[AG-TECH] Re: Shared Presentation
Mike Daley
Mike.W.Daley at cs.cardiff.ac.uk
Tue Jul 18 10:16:41 CDT 2006
Hi Tom
Still no luck I am using version 1.46 from CVS is this the right
version. Do I need any of the other files in that directory apart from
SharedPresenter.app.
The other thing I should have mentioned was that the "Open for all
participants" does not work either, the remote sites do not get the
usual pop up box, is this part of the same problem.
One last thing agpm3.py assumes the file path for imports is on a UNIX
system. I had to modify it to install the new SharedPresentation.
Many Thanks
Mike
Thomas D. Uram wrote:
> Hi Mike:
> It's a known bug that's fixed in cvs and will be included in an
> upcoming update release.
> http://bugzilla.mcs.anl.gov/accessgrid/show_bug.cgi?id=1531
> Tom
> On 7/17/06 10:05 AM, Mike.W.Daley at cs.cardiff.ac.uk wrote:
>> Hi Tom
>> We are having problems with Shared Presentaion in AG3.0
>> The remote site cannot see the slide change. If you run the monitor
>> you can see the remote sites connect and you can see who is master
>> you can see the master change and what slide is currently supposed to
>> be showing. Any ideas. Has anyone else tried?
>> Many Thanks
>> Mike
>> This message was sent using IMP, the Internet Messaging Program.
