[AG-TECH] Bridge Server problmes?
    Thomas D. Uram
    turam at mcs.anl.gov
    Mon Jan 30 13:01:48 CST 2006
One point:  If the venue uses statically assigned multicast addresses, the
bridgeserver should bridge them
at the start.  If not, multicast addresses will be allocated when someone
enters the venue, at which point
the bridge will be triggered.  If you're in the second camp, then it's possible
that your seeing the intended
behavior.
Does the logfile reveal anything about the startup of the bridgeserver?
Tom
On 1/30/06 12:49 PM, G.T. Chiang wrote:
> Dear Tom
>  the following is our bridge.conf. we use the same just using different
> venue server and it works.
> Best Regard!!
>         mike
> [BridgeServer]
> name = NIEeS-bridge
> location = Cambridge
> #qbexec = /usr/local/bin/QuickBridge
> qbexec = /usr/bin/QuickBridge
> portMin = 30000 portMax = 40000
> [https://bridge.escience.cam.ac.uk:8000/Venues/000001091b36c0bd007f000000000001b29]
> type = Venue
> On Jan 30 2006, Thomas D. Uram wrote:
>> Hi Mike:
>> If your CA and certs from CA are being used on the venue server you're
>> trying to bridge, you should not have a problem. Can you post the
>> bridge.conf file ?
>> Tom
>> On 1/30/06 7:52 AM, G.T. Chiang wrote:
>>> Dear All
>>>   we are trying to set our bridge server. we are running venues
>>> server at same mahcines for testing. however, when we start the
>>> bridge server using BridgeServer.py -c bridge.conf
>>> it is hanging there, i fi chekc the log it stop at 01/30/06 12:13:07
>>> -1208039744 Toolkit BridgeServer.py:720 INFO - Send stop message to
>>> queue processor 01/30/06 12:13:07 -1208039744 Toolkit
>>> BridgeServer.py:726 INFO Shutdown exiting 01/30/06 12:13:07 95853488
>>> Toolkit BridgeServer.py:623 INFO RunQueueThread exiting (END)
>>> we had a notehr machines using the same environment, same AG version
>>> and OS. it works there. is it due to the host certificate? at this
>>> moment, we still not get the AG host cert, just send requet. however,
>>> we are using our CA and signing policy and issue cert to this machine
>>> using ourself CA. will that be a problme without using AG issued cert?
>>> or there is anothter part we have to check for running bridge server?
>>> thakn you so much for any suggestion!
>>> Best regard!
>>>               mike
