[AG-TECH]too much Bitrate in RAT
Andrew A Rowley
Andrew.Rowley at manchester.ac.uk
Fri Jul 21 04:28:26 CDT 2006
Note that to be compatible with InSORS IGAudio, I think we are restricted to L16-16K-MONO (256kbps), PCMU-16K-MONO (128kbps) and PCMU-8K-MONO (64kpbs). Of the PCMU codecs, the 16K Mono one should be of the same quality as L16.
This depends on how important this interoperability is in your meetings - presumably if there was a move to another codec in general, I would guess that InSORS would consider implementing this in IGAudio too, but I wouldn't like to speak for them on this.
Andrew :)
Access Grid Support Centre,
RSS Group,
Manchester Computing,
Kilburn Building,
University of Manchester,
Oxford Road,
Manchester,
M13 9PL,
UK
Tel: +44(0)161-275 0685
Email: Andrew.Rowley at manchester.ac.uk
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
> Behalf Of Colin Perkins
> Sent: 20 July 2006 18:54
> To: John Hodrien
> Cc: ag-tech
> Subject: Re: [AG-TECH]too much Bitrate in RAT
> On 20 Jul 2006, at 17:05, John Hodrien wrote:
> > On Thu, 20 Jul 2006, Robert Olson wrote:
> >> It may be historical. When we started out the compressed codecs
> >> seemed to be much less stable.
> > I'm not sure that's not still the case. We had no end of problem
> > using GSM
> > under windows with rat crashing.
> > There's also the other bonus. If you compress, you always
> > introduce a 1 frame delay to the audio.
> The way rat works, you always get that delay, no matter what codec is
> selected.
> Colin
