[AG-TECH] Libeay32.dll error installing AG
Fabrizio.Berdondini at prototipo.it
Thu Mar 9 02:19:54 CST 2006
Hello Tom,
on this machine I installed the "standard" package proposed on the AG
site:
Python 2.3.5
Python Win32 extensions for Python 2.3
wxPython 2.6 (Active State)
thanx as always for your support,
Faber B.
"Thomas D. Uram" <turam at mcs.anl.gov> scritti il 03/03/2006 20.18.48
> Hello Fabrizio:
> Can you say which version of Python is installed on this machine? And,
> is it the ActiveState Python, or python.org install?
> Tom
> On 2/20/06 2:45 AM, Fabrizio.Berdondini at prototipo.it wrote:
> > Hello,
> > I tried to install AccessGrid onto a fellow notebook, running Windows
> > XP Pro SP2, and I got the following error "The ordinal number 3212
could
> > not be found in LIBEAY32.DLL". I saw he had a "wrong" versionof that
dll
> > under the folder windows\system32 so I replaced it with the version I
> > found installed on my notebook (which runs AG correctly) but no luck.
I
> > also tried to see if there was other instances of that dll on his PC:
I
> > found three other different version of it, due to other installed
> > programs using the openSSL. I tried to rename all instances of
> > libeay32.dll on his PC about the one under system32, I also
> > checked/removed locations of the other libeay32.dll from the system
path
> > but no luck: the error simply changed ordinal: 968 instead of 3212.
> > Unfortunately I cannot remove the programs using the libeay32.dll
> > (versions different from the one used by AG) because my fellow uses
them
> > for working at customer's home (they are VPN applications). Is there
> > some trick/workaround for installing AG on his PC without "tampering"
> > those applications?
> > Thank you for support,
> > Faber B.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20060309/5823d653/attachment.htm>
