0 already in repository 03/14/06 16:07:02 2428 Toolkit
> toolkit.py:456 INFO Marking cert as CA cert 03/14/06 16:07:03 2428
> 03/14/06 16:07:03 2428 Toolkit toolkit.py:478 DEBUG Init'ing
> globus. 03/14/06 16:07:03 2428 CertificateManager
> 16:07:03 2428 CertificateManager certificatemanager.py:1083 DEBUG
> 16:07:03 2428 CertificateManager certificatemanager.py:1098 INFO
> to 644 03/14/06 16:07:03 2428 CertificateManager
> to 600 03/14/06 16:07:03 2428 CertificateManagerWXGUI
> 16:07:03 2428 Toolkit toolkit.py:482 DEBUG Done with globus.
> 03/14/06 16:07:03 2428 Toolkit venueclient.py:83 INFO wx version
> is: 2.5.1.5 03/14/06 16:07:03 2428 VenueClient
> https://SCV-BADTZ.ad.bu.edu:11000/VenueClient 03/14/06 16:07:03 2428
> Data\AccessGrid\local_services 03/14/06 16:07:03 2428 ServiceManager
> agservicemanager.py:424 INFO __DiscoverResources 03/14/06 16:07:03
> 2428 Toolkit config.py:997 INFO Using vfwscan to get devices
> 03/14/06 16:07:03 2428 Toolkit config.py:998 DEBUG vfwscanexe =
> C:\PROGRA~1\AGTk-2.4\bin\vfwscan.exe 03/14/06 16:07:05 2428 Toolkit
> (Win32)\n'] 03/14/06 16:07:05 2428 Toolkit config.py:1031 INFO
> 16:07:05 2428 VenueClient venueclient.py:296 DEBUG
> https://SCV-BADTZ.ad.bu.edu:11000/ServiceManager 03/14/06 16:07:05
> 2428 NodeService agnodeservice.py:756 INFO
> NodeService.__ReadConfigFile 03/14/06 16:07:05 2428 Toolkit
> 03/14/06 16:07:05 2428 Toolkit toolkit.py:340 DEBUG Looking for:
> C:\Program Files\AGTk-2.4\Config\AGNodeService.cfg 03/14/06 16:07:05
> 2428 NodeService agnodeservice.py:764 DEBUG DEFAULT NODE SERVICE
> 16:07:05 2428 NodeService agnodeservice.py:768 INFO Reading node
> Files\AGTk-2.4\Config\AGNodeService.cfg 03/14/06 16:07:05 2428
> 16:07:05 2428 VenueClient venueclient.py:1328 DEBUG SerNodeUrl:
> 03/14/06 16:07:05 2428 NodeService agnodeservice.py:698 INFO
> NodeService.GetDefaultConfiguration 03/14/06 16:07:05 2428
> 03/14/06 16:07:05 2428 NodeService agnodeservice.py:374 INFO
> NodeService.LoadDefaultConfig 03/14/06 16:07:05 2428 NodeService
> defaultWindows 03/14/06 16:07:05 2428 NodeService
> 16:07:05 2428 NodeService agnodeservice.py:407 INFO Trying to
> Data\AccessGrid\Config\nodeConfig\defaultWindows 03/14/06 16:07:05
> 2428 NodeService agnodeservice.py:480 INFO AddServiceManager:
> 03/14/06 16:07:05 2428 NodeService agnodeservice.py:381 ERROR
> last): File
> 16:07:05 2428 VenueClient venueclient.py:313 ERROR Error loading
> <defaultWindows> 03/14/06 16:07:05 2428 VenueClient
> personalDataStore and port 0 03/14/06 16:07:05 2428 DataStore
> datastore.py:1537 DEBUG Creating thread 0 03/14/06 16:07:05 2428
> 16:07:05 4036 DataStore datastore.py:1550 DEBUG Worker 0 starting
> 03/14/06 16:07:05 2428 DataStore datastore.py:1544 DEBUG Waiting
> thread 0 03/14/06 16:07:05 2428 DataStore datastore.py:1547
> DEBUG Done creating workers 03/14/06 16:07:05 2428 DataStore
> 16:07:05 2428 VenueClient venueclient.py:210 DEBUG
> 16:07:05 2428 VenueClientController venueclientcontroller.py:1255
> DEBUG There is no personal venues file to load. 03/14/06 16:07:15
> 2428 CertificateRepository certificaterepository.py:592 DEBUG
> wxPanel instance at _c04ed701_p_wxPanel>> 03/14/06 16:07:15 2428
> <weakref at 020DA2D0; to 'instancemethod' at 020D8A30 (OnRepoUpdate)>
> 03/14/06 16:07:15 2428 CertificateRepository
> C++ wxPanel instance at _18dd1002_p_wxPanel>> 03/14/06 16:07:15 2428
> <weakref at 020DA5A0; to 'instancemethod' at 020D8B98 (OnRepoUpdate)>
> instance at _28c9f001_p_wxPanel>> 03/14/06 16:07:15 2428
> <weakref at 020DA7B0; to 'instancemethod' at 020D8D78 (OnRepoUpdate)>
> proxy of C++ wxPanel instance at _d009f101_p_wxPanel>> 03/14/06
> 16:07:15 2428 CertificateRepository certificaterepository.py:594
> DEBUG Adding <weakref at 020DAB70; to 'instancemethod' at 020D8FA8
> (OnRepoUpdate)> 03/14/06 16:14:47 2428 CertificateRepository
> certificaterepository.py:129 ERROR Could not open certificate file
> 03/14/06 16:15:06 2428 CertificateRepository
> certificaterepository.py:133 INFO Found valid cert, validKey=1
> 03/14/06 16:15:07 2428 CertificateRepository
> 03/14/06 16:15:11 2428 CertificateRepository
> certificaterepository.py:741 ERROR load error Traceback (most recent
> call last): File
> "C:\Python23\Lib\site-packages\AccessGrid\Security\CertificateRepository.py",
> line 738, in ImportCertificatePEM passphrase) Error: [('digital
> envelope routines', 'EVP_DecryptFinal', 'bad decrypt'), ('PEM
> routines', 'PEM_do_header', 'bad decrypt')] 03/14/06 16:15:11 2428
> CertificateManagerWXGUI importexportutils.py:792 ERROR Import fails:
> Incorrect passphrase. cert file S:\AG\jtvh\cert-exp-12-2006.pem
> keyfile S:\AG\jtvh\cert-exp-12-2006.pem Traceback (most recent call
> last): File
> "C:\Python23\Lib\site-packages\AccessGrid\Security\wxgui\ImportExportUtils.py",
> line 775, in ImportPEMIdentityCertificate certFile, keyFile, cb)
> File
> "C:\Python23\Lib\site-packages\AccessGrid\Security\CertificateManager.py",
> line 465, in ImportIdentityCertificatePEM impCert =
> repo.ImportCertificatePEM(userCert, userKey, passphraseCB) File
> line 742, in ImportCertificatePEM raise RepoBadPassphrase
> RepoBadPassphrase 03/14/06 16:15:16 2428 CertificateRepository
> 03/14/06 16:15:19 2428 CertificateRepository
> 03/14/06 16:15:21 2428 CertificateRepository
> 03/14/06 16:15:24 2428 CertificateRepository
> certificaterepository.py:952 INFO _ImportPrivateKey importing pkey
> Data\AccessGrid\Config\certRepo\privatekeys\b6ea2d1e21eb850bef7b799ce043d5e9.pem
> Data\AccessGrid\Config\certRepo\certificates\9469dc4861d79549ca6a9e6a2ed4909f\7fd839972fa295d09928e28808b848ea
> 03/14/06 16:15:25 2428 CertificateManagerWXGUI
> importexportutils.py:776 DEBUG Imported identity /O=Access
> Grid/OU=agdev-ca.mcs.anl.gov/OU=bu.edu/CN=Jennifer Teig von Hoffman
> importexportutils.py:834 DEBUG ID certs:
> [<AccessGrid.Security.CertificateRepository.CertificateDescriptor
> instance at 0x02132918>] 03/14/06 16:15:25 2428 CertificateManager
> 16:15:25 2428 CertificateManager certificatemanager.py:1083 DEBUG
> 16:15:25 2428 CertificateManager certificatemanager.py:1098 INFO
> to 644 03/14/06 16:15:25 2428 CertificateManager
> to 600 03/14/06 16:15:30 2428 CertificateManager
> certificatemanager.py:902 DEBUG Initializing environment with proxy
> cert for /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=bu.edu/CN=Jennifer
> Teig von Hoffman 03/14/06 16:15:30 2428 CertificateManager
> certificatemanager.py:968 DEBUG _VerifyGlobusProxy: file
> C:\DOCUME~1\jtvh\LOCALS~1\Temp\proxy not found 03/14/06 16:15:40 2428
> CertificateManagerWXGUI certificatemanagerwxgui.py:550 DEBUG Proxy
> successfully created 03/14/06 16:15:40 2428 CertificateManager
> Teig von Hoffman 03/14/06 16:15:40 2428 CertificateManager
> certificatemanager.py:1011 INFO Verifying local proxy cert 03/14/06
> 16:15:40 2428 CertificateManager certificatemanager.py:921 DEBUG
> Configuring for user proxy issued from /O=Access
> certificatemanager.py:924 DEBUG Proxy
> C:\DOCUME~1\jtvh\LOCALS~1\Temp\proxy will expire 03/15/06 05:15:40
> 03/14/06 16:15:40 2428 CertificateManagerWXGUI
> 16:18:36 2428 VenueClient venueclient.py:805 DEBUG EnterVenue;
> url=https://vv2.mcs.anl.gov:9000/Venues/default 03/14/06 16:18:36
> 2428 CertificateManager certificatemanager.py:1011 INFO
> Verifying local proxy cert 03/14/06 16:18:36 2428 CertificateManager
> certificatemanager.py:663 DEBUG HaveValidProxy: found proxy ident
> /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=bu.edu/CN=Jennifer Teig von
> Hoffman/CN=proxy 03/14/06 16:18:36 2428 CertificateManager
> 16:18:36 2428 CertificateManager certificatemanager.py:663 DEBUG
> HaveValidProxy: found proxy ident /O=Access
> Hoffman/CN=proxy 03/14/06 16:18:36 2428 VenueClient
> venueclient.py:833 INFO EnterVenue: Error getting node capabilities
> 03/14/06 16:18:36 2428 VenueClient venueclient.py:705 DEBUG
> EnterVenue: Invoke venue enter 03/14/06 16:18:36 2428 VenueClient
> venueclient.py:866 ERROR EnterVenue: failed Traceback (most recent
> call last): File
> global name 'TupleType' is not defined 03/14/06 16:18:36 2428
> https://vv2.mcs.anl.gov:9000/Venues/default 03/14/06 16:18:36 2428
> 16:18:42 2428 VenueClient venueclient.py:1343 INFO Error enabling
> video 03/14/06 16:18:44 2428 VenueClient venueclient.py:1349 INFO
> Error enabling audio 03/14/06 16:19:06 2428 VenueClient
> 16:19:06 2428 DataStore datastore.py:1614 DEBUG Quitting thread 0
> 03/14/06 16:19:06 4036 DataStore datastore.py:1555 DEBUG Worker
> 0 gets cmd quit 03/14/06 16:19:06 4036 DataStore
> datastore.py:1568 DEBUG Worker 0 exiting 03/14/06 16:19:06 4032
> 03/14/06 16:19:06 2428 NodeService agnodeservice.py:136 INFO
> NodeService.Stop 03/14/06 16:19:06 2428 ServiceManager
> 16:19:06 2428 ServiceManager agservicemanager.py:85 INFO Remove
> services 03/14/06 16:19:06 2428 ServiceManager
> 16:19:06 2428 ServiceManager agservicemanager.py:87 INFO Stop
> network interface 03/14/06 16:19:06 2084 Hosting server.py:65
> last): File
> 03/14/06 16:19:06 2428 Hosting server.py:97 ERROR server_close()
> as argument 1 to globus_io_register_close 03/14/06 16:19:06 2428
> as argument 1 to globus_io_register_close 03/15/06 11:34:51 444
> SCV-BADTZ.ad.bu.edu is valid 03/15/06 11:34:51 444 CertificateManager
> certificatemanager.py:269 DEBUG Opened repository C:\Documents and
> Settings\jtvh\Application Data\AccessGrid\Config\certRepo 03/15/06
> 11:34:52 444 Toolkit toolkit.py:404 DEBUG looking in system ca
> dir: C:\Program Files\AGTk-2.4\Config\CAcertificates 03/15/06
> 11:34:52 444 Toolkit toolkit.py:418 INFO C:\Program
> 03/15/06 11:34:52 444 Toolkit toolkit.py:440 INFO Certificate
> 1c3f2ca8.0 already in repository 03/15/06 11:34:52 444 Toolkit
> toolkit.py:456 INFO Marking cert as CA cert 03/15/06 11:34:52 444
> 03/15/06 11:34:52 444 Toolkit toolkit.py:418 INFO C:\Program
> 45cc9e80.0 already in repository 03/15/06 11:34:52 444 Toolkit
> d1b603c3.0 already in repository 03/15/06 11:34:52 444 Toolkit
> f18fa857.0 already in repository 03/15/06 11:34:52 444 Toolkit
> 03/15/06 11:34:52 444 Toolkit toolkit.py:478 DEBUG Init'ing
> globus. 03/15/06 11:34:53 444 CertificateManager
> Teig von Hoffman 03/15/06 11:34:53 444 CertificateManager
> certificatemanager.py:1011 INFO Verifying local proxy cert 03/15/06
> 11:34:53 444 CertificateManager certificatemanager.py:1024 DEBUG
> _VerifyGlobusProxy: proxy C:\DOCUME~1\jtvh\LOCALS~1\Temp\proxy
> expired 03/15/06 11:35:01 444 CertificateManagerWXGUI
> certificatemanagerwxgui.py:550 DEBUG Proxy successfully created
> Teig von Hoffman 03/15/06 11:35:01 444 CertificateManager
> 11:35:01 444 CertificateManager certificatemanager.py:921 DEBUG
> C:\DOCUME~1\jtvh\LOCALS~1\Temp\proxy will expire 03/16/06 00:35:01
> certificatemanagerwxgui.py:422 DEBUG done, success=1 03/15/06
> 11:35:01 444 Toolkit toolkit.py:482 DEBUG Done with globus.
> 03/15/06 11:35:01 444 Toolkit venueclient.py:83 INFO wx version
> is: 2.5.1.5 03/15/06 11:35:01 444 VenueClient venueclient.py:287
> https://SCV-BADTZ.ad.bu.edu:11000/VenueClient 03/15/06 11:35:01 444
> Data\AccessGrid\local_services 03/15/06 11:35:01 444 ServiceManager
> agservicemanager.py:424 INFO __DiscoverResources 03/15/06 11:35:01
> 444 Toolkit config.py:997 INFO Using vfwscan to get devices
> 03/15/06 11:35:01 444 Toolkit config.py:998 DEBUG vfwscanexe =
> C:\PROGRA~1\AGTk-2.4\bin\vfwscan.exe 03/15/06 11:35:01 444 Toolkit
> (Win32)\n'] 03/15/06 11:35:01 444 Toolkit config.py:1031 INFO
> GetResources: ['Microsoft WDM Image Capture (Win32)'] 03/15/06
> 11:35:01 444 VenueClient venueclient.py:296 DEBUG
> https://SCV-BADTZ.ad.bu.edu:11000/ServiceManager 03/15/06 11:35:01
> 444 NodeService agnodeservice.py:756 INFO
> NodeService.__ReadConfigFile 03/15/06 11:35:01 444 Toolkit
> 03/15/06 11:35:01 444 Toolkit toolkit.py:340 DEBUG Looking for:
> C:\Program Files\AGTk-2.4\Config\AGNodeService.cfg 03/15/06 11:35:01
> 444 NodeService agnodeservice.py:764 DEBUG DEFAULT NODE SERVICE
> CONFIG: C:\Program Files\AGTk-2.4\Config\AGNodeService.cfg 03/15/06
> 11:35:01 444 NodeService agnodeservice.py:768 INFO Reading node
> Files\AGTk-2.4\Config\AGNodeService.cfg 03/15/06 11:35:01 444
> service: https://SCV-BADTZ.ad.bu.edu:11000/NodeService 03/15/06
> 11:35:01 444 VenueClient venueclient.py:1328 DEBUG SerNodeUrl:
> 03/15/06 11:35:01 444 NodeService agnodeservice.py:698 INFO
> NodeService.GetDefaultConfiguration 03/15/06 11:35:02 444 NodeService
> agnodeservice.py:581 INFO Migration unnecessary 03/15/06 11:35:02 444
> NodeService.LoadDefaultConfig 03/15/06 11:35:02 444 NodeService
> defaultWindows 03/15/06 11:35:02 444 NodeService
> agnodeservice.py:392 INFO NodeService.LoadConfiguration 03/15/06
> 11:35:02 444 NodeService agnodeservice.py:407 INFO Trying to
> Data\AccessGrid\Config\nodeConfig\defaultWindows 03/15/06 11:35:02
> 444 NodeService agnodeservice.py:480 INFO AddServiceManager:
> 03/15/06 11:35:02 444 NodeService agnodeservice.py:381 ERROR
> last): File
> Exception: Couldn't reach service manager: localhost:11000 03/15/06
> 11:35:02 444 VenueClient venueclient.py:313 ERROR Error loading
> <defaultWindows> 03/15/06 11:35:02 444 VenueClient
> personalDataStore and port 0 03/15/06 11:35:02 444 DataStore
> datastore.py:1537 DEBUG Creating thread 0 03/15/06 11:35:02 444
> DataStore datastore.py:1542 DEBUG Starting thread 0 03/15/06
> 11:35:02 284 DataStore datastore.py:1550 DEBUG Worker 0 starting
> 03/15/06 11:35:02 444 DataStore datastore.py:1544 DEBUG Waiting
> thread 0 03/15/06 11:35:02 444 DataStore datastore.py:1547 DEBUG
> Done creating workers 03/15/06 11:35:02 444 DataStore
> Data\AccessGrid\Config\personalDataStore\DataStore.dat 03/15/06
> 11:35:02 444 VenueClient venueclient.py:210 DEBUG
> __createPersonalDataStore: Load personal data from file 03/15/06
> 11:35:02 444 VenueClientController venueclientcontroller.py:1255
> DEBUG There is no personal venues file to load. 03/15/06 11:35:22 444
> CertificateRepository certificaterepository.py:592 DEBUG Register
> wxPanel instance at _c04ed701_p_wxPanel>> 03/15/06 11:35:22 444
> <weakref at 020DB270; to 'instancemethod' at 020D6A58 (OnRepoUpdate)>
> 03/15/06 11:35:22 444 CertificateRepository
> C++ wxPanel instance at _d028de01_p_wxPanel>> 03/15/06 11:35:22 444
> <weakref at 020DB540; to 'instancemethod' at 020D6AD0 (OnRepoUpdate)>
> instance at _6886e301_p_wxPanel>> 03/15/06 11:35:22 444
> <weakref at 020DB750; to 'instancemethod' at 020D6C38 (OnRepoUpdate)>
> proxy of C++ wxPanel instance at _f003ef01_p_wxPanel>> 03/15/06
> 11:35:22 444 CertificateRepository certificaterepository.py:594 DEBUG
> Adding <weakref at 020DBB10; to 'instancemethod' at 020DF030
> (OnRepoUpdate)> 03/15/06 11:35:43 444 VenueClient
> url=https://vv2.mcs.anl.gov:9000/Venues/default 03/15/06 11:35:43 444
> CertificateManager certificatemanager.py:1011 INFO Verifying
> local proxy cert 03/15/06 11:35:43 444 CertificateManager
> Hoffman/CN=proxy 03/15/06 11:35:43 444 CertificateManager
> 11:35:43 444 CertificateManager certificatemanager.py:663 DEBUG
> Hoffman/CN=proxy 03/15/06 11:35:43 444 VenueClient
> 03/15/06 11:35:43 444 VenueClient venueclient.py:705 DEBUG
> EnterVenue: Invoke venue enter 03/15/06 11:35:43 444 VenueClient
> call last): File
> global name 'TupleType' is not defined 03/15/06 11:35:43 444
> VenueClient venueclientui.py:1938 DEBUG warningString: 03/15/06
> 11:37:41 444 VenueClient venueclient.py:805 DEBUG EnterVenue;
> url=https://venues.ncsa.uiuc.edu:9000/Venues/default 03/15/06
> 11:37:41 444 CertificateManager certificatemanager.py:1011 INFO
> Verifying local proxy cert 03/15/06 11:37:41 444 CertificateManager
> Hoffman/CN=proxy 03/15/06 11:37:41 444 CertificateManager
> 11:37:41 444 CertificateManager certificatemanager.py:663 DEBUG
> Hoffman/CN=proxy 03/15/06 11:37:41 444 VenueClient
> 03/15/06 11:37:41 444 VenueClient venueclient.py:705 DEBUG
> EnterVenue: Invoke venue enter 03/15/06 11:37:41 444 VenueClient
> call last): File
> global name 'TupleType' is not defined 03/15/06 11:37:41 444
> https://venues.ncsa.uiuc.edu:9000/Venues/default 03/15/06 11:37:41
> 444 VenueClient venueclientui.py:1938 DEBUG warningString:
> 03/15/06 11:39:38 444 VenueClient venueclientui.py:1565 INFO
> --------- END VenueClient 03/15/06 11:39:38 444 DataStore
> datastore.py:1614 DEBUG Quitting thread 0 03/15/06 11:39:38 284
> DataStore datastore.py:1555 DEBUG Worker 0 gets cmd quit 03/15/06
> 11:39:38 284 DataStore datastore.py:1568 DEBUG Worker 0 exiting
> 03/15/06 11:39:38 444 NodeService agnodeservice.py:136 INFO
> NodeService.Stop 03/15/06 11:39:38 444 ServiceManager
> agservicemanager.py:84 INFO AGServiceManager.Shutdown 03/15/06
> 11:39:38 444 ServiceManager agservicemanager.py:85 INFO Remove
> services 03/15/06 11:39:38 444 ServiceManager
> agservicemanager.py:389 INFO AGServiceManager.RemoveServices 03/15/06
> 11:39:38 444 ServiceManager agservicemanager.py:87 INFO Stop
> network interface 03/15/06 11:39:38 1732 DataStore
> datastore.py:1627 INFO GSIHTTPTransferServer: GSITCPSocket,
> interrupted I/O operation, most likely shutting down. 03/15/06
> 11:39:38 3836 Hosting server.py:65 ERROR Exception in SOAP server
> main loop Traceback (most recent call last): File
> 03/15/06 11:39:38 444 Hosting server.py:97 ERROR server_close()
> as argument 1 to globus_io_register_close 03/15/06 11:39:38 444
> as argument 1 to globus_io_register_close 03/15/06 11:40:54 240
> Toolkit toolkit.py:96 DEBUG Initializing AG Toolkit version 2.4
> (build 1) 03/15/06 11:40:54 240 Toolkit toolkit.py:138 INFO
> Logfile Name: VenueClient.log 03/15/06 11:40:54 240 Toolkit
> config.py:196 DEBUG Using GLOBUS_HOSTNAME=SCV-BADTZ.ad.bu.edu as set
> in the environment 03/15/06 11:40:54 240 CertificateManager
> 11:40:54 240 Toolkit toolkit.py:404 DEBUG looking in system ca
> 11:40:54 240 Toolkit toolkit.py:418 INFO C:\Program
> 03/15/06 11:40:54 240 Toolkit toolkit.py:440 INFO Certificate
> 1c3f2ca8.0 already in repository 03/15/06 11:40:54 240 Toolkit
> toolkit.py:456 INFO Marking cert as CA cert 03/15/06 11:40:54 240
> 03/15/06 11:40:54 240 Toolkit toolkit.py:418 INFO C:\Program
> 45cc9e80.0 already in repository 03/15/06 11:40:54 240 Toolkit
> d1b603c3.0 already in repository 03/15/06 11:40:54 240 Toolkit
> f18fa857.0 already in repository 03/15/06 11:40:54 240 Toolkit
> 03/15/06 11:40:54 240 Toolkit toolkit.py:478 DEBUG Init'ing
> globus. 03/15/06 11:40:54 240 CertificateManager
> Teig von Hoffman 03/15/06 11:40:54 240 CertificateManager
> 11:40:54 240 CertificateManager certificatemanager.py:921 DEBUG
> 03/15/06 11:40:54 240 CertificateManagerWXGUI
> 11:40:54 240 Toolkit toolkit.py:482 DEBUG Done with globus.
> 03/15/06 11:40:54 240 Toolkit venueclient.py:83 INFO wx version
> is: 2.5.1.5 03/15/06 11:40:55 240 VenueClient venueclient.py:287
> https://SCV-BADTZ.ad.bu.edu:11000/VenueClient 03/15/06 11:40:55 240
> Data\AccessGrid\local_services 03/15/06 11:40:55 240 ServiceManager
> agservicemanager.py:424 INFO __DiscoverResources 03/15/06 11:40:55
> 240 Toolkit config.py:997 INFO Using vfwscan to get devices
> 03/15/06 11:40:55 240 Toolkit config.py:998 DEBUG vfwscanexe =
> C:\PROGRA~1\AGTk-2.4\bin\vfwscan.exe 03/15/06 11:40:55 240 Toolkit
> (Win32)\n'] 03/15/06 11:40:55 240 Toolkit config.py:1031 INFO
> 11:40:55 240 VenueClient venueclient.py:296 DEBUG
> https://SCV-BADTZ.ad.bu.edu:11000/ServiceManager 03/15/06 11:40:55
> 240 NodeService agnodeservice.py:756 INFO
> NodeService.__ReadConfigFile 03/15/06 11:40:55 240 Toolkit
> 03/15/06 11:40:55 240 Toolkit toolkit.py:340 DEBUG Looking for:
> C:\Program Files\AGTk-2.4\Config\AGNodeService.cfg 03/15/06 11:40:55
> 240 NodeService agnodeservice.py:764 DEBUG DEFAULT NODE SERVICE
> 11:40:55 240 NodeService agnodeservice.py:768 INFO Reading node
> Files\AGTk-2.4\Config\AGNodeService.cfg 03/15/06 11:40:55 240
> 11:40:55 240 VenueClient venueclient.py:1328 DEBUG SerNodeUrl:
> 03/15/06 11:40:55 240 NodeService agnodeservice.py:698 INFO
> NodeService.GetDefaultConfiguration 03/15/06 11:40:55 240 NodeService
> agnodeservice.py:581 INFO Migration unnecessary 03/15/06 11:40:55 240
> NodeService.LoadDefaultConfig 03/15/06 11:40:55 240 NodeService
> defaultWindows 03/15/06 11:40:55 240 NodeService
> 11:40:55 240 NodeService agnodeservice.py:407 INFO Trying to
> Data\AccessGrid\Config\nodeConfig\defaultWindows 03/15/06 11:40:55
> 240 NodeService agnodeservice.py:480 INFO AddServiceManager:
> 03/15/06 11:40:55 240 NodeService agnodeservice.py:381 ERROR
> last): File
> 11:40:55 240 VenueClient venueclient.py:313 ERROR Error loading
> <defaultWindows> 03/15/06 11:40:55 240 VenueClient
> personalDataStore and port 0 03/15/06 11:40:55 240 DataStore
> datastore.py:1537 DEBUG Creating thread 0 03/15/06 11:40:55 240
> 11:40:55 2996 DataStore datastore.py:1550 DEBUG Worker 0 starting
> 03/15/06 11:40:55 240 DataStore datastore.py:1544 DEBUG Waiting
> thread 0 03/15/06 11:40:55 240 DataStore datastore.py:1547 DEBUG
> Done creating workers 03/15/06 11:40:55 240 DataStore
> 11:40:55 240 VenueClient venueclient.py:210 DEBUG
> 11:40:55 240 VenueClientController venueclientcontroller.py:1255
> DEBUG There is no personal venues file to load. 03/15/06 11:40:55 240
> 11:40:55 240 CertificateManager certificatemanager.py:1011 INFO
> Verifying local proxy cert 03/15/06 11:40:55 240 CertificateManager
> Hoffman/CN=proxy 03/15/06 11:40:55 240 CertificateManager
> 11:40:55 240 CertificateManager certificatemanager.py:663 DEBUG
> Hoffman/CN=proxy 03/15/06 11:40:55 240 VenueClient
> 03/15/06 11:40:55 240 VenueClient venueclient.py:705 DEBUG
> EnterVenue: Invoke venue enter 03/15/06 11:40:55 240 VenueClient
> call last): File
> global name 'TupleType' is not defined 03/15/06 11:40:55 240
> https://venues.ncsa.uiuc.edu:9000/Venues/default 03/15/06 11:40:55
> 240 VenueClient venueclientui.py:1938 DEBUG warningString:
> 03/15/06 11:41:01 240 VenueClient venueclientui.py:1565 INFO
> --------- END VenueClient 03/15/06 11:41:01 240 DataStore
> datastore.py:1614 DEBUG Quitting thread 0 03/15/06 11:41:01 2996
> 11:41:01 2996 DataStore datastore.py:1568 DEBUG Worker 0 exiting
> 03/15/06 11:41:01 3376 DataStore datastore.py:1627 INFO
> GSIHTTPTransferServer: GSITCPSocket, interrupted I/O operation, most
> likely shutting down. 03/15/06 11:41:01 240 NodeService
> agnodeservice.py:136 INFO NodeService.Stop 03/15/06 11:41:01 240
> ServiceManager agservicemanager.py:84 INFO
> AGServiceManager.Shutdown 03/15/06 11:41:01 240 ServiceManager
> agservicemanager.py:85 INFO Remove services 03/15/06 11:41:01 240
> ServiceManager agservicemanager.py:389 INFO
> AGServiceManager.RemoveServices 03/15/06 11:41:01 240 ServiceManager
> agservicemanager.py:87 INFO Stop network interface 03/15/06 11:41:01
> 1340 Hosting server.py:65 ERROR Exception in SOAP server main
> 03/15/06 11:41:01 240 Hosting server.py:97 ERROR server_close()
> as argument 1 to globus_io_register_close 03/15/06 11:41:01 240
> as argument 1 to globus_io_register_close 03/15/06 11:42:29 2300
> SCV-BADTZ.ad.bu.edu is valid 03/15/06 11:42:29 2300
> Data\AccessGrid\Config\certRepo 03/15/06 11:42:29 2300 Toolkit
> Files\AGTk-2.4\Config\CAcertificates 03/15/06 11:42:29 2300 Toolkit
> 03/15/06 11:42:29 2300 Toolkit toolkit.py:440 INFO Certificate
> 1c3f2ca8.0 already in repository 03/15/06 11:42:29 2300 Toolkit
> toolkit.py:456 INFO Marking cert as CA cert 03/15/06 11:42:29 2300
> 03/15/06 11:42:29 2300 Toolkit toolkit.py:418 INFO C:\Program
> 45cc9e80.0 already in repository 03/15/06 11:42:29 2300 Toolkit
> d1b603c3.0 already in repository 03/15/06 11:42:29 2300 Toolkit
> f18fa857.0 already in repository 03/15/06 11:42:29 2300 Toolkit
> 03/15/06 11:42:29 2300 Toolkit toolkit.py:478 DEBUG Init'ing
> globus. 03/15/06 11:42:29 2300 CertificateManager
> Teig von Hoffman 03/15/06 11:42:29 2300 CertificateManager
> 11:42:29 2300 CertificateManager certificatemanager.py:921 DEBUG
> 03/15/06 11:42:29 2300 CertificateManagerWXGUI
> 11:42:29 2300 Toolkit toolkit.py:482 DEBUG Done with globus.
> 03/15/06 11:42:29 2300 Toolkit venueclient.py:83 INFO wx version
> is: 2.5.1.5 03/15/06 11:42:29 2300 VenueClient
> https://SCV-BADTZ.ad.bu.edu:11000/VenueClient 03/15/06 11:42:29 2300
> Data\AccessGrid\local_services 03/15/06 11:42:29 2300 ServiceManager
> agservicemanager.py:424 INFO __DiscoverResources 03/15/06 11:42:29
> 2300 Toolkit config.py:997 INFO Using vfwscan to get devices
> 03/15/06 11:42:29 2300 Toolkit config.py:998 DEBUG vfwscanexe =
> C:\PROGRA~1\AGTk-2.4\bin\vfwscan.exe 03/15/06 11:42:30 2300 Toolkit
> (Win32)\n'] 03/15/06 11:42:30 2300 Toolkit config.py:1031 INFO
> 11:42:30 2300 VenueClient venueclient.py:296 DEBUG
> https://SCV-BADTZ.ad.bu.edu:11000/ServiceManager 03/15/06 11:42:30
> 2300 NodeService agnodeservice.py:756 INFO
> NodeService.__ReadConfigFile 03/15/06 11:42:30 2300 Toolkit
> 03/15/06 11:42:30 2300 Toolkit toolkit.py:340 DEBUG Looking for:
> C:\Program Files\AGTk-2.4\Config\AGNodeService.cfg 03/15/06 11:42:30
> 2300 NodeService agnodeservice.py:764 DEBUG DEFAULT NODE SERVICE
> 11:42:30 2300 NodeService agnodeservice.py:768 INFO Reading node
> Files\AGTk-2.4\Config\AGNodeService.cfg 03/15/06 11:42:30 2300
> 11:42:30 2300 VenueClient venueclient.py:1328 DEBUG SerNodeUrl:
> 03/15/06 11:42:30 2300 NodeService agnodeservice.py:698 INFO
> NodeService.GetDefaultConfiguration 03/15/06 11:42:30 2300
> 03/15/06 11:42:30 2300 NodeService agnodeservice.py:374 INFO
> NodeService.LoadDefaultConfig 03/15/06 11:42:30 2300 NodeService
> defaultWindows 03/15/06 11:42:30 2300 NodeService
> 11:42:30 2300 NodeService agnodeservice.py:407 INFO Trying to
> Data\AccessGrid\Config\nodeConfig\defaultWindows 03/15/06 11:42:30
> 2300 NodeService agnodeservice.py:480 INFO AddServiceManager:
> 03/15/06 11:42:30 2300 NodeService agnodeservice.py:381 ERROR
> last): File
> 11:42:30 2300 VenueClient venueclient.py:313 ERROR Error loading
> <defaultWindows> 03/15/06 11:42:30 2300 VenueClient
> personalDataStore and port 0 03/15/06 11:42:30 2300 DataStore
> datastore.py:1537 DEBUG Creating thread 0 03/15/06 11:42:30 2300
> 11:42:30 1608 DataStore datastore.py:1550 DEBUG Worker 0 starting
> 03/15/06 11:42:30 2300 DataStore datastore.py:1544 DEBUG Waiting
> thread 0 03/15/06 11:42:30 2300 DataStore datastore.py:1547
> DEBUG Done creating workers 03/15/06 11:42:30 2300 DataStore
> 11:42:30 2300 VenueClient venueclient.py:210 DEBUG
> 11:42:30 2300 VenueClientController venueclientcontroller.py:1255
> DEBUG There is no personal venues file to load. 03/15/06 11:42:37
> 2300 VenueClient venueclient.py:805 DEBUG EnterVenue;
> url=https://vv2.mcs.anl.gov:9000/Venues/default 03/15/06 11:42:37
> 2300 CertificateManager certificatemanager.py:1011 INFO
> Verifying local proxy cert 03/15/06 11:42:37 2300 CertificateManager
> Hoffman/CN=proxy 03/15/06 11:42:37 2300 CertificateManager
> 11:42:37 2300 CertificateManager certificatemanager.py:663 DEBUG
> Hoffman/CN=proxy 03/15/06 11:42:37 2300 VenueClient
> 03/15/06 11:42:37 2300 VenueClient venueclient.py:705 DEBUG
> EnterVenue: Invoke venue enter 03/15/06 11:42:37 2300 VenueClient
> call last): File
> global name 'TupleType' is not defined 03/15/06 11:42:37 2300
> https://vv2.mcs.anl.gov:9000/Venues/default 03/15/06 11:42:37 2300
> 11:45:42 2300 VenueClient venueclientui.py:1565 INFO --------- END
> VenueClient 03/15/06 11:45:42 2300 DataStore datastore.py:1614
> DEBUG Quitting thread 0 03/15/06 11:45:42 1608 DataStore
> datastore.py:1555 DEBUG Worker 0 gets cmd quit 03/15/06 11:45:42 1608
> DataStore datastore.py:1568 DEBUG Worker 0 exiting 03/15/06
> 11:45:42 3752 DataStore datastore.py:1627 INFO
> likely shutting down. 03/15/06 11:45:42 2300 NodeService
> agnodeservice.py:136 INFO NodeService.Stop 03/15/06 11:45:42 2300
> AGServiceManager.Shutdown 03/15/06 11:45:42 2300 ServiceManager
> agservicemanager.py:85 INFO Remove services 03/15/06 11:45:42 2300
> AGServiceManager.RemoveServices 03/15/06 11:45:42 2300 ServiceManager
> agservicemanager.py:87 INFO Stop network interface 03/15/06 11:45:42
> 1120 Hosting server.py:65 ERROR Exception in SOAP server main
> 03/15/06 11:45:42 2300 Hosting server.py:97 ERROR server_close()
> as argument 1 to globus_io_register_close 03/15/06 11:45:42 2300
