[AG-TECH] Probs starting VIC&RAT on AGTK3.01 winxp
    Thomas D. Uram
    turam at mcs.anl.gov
    Fri Jun  2 08:14:01 CDT 2006
I would expect to find some conflict like the one you've already sought.
In addition to looking for files like "c:\documents" , have you looked for
a conflict with "c:\documents and settings\jww\application" ?
The fact that it worked at some point and has stopped makes me suspect
that a conflicting file has appeared in one of these locations.
We'll fix this problem in a future release.  Let me know how things work
out for you so we can be sure to address the problem you're seeing, if
it turns out to be something new.
Tom
Sebastian Adams wrote:
> Hi there,
> One of the machines here has an odd prob starting the vic & rat executables. Example error:
> eg audioservice.log
> 06/02/06 12:00:27 2984 Toolkit     agservice.py:182 INFO  SetStream: ignoring trivial re-configuration
> 06/02/06 12:00:27 2984 Toolkit     audioservice.py:274 INFO  Starting AudioService
> 06/02/06 12:00:27 2984 Toolkit     audioservice.py:275 INFO   executable = C:\Documents and Settings\JWW\Application Data\AccessGrid3\local_services\AudioService\rat.exe
> 06/02/06 12:00:27 2984 Toolkit     audioservice.py:277 INFO   options = ['-C', u'AGSC Venue Server Lobby', '-S', u'c0ab9a180f6c420a2c48365f6d2f3d12', '-f', 'L16-16K-Mono', u'sam.ag.manchester.ac.uk/10824']
> 06/02/06 12:00:27 2960 ProcessManager     processmanager.py:138 ERROR couldn't shutdown process <PyHANDLE:660>: (1444, 'PostThreadMessage', 'Invalid thread identifier.')
> Traceback (most recent call last):
>   File "C:\Python23\lib\site-packages\AccessGrid3\AccessGrid\Platform\win32\ProcessManager.py", line 131, in TerminateProcess
>     win32api.PostThreadMessage(self.threadid[pid], 18, 0, 0)
> error: (1444, 'PostThreadMessage', 'Invalid thread identifier.')
> 06/02/06 12:00:27 2984 ProcessManager     processmanager.py:62 DEBUG Creating process: C:\Documents and Settings\JWW\Application Data\AccessGrid3\local_services\AudioService\rat.exe -C "AGSC Venue Server Lobby" -S c0ab9a180f6c420a2c48365f6d2f3d12 -f L16-16K-Mono sam.ag.manchester.ac.uk/10824
> 06/02/06 12:00:27 2984 ProcessManager     processmanager.py:100 ERROR process creation failed: (193, 'CreateProcess', '%1 is not a valid Win32 application.')
>   File "C:\Python23\lib\site-packages\AccessGrid3\AccessGrid\Platform\win32\ProcessManager.py", line 73, in StartProcess
>     startup_info)
> error: (193, 'CreateProcess', '%1 is not a valid Win32 application.')
> similarlarly for vic (videoproducerservice.log):
> 06/02/06 12:14:08 2884 Toolkit     videoproducerservice.py:324 INFO    enabled: 1
> 06/02/06 12:14:08 2884 Toolkit     agservice.py:171 INFO  SetStream: [consume
> ster.ac.uk 10194
> 06/02/06 12:14:08 2884 Toolkit     videoproducerservice.py:175 INFO  Mapping windows device: Logitech QuickCam Pro 4000
> 06/02/06 12:14:08 2884 Toolkit     videoproducerservice.py:303 INFO  Starting VideoProducerService
> 06/02/06 12:14:08 2884 Toolkit     videoproducerservice.py:304 INFO   executable = C:\Documents and Settings\JWW\Application Data\AccessGrid3\local_services\VideoProducerService\vic.exe
> 06/02/06 12:14:08 2884 Toolkit     videoproducerservice.py:305 INFO   options = ['-u', 'C:/DOCUME~1/JWW/LOCALS~1/Temp/VideoProducerService_2920.vic', '-C', 'Logitech QuickCam Pro 4000', '-X', u'site=c0ab9a180f6c420a2c48365f6d2f3d12', u'sam.ag.manchester.ac.uk/10194']
> 06/02/06 12:14:08 2884 ProcessManager     processmanager.py:62 DEBUG Creating process: C:\Documents and Settings\JWW\Application Data\AccessGrid3\local_services\VideoProducerService\vic.exe -u C:/DOCUME~1/JWW/LOCALS~1/Temp/VideoProducerService_2920.vic -C "Logitech QuickCam Pro 4000" -X site=c0ab9a180f6c420a2c48365f6d2f3d12 sam.ag.manchester.ac.uk/10194
> 06/02/06 12:14:08 2884 ProcessManager     processmanager.py:100 ERROR process creation failed: (193, 'CreateProcess', '%1 is not a valid Win32 application.')
>     startup_info)
> So it looks like python getting confused with the path/arguments or somesuch? I have checked that there isn't a directory called c:\documents which could cause this prob.
> I can start (without probs) vic & rat with the correct arguments via command line.
> At first I thought it was another application (statistica) installed on the PC which uses the .svc extension for macros - but have uninstalled that without resolution.
> AGTK has worked the machine in the past but has stopped working at some point (both agtk 2.4 & 3.01 exhibit the same prob).
> Many thanks, Seb
> Seb Adams
> CEH Computer Support
> Tel 01524 595818
