[AG-TECH] AG3 venue management can't connect
    Javier Gomez Alonso
    Javier.Gomez-Alonso at manchester.ac.uk
    Thu Jun 29 10:25:39 CDT 2006
I am running an AG3 venue server under Fedora Core 5 x86_64. When I run the Venue Server with a service certificate, and then try to connect to it with the Venue Manager (from the same machine), I cannot establish the connection. I have not changed the default certificate, so I think I should be able to connect. Any ideas? I attach the debug information for reference. Many thanks,
 - Javi
06/29/2006 03:14:23 PM 46912496279184 VenueManagement     VenueManagement:261 DEBUG There is no my servers file to load.
06/29/2006 03:14:23 PM 46912496279184 Toolkit     Config.py:559 DEBUG System hostname of gimli.ag.manchester.ac.uk is valid
06/29/2006 03:14:23 PM 46912496279184 Toolkit     Toolkit.py:109 DEBUG Initializing AG Toolkit version 3.0.1
06/29/2006 03:14:23 PM 46912496279184 Toolkit     Toolkit.py:110 INFO  Command and arguments: ['/usr/bin/VenueManagement', '-d']
06/29/2006 03:14:23 PM 46912496279184 Platform     Config.py:779 INFO  gnome directory /home/ag/.gnome/application-info or /home/ag/.gnome/mime-info not found, not registering file type .agpkg3 with gnome
06/29/2006 03:14:23 PM 46912496279184 Platform     Config.py:779 INFO  gnome directory /home/ag/.gnome/application-info or /home/ag/.gnome/mime-info not found, not registering file type .vv3d with gnome
06/29/2006 03:14:23 PM 46912496279184 VenueClient     Preferences.py:180 DEBUG Preferences.LoadPreferences: open file
06/29/2006 03:14:23 PM 46912496279184 Toolkit     Toolkit.py:159 INFO  Logfile Name: VenueManagement.log
06/29/2006 03:14:23 PM 46912496279184 CertificateManager     CertificateManager.py:204 DEBUG Opened repository /home/ag/.AccessGrid3/Config/certRepo
06/29/2006 03:14:23 PM 46912496279184 Toolkit     Toolkit.py:429 INFO  Initialized certificate manager.
06/29/2006 03:14:23 PM 46912496279184 CertificateManager     CertificateManager.py:529 DEBUG Configuring standard environment
06/29/2006 03:14:23 PM 46912496279184 CertificateManager     CertificateManager.py:580 DEBUG Using default identity /O=Access Grid/OU=agdev-ca.mcs.anl.gov/CN=VenueServer/gimli.ag.manchester.ac.uk
06/29/2006 03:14:32 PM 46912496279184 VenueManagement     VenueManagement:414 DEBUG VenueManagementClient.ConnectToServer: Connect to server https://localhost:8000/VenueServer
VenueManagement   06/29/2006 03:14:32 PM DEBUG VenueManagementClient.ConnectToServer: Connect to server https://localhost:8000/VenueServer
06/29/2006 03:14:32 PM 46912496279184 VenueManagement     VenueManagement:422 DEBUG VenueManagementClient.ConnectToServer: Connect to server
06/29/2006 03:14:32 PM 46912496279184 VenueManagement     VenueManagement:429 DEBUG VenueManagementClient.ConnectToServer: Get venues from server
VenueManagement   06/29/2006 03:14:32 PM DEBUG VenueManagementClient.ConnectToServer: Get venues from server
06/29/2006 03:14:32 PM 46912496279184 VenueManagement     VenueManagement:513 ERROR VenueManagementClient.ConnectToServer: Can not connect.:
Traceback (most recent call last):
  File "/usr/bin/VenueManagement", line 432, in ConnectToServer
    vl = self.server.GetVenues()
  File "/usr/lib/python2.4/site-packages/AccessGrid/interfaces/VenueServer_client.py", line 142, in GetVenues
    self.binding.Send(None, None, request, soapaction="urn:#GetVenues", **kw)
  File "/usr/lib/python2.4/site-packages/ZSI/client.py", line 254, in Send
    self.h.connect()
  File "/usr/lib64/python2.4/httplib.py", line 1072, in connect
    sock.connect((self.host, self.port))
  File "<string>", line 1, in connect
error: (111, 'Connection refused')
VenueManagement   06/29/2006 03:14:32 PM ERROR VenueManagementClient.ConnectToServer: Can not connect.:
    self.h.connect()
