[AG-TECH] Is MatchMaker needed?
Bonnett, PG (Paul)
P.G.Bonnett at rl.ac.uk
Wed Jun 28 05:01:47 CDT 2006
Zephyr,
Yes you do need one.
The Clear one kit is all balanced signals, so you need to convert these
both to go in & out of the PC system and possibly if you use an
amplifier remotely without balanced inputs.
You can however 'cheat' sometimes and get away with acceptable results
(I do it in one of our rooms and no-one has noticed).
http://www.dplay.com/dv/balance/balance.html
see section on Connecting Balanced...
However, as an audiophile who runs a balanced home Hi-Fi system, I
should be telling you not to do this; and I don't know how the different
loading affects the Clear One unit on a long term basis.
Paul
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
Behalf Of Zephyr Zhangbo Liu
Sent: 27 June 2006 19:06
To: ag-tech at mcs.anl.gov
Subject: [AG-TECH] Is MatchMaker needed?
Just wondering if we have XAP 400, do we still need to MatchMaker (such
as MM100) to do the signal balancing?
Zephyr
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20060628/d945a1ab/attachment.htm>
