[AG-TECH] cannot connect to venue on new PIG
Jennifer Teig von Hoffman
jtvh at bu.edu
Wed Mar 15 10:46:23 CST 2006
Hi all,
I've just migrated to a new laptop and installed AG 2.4. I've imported my (valid) certificate, and can successfully make a proxy. However, I cannot connect to a venue. When I try to connect, I get the standard "Can not connect to venue located at https://vvw.mcs.anl.gov:9000/Venues/default. Please try again." error message. I've tried to connect to both the address above, and venues.ncsa.uiuc.edu.
I wonder if my laptop may be in a strange state -- I used the Lenovo migration assistant when switching over to the new hardware, and generally speaking it has been inconsistent about what settings/etc it's carried over from the old machine. I installed AG 2.4 *after* migration, so theoretically it shouldn't have taken any of the AG-related settings, but nonetheless the Lenovo experience has overall been quite mixed and I wonder if it may be the issue here.
My entire VenueClient.log is below. Any suggestions?
Cheers,
Jennifer
03/14/06 15:43:06 824 Toolkit config.py:364 ERROR Couldn't retrieve globus key from registry.
Traceback (most recent call last):
File "C:\Python23\Lib\site-packages\AccessGrid\Platform\win32\Config.py", line 362, in GetGlobusKey
"Software\Globus", 0, _winreg.KEY_SET_VALUE)
WindowsError: [Errno 2] The system cannot find the file specified
03/14/06 15:43:06 824 Toolkit config.py:214 DEBUG System hostname of SCV-BADTZ.ad.bu.edu is valid
03/14/06 15:44:45 2840 Toolkit config.py:381 ERROR Couldn't retrieve gsi key from registry.
File "C:\Python23\Lib\site-packages\AccessGrid\Platform\win32\Config.py", line 378, in GetGlobusKey
gsikey = _winreg.OpenKey(gkey, "GSI", 0, _winreg.KEY_SET_VALUE)
03/14/06 15:44:45 2840 Toolkit config.py:214 DEBUG System hostname of SCV-BADTZ.ad.bu.edu is valid
03/14/06 15:44:45 2840 CertificateManager certificatemanager.py:297 DEBUG initializing repository
03/14/06 15:44:45 2840 CertificateManager certificatemanager.py:327 DEBUG Initializing from C:\Program Files\AGTk-2.4\Config\CAcertificates
03/14/06 15:44:45 2840 CertificateManager certificatemanager.py:340 WARNING Didn't find certficate in old globus path: C:\Documents and Settings\jtvh\Application Data\globus\usercert.pem
03/14/06 15:44:45 2840 CertificateManager certificatemanager.py:416 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\1c3f2ca8.0 might be a cert
03/14/06 15:44:45 2840 CertificateRepository certificaterepository.py:889 DEBUG _ImportCertificate: create C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\certificates\a82c3f1c4b096b896061778ee79efeff\9c8df64aa35ebf832613413527bc073d
03/14/06 15:44:46 2840 CertificateRepository certificaterepository.py:1615 DEBUG GetFilePath: create C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\certificates\a82c3f1c4b096b896061778ee79efeff\9c8df64aa35ebf832613413527bc073d\user_files
03/14/06 15:44:46 2840 CertificateManager certificatemanager.py:441 INFO Imported cert as 1c3f2ca8.0
03/14/06 15:44:46 2840 CertificateManager certificatemanager.py:416 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\45cc9e80.0 might be a cert
03/14/06 15:44:46 2840 CertificateRepository certificaterepository.py:889 DEBUG _ImportCertificate: create C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\certificates\809ecc45460c1482e61e26bdfbf9e18c\9f380c9a586af2bb913ace809d5badfe
03/14/06 15:44:46 2840 CertificateRepository certificaterepository.py:1615 DEBUG GetFilePath: create C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\certificates\809ecc45460c1482e61e26bdfbf9e18c\9f380c9a586af2bb913ace809d5badfe\user_files
03/14/06 15:44:46 2840 CertificateManager certificatemanager.py:441 INFO Imported cert as 45cc9e80.0
03/14/06 15:44:46 2840 CertificateManager certificatemanager.py:416 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\d1b603c3.0 might be a cert
03/14/06 15:44:46 2840 CertificateRepository certificaterepository.py:889 DEBUG _ImportCertificate: create C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\certificates\c303b6d10c962b37482e68ca64d383a0\05a2039fe10ed1b4195d9f9d35b32c68
03/14/06 15:44:46 2840 CertificateRepository certificaterepository.py:1615 DEBUG GetFilePath: create C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\certificates\c303b6d10c962b37482e68ca64d383a0\05a2039fe10ed1b4195d9f9d35b32c68\user_files
03/14/06 15:44:46 2840 CertificateManager certificatemanager.py:441 INFO Imported cert as d1b603c3.0
03/14/06 15:44:46 2840 CertificateManager certificatemanager.py:416 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\f18fa857.0 might be a cert
03/14/06 15:44:46 2840 CertificateRepository certificaterepository.py:889 DEBUG _ImportCertificate: create C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\certificates\57a88ff1707d87e926f2287c702a8466\eff65f03366cb8e20247f831ccc87fd5
03/14/06 15:44:46 2840 CertificateRepository certificaterepository.py:1615 DEBUG GetFilePath: create C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\certificates\57a88ff1707d87e926f2287c702a8466\eff65f03366cb8e20247f831ccc87fd5\user_files
03/14/06 15:44:46 2840 CertificateManager certificatemanager.py:441 INFO Imported cert as f18fa857.0
03/14/06 15:44:46 2840 CertificateManager certificatemanager.py:1198 WARNING No identity certs found
03/14/06 15:44:46 2840 CertificateManager certificatemanager.py:1209 WARNING No default identity certificate found
03/14/06 15:44:46 2840 Toolkit toolkit.py:404 DEBUG looking in system ca dir: C:\Program Files\AGTk-2.4\Config\CAcertificates
03/14/06 15:44:46 2840 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\1c3f2ca8.0 might be a cert
03/14/06 15:44:46 2840 Toolkit toolkit.py:440 INFO Certificate 1c3f2ca8.0 already in repository
03/14/06 15:44:46 2840 Toolkit toolkit.py:456 INFO Marking cert as CA cert
03/14/06 15:44:46 2840 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\certificates\a82c3f1c4b096b896061778ee79efeff\9c8df64aa35ebf832613413527bc073d\user_files\signing_policy
03/14/06 15:44:46 2840 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\45cc9e80.0 might be a cert
03/14/06 15:44:46 2840 Toolkit toolkit.py:440 INFO Certificate 45cc9e80.0 already in repository
03/14/06 15:44:46 2840 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\certificates\809ecc45460c1482e61e26bdfbf9e18c\9f380c9a586af2bb913ace809d5badfe\user_files\signing_policy
03/14/06 15:44:46 2840 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\d1b603c3.0 might be a cert
03/14/06 15:44:46 2840 Toolkit toolkit.py:440 INFO Certificate d1b603c3.0 already in repository
03/14/06 15:44:46 2840 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\certificates\c303b6d10c962b37482e68ca64d383a0\05a2039fe10ed1b4195d9f9d35b32c68\user_files\signing_policy
03/14/06 15:44:46 2840 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\f18fa857.0 might be a cert
03/14/06 15:44:46 2840 Toolkit toolkit.py:440 INFO Certificate f18fa857.0 already in repository
03/14/06 15:44:47 2840 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\certificates\57a88ff1707d87e926f2287c702a8466\eff65f03366cb8e20247f831ccc87fd5\user_files\signing_policy
03/14/06 15:44:47 2840 Toolkit toolkit.py:478 DEBUG Init'ing globus.
03/14/06 15:44:47 2840 CertificateManager certificatemanager.py:759 DEBUG Configuring standard environment
03/14/06 15:44:47 2840 CertificateManager certificatemanager.py:1198 WARNING No identity certs found
03/14/06 15:44:47 2840 CertificateManager certificatemanager.py:1209 WARNING No default identity certificate found
03/14/06 15:44:47 2840 CertificateManager certificatemanager.py:829 DEBUG No default identity found <type 'NoneType'> None
03/14/06 15:44:47 2840 CertificateRepository certificaterepository.py:952 INFO _ImportPrivateKey importing pkey to C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\privatekeys\b82eff976e60282028802c8814e23901.pem
03/14/06 15:44:47 2840 CertificateRepository certificaterepository.py:918 INFO _ImportCertificateRequest writing to C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\requests\b82eff976e60282028802c8814e23901.pem
03/14/06 15:44:47 2840 CRSClient crsclient.py:40 DEBUG create client
03/14/06 15:44:47 2840 CRSClient crsclient.py:73 DEBUG request certificate
03/14/06 15:44:49 2840 CertificateManager certificatemanager.py:1275 DEBUG CheckRequestedCertificate: req=<AccessGrid.Security.CertificateRepository.CertificateRequestDescriptor instance at 0x01F892D8>, token=267d22fbd98fcbd8bca067f7148e034a, server=http://www-unix.mcs.anl.gov/fl/research/accessgrid/ca/anonymous/anonReqServer.cgi
03/14/06 15:44:49 2840 CRSClient crsclient.py:40 DEBUG create client
03/14/06 15:44:49 2840 CRSClient crsclient.py:104 DEBUG retrieve certificate for token 267d22fbd98fcbd8bca067f7148e034a
03/14/06 15:44:49 2840 CRSClient crsclient.py:115 DEBUG retrieved certificate [1, '-----BEGIN CERTIFICATE-----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\ndGljYXRvcjANBgk
qhkiG9w0BAQQFAAOCAQEALmC3il6vFPYI1PERDado53isFC8R\n0w1SXWv8skr9XZWw/Gbc2Lms9MgVn5PxN6aeSoRr30M0IOk/xYAObNWKRbyzTaaE\nle7xuILHPwEB7GaeHDr11gcRCU6cs1a+DwMEXTWb9nTyK3w6yYvE4ZuGaqJDnFFc\n4YCqiDx0XmJjqz5YDp7l6tn5j2PLF1WW3rGWATBAo+jjcGrCu/KzlI0RFAXANPWg\npTj/pOprcOinLUWr7XXos90NY91/vHmvFVP2mQqQPI7OwbqFiviAo8+dcC2/ozDj\nJkECJYzHJrYQFu5udPHajE2wTaYP7R6Nhn20D9PvD3cgSBv/AXXKSk0bwQ==\n-----END CERTIFICATE-----\n\n']
03/14/06 15:44:49 2840 CertificateManager certificatemanager.py:1280 DEBUG Retrieve returns [1, '-----BEGIN CERTIFICATE-----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\nd
GljYXRvcjANBgkqhkiG9w0BAQQFAAOCAQEALmC3il6vFPYI1PERDado53isFC8R\n0w1SXWv8skr9XZWw/Gbc2Lms9MgVn5PxN6aeSoRr30M0IOk/xYAObNWKRbyzTaaE\nle7xuILHPwEB7GaeHDr11gcRCU6cs1a+DwMEXTWb9nTyK3w6yYvE4ZuGaqJDnFFc\n4YCqiDx0XmJjqz5YDp7l6tn5j2PLF1WW3rGWATBAo+jjcGrCu/KzlI0RFAXANPWg\npTj/pOprcOinLUWr7XXos90NY91/vHmvFVP2mQqQPI7OwbqFiviAo8+dcC2/ozDj\nJkECJYzHJrYQFu5udPHajE2wTaYP7R6Nhn20D9PvD3cgSBv/AXXKSk0bwQ==\n-----END CERTIFICATE-----\n\n']
03/14/06 15:44:49 2840 CertificateRepository certificaterepository.py:866 DEBUG Importing requested certificate subj=/O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 4a250eb4e3231f2abbe3d4021c330646 path=C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\certificates\5cf11fcf8b5d698d7eb3ccdba1980efb\99514c538e7a32167c1699b16c025df4
03/14/06 15:44:49 2840 CertificateRepository certificaterepository.py:867 DEBUG Modulus hash is b82eff976e60282028802c8814e23901
03/14/06 15:44:49 2840 CertificateRepository certificaterepository.py:889 DEBUG _ImportCertificate: create C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\certificates\5cf11fcf8b5d698d7eb3ccdba1980efb\99514c538e7a32167c1699b16c025df4
03/14/06 15:44:50 2840 CertificateManager certificatemanager.py:453 DEBUG imported requested cert /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 4a250eb4e3231f2abbe3d4021c330646
03/14/06 15:44:50 2840 CertificateManager certificatemanager.py:759 DEBUG Configuring standard environment
03/14/06 15:44:50 2840 CertificateManager certificatemanager.py:827 DEBUG Using default identity /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 4a250eb4e3231f2abbe3d4021c330646
03/14/06 15:44:50 2840 CertificateManager certificatemanager.py:1083 DEBUG Initializing environment with unencrypted cert /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 4a250eb4e3231f2abbe3d4021c330646
03/14/06 15:44:50 2840 CertificateManager certificatemanager.py:1098 INFO Setting permissions on certificate C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\certificates\5cf11fcf8b5d698d7eb3ccdba1980efb\99514c538e7a32167c1699b16c025df4\cert.pem to 644
03/14/06 15:44:50 2840 CertificateManager certificatemanager.py:1109 INFO Setting permissions on certificate C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\privatekeys\b82eff976e60282028802c8814e23901.pem to 600
03/14/06 15:44:50 2840 CertificateManagerWXGUI certificatemanagerwxgui.py:422 DEBUG done, success=1
03/14/06 15:44:50 2840 Toolkit toolkit.py:482 DEBUG Done with globus.
03/14/06 15:44:50 2840 Toolkit venueclient.py:83 INFO wx version is: 2.5.1.5
03/14/06 15:44:50 2840 VenueClient venueclient.py:287 DEBUG __StartWebService: venueclient: https://SCV-BADTZ.ad.bu.edu:11000/VenueClient
03/14/06 15:44:50 2840 ServiceManager agservicemanager.py:68 INFO Creating user services directory C:\Documents and Settings\jtvh\Application Data\AccessGrid\local_services
03/14/06 15:44:50 2840 ServiceManager agservicemanager.py:424 INFO __DiscoverResources
03/14/06 15:44:50 2840 Toolkit config.py:997 INFO Using vfwscan to get devices
03/14/06 15:44:50 2840 Toolkit config.py:998 DEBUG vfwscanexe = C:\PROGRA~1\AGTk-2.4\bin\vfwscan.exe
03/14/06 15:44:51 2840 Toolkit config.py:1003 DEBUG filelines = ['Microsoft WDM Image Capture (Win32)\n']
03/14/06 15:44:51 2840 Toolkit config.py:1031 INFO GetResources: ['Microsoft WDM Image Capture (Win32)']
03/14/06 15:44:51 2840 VenueClient venueclient.py:296 DEBUG __StartWebService: service manager: https://SCV-BADTZ.ad.bu.edu:11000/ServiceManager
03/14/06 15:44:51 2840 NodeService agnodeservice.py:115 INFO Copying system node configs to user node config dir
03/14/06 15:44:51 2840 NodeService agnodeservice.py:116 INFO system node config = C:\Program Files\AGTk-2.4\Config\nodeConfig
03/14/06 15:44:51 2840 NodeService agnodeservice.py:117 INFO user node config = C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\nodeConfig
03/14/06 15:44:51 2840 NodeService agnodeservice.py:120 INFO node config: defaultWindows
03/14/06 15:44:51 2840 NodeService agnodeservice.py:756 INFO NodeService.__ReadConfigFile
03/14/06 15:44:51 2840 Toolkit toolkit.py:335 DEBUG Looking for: C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\AGNodeService.cfg
03/14/06 15:44:51 2840 Toolkit toolkit.py:340 DEBUG Looking for: C:\Program Files\AGTk-2.4\Config\AGNodeService.cfg
03/14/06 15:44:51 2840 NodeService agnodeservice.py:764 DEBUG DEFAULT NODE SERVICE CONFIG: C:\Program Files\AGTk-2.4\Config\AGNodeService.cfg
03/14/06 15:44:51 2840 NodeService agnodeservice.py:768 INFO Reading node service config file: C:\Program Files\AGTk-2.4\Config\AGNodeService.cfg
03/14/06 15:44:51 2840 VenueClient venueclient.py:302 DEBUG __StartWebService: node service: https://SCV-BADTZ.ad.bu.edu:11000/NodeService
03/14/06 15:44:51 2840 VenueClient venueclient.py:1328 DEBUG SerNodeUrl: Set node service url: https://SCV-BADTZ.ad.bu.edu:11000/NodeService
03/14/06 15:44:51 2840 NodeService agnodeservice.py:698 INFO NodeService.GetDefaultConfiguration
03/14/06 15:44:51 2840 NodeService agnodeservice.py:581 INFO Migration unnecessary
03/14/06 15:44:51 2840 NodeService agnodeservice.py:374 INFO NodeService.LoadDefaultConfig
03/14/06 15:44:51 2840 NodeService agnodeservice.py:378 INFO Loading default node configuration: defaultWindows
03/14/06 15:44:51 2840 NodeService agnodeservice.py:392 INFO NodeService.LoadConfiguration
03/14/06 15:44:51 2840 NodeService agnodeservice.py:407 INFO Trying to load node configuration from: C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\nodeConfig\defaultWindows
03/14/06 15:44:51 2840 NodeService agnodeservice.py:480 INFO AddServiceManager: Invalid service manager url (https://localhost:11000/ServiceManager)
03/14/06 15:44:51 2840 NodeService agnodeservice.py:381 ERROR Exception loading default configuration.
File "C:\Python23\Lib\site-packages\AccessGrid\AGNodeService.py", line 379, in LoadDefaultConfig
self.LoadConfiguration( self.defaultConfig )
File "C:\Python23\Lib\site-packages\AccessGrid\AGNodeService.py", line 523, in LoadConfiguration
raise Exception(exceptionText)
Exception: Couldn't reach service manager: localhost:11000
03/14/06 15:44:51 2840 VenueClient venueclient.py:313 ERROR Error loading default configuration
File "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line 311, in __StartWebService
self.ns.LoadDefaultConfig()
File "C:\Python23\Lib\site-packages\AccessGrid\AGNodeService.py", line 382, in LoadDefaultConfig
raise Exception("Failed to load default configuration <%s>" %
Exception: Failed to load default configuration <defaultWindows>
03/14/06 15:44:51 2840 VenueClient venueclient.py:185 DEBUG __createPersonalDataStore: Creating personal datastore at C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\personalDataStore using prefix personalDataStore and port 0
03/14/06 15:44:51 2840 DataStore datastore.py:1537 DEBUG Creating thread 0
03/14/06 15:44:51 2840 DataStore datastore.py:1542 DEBUG Starting thread 0
03/14/06 15:44:51 3284 DataStore datastore.py:1550 DEBUG Worker 0 starting
03/14/06 15:44:51 2840 DataStore datastore.py:1544 DEBUG Waiting thread 0
03/14/06 15:44:51 2840 DataStore datastore.py:1547 DEBUG Done creating workers
03/14/06 15:45:17 2840 DataStore datastore.py:278 DEBUG Reading persisted data from: C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\personalDataStore\DataStore.dat
03/14/06 15:45:17 2840 VenueClient venueclient.py:210 DEBUG __createPersonalDataStore: Load personal data from file
03/14/06 15:45:17 2840 VenueClientController venueclientcontroller.py:1255 DEBUG There is no personal venues file to load.
03/14/06 15:45:17 2840 VenueClient venueclientui.py:188 DEBUG the profile is the default profile - open profile dialog
03/14/06 15:45:17 2840 VenueClient venueclientui.py:3871 DEBUG VenueClientUI.py: Set editable in successfully dialog
03/14/06 15:45:17 2840 VenueClient venueclientui.py:3942 DEBUG ProfileDialog.SetProfile: Set profile information successfully in dialog
03/14/06 15:45:42 2840 VenueClient venueclientui.py:3924 DEBUG ProfileDialog.GetNewProfile: Got profile information from dialog
03/14/06 15:45:42 2840 VenueClientController venueclientcontroller.py:624 DEBUG Can not update client profile in venue - not connected
03/14/06 15:49:19 2840 VenueClient venueclientui.py:1565 INFO --------- END VenueClient
03/14/06 15:49:19 2840 DataStore datastore.py:1614 DEBUG Quitting thread 0
03/14/06 15:49:19 3284 DataStore datastore.py:1555 DEBUG Worker 0 gets cmd quit
03/14/06 15:49:19 3284 DataStore datastore.py:1568 DEBUG Worker 0 exiting
03/14/06 15:49:19 3076 DataStore datastore.py:1627 INFO GSIHTTPTransferServer: GSITCPSocket, interrupted I/O operation, most likely shutting down.
03/14/06 15:49:19 2840 NodeService agnodeservice.py:136 INFO NodeService.Stop
03/14/06 15:49:19 2840 ServiceManager agservicemanager.py:84 INFO AGServiceManager.Shutdown
03/14/06 15:49:19 2840 ServiceManager agservicemanager.py:85 INFO Remove services
03/14/06 15:49:19 2840 ServiceManager agservicemanager.py:389 INFO AGServiceManager.RemoveServices
03/14/06 15:49:19 2840 ServiceManager agservicemanager.py:87 INFO Stop network interface
03/14/06 15:49:19 3924 Hosting server.py:65 ERROR Exception in SOAP server main loop
File "C:\Python23\Lib\site-packages\AccessGrid\hosting\SOAPpy\Server.py", line 63, in Run
self._server.handle_request()
File "C:\Python23\lib\SocketServer.py", line 217, in handle_request
request, client_address = self.get_request()
File "C:\Python23\Lib\site-packages\SOAPpy\GSIServer.py", line 140, in get_request
sock, addr = ThreadingGSITCPSocketServer.get_request(self)
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 525, in get_request
self.socket.listen()
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 857, in listen
raise ex
GSITCPSocketException: an I/O operation was cancelled
03/14/06 15:49:19 2840 Hosting server.py:97 ERROR server_close() failed
File "C:\Python23\Lib\site-packages\AccessGrid\hosting\SOAPpy\Server.py", line 95, in Stop
self._server.server_close()
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1043, in server_close
self.socket.close()
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1020, in close
IOBase.close(self)
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 176, in close
raise ex
IOBaseException: an uninitialied data structure was passed as argument 1 to globus_io_register_close
self.socket.close()
IOBase.close(self)
raise ex
03/14/06 15:49:32 2580 Toolkit config.py:214 DEBUG System hostname of SCV-BADTZ.ad.bu.edu is valid
03/14/06 15:49:32 2580 CertificateManager certificatemanager.py:269 DEBUG Opened repository C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo
03/14/06 15:49:32 2580 Toolkit toolkit.py:404 DEBUG looking in system ca dir: C:\Program Files\AGTk-2.4\Config\CAcertificates
03/14/06 15:49:32 2580 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\1c3f2ca8.0 might be a cert
03/14/06 15:49:32 2580 Toolkit toolkit.py:440 INFO Certificate 1c3f2ca8.0 already in repository
03/14/06 15:49:32 2580 Toolkit toolkit.py:456 INFO Marking cert as CA cert
03/14/06 15:49:32 2580 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\certificates\a82c3f1c4b096b896061778ee79efeff\9c8df64aa35ebf832613413527bc073d\user_files\signing_policy
03/14/06 15:49:32 2580 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\45cc9e80.0 might be a cert
03/14/06 15:49:32 2580 Toolkit toolkit.py:440 INFO Certificate 45cc9e80.0 already in repository
03/14/06 15:49:32 2580 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\certificates\809ecc45460c1482e61e26bdfbf9e18c\9f380c9a586af2bb913ace809d5badfe\user_files\signing_policy
03/14/06 15:49:32 2580 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\d1b603c3.0 might be a cert
03/14/06 15:49:32 2580 Toolkit toolkit.py:440 INFO Certificate d1b603c3.0 already in repository
03/14/06 15:49:32 2580 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\certificates\c303b6d10c962b37482e68ca64d383a0\05a2039fe10ed1b4195d9f9d35b32c68\user_files\signing_policy
03/14/06 15:49:32 2580 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\f18fa857.0 might be a cert
03/14/06 15:49:32 2580 Toolkit toolkit.py:440 INFO Certificate f18fa857.0 already in repository
03/14/06 15:49:33 2580 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\certificates\57a88ff1707d87e926f2287c702a8466\eff65f03366cb8e20247f831ccc87fd5\user_files\signing_policy
03/14/06 15:49:33 2580 Toolkit toolkit.py:478 DEBUG Init'ing globus.
03/14/06 15:49:33 2580 CertificateManager certificatemanager.py:759 DEBUG Configuring standard environment
03/14/06 15:49:33 2580 CertificateManager certificatemanager.py:827 DEBUG Using default identity /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 4a250eb4e3231f2abbe3d4021c330646
03/14/06 15:49:33 2580 CertificateManager certificatemanager.py:1083 DEBUG Initializing environment with unencrypted cert /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 4a250eb4e3231f2abbe3d4021c330646
03/14/06 15:49:33 2580 CertificateManager certificatemanager.py:1098 INFO Setting permissions on certificate C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\certificates\5cf11fcf8b5d698d7eb3ccdba1980efb\99514c538e7a32167c1699b16c025df4\cert.pem to 644
03/14/06 15:49:33 2580 CertificateManager certificatemanager.py:1109 INFO Setting permissions on certificate C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\privatekeys\b82eff976e60282028802c8814e23901.pem to 600
03/14/06 15:49:33 2580 CertificateManagerWXGUI certificatemanagerwxgui.py:422 DEBUG done, success=1
03/14/06 15:49:33 2580 Toolkit toolkit.py:482 DEBUG Done with globus.
03/14/06 15:49:33 2580 Toolkit venueclient.py:83 INFO wx version is: 2.5.1.5
03/14/06 15:49:33 2580 VenueClient venueclient.py:287 DEBUG __StartWebService: venueclient: https://SCV-BADTZ.ad.bu.edu:11000/VenueClient
03/14/06 15:49:33 2580 ServiceManager agservicemanager.py:75 INFO Using services dir: C:\Documents and Settings\jtvh\Application Data\AccessGrid\local_services
03/14/06 15:49:33 2580 ServiceManager agservicemanager.py:424 INFO __DiscoverResources
03/14/06 15:49:33 2580 Toolkit config.py:997 INFO Using vfwscan to get devices
03/14/06 15:49:33 2580 Toolkit config.py:998 DEBUG vfwscanexe = C:\PROGRA~1\AGTk-2.4\bin\vfwscan.exe
03/14/06 15:49:33 2580 Toolkit config.py:1003 DEBUG filelines = ['Microsoft WDM Image Capture (Win32)\n']
03/14/06 15:49:33 2580 Toolkit config.py:1031 INFO GetResources: ['Microsoft WDM Image Capture (Win32)']
03/14/06 15:49:33 2580 VenueClient venueclient.py:296 DEBUG __StartWebService: service manager: https://SCV-BADTZ.ad.bu.edu:11000/ServiceManager
03/14/06 15:49:33 2580 NodeService agnodeservice.py:756 INFO NodeService.__ReadConfigFile
03/14/06 15:49:33 2580 Toolkit toolkit.py:335 DEBUG Looking for: C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\AGNodeService.cfg
03/14/06 15:49:33 2580 Toolkit toolkit.py:340 DEBUG Looking for: C:\Program Files\AGTk-2.4\Config\AGNodeService.cfg
03/14/06 15:49:33 2580 NodeService agnodeservice.py:764 DEBUG DEFAULT NODE SERVICE CONFIG: C:\Program Files\AGTk-2.4\Config\AGNodeService.cfg
03/14/06 15:49:33 2580 NodeService agnodeservice.py:768 INFO Reading node service config file: C:\Program Files\AGTk-2.4\Config\AGNodeService.cfg
03/14/06 15:49:33 2580 VenueClient venueclient.py:302 DEBUG __StartWebService: node service: https://SCV-BADTZ.ad.bu.edu:11000/NodeService
03/14/06 15:49:33 2580 VenueClient venueclient.py:1328 DEBUG SerNodeUrl: Set node service url: https://SCV-BADTZ.ad.bu.edu:11000/NodeService
03/14/06 15:49:33 2580 NodeService agnodeservice.py:698 INFO NodeService.GetDefaultConfiguration
03/14/06 15:49:33 2580 NodeService agnodeservice.py:581 INFO Migration unnecessary
03/14/06 15:49:33 2580 NodeService agnodeservice.py:374 INFO NodeService.LoadDefaultConfig
03/14/06 15:49:33 2580 NodeService agnodeservice.py:378 INFO Loading default node configuration: defaultWindows
03/14/06 15:49:33 2580 NodeService agnodeservice.py:392 INFO NodeService.LoadConfiguration
03/14/06 15:49:33 2580 NodeService agnodeservice.py:407 INFO Trying to load node configuration from: C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\nodeConfig\defaultWindows
03/14/06 15:49:33 2580 NodeService agnodeservice.py:480 INFO AddServiceManager: Invalid service manager url (https://localhost:11000/ServiceManager)
03/14/06 15:49:33 2580 NodeService agnodeservice.py:381 ERROR Exception loading default configuration.
03/14/06 15:49:33 2580 VenueClient venueclient.py:313 ERROR Error loading default configuration
03/14/06 15:49:33 2580 VenueClient venueclient.py:185 DEBUG __createPersonalDataStore: Creating personal datastore at C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\personalDataStore using prefix personalDataStore and port 0
03/14/06 15:49:33 2580 DataStore datastore.py:1537 DEBUG Creating thread 0
03/14/06 15:49:33 2580 DataStore datastore.py:1542 DEBUG Starting thread 0
03/14/06 15:49:33 2256 DataStore datastore.py:1550 DEBUG Worker 0 starting
03/14/06 15:49:33 2580 DataStore datastore.py:1544 DEBUG Waiting thread 0
03/14/06 15:49:33 2580 DataStore datastore.py:1547 DEBUG Done creating workers
03/14/06 15:49:33 2580 DataStore datastore.py:278 DEBUG Reading persisted data from: C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\personalDataStore\DataStore.dat
03/14/06 15:49:33 2580 VenueClient venueclient.py:210 DEBUG __createPersonalDataStore: Load personal data from file
03/14/06 15:49:33 2580 VenueClientController venueclientcontroller.py:1255 DEBUG There is no personal venues file to load.
03/14/06 15:49:49 2580 VenueClient venueclient.py:805 DEBUG EnterVenue; url=https://vv2.mcs.anl.gov:9000/Venues/default
03/14/06 15:49:49 2580 VenueClient venueclient.py:833 INFO EnterVenue: Error getting node capabilities
03/14/06 15:49:49 2580 VenueClient venueclient.py:705 DEBUG EnterVenue: Invoke venue enter
03/14/06 15:49:49 2580 VenueClient venueclient.py:866 ERROR EnterVenue: failed
File "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line 837, in EnterVenue
self.__EnterVenue(URL)
File "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line 706, in __EnterVenue
(venueState, self.privateId, self.streamDescList ) = self.__venueProxy.Enter( self.profile )
File "C:\Python23\Lib\site-packages\AccessGrid\Venue.py", line 3499, in Enter
(r1, r2, r3) = self.proxy.Enter(profile)
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 453, in __call__
return self.__r_call(*args, **kw)
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 475, in __r_call
self.__hd, self.__ma)
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 338, in __call
config = self.config, noroot = self.noroot)
File "C:\Python23\Lib\site-packages\SOAPpy\SOAPBuilder.py", line 620, in buildSOAP
return t.build()
File "C:\Python23\Lib\site-packages\SOAPpy\SOAPBuilder.py", line 118, in build
body_ns = self.genns(ns_map, NS.ENV)[0]
File "C:\Python23\Lib\site-packages\SOAPpy\SOAPBuilder.py", line 204, in genns
if type(nsURI) == TupleType: # already a tuple
NameError: global name 'TupleType' is not defined
03/14/06 15:49:49 2580 VenueClient venueclientui.py:1925 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://vv2.mcs.anl.gov:9000/Venues/default
03/14/06 15:49:49 2580 VenueClient venueclientui.py:1938 DEBUG warningString:
03/14/06 15:49:55 2580 CertificateRepository certificaterepository.py:592 DEBUG Register observer <bound method ProxyBrowser.OnRepoUpdate of <AccessGrid.Security.wxgui.ProxyBrowser.ProxyBrowser; proxy of C++ wxPanel instance at _c04ed701_p_wxPanel>>
03/14/06 15:49:55 2580 CertificateRepository certificaterepository.py:594 DEBUG Adding <weakref at 0212F1B0; to 'instancemethod' at 020D8E40 (OnRepoUpdate)>
03/14/06 15:49:55 2580 CertificateRepository certificaterepository.py:592 DEBUG Register observer <bound method IdentityBrowser.OnRepoUpdate of <AccessGrid.Security.wxgui.IdentityBrowser.IdentityBrowser; proxy of C++ wxPanel instance at _b073e301_p_wxPanel>>
03/14/06 15:49:55 2580 CertificateRepository certificaterepository.py:594 DEBUG Adding <weakref at 0212F480; to 'instancemethod' at 020D8D28 (OnRepoUpdate)>
03/14/06 15:49:55 2580 CertificateRepository certificaterepository.py:592 DEBUG Register observer <bound method CABrowser.OnRepoUpdate of <AccessGrid.Security.wxgui.CABrowser.CABrowser; proxy of C++ wxPanel instance at _90c10f02_p_wxPanel>>
03/14/06 15:49:55 2580 CertificateRepository certificaterepository.py:594 DEBUG Adding <weakref at 0212F690; to 'instancemethod' at 0211BF08 (OnRepoUpdate)>
03/14/06 15:49:55 2580 CertificateRepository certificaterepository.py:592 DEBUG Register observer <bound method CertificateStatusBrowser.OnRepoUpdate of <AccessGrid.Security.wxgui.CertificateStatusBrowser.CertificateStatusBrowser; proxy of C++ wxPanel instance at _18fe0f02_p_wxPanel>>
03/14/06 15:49:55 2580 CertificateRepository certificaterepository.py:594 DEBUG Adding <weakref at 0212FA50; to 'instancemethod' at 02131260 (OnRepoUpdate)>
03/14/06 16:07:01 2428 Toolkit config.py:214 DEBUG System hostname of SCV-BADTZ.ad.bu.edu is valid
03/14/06 16:07:01 2428 CertificateManager certificatemanager.py:269 DEBUG Opened repository C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo
03/14/06 16:07:02 2428 Toolkit toolkit.py:404 DEBUG looking in system ca dir: C:\Program Files\AGTk-2.4\Config\CAcertificates
03/14/06 16:07:02 2428 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\1c3f2ca8.0 might be a cert
03/14/06 16:07:02 2428 Toolkit toolkit.py:440 INFO Certificate 1c3f2ca8.0 already in repository
03/14/06 16:07:02 2428 Toolkit toolkit.py:456 INFO Marking cert as CA cert
03/14/06 16:07:02 2428 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\certificates\a82c3f1c4b096b896061778ee79efeff\9c8df64aa35ebf832613413527bc073d\user_files\signing_policy
03/14/06 16:07:02 2428 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\45cc9e80.0 might be a cert
03/14/06 16:07:02 2428 Toolkit toolkit.py:440 INFO Certificate 45cc9e80.0 already in repository
03/14/06 16:07:02 2428 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\certificates\809ecc45460c1482e61e26bdfbf9e18c\9f380c9a586af2bb913ace809d5badfe\user_files\signing_policy
03/14/06 16:07:02 2428 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\d1b603c3.0 might be a cert
03/14/06 16:07:02 2428 Toolkit toolkit.py:440 INFO Certificate d1b603c3.0 already in repository
03/14/06 16:07:02 2428 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\certificates\c303b6d10c962b37482e68ca64d383a0\05a2039fe10ed1b4195d9f9d35b32c68\user_files\signing_policy
03/14/06 16:07:02 2428 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\f18fa857.0 might be a cert
03/14/06 16:07:02 2428 Toolkit toolkit.py:440 INFO Certificate f18fa857.0 already in repository
03/14/06 16:07:03 2428 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\certificates\57a88ff1707d87e926f2287c702a8466\eff65f03366cb8e20247f831ccc87fd5\user_files\signing_policy
03/14/06 16:07:03 2428 Toolkit toolkit.py:478 DEBUG Init'ing globus.
03/14/06 16:07:03 2428 CertificateManager certificatemanager.py:759 DEBUG Configuring standard environment
03/14/06 16:07:03 2428 CertificateManager certificatemanager.py:827 DEBUG Using default identity /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 4a250eb4e3231f2abbe3d4021c330646
03/14/06 16:07:03 2428 CertificateManager certificatemanager.py:1083 DEBUG Initializing environment with unencrypted cert /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 4a250eb4e3231f2abbe3d4021c330646
03/14/06 16:07:03 2428 CertificateManager certificatemanager.py:1098 INFO Setting permissions on certificate C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\certificates\5cf11fcf8b5d698d7eb3ccdba1980efb\99514c538e7a32167c1699b16c025df4\cert.pem to 644
03/14/06 16:07:03 2428 CertificateManager certificatemanager.py:1109 INFO Setting permissions on certificate C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\privatekeys\b82eff976e60282028802c8814e23901.pem to 600
03/14/06 16:07:03 2428 CertificateManagerWXGUI certificatemanagerwxgui.py:422 DEBUG done, success=1
03/14/06 16:07:03 2428 Toolkit toolkit.py:482 DEBUG Done with globus.
03/14/06 16:07:03 2428 Toolkit venueclient.py:83 INFO wx version is: 2.5.1.5
03/14/06 16:07:03 2428 VenueClient venueclient.py:287 DEBUG __StartWebService: venueclient: https://SCV-BADTZ.ad.bu.edu:11000/VenueClient
03/14/06 16:07:03 2428 ServiceManager agservicemanager.py:75 INFO Using services dir: C:\Documents and Settings\jtvh\Application Data\AccessGrid\local_services
03/14/06 16:07:03 2428 ServiceManager agservicemanager.py:424 INFO __DiscoverResources
03/14/06 16:07:03 2428 Toolkit config.py:997 INFO Using vfwscan to get devices
03/14/06 16:07:03 2428 Toolkit config.py:998 DEBUG vfwscanexe = C:\PROGRA~1\AGTk-2.4\bin\vfwscan.exe
03/14/06 16:07:05 2428 Toolkit config.py:1003 DEBUG filelines = ['Microsoft WDM Image Capture (Win32)\n']
03/14/06 16:07:05 2428 Toolkit config.py:1031 INFO GetResources: ['Microsoft WDM Image Capture (Win32)']
03/14/06 16:07:05 2428 VenueClient venueclient.py:296 DEBUG __StartWebService: service manager: https://SCV-BADTZ.ad.bu.edu:11000/ServiceManager
03/14/06 16:07:05 2428 NodeService agnodeservice.py:756 INFO NodeService.__ReadConfigFile
03/14/06 16:07:05 2428 Toolkit toolkit.py:335 DEBUG Looking for: C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\AGNodeService.cfg
03/14/06 16:07:05 2428 Toolkit toolkit.py:340 DEBUG Looking for: C:\Program Files\AGTk-2.4\Config\AGNodeService.cfg
03/14/06 16:07:05 2428 NodeService agnodeservice.py:764 DEBUG DEFAULT NODE SERVICE CONFIG: C:\Program Files\AGTk-2.4\Config\AGNodeService.cfg
03/14/06 16:07:05 2428 NodeService agnodeservice.py:768 INFO Reading node service config file: C:\Program Files\AGTk-2.4\Config\AGNodeService.cfg
03/14/06 16:07:05 2428 VenueClient venueclient.py:302 DEBUG __StartWebService: node service: https://SCV-BADTZ.ad.bu.edu:11000/NodeService
03/14/06 16:07:05 2428 VenueClient venueclient.py:1328 DEBUG SerNodeUrl: Set node service url: https://SCV-BADTZ.ad.bu.edu:11000/NodeService
03/14/06 16:07:05 2428 NodeService agnodeservice.py:698 INFO NodeService.GetDefaultConfiguration
03/14/06 16:07:05 2428 NodeService agnodeservice.py:581 INFO Migration unnecessary
03/14/06 16:07:05 2428 NodeService agnodeservice.py:374 INFO NodeService.LoadDefaultConfig
03/14/06 16:07:05 2428 NodeService agnodeservice.py:378 INFO Loading default node configuration: defaultWindows
03/14/06 16:07:05 2428 NodeService agnodeservice.py:392 INFO NodeService.LoadConfiguration
03/14/06 16:07:05 2428 NodeService agnodeservice.py:407 INFO Trying to load node configuration from: C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\nodeConfig\defaultWindows
03/14/06 16:07:05 2428 NodeService agnodeservice.py:480 INFO AddServiceManager: Invalid service manager url (https://localhost:11000/ServiceManager)
03/14/06 16:07:05 2428 NodeService agnodeservice.py:381 ERROR Exception loading default configuration.
03/14/06 16:07:05 2428 VenueClient venueclient.py:313 ERROR Error loading default configuration
03/14/06 16:07:05 2428 VenueClient venueclient.py:185 DEBUG __createPersonalDataStore: Creating personal datastore at C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\personalDataStore using prefix personalDataStore and port 0
03/14/06 16:07:05 2428 DataStore datastore.py:1537 DEBUG Creating thread 0
03/14/06 16:07:05 2428 DataStore datastore.py:1542 DEBUG Starting thread 0
03/14/06 16:07:05 4036 DataStore datastore.py:1550 DEBUG Worker 0 starting
03/14/06 16:07:05 2428 DataStore datastore.py:1544 DEBUG Waiting thread 0
03/14/06 16:07:05 2428 DataStore datastore.py:1547 DEBUG Done creating workers
03/14/06 16:07:05 2428 DataStore datastore.py:278 DEBUG Reading persisted data from: C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\personalDataStore\DataStore.dat
03/14/06 16:07:05 2428 VenueClient venueclient.py:210 DEBUG __createPersonalDataStore: Load personal data from file
03/14/06 16:07:05 2428 VenueClientController venueclientcontroller.py:1255 DEBUG There is no personal venues file to load.
03/14/06 16:07:15 2428 CertificateRepository certificaterepository.py:592 DEBUG Register observer <bound method ProxyBrowser.OnRepoUpdate of <AccessGrid.Security.wxgui.ProxyBrowser.ProxyBrowser; proxy of C++ wxPanel instance at _c04ed701_p_wxPanel>>
03/14/06 16:07:15 2428 CertificateRepository certificaterepository.py:594 DEBUG Adding <weakref at 020DA2D0; to 'instancemethod' at 020D8A30 (OnRepoUpdate)>
03/14/06 16:07:15 2428 CertificateRepository certificaterepository.py:592 DEBUG Register observer <bound method IdentityBrowser.OnRepoUpdate of <AccessGrid.Security.wxgui.IdentityBrowser.IdentityBrowser; proxy of C++ wxPanel instance at _18dd1002_p_wxPanel>>
03/14/06 16:07:15 2428 CertificateRepository certificaterepository.py:594 DEBUG Adding <weakref at 020DA5A0; to 'instancemethod' at 020D8B98 (OnRepoUpdate)>
03/14/06 16:07:15 2428 CertificateRepository certificaterepository.py:592 DEBUG Register observer <bound method CABrowser.OnRepoUpdate of <AccessGrid.Security.wxgui.CABrowser.CABrowser; proxy of C++ wxPanel instance at _28c9f001_p_wxPanel>>
03/14/06 16:07:15 2428 CertificateRepository certificaterepository.py:594 DEBUG Adding <weakref at 020DA7B0; to 'instancemethod' at 020D8D78 (OnRepoUpdate)>
03/14/06 16:07:15 2428 CertificateRepository certificaterepository.py:592 DEBUG Register observer <bound method CertificateStatusBrowser.OnRepoUpdate of <AccessGrid.Security.wxgui.CertificateStatusBrowser.CertificateStatusBrowser; proxy of C++ wxPanel instance at _d009f101_p_wxPanel>>
03/14/06 16:07:15 2428 CertificateRepository certificaterepository.py:594 DEBUG Adding <weakref at 020DAB70; to 'instancemethod' at 020D8FA8 (OnRepoUpdate)>
03/14/06 16:14:47 2428 CertificateRepository certificaterepository.py:129 ERROR Could not open certificate file
03/14/06 16:15:06 2428 CertificateRepository certificaterepository.py:133 INFO Found valid cert, validKey=1
03/14/06 16:15:07 2428 CertificateRepository certificaterepository.py:133 INFO Found valid cert, validKey=1
03/14/06 16:15:11 2428 CertificateRepository certificaterepository.py:741 ERROR load error
File "C:\Python23\Lib\site-packages\AccessGrid\Security\CertificateRepository.py", line 738, in ImportCertificatePEM
passphrase)
Error: [('digital envelope routines', 'EVP_DecryptFinal', 'bad decrypt'), ('PEM routines', 'PEM_do_header', 'bad decrypt')]
03/14/06 16:15:11 2428 CertificateManagerWXGUI importexportutils.py:792 ERROR Import fails: Incorrect passphrase. cert file S:\AG\jtvh\cert-exp-12-2006.pem keyfile S:\AG\jtvh\cert-exp-12-2006.pem
File "C:\Python23\Lib\site-packages\AccessGrid\Security\wxgui\ImportExportUtils.py", line 775, in ImportPEMIdentityCertificate
certFile, keyFile, cb)
File "C:\Python23\Lib\site-packages\AccessGrid\Security\CertificateManager.py", line 465, in ImportIdentityCertificatePEM
impCert = repo.ImportCertificatePEM(userCert, userKey, passphraseCB)
File "C:\Python23\Lib\site-packages\AccessGrid\Security\CertificateRepository.py", line 742, in ImportCertificatePEM
raise RepoBadPassphrase
RepoBadPassphrase
03/14/06 16:15:16 2428 CertificateRepository certificaterepository.py:129 ERROR Could not open certificate file
03/14/06 16:15:19 2428 CertificateRepository certificaterepository.py:133 INFO Found valid cert, validKey=1
03/14/06 16:15:21 2428 CertificateRepository certificaterepository.py:133 INFO Found valid cert, validKey=1
03/14/06 16:15:24 2428 CertificateRepository certificaterepository.py:952 INFO _ImportPrivateKey importing pkey to C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\privatekeys\b6ea2d1e21eb850bef7b799ce043d5e9.pem
03/14/06 16:15:24 2428 CertificateRepository certificaterepository.py:889 DEBUG _ImportCertificate: create C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\certificates\9469dc4861d79549ca6a9e6a2ed4909f\7fd839972fa295d09928e28808b848ea
03/14/06 16:15:25 2428 CertificateManagerWXGUI importexportutils.py:776 DEBUG Imported identity /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=bu.edu/CN=Jennifer Teig von Hoffman
03/14/06 16:15:25 2428 CertificateManagerWXGUI importexportutils.py:834 DEBUG ID certs: [<AccessGrid.Security.CertificateRepository.CertificateDescriptor instance at 0x02132918>]
03/14/06 16:15:25 2428 CertificateManager certificatemanager.py:759 DEBUG Configuring standard environment
03/14/06 16:15:25 2428 CertificateManager certificatemanager.py:827 DEBUG Using default identity /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 4a250eb4e3231f2abbe3d4021c330646
03/14/06 16:15:25 2428 CertificateManager certificatemanager.py:1083 DEBUG Initializing environment with unencrypted cert /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 4a250eb4e3231f2abbe3d4021c330646
03/14/06 16:15:25 2428 CertificateManager certificatemanager.py:1098 INFO Setting permissions on certificate C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\certificates\5cf11fcf8b5d698d7eb3ccdba1980efb\99514c538e7a32167c1699b16c025df4\cert.pem to 644
03/14/06 16:15:25 2428 CertificateManager certificatemanager.py:1109 INFO Setting permissions on certificate C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\privatekeys\b82eff976e60282028802c8814e23901.pem to 600
03/14/06 16:15:30 2428 CertificateManager certificatemanager.py:759 DEBUG Configuring standard environment
03/14/06 16:15:30 2428 CertificateManager certificatemanager.py:827 DEBUG Using default identity /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=bu.edu/CN=Jennifer Teig von Hoffman
03/14/06 16:15:30 2428 CertificateManager certificatemanager.py:902 DEBUG Initializing environment with proxy cert for /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=bu.edu/CN=Jennifer Teig von Hoffman
03/14/06 16:15:30 2428 CertificateManager certificatemanager.py:968 DEBUG _VerifyGlobusProxy: file C:\DOCUME~1\jtvh\LOCALS~1\Temp\proxy not found
03/14/06 16:15:40 2428 CertificateManagerWXGUI certificatemanagerwxgui.py:550 DEBUG Proxy successfully created
03/14/06 16:15:40 2428 CertificateManager certificatemanager.py:759 DEBUG Configuring standard environment
03/14/06 16:15:40 2428 CertificateManager certificatemanager.py:827 DEBUG Using default identity /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=bu.edu/CN=Jennifer Teig von Hoffman
03/14/06 16:15:40 2428 CertificateManager certificatemanager.py:902 DEBUG Initializing environment with proxy cert for /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=bu.edu/CN=Jennifer Teig von Hoffman
03/14/06 16:15:40 2428 CertificateManager certificatemanager.py:1011 INFO Verifying local proxy cert
03/14/06 16:15:40 2428 CertificateManager certificatemanager.py:921 DEBUG Configuring for user proxy issued from /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=bu.edu/CN=Jennifer Teig von Hoffman
03/14/06 16:15:40 2428 CertificateManager certificatemanager.py:924 DEBUG Proxy C:\DOCUME~1\jtvh\LOCALS~1\Temp\proxy will expire 03/15/06 05:15:40
03/14/06 16:15:40 2428 CertificateManagerWXGUI certificatemanagerwxgui.py:422 DEBUG done, success=1
03/14/06 16:18:36 2428 VenueClient venueclient.py:805 DEBUG EnterVenue; url=https://vv2.mcs.anl.gov:9000/Venues/default
03/14/06 16:18:36 2428 CertificateManager certificatemanager.py:1011 INFO Verifying local proxy cert
03/14/06 16:18:36 2428 CertificateManager certificatemanager.py:663 DEBUG HaveValidProxy: found proxy ident /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=bu.edu/CN=Jennifer Teig von Hoffman/CN=proxy
03/14/06 16:18:36 2428 VenueClient venueclient.py:833 INFO EnterVenue: Error getting node capabilities
03/14/06 16:18:36 2428 VenueClient venueclient.py:705 DEBUG EnterVenue: Invoke venue enter
03/14/06 16:18:36 2428 VenueClient venueclient.py:866 ERROR EnterVenue: failed
return t.build()
03/14/06 16:18:36 2428 VenueClient venueclientui.py:1925 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://vv2.mcs.anl.gov:9000/Venues/default
03/14/06 16:18:36 2428 VenueClient venueclientui.py:1938 DEBUG warningString:
03/14/06 16:18:42 2428 VenueClient venueclient.py:1343 INFO Error enabling video
03/14/06 16:18:44 2428 VenueClient venueclient.py:1349 INFO Error enabling audio
03/14/06 16:19:06 2428 VenueClient venueclientui.py:1565 INFO --------- END VenueClient
03/14/06 16:19:06 2428 DataStore datastore.py:1614 DEBUG Quitting thread 0
03/14/06 16:19:06 4036 DataStore datastore.py:1555 DEBUG Worker 0 gets cmd quit
03/14/06 16:19:06 4036 DataStore datastore.py:1568 DEBUG Worker 0 exiting
03/14/06 16:19:06 4032 DataStore datastore.py:1627 INFO GSIHTTPTransferServer: GSITCPSocket, interrupted I/O operation, most likely shutting down.
03/14/06 16:19:06 2428 NodeService agnodeservice.py:136 INFO NodeService.Stop
03/14/06 16:19:06 2428 ServiceManager agservicemanager.py:84 INFO AGServiceManager.Shutdown
03/14/06 16:19:06 2428 ServiceManager agservicemanager.py:85 INFO Remove services
03/14/06 16:19:06 2428 ServiceManager agservicemanager.py:389 INFO AGServiceManager.RemoveServices
03/14/06 16:19:06 2428 ServiceManager agservicemanager.py:87 INFO Stop network interface
03/14/06 16:19:06 2084 Hosting server.py:65 ERROR Exception in SOAP server main loop
raise ex
03/14/06 16:19:06 2428 Hosting server.py:97 ERROR server_close() failed
self.socket.close()
IOBase.close(self)
raise ex
self.socket.close()
IOBase.close(self)
raise ex
03/15/06 11:34:51 444 Toolkit config.py:214 DEBUG System hostname of SCV-BADTZ.ad.bu.edu is valid
03/15/06 11:34:51 444 CertificateManager certificatemanager.py:269 DEBUG Opened repository C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo
03/15/06 11:34:52 444 Toolkit toolkit.py:404 DEBUG looking in system ca dir: C:\Program Files\AGTk-2.4\Config\CAcertificates
03/15/06 11:34:52 444 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\1c3f2ca8.0 might be a cert
03/15/06 11:34:52 444 Toolkit toolkit.py:440 INFO Certificate 1c3f2ca8.0 already in repository
03/15/06 11:34:52 444 Toolkit toolkit.py:456 INFO Marking cert as CA cert
03/15/06 11:34:52 444 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\certificates\a82c3f1c4b096b896061778ee79efeff\9c8df64aa35ebf832613413527bc073d\user_files\signing_policy
03/15/06 11:34:52 444 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\45cc9e80.0 might be a cert
03/15/06 11:34:52 444 Toolkit toolkit.py:440 INFO Certificate 45cc9e80.0 already in repository
03/15/06 11:34:52 444 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\certificates\809ecc45460c1482e61e26bdfbf9e18c\9f380c9a586af2bb913ace809d5badfe\user_files\signing_policy
03/15/06 11:34:52 444 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\d1b603c3.0 might be a cert
03/15/06 11:34:52 444 Toolkit toolkit.py:440 INFO Certificate d1b603c3.0 already in repository
03/15/06 11:34:52 444 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\certificates\c303b6d10c962b37482e68ca64d383a0\05a2039fe10ed1b4195d9f9d35b32c68\user_files\signing_policy
03/15/06 11:34:52 444 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\f18fa857.0 might be a cert
03/15/06 11:34:52 444 Toolkit toolkit.py:440 INFO Certificate f18fa857.0 already in repository
03/15/06 11:34:52 444 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\certificates\57a88ff1707d87e926f2287c702a8466\eff65f03366cb8e20247f831ccc87fd5\user_files\signing_policy
03/15/06 11:34:52 444 Toolkit toolkit.py:478 DEBUG Init'ing globus.
03/15/06 11:34:53 444 CertificateManager certificatemanager.py:759 DEBUG Configuring standard environment
03/15/06 11:34:53 444 CertificateManager certificatemanager.py:827 DEBUG Using default identity /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=bu.edu/CN=Jennifer Teig von Hoffman
03/15/06 11:34:53 444 CertificateManager certificatemanager.py:902 DEBUG Initializing environment with proxy cert for /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=bu.edu/CN=Jennifer Teig von Hoffman
03/15/06 11:34:53 444 CertificateManager certificatemanager.py:1011 INFO Verifying local proxy cert
03/15/06 11:34:53 444 CertificateManager certificatemanager.py:1024 DEBUG _VerifyGlobusProxy: proxy C:\DOCUME~1\jtvh\LOCALS~1\Temp\proxy expired
03/15/06 11:35:01 444 CertificateManagerWXGUI certificatemanagerwxgui.py:550 DEBUG Proxy successfully created
03/15/06 11:35:01 444 CertificateManager certificatemanager.py:759 DEBUG Configuring standard environment
03/15/06 11:35:01 444 CertificateManager certificatemanager.py:827 DEBUG Using default identity /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=bu.edu/CN=Jennifer Teig von Hoffman
03/15/06 11:35:01 444 CertificateManager certificatemanager.py:902 DEBUG Initializing environment with proxy cert for /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=bu.edu/CN=Jennifer Teig von Hoffman
03/15/06 11:35:01 444 CertificateManager certificatemanager.py:1011 INFO Verifying local proxy cert
03/15/06 11:35:01 444 CertificateManager certificatemanager.py:921 DEBUG Configuring for user proxy issued from /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=bu.edu/CN=Jennifer Teig von Hoffman
03/15/06 11:35:01 444 CertificateManager certificatemanager.py:924 DEBUG Proxy C:\DOCUME~1\jtvh\LOCALS~1\Temp\proxy will expire 03/16/06 00:35:01
03/15/06 11:35:01 444 CertificateManagerWXGUI certificatemanagerwxgui.py:422 DEBUG done, success=1
03/15/06 11:35:01 444 Toolkit toolkit.py:482 DEBUG Done with globus.
03/15/06 11:35:01 444 Toolkit venueclient.py:83 INFO wx version is: 2.5.1.5
03/15/06 11:35:01 444 VenueClient venueclient.py:287 DEBUG __StartWebService: venueclient: https://SCV-BADTZ.ad.bu.edu:11000/VenueClient
03/15/06 11:35:01 444 ServiceManager agservicemanager.py:75 INFO Using services dir: C:\Documents and Settings\jtvh\Application Data\AccessGrid\local_services
03/15/06 11:35:01 444 ServiceManager agservicemanager.py:424 INFO __DiscoverResources
03/15/06 11:35:01 444 Toolkit config.py:997 INFO Using vfwscan to get devices
03/15/06 11:35:01 444 Toolkit config.py:998 DEBUG vfwscanexe = C:\PROGRA~1\AGTk-2.4\bin\vfwscan.exe
03/15/06 11:35:01 444 Toolkit config.py:1003 DEBUG filelines = ['Microsoft WDM Image Capture (Win32)\n']
03/15/06 11:35:01 444 Toolkit config.py:1031 INFO GetResources: ['Microsoft WDM Image Capture (Win32)']
03/15/06 11:35:01 444 VenueClient venueclient.py:296 DEBUG __StartWebService: service manager: https://SCV-BADTZ.ad.bu.edu:11000/ServiceManager
03/15/06 11:35:01 444 NodeService agnodeservice.py:756 INFO NodeService.__ReadConfigFile
03/15/06 11:35:01 444 Toolkit toolkit.py:335 DEBUG Looking for: C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\AGNodeService.cfg
03/15/06 11:35:01 444 Toolkit toolkit.py:340 DEBUG Looking for: C:\Program Files\AGTk-2.4\Config\AGNodeService.cfg
03/15/06 11:35:01 444 NodeService agnodeservice.py:764 DEBUG DEFAULT NODE SERVICE CONFIG: C:\Program Files\AGTk-2.4\Config\AGNodeService.cfg
03/15/06 11:35:01 444 NodeService agnodeservice.py:768 INFO Reading node service config file: C:\Program Files\AGTk-2.4\Config\AGNodeService.cfg
03/15/06 11:35:01 444 VenueClient venueclient.py:302 DEBUG __StartWebService: node service: https://SCV-BADTZ.ad.bu.edu:11000/NodeService
03/15/06 11:35:01 444 VenueClient venueclient.py:1328 DEBUG SerNodeUrl: Set node service url: https://SCV-BADTZ.ad.bu.edu:11000/NodeService
03/15/06 11:35:01 444 NodeService agnodeservice.py:698 INFO NodeService.GetDefaultConfiguration
03/15/06 11:35:02 444 NodeService agnodeservice.py:581 INFO Migration unnecessary
03/15/06 11:35:02 444 NodeService agnodeservice.py:374 INFO NodeService.LoadDefaultConfig
03/15/06 11:35:02 444 NodeService agnodeservice.py:378 INFO Loading default node configuration: defaultWindows
03/15/06 11:35:02 444 NodeService agnodeservice.py:392 INFO NodeService.LoadConfiguration
03/15/06 11:35:02 444 NodeService agnodeservice.py:407 INFO Trying to load node configuration from: C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\nodeConfig\defaultWindows
03/15/06 11:35:02 444 NodeService agnodeservice.py:480 INFO AddServiceManager: Invalid service manager url (https://localhost:11000/ServiceManager)
03/15/06 11:35:02 444 NodeService agnodeservice.py:381 ERROR Exception loading default configuration.
03/15/06 11:35:02 444 VenueClient venueclient.py:313 ERROR Error loading default configuration
03/15/06 11:35:02 444 VenueClient venueclient.py:185 DEBUG __createPersonalDataStore: Creating personal datastore at C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\personalDataStore using prefix personalDataStore and port 0
03/15/06 11:35:02 444 DataStore datastore.py:1537 DEBUG Creating thread 0
03/15/06 11:35:02 444 DataStore datastore.py:1542 DEBUG Starting thread 0
03/15/06 11:35:02 284 DataStore datastore.py:1550 DEBUG Worker 0 starting
03/15/06 11:35:02 444 DataStore datastore.py:1544 DEBUG Waiting thread 0
03/15/06 11:35:02 444 DataStore datastore.py:1547 DEBUG Done creating workers
03/15/06 11:35:02 444 DataStore datastore.py:278 DEBUG Reading persisted data from: C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\personalDataStore\DataStore.dat
03/15/06 11:35:02 444 VenueClient venueclient.py:210 DEBUG __createPersonalDataStore: Load personal data from file
03/15/06 11:35:02 444 VenueClientController venueclientcontroller.py:1255 DEBUG There is no personal venues file to load.
03/15/06 11:35:22 444 CertificateRepository certificaterepository.py:592 DEBUG Register observer <bound method ProxyBrowser.OnRepoUpdate of <AccessGrid.Security.wxgui.ProxyBrowser.ProxyBrowser; proxy of C++ wxPanel instance at _c04ed701_p_wxPanel>>
03/15/06 11:35:22 444 CertificateRepository certificaterepository.py:594 DEBUG Adding <weakref at 020DB270; to 'instancemethod' at 020D6A58 (OnRepoUpdate)>
03/15/06 11:35:22 444 CertificateRepository certificaterepository.py:592 DEBUG Register observer <bound method IdentityBrowser.OnRepoUpdate of <AccessGrid.Security.wxgui.IdentityBrowser.IdentityBrowser; proxy of C++ wxPanel instance at _d028de01_p_wxPanel>>
03/15/06 11:35:22 444 CertificateRepository certificaterepository.py:594 DEBUG Adding <weakref at 020DB540; to 'instancemethod' at 020D6AD0 (OnRepoUpdate)>
03/15/06 11:35:22 444 CertificateRepository certificaterepository.py:592 DEBUG Register observer <bound method CABrowser.OnRepoUpdate of <AccessGrid.Security.wxgui.CABrowser.CABrowser; proxy of C++ wxPanel instance at _6886e301_p_wxPanel>>
03/15/06 11:35:22 444 CertificateRepository certificaterepository.py:594 DEBUG Adding <weakref at 020DB750; to 'instancemethod' at 020D6C38 (OnRepoUpdate)>
03/15/06 11:35:22 444 CertificateRepository certificaterepository.py:592 DEBUG Register observer <bound method CertificateStatusBrowser.OnRepoUpdate of <AccessGrid.Security.wxgui.CertificateStatusBrowser.CertificateStatusBrowser; proxy of C++ wxPanel instance at _f003ef01_p_wxPanel>>
03/15/06 11:35:22 444 CertificateRepository certificaterepository.py:594 DEBUG Adding <weakref at 020DBB10; to 'instancemethod' at 020DF030 (OnRepoUpdate)>
03/15/06 11:35:43 444 VenueClient venueclient.py:805 DEBUG EnterVenue; url=https://vv2.mcs.anl.gov:9000/Venues/default
03/15/06 11:35:43 444 CertificateManager certificatemanager.py:1011 INFO Verifying local proxy cert
03/15/06 11:35:43 444 CertificateManager certificatemanager.py:663 DEBUG HaveValidProxy: found proxy ident /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=bu.edu/CN=Jennifer Teig von Hoffman/CN=proxy
03/15/06 11:35:43 444 VenueClient venueclient.py:833 INFO EnterVenue: Error getting node capabilities
03/15/06 11:35:43 444 VenueClient venueclient.py:705 DEBUG EnterVenue: Invoke venue enter
03/15/06 11:35:43 444 VenueClient venueclient.py:866 ERROR EnterVenue: failed
Traceback (most recent call last):
return t.build()
03/15/06 11:35:43 444 VenueClient venueclientui.py:1925 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://vv2.mcs.anl.gov:9000/Venues/default
03/15/06 11:35:43 444 VenueClient venueclientui.py:1938 DEBUG warningString:
03/15/06 11:37:41 444 VenueClient venueclient.py:805 DEBUG EnterVenue; url=https://venues.ncsa.uiuc.edu:9000/Venues/default
03/15/06 11:37:41 444 CertificateManager certificatemanager.py:1011 INFO Verifying local proxy cert
03/15/06 11:37:41 444 CertificateManager certificatemanager.py:663 DEBUG HaveValidProxy: found proxy ident /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=bu.edu/CN=Jennifer Teig von Hoffman/CN=proxy
03/15/06 11:37:41 444 VenueClient venueclient.py:833 INFO EnterVenue: Error getting node capabilities
03/15/06 11:37:41 444 VenueClient venueclient.py:705 DEBUG EnterVenue: Invoke venue enter
03/15/06 11:37:41 444 VenueClient venueclient.py:866 ERROR EnterVenue: failed
return t.build()
03/15/06 11:37:41 444 VenueClient venueclientui.py:1925 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://venues.ncsa.uiuc.edu:9000/Venues/default
03/15/06 11:37:41 444 VenueClient venueclientui.py:1938 DEBUG warningString:
03/15/06 11:39:38 444 VenueClient venueclientui.py:1565 INFO --------- END VenueClient
03/15/06 11:39:38 444 DataStore datastore.py:1614 DEBUG Quitting thread 0
03/15/06 11:39:38 284 DataStore datastore.py:1555 DEBUG Worker 0 gets cmd quit
03/15/06 11:39:38 284 DataStore datastore.py:1568 DEBUG Worker 0 exiting
03/15/06 11:39:38 444 NodeService agnodeservice.py:136 INFO NodeService.Stop
03/15/06 11:39:38 444 ServiceManager agservicemanager.py:84 INFO AGServiceManager.Shutdown
03/15/06 11:39:38 444 ServiceManager agservicemanager.py:85 INFO Remove services
03/15/06 11:39:38 444 ServiceManager agservicemanager.py:389 INFO AGServiceManager.RemoveServices
03/15/06 11:39:38 444 ServiceManager agservicemanager.py:87 INFO Stop network interface
03/15/06 11:39:38 1732 DataStore datastore.py:1627 INFO GSIHTTPTransferServer: GSITCPSocket, interrupted I/O operation, most likely shutting down.
03/15/06 11:39:38 3836 Hosting server.py:65 ERROR Exception in SOAP server main loop
raise ex
03/15/06 11:39:38 444 Hosting server.py:97 ERROR server_close() failed
self.socket.close()
IOBase.close(self)
raise ex
self.socket.close()
IOBase.close(self)
raise ex
03/15/06 11:40:54 240 Toolkit toolkit.py:96 DEBUG Initializing AG Toolkit version 2.4 (build 1)
03/15/06 11:40:54 240 Toolkit toolkit.py:138 INFO Logfile Name: VenueClient.log
03/15/06 11:40:54 240 Toolkit config.py:196 DEBUG Using GLOBUS_HOSTNAME=SCV-BADTZ.ad.bu.edu as set in the environment
03/15/06 11:40:54 240 CertificateManager certificatemanager.py:269 DEBUG Opened repository C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo
03/15/06 11:40:54 240 Toolkit toolkit.py:404 DEBUG looking in system ca dir: C:\Program Files\AGTk-2.4\Config\CAcertificates
03/15/06 11:40:54 240 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\1c3f2ca8.0 might be a cert
03/15/06 11:40:54 240 Toolkit toolkit.py:440 INFO Certificate 1c3f2ca8.0 already in repository
03/15/06 11:40:54 240 Toolkit toolkit.py:456 INFO Marking cert as CA cert
03/15/06 11:40:54 240 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\certificates\a82c3f1c4b096b896061778ee79efeff\9c8df64aa35ebf832613413527bc073d\user_files\signing_policy
03/15/06 11:40:54 240 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\45cc9e80.0 might be a cert
03/15/06 11:40:54 240 Toolkit toolkit.py:440 INFO Certificate 45cc9e80.0 already in repository
03/15/06 11:40:54 240 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\certificates\809ecc45460c1482e61e26bdfbf9e18c\9f380c9a586af2bb913ace809d5badfe\user_files\signing_policy
03/15/06 11:40:54 240 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\d1b603c3.0 might be a cert
03/15/06 11:40:54 240 Toolkit toolkit.py:440 INFO Certificate d1b603c3.0 already in repository
03/15/06 11:40:54 240 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\certificates\c303b6d10c962b37482e68ca64d383a0\05a2039fe10ed1b4195d9f9d35b32c68\user_files\signing_policy
03/15/06 11:40:54 240 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\f18fa857.0 might be a cert
03/15/06 11:40:54 240 Toolkit toolkit.py:440 INFO Certificate f18fa857.0 already in repository
03/15/06 11:40:54 240 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\certificates\57a88ff1707d87e926f2287c702a8466\eff65f03366cb8e20247f831ccc87fd5\user_files\signing_policy
03/15/06 11:40:54 240 Toolkit toolkit.py:478 DEBUG Init'ing globus.
03/15/06 11:40:54 240 CertificateManager certificatemanager.py:759 DEBUG Configuring standard environment
03/15/06 11:40:54 240 CertificateManager certificatemanager.py:827 DEBUG Using default identity /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=bu.edu/CN=Jennifer Teig von Hoffman
03/15/06 11:40:54 240 CertificateManager certificatemanager.py:902 DEBUG Initializing environment with proxy cert for /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=bu.edu/CN=Jennifer Teig von Hoffman
03/15/06 11:40:54 240 CertificateManager certificatemanager.py:1011 INFO Verifying local proxy cert
03/15/06 11:40:54 240 CertificateManager certificatemanager.py:921 DEBUG Configuring for user proxy issued from /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=bu.edu/CN=Jennifer Teig von Hoffman
03/15/06 11:40:54 240 CertificateManager certificatemanager.py:924 DEBUG Proxy C:\DOCUME~1\jtvh\LOCALS~1\Temp\proxy will expire 03/16/06 00:35:01
03/15/06 11:40:54 240 CertificateManagerWXGUI certificatemanagerwxgui.py:422 DEBUG done, success=1
03/15/06 11:40:54 240 Toolkit toolkit.py:482 DEBUG Done with globus.
03/15/06 11:40:54 240 Toolkit venueclient.py:83 INFO wx version is: 2.5.1.5
03/15/06 11:40:55 240 VenueClient venueclient.py:287 DEBUG __StartWebService: venueclient: https://SCV-BADTZ.ad.bu.edu:11000/VenueClient
03/15/06 11:40:55 240 ServiceManager agservicemanager.py:75 INFO Using services dir: C:\Documents and Settings\jtvh\Application Data\AccessGrid\local_services
03/15/06 11:40:55 240 ServiceManager agservicemanager.py:424 INFO __DiscoverResources
03/15/06 11:40:55 240 Toolkit config.py:997 INFO Using vfwscan to get devices
03/15/06 11:40:55 240 Toolkit config.py:998 DEBUG vfwscanexe = C:\PROGRA~1\AGTk-2.4\bin\vfwscan.exe
03/15/06 11:40:55 240 Toolkit config.py:1003 DEBUG filelines = ['Microsoft WDM Image Capture (Win32)\n']
03/15/06 11:40:55 240 Toolkit config.py:1031 INFO GetResources: ['Microsoft WDM Image Capture (Win32)']
03/15/06 11:40:55 240 VenueClient venueclient.py:296 DEBUG __StartWebService: service manager: https://SCV-BADTZ.ad.bu.edu:11000/ServiceManager
03/15/06 11:40:55 240 NodeService agnodeservice.py:756 INFO NodeService.__ReadConfigFile
03/15/06 11:40:55 240 Toolkit toolkit.py:335 DEBUG Looking for: C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\AGNodeService.cfg
03/15/06 11:40:55 240 Toolkit toolkit.py:340 DEBUG Looking for: C:\Program Files\AGTk-2.4\Config\AGNodeService.cfg
03/15/06 11:40:55 240 NodeService agnodeservice.py:764 DEBUG DEFAULT NODE SERVICE CONFIG: C:\Program Files\AGTk-2.4\Config\AGNodeService.cfg
03/15/06 11:40:55 240 NodeService agnodeservice.py:768 INFO Reading node service config file: C:\Program Files\AGTk-2.4\Config\AGNodeService.cfg
03/15/06 11:40:55 240 VenueClient venueclient.py:302 DEBUG __StartWebService: node service: https://SCV-BADTZ.ad.bu.edu:11000/NodeService
03/15/06 11:40:55 240 VenueClient venueclient.py:1328 DEBUG SerNodeUrl: Set node service url: https://SCV-BADTZ.ad.bu.edu:11000/NodeService
03/15/06 11:40:55 240 NodeService agnodeservice.py:698 INFO NodeService.GetDefaultConfiguration
03/15/06 11:40:55 240 NodeService agnodeservice.py:581 INFO Migration unnecessary
03/15/06 11:40:55 240 NodeService agnodeservice.py:374 INFO NodeService.LoadDefaultConfig
03/15/06 11:40:55 240 NodeService agnodeservice.py:378 INFO Loading default node configuration: defaultWindows
03/15/06 11:40:55 240 NodeService agnodeservice.py:392 INFO NodeService.LoadConfiguration
03/15/06 11:40:55 240 NodeService agnodeservice.py:407 INFO Trying to load node configuration from: C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\nodeConfig\defaultWindows
03/15/06 11:40:55 240 NodeService agnodeservice.py:480 INFO AddServiceManager: Invalid service manager url (https://localhost:11000/ServiceManager)
03/15/06 11:40:55 240 NodeService agnodeservice.py:381 ERROR Exception loading default configuration.
03/15/06 11:40:55 240 VenueClient venueclient.py:313 ERROR Error loading default configuration
03/15/06 11:40:55 240 VenueClient venueclient.py:185 DEBUG __createPersonalDataStore: Creating personal datastore at C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\personalDataStore using prefix personalDataStore and port 0
03/15/06 11:40:55 240 DataStore datastore.py:1537 DEBUG Creating thread 0
03/15/06 11:40:55 240 DataStore datastore.py:1542 DEBUG Starting thread 0
03/15/06 11:40:55 2996 DataStore datastore.py:1550 DEBUG Worker 0 starting
03/15/06 11:40:55 240 DataStore datastore.py:1544 DEBUG Waiting thread 0
03/15/06 11:40:55 240 DataStore datastore.py:1547 DEBUG Done creating workers
03/15/06 11:40:55 240 DataStore datastore.py:278 DEBUG Reading persisted data from: C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\personalDataStore\DataStore.dat
03/15/06 11:40:55 240 VenueClient venueclient.py:210 DEBUG __createPersonalDataStore: Load personal data from file
03/15/06 11:40:55 240 VenueClientController venueclientcontroller.py:1255 DEBUG There is no personal venues file to load.
03/15/06 11:40:55 240 VenueClient venueclient.py:805 DEBUG EnterVenue; url=https://venues.ncsa.uiuc.edu:9000/Venues/default
03/15/06 11:40:55 240 CertificateManager certificatemanager.py:1011 INFO Verifying local proxy cert
03/15/06 11:40:55 240 CertificateManager certificatemanager.py:663 DEBUG HaveValidProxy: found proxy ident /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=bu.edu/CN=Jennifer Teig von Hoffman/CN=proxy
03/15/06 11:40:55 240 VenueClient venueclient.py:833 INFO EnterVenue: Error getting node capabilities
03/15/06 11:40:55 240 VenueClient venueclient.py:705 DEBUG EnterVenue: Invoke venue enter
03/15/06 11:40:55 240 VenueClient venueclient.py:866 ERROR EnterVenue: failed
return t.build()
03/15/06 11:40:55 240 VenueClient venueclientui.py:1925 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://venues.ncsa.uiuc.edu:9000/Venues/default
03/15/06 11:40:55 240 VenueClient venueclientui.py:1938 DEBUG warningString:
03/15/06 11:41:01 240 VenueClient venueclientui.py:1565 INFO --------- END VenueClient
03/15/06 11:41:01 240 DataStore datastore.py:1614 DEBUG Quitting thread 0
03/15/06 11:41:01 2996 DataStore datastore.py:1555 DEBUG Worker 0 gets cmd quit
03/15/06 11:41:01 2996 DataStore datastore.py:1568 DEBUG Worker 0 exiting
03/15/06 11:41:01 3376 DataStore datastore.py:1627 INFO GSIHTTPTransferServer: GSITCPSocket, interrupted I/O operation, most likely shutting down.
03/15/06 11:41:01 240 NodeService agnodeservice.py:136 INFO NodeService.Stop
03/15/06 11:41:01 240 ServiceManager agservicemanager.py:84 INFO AGServiceManager.Shutdown
03/15/06 11:41:01 240 ServiceManager agservicemanager.py:85 INFO Remove services
03/15/06 11:41:01 240 ServiceManager agservicemanager.py:389 INFO AGServiceManager.RemoveServices
03/15/06 11:41:01 240 ServiceManager agservicemanager.py:87 INFO Stop network interface
03/15/06 11:41:01 1340 Hosting server.py:65 ERROR Exception in SOAP server main loop
raise ex
03/15/06 11:41:01 240 Hosting server.py:97 ERROR server_close() failed
self.socket.close()
IOBase.close(self)
raise ex
self.socket.close()
IOBase.close(self)
raise ex
03/15/06 11:42:29 2300 Toolkit config.py:214 DEBUG System hostname of SCV-BADTZ.ad.bu.edu is valid
03/15/06 11:42:29 2300 CertificateManager certificatemanager.py:269 DEBUG Opened repository C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo
03/15/06 11:42:29 2300 Toolkit toolkit.py:404 DEBUG looking in system ca dir: C:\Program Files\AGTk-2.4\Config\CAcertificates
03/15/06 11:42:29 2300 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\1c3f2ca8.0 might be a cert
03/15/06 11:42:29 2300 Toolkit toolkit.py:440 INFO Certificate 1c3f2ca8.0 already in repository
03/15/06 11:42:29 2300 Toolkit toolkit.py:456 INFO Marking cert as CA cert
03/15/06 11:42:29 2300 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\certificates\a82c3f1c4b096b896061778ee79efeff\9c8df64aa35ebf832613413527bc073d\user_files\signing_policy
03/15/06 11:42:29 2300 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\45cc9e80.0 might be a cert
03/15/06 11:42:29 2300 Toolkit toolkit.py:440 INFO Certificate 45cc9e80.0 already in repository
03/15/06 11:42:29 2300 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\certificates\809ecc45460c1482e61e26bdfbf9e18c\9f380c9a586af2bb913ace809d5badfe\user_files\signing_policy
03/15/06 11:42:29 2300 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\d1b603c3.0 might be a cert
03/15/06 11:42:29 2300 Toolkit toolkit.py:440 INFO Certificate d1b603c3.0 already in repository
03/15/06 11:42:29 2300 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\certificates\c303b6d10c962b37482e68ca64d383a0\05a2039fe10ed1b4195d9f9d35b32c68\user_files\signing_policy
03/15/06 11:42:29 2300 Toolkit toolkit.py:418 INFO C:\Program Files\AGTk-2.4\Config\CAcertificates\f18fa857.0 might be a cert
03/15/06 11:42:29 2300 Toolkit toolkit.py:440 INFO Certificate f18fa857.0 already in repository
03/15/06 11:42:29 2300 Toolkit toolkit.py:469 INFO Imported signing policy as C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\certRepo\certificates\57a88ff1707d87e926f2287c702a8466\eff65f03366cb8e20247f831ccc87fd5\user_files\signing_policy
03/15/06 11:42:29 2300 Toolkit toolkit.py:478 DEBUG Init'ing globus.
03/15/06 11:42:29 2300 CertificateManager certificatemanager.py:759 DEBUG Configuring standard environment
03/15/06 11:42:29 2300 CertificateManager certificatemanager.py:827 DEBUG Using default identity /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=bu.edu/CN=Jennifer Teig von Hoffman
03/15/06 11:42:29 2300 CertificateManager certificatemanager.py:902 DEBUG Initializing environment with proxy cert for /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=bu.edu/CN=Jennifer Teig von Hoffman
03/15/06 11:42:29 2300 CertificateManager certificatemanager.py:1011 INFO Verifying local proxy cert
03/15/06 11:42:29 2300 CertificateManager certificatemanager.py:921 DEBUG Configuring for user proxy issued from /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=bu.edu/CN=Jennifer Teig von Hoffman
03/15/06 11:42:29 2300 CertificateManager certificatemanager.py:924 DEBUG Proxy C:\DOCUME~1\jtvh\LOCALS~1\Temp\proxy will expire 03/16/06 00:35:01
03/15/06 11:42:29 2300 CertificateManagerWXGUI certificatemanagerwxgui.py:422 DEBUG done, success=1
03/15/06 11:42:29 2300 Toolkit toolkit.py:482 DEBUG Done with globus.
03/15/06 11:42:29 2300 Toolkit venueclient.py:83 INFO wx version is: 2.5.1.5
03/15/06 11:42:29 2300 VenueClient venueclient.py:287 DEBUG __StartWebService: venueclient: https://SCV-BADTZ.ad.bu.edu:11000/VenueClient
03/15/06 11:42:29 2300 ServiceManager agservicemanager.py:75 INFO Using services dir: C:\Documents and Settings\jtvh\Application Data\AccessGrid\local_services
03/15/06 11:42:29 2300 ServiceManager agservicemanager.py:424 INFO __DiscoverResources
03/15/06 11:42:29 2300 Toolkit config.py:997 INFO Using vfwscan to get devices
03/15/06 11:42:29 2300 Toolkit config.py:998 DEBUG vfwscanexe = C:\PROGRA~1\AGTk-2.4\bin\vfwscan.exe
03/15/06 11:42:30 2300 Toolkit config.py:1003 DEBUG filelines = ['Microsoft WDM Image Capture (Win32)\n']
03/15/06 11:42:30 2300 Toolkit config.py:1031 INFO GetResources: ['Microsoft WDM Image Capture (Win32)']
03/15/06 11:42:30 2300 VenueClient venueclient.py:296 DEBUG __StartWebService: service manager: https://SCV-BADTZ.ad.bu.edu:11000/ServiceManager
03/15/06 11:42:30 2300 NodeService agnodeservice.py:756 INFO NodeService.__ReadConfigFile
03/15/06 11:42:30 2300 Toolkit toolkit.py:335 DEBUG Looking for: C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\AGNodeService.cfg
03/15/06 11:42:30 2300 Toolkit toolkit.py:340 DEBUG Looking for: C:\Program Files\AGTk-2.4\Config\AGNodeService.cfg
03/15/06 11:42:30 2300 NodeService agnodeservice.py:764 DEBUG DEFAULT NODE SERVICE CONFIG: C:\Program Files\AGTk-2.4\Config\AGNodeService.cfg
03/15/06 11:42:30 2300 NodeService agnodeservice.py:768 INFO Reading node service config file: C:\Program Files\AGTk-2.4\Config\AGNodeService.cfg
03/15/06 11:42:30 2300 VenueClient venueclient.py:302 DEBUG __StartWebService: node service: https://SCV-BADTZ.ad.bu.edu:11000/NodeService
03/15/06 11:42:30 2300 VenueClient venueclient.py:1328 DEBUG SerNodeUrl: Set node service url: https://SCV-BADTZ.ad.bu.edu:11000/NodeService
03/15/06 11:42:30 2300 NodeService agnodeservice.py:698 INFO NodeService.GetDefaultConfiguration
03/15/06 11:42:30 2300 NodeService agnodeservice.py:581 INFO Migration unnecessary
03/15/06 11:42:30 2300 NodeService agnodeservice.py:374 INFO NodeService.LoadDefaultConfig
03/15/06 11:42:30 2300 NodeService agnodeservice.py:378 INFO Loading default node configuration: defaultWindows
03/15/06 11:42:30 2300 NodeService agnodeservice.py:392 INFO NodeService.LoadConfiguration
03/15/06 11:42:30 2300 NodeService agnodeservice.py:407 INFO Trying to load node configuration from: C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\nodeConfig\defaultWindows
03/15/06 11:42:30 2300 NodeService agnodeservice.py:480 INFO AddServiceManager: Invalid service manager url (https://localhost:11000/ServiceManager)
03/15/06 11:42:30 2300 NodeService agnodeservice.py:381 ERROR Exception loading default configuration.
File "C:\Python23\Lib\site-packages\AccessGrid\AGNodeService.py", line 379, in LoadDefaultConfig
self.LoadConfiguration( self.defaultConfig )
File "C:\Python23\Lib\site-packages\AccessGrid\AGNodeService.py", line 523, in LoadConfiguration
raise Exception(exceptionText)
Exception: Couldn't reach service manager: localhost:11000
03/15/06 11:42:30 2300 VenueClient venueclient.py:313 ERROR Error loading default configuration
File "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line 311, in __StartWebService
self.ns.LoadDefaultConfig()
File "C:\Python23\Lib\site-packages\AccessGrid\AGNodeService.py", line 382, in LoadDefaultConfig
raise Exception("Failed to load default configuration <%s>" %
Exception: Failed to load default configuration <defaultWindows>
03/15/06 11:42:30 2300 VenueClient venueclient.py:185 DEBUG __createPersonalDataStore: Creating personal datastore at C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\personalDataStore using prefix personalDataStore and port 0
03/15/06 11:42:30 2300 DataStore datastore.py:1537 DEBUG Creating thread 0
03/15/06 11:42:30 2300 DataStore datastore.py:1542 DEBUG Starting thread 0
03/15/06 11:42:30 1608 DataStore datastore.py:1550 DEBUG Worker 0 starting
03/15/06 11:42:30 2300 DataStore datastore.py:1544 DEBUG Waiting thread 0
03/15/06 11:42:30 2300 DataStore datastore.py:1547 DEBUG Done creating workers
03/15/06 11:42:30 2300 DataStore datastore.py:278 DEBUG Reading persisted data from: C:\Documents and Settings\jtvh\Application Data\AccessGrid\Config\personalDataStore\DataStore.dat
03/15/06 11:42:30 2300 VenueClient venueclient.py:210 DEBUG __createPersonalDataStore: Load personal data from file
03/15/06 11:42:30 2300 VenueClientController venueclientcontroller.py:1255 DEBUG There is no personal venues file to load.
03/15/06 11:42:37 2300 VenueClient venueclient.py:805 DEBUG EnterVenue; url=https://vv2.mcs.anl.gov:9000/Venues/default
03/15/06 11:42:37 2300 CertificateManager certificatemanager.py:1011 INFO Verifying local proxy cert
03/15/06 11:42:37 2300 CertificateManager certificatemanager.py:663 DEBUG HaveValidProxy: found proxy ident /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=bu.edu/CN=Jennifer Teig von Hoffman/CN=proxy
03/15/06 11:42:37 2300 VenueClient venueclient.py:833 INFO EnterVenue: Error getting node capabilities
03/15/06 11:42:37 2300 VenueClient venueclient.py:705 DEBUG EnterVenue: Invoke venue enter
03/15/06 11:42:37 2300 VenueClient venueclient.py:866 ERROR EnterVenue: failed
return t.build()
03/15/06 11:42:37 2300 VenueClient venueclientui.py:1925 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://vv2.mcs.anl.gov:9000/Venues/default
03/15/06 11:42:37 2300 VenueClient venueclientui.py:1938 DEBUG warningString:
03/15/06 11:45:42 2300 VenueClient venueclientui.py:1565 INFO --------- END VenueClient
03/15/06 11:45:42 2300 DataStore datastore.py:1614 DEBUG Quitting thread 0
03/15/06 11:45:42 1608 DataStore datastore.py:1555 DEBUG Worker 0 gets cmd quit
03/15/06 11:45:42 1608 DataStore datastore.py:1568 DEBUG Worker 0 exiting
03/15/06 11:45:42 3752 DataStore datastore.py:1627 INFO GSIHTTPTransferServer: GSITCPSocket, interrupted I/O operation, most likely shutting down.
03/15/06 11:45:42 2300 NodeService agnodeservice.py:136 INFO NodeService.Stop
03/15/06 11:45:42 2300 ServiceManager agservicemanager.py:84 INFO AGServiceManager.Shutdown
03/15/06 11:45:42 2300 ServiceManager agservicemanager.py:85 INFO Remove services
03/15/06 11:45:42 2300 ServiceManager agservicemanager.py:389 INFO AGServiceManager.RemoveServices
03/15/06 11:45:42 2300 ServiceManager agservicemanager.py:87 INFO Stop network interface
03/15/06 11:45:42 1120 Hosting server.py:65 ERROR Exception in SOAP server main loop
File "C:\Python23\Lib\site-packages\AccessGrid\hosting\SOAPpy\Server.py", line 63, in Run
self._server.handle_request()
File "C:\Python23\lib\SocketServer.py", line 217, in handle_request
request, client_address = self.get_request()
File "C:\Python23\Lib\site-packages\SOAPpy\GSIServer.py", line 140, in get_request
sock, addr = ThreadingGSITCPSocketServer.get_request(self)
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 525, in get_request
self.socket.listen()
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 857, in listen
raise ex
GSITCPSocketException: an I/O operation was cancelled
03/15/06 11:45:42 2300 Hosting server.py:97 ERROR server_close() failed
File "C:\Python23\Lib\site-packages\AccessGrid\hosting\SOAPpy\Server.py", line 95, in Stop
self._server.server_close()
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1043, in server_close
self.socket.close()
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1020, in close
IOBase.close(self)
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 176, in close
raise ex
IOBaseException: an uninitialied data structure was passed as argument 1 to globus_io_register_close
self.socket.close()
IOBase.close(self)
raise ex
