[AG-TECH] VenueServer woes
    Thomas D. Uram
    turam at mcs.anl.gov
    Thu Jun 29 09:38:09 CDT 2006
Can you provide more of the log?  You can send it to me privately rather
than to the list.
How are venues on the server addressed?  Does each venue have addresses
assigned to
it, or are the addresses dynamically allocated?  (dynamic allocation is
the default).
Tom
On 6/29/06 9:17 AM, Niall Moran wrote:
> Here is an extract from the log files where the problem occurred.
> 06/28/06 10:38:03 245776 Hosting     Server.py:65 ERROR Exception in SOAP server main loop
> Traceback (most recent call last):
>   File "/usr/lib/python2.4/site-packages/AccessGrid/hosting/SOAPpy/Server.py", line 63, in Run
>     self._server.handle_request()
>   File "/usr/lib/python2.4/SocketServer.py", line 217, in handle_request
>     request, client_address = self.get_request()
>   File "/usr/lib/python2.4/site-packages/SOAPpy/GSIServer.py", line 140, in get_request
>     sock, addr = ThreadingGSITCPSocketServer.get_request(self)
>   File "/usr/lib/python2.4/site-packages/pyGlobus/io.py", line 846, in get_request
>     raise(str(self.socket) + str(" is having trouble listening!:" + str(ex.args)))
> <pyGlobus.io.GSITCPSocket instance at 0xb716062c> is having trouble listening!:('an I/O operation was cancelled',)
> 06/28/06 10:38:03 16384 VenueServer     VenueServer.py:646 INFO                                done.
> 06/28/06 10:38:03 131081 DataStore     DataStore.py:1629 ERROR Exception handling request
>   File "/usr/lib/python2.4/site-packages/AccessGrid/DataStore.py", line 1625, in thread_run
>     self.handle_request()
> <pyGlobus.io.GSITCPSocket instance at 0xb6a65e0c> is having trouble listening!:('an I/O operation was cancelled',)
> 06/28/06 10:38:03 16384 VenueServer     VenueServer.py:648 INFO  Shutdown Complete.
> 06/28/06 10:38:03 114696 DataStore     DataStore.py:1555 DEBUG Worker 3 gets cmd quit
> 06/28/06 10:38:03 16384 Toolkit     VenueServer.py:116 DEBUG After main loop!
> 06/28/06 10:38:03 98311 DataStore     DataStore.py:1568 DEBUG Worker 2 exiting
> 06/28/06 10:38:03 16384 Hosting     Server.py:97 ERROR server_close() failed
>   File "/usr/lib/python2.4/site-packages/AccessGrid/hosting/SOAPpy/Server.py", line 95, in Stop
>     self._server.server_close()
>   File "/usr/lib/python2.4/site-packages/pyGlobus/io.py", line 1375, in server_close
>     self.socket.close()
>   File "/usr/lib/python2.4/site-packages/pyGlobus/io.py", line 1348, in close
>     IOBase.close(self)
>   File "/usr/lib/python2.4/site-packages/pyGlobus/io.py", line 264, in close
>     raise ex
> IOBaseException: an uninitialied data structure was passed as argument 1 to globus_io_register_close
> 06/28/06 10:38:03 114696 DataStore     DataStore.py:1568 DEBUG Worker 3 exiting
> 06/28/06 10:38:03 16384 Toolkit     VenueServer.py:121 DEBUG Stopped Hosting Environment, exiting.
> 06/28/06 10:38:03 16384 Toolkit     VenueServer.py:127 DEBUG Thread <_MainThread(MainThread, started)>
> 06/28/06 10:38:03 16384 Toolkit     VenueServer.py:127 DEBUG Thread <_DummyThread(Dummy-7, started daemon)>
> 06/28/06 10:38:03 16384 Toolkit     VenueServer.py:127 DEBUG Thread <Thread(ConnectionMonitor.Run, started)>
> 06/28/06 10:38:03 16384 Toolkit     VenueServer.py:127 DEBUG Thread <Thread(Thread-23, started)>
> 06/28/06 10:38:03 16384 Toolkit     VenueServer.py:127 DEBUG Thread <_DummyThread(Dummy-24, started daemon)>
> 06/28/06 10:38:03 16384 Toolkit     VenueServer.py:127 DEBUG Thread <_DummyThread(Dummy-25, started daemon)>
> 06/28/06 10:38:03 16384 Toolkit     VenueServer.py:127 DEBUG Thread <_DummyThread(Dummy-26, started daemon)>
> 06/28/06 16:46:37 16384 ProxyGen     ProxyGen.py:558 DEBUG Using GT24 proxy code
> 06/28/06 16:46:37 16384 Toolkit     Toolkit.py:96 DEBUG Initializing AG Toolkit version 2.4 (build 0)
> 06/28/06 16:46:37 16384 Toolkit     Toolkit.py:138 INFO  Logfile Name: VenueServer.log
> 06/28/06 16:46:45 16384 Toolkit     Toolkit.py:709 INFO  Service init: have profile None
> 06/28/06 16:46:45 16384 Toolkit     Config.py:214 DEBUG System hostname of icarus.ichec.ie is valid
> 06/28/06 16:46:45 16384 CertificateManager     CertificateManager.py:269 DEBUG Opened repository /home/ag2user/.AccessGrid/Config/certRepo
> 06/28/06 16:46:45 16384 Toolkit     Toolkit.py:738 INFO  Initialized cert mgmt.
> 06/28/06 16:46:45 16384 Toolkit     Toolkit.py:753 INFO  Loaded profile and configured with it.
> 06/28/06 16:46:45 16384 CertificateManager     CertificateManager.py:759 DEBUG Configuring standard environment
> 06/28/06 16:46:45 16384 CertificateManager     CertificateManager.py:827 DEBUG Using default identity /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 8dfa3c134968ca0afd2fff7b6e462d25
> 06/28/06 16:46:45 16384 CertificateManager     CertificateManager.py:1083 DEBUG Initializing environment with unencrypted cert /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 8dfa3c134968ca0afd2fff7b6e462d25
> 06/28/06 16:46:45 16384 CertificateManager     CertificateManager.py:1572 DEBUG done, success=1
> 06/28/06 16:46:45 16384 Toolkit     Toolkit.py:764 INFO  Initialized Globus.
> Cheers,
> Niall.
