[AG-TECH] Probs starting VIC&RAT on AGTK3.01 winxp
    Sebastian Adams
    sad at ceh.ac.uk
    Fri Jun  2 06:55:39 CDT 2006
Hi there,
One of the machines here has an odd prob starting the vic & rat executables. Example error:
eg audioservice.log
06/02/06 12:00:27 2984 Toolkit     agservice.py:182 INFO  SetStream: ignoring trivial re-configuration
06/02/06 12:00:27 2984 Toolkit     audioservice.py:274 INFO  Starting AudioService
06/02/06 12:00:27 2984 Toolkit     audioservice.py:275 INFO   executable = C:\Documents and Settings\JWW\Application Data\AccessGrid3\local_services\AudioService\rat.exe
06/02/06 12:00:27 2984 Toolkit     audioservice.py:277 INFO   options = ['-C', u'AGSC Venue Server Lobby', '-S', u'c0ab9a180f6c420a2c48365f6d2f3d12', '-f', 'L16-16K-Mono', u'sam.ag.manchester.ac.uk/10824']
06/02/06 12:00:27 2960 ProcessManager     processmanager.py:138 ERROR couldn't shutdown process <PyHANDLE:660>: (1444, 'PostThreadMessage', 'Invalid thread identifier.')
Traceback (most recent call last):
  File "C:\Python23\lib\site-packages\AccessGrid3\AccessGrid\Platform\win32\ProcessManager.py", line 131, in TerminateProcess
    win32api.PostThreadMessage(self.threadid[pid], 18, 0, 0)
error: (1444, 'PostThreadMessage', 'Invalid thread identifier.')
06/02/06 12:00:27 2984 ProcessManager     processmanager.py:62 DEBUG Creating process: C:\Documents and Settings\JWW\Application Data\AccessGrid3\local_services\AudioService\rat.exe -C "AGSC Venue Server Lobby" -S c0ab9a180f6c420a2c48365f6d2f3d12 -f L16-16K-Mono sam.ag.manchester.ac.uk/10824
06/02/06 12:00:27 2984 ProcessManager     processmanager.py:100 ERROR process creation failed: (193, 'CreateProcess', '%1 is not a valid Win32 application.')
  File "C:\Python23\lib\site-packages\AccessGrid3\AccessGrid\Platform\win32\ProcessManager.py", line 73, in StartProcess
    startup_info)
error: (193, 'CreateProcess', '%1 is not a valid Win32 application.')
similarlarly for vic (videoproducerservice.log):
06/02/06 12:14:08 2884 Toolkit     videoproducerservice.py:324 INFO    enabled: 1
06/02/06 12:14:08 2884 Toolkit     agservice.py:171 INFO  SetStream: [consume
ster.ac.uk 10194
06/02/06 12:14:08 2884 Toolkit     videoproducerservice.py:175 INFO  Mapping windows device: Logitech QuickCam Pro 4000
06/02/06 12:14:08 2884 Toolkit     videoproducerservice.py:303 INFO  Starting VideoProducerService
06/02/06 12:14:08 2884 Toolkit     videoproducerservice.py:304 INFO   executable = C:\Documents and Settings\JWW\Application Data\AccessGrid3\local_services\VideoProducerService\vic.exe
06/02/06 12:14:08 2884 Toolkit     videoproducerservice.py:305 INFO   options = ['-u', 'C:/DOCUME~1/JWW/LOCALS~1/Temp/VideoProducerService_2920.vic', '-C', 'Logitech QuickCam Pro 4000', '-X', u'site=c0ab9a180f6c420a2c48365f6d2f3d12', u'sam.ag.manchester.ac.uk/10194']
06/02/06 12:14:08 2884 ProcessManager     processmanager.py:62 DEBUG Creating process: C:\Documents and Settings\JWW\Application Data\AccessGrid3\local_services\VideoProducerService\vic.exe -u C:/DOCUME~1/JWW/LOCALS~1/Temp/VideoProducerService_2920.vic -C "Logitech QuickCam Pro 4000" -X site=c0ab9a180f6c420a2c48365f6d2f3d12 sam.ag.manchester.ac.uk/10194
06/02/06 12:14:08 2884 ProcessManager     processmanager.py:100 ERROR process creation failed: (193, 'CreateProcess', '%1 is not a valid Win32 application.')
    startup_info)
So it looks like python getting confused with the path/arguments or somesuch? I have checked that there isn't a directory called c:\documents which could cause this prob.
I can start (without probs) vic & rat with the correct arguments via command line.
At first I thought it was another application (statistica) installed on the PC which uses the .svc extension for macros - but have uninstalled that without resolution.
AGTK has worked the machine in the past but has stopped working at some point (both agtk 2.4 & 3.01 exhibit the same prob).
Many thanks, Seb
Seb Adams
CEH Computer Support
Tel 01524 595818
This message (and any attachments) is for the recipient only. NERC
is subject to the Freedom of Information Act 2000 and the contents
of this email and any reply you make may be disclosed by NERC unless
it is exempt from release under the Act. Any material supplied to
NERC may be stored in an electronic records management system.
