[AG-TECH] VideoPresence and Unicast: looking for a VIC replacement when bridged
Rhys Hawkins
Rhys.Hawkins at anu.edu.au
Mon Jun 5 20:16:15 CDT 2006
Hi Fabrizio,
VP does handle unicast. There is a known issue where if you have VIC
and VP running then only VIC receives the video packets due to the
different ways VIC and VP bind to the receiving port. Could you please
confirm that you were running VIC at the same time and that you're
using windows? Otherwise its a separate issue.
Cheers,
Rhys
On Mon, 2006-06-05 at 10:24 +0200, Fabrizio.Berdondini at prototipo.it
wrote:
> Hello all,
> while inside our LAN, using multicast, we found very useful the
> VideoPresence tool as a replacement of standard VIC (easier interface
> for less experienced users, just needing a videoference personal node,
> no needs of tools for sharing applications and datas).
> However, while conferencing with people outside our network, leaning
> on our unicast bridge, the VP tool becomes useless (it works only with
> a multicast configuration). Is there some similar replacement for the
> VIC which could be used with a unicast bridge too?
> Furthermore, we read something about the development of an "enhanced
> VIC" that has been showed up during the 2006 AG Retreat. We thought it
> may be suitable for our solution and so wondering if this tool is
> going to be somehow distributed, even for trial/testing.
> Thank you in advance,
> Faber B.
