[AG-TECH] Re: Shared Presentation
Mike Daley
Mike.W.Daley at cs.cardiff.ac.uk
Tue Jul 18 10:25:01 CDT 2006
I should also say that I did download the SharedPresentation.py file.
The last message makes it sound as if I only downloaded the .app
Mike
Mike Daley wrote:
> Hi Tom
> Still no luck I am using version 1.46 from CVS is this the right
> version. Do I need any of the other files in that directory apart from
> SharedPresenter.app.
> The other thing I should have mentioned was that the "Open for all
> participants" does not work either, the remote sites do not get the
> usual pop up box, is this part of the same problem.
> One last thing agpm3.py assumes the file path for imports is on a UNIX
> system. I had to modify it to install the new SharedPresentation.
> Many Thanks
> Mike
> Thomas D. Uram wrote:
>> Hi Mike:
>> It's a known bug that's fixed in cvs and will be included in an
>> upcoming update release.
>> http://bugzilla.mcs.anl.gov/accessgrid/show_bug.cgi?id=1531
>> Tom
>> On 7/17/06 10:05 AM, Mike.W.Daley at cs.cardiff.ac.uk wrote:
>>> Hi Tom
>>> We are having problems with Shared Presentaion in AG3.0
>>> The remote site cannot see the slide change. If you run the monitor
>>> you can see the remote sites connect and you can see who is master
>>> you can see the master change and what slide is currently supposed
>>> to be showing. Any ideas. Has anyone else tried?
>>> Many Thanks
>>> Mike
>>> This message was sent using IMP, the Internet Messaging Program.
