[AG-TECH] Access Grid 3.0 beta1 available !
    Frank Sweetser
    fs at WPI.EDU
    Mon Jan 30 12:43:16 CST 2006
On Mon, Jan 30, 2006 at 06:21:02PM +0000, Piers O'Hanlon wrote:
> - Secondly the firewall interaction then depends on which platform AG
Actually, that only covers the firewall running on the local machine.  Far,
*far* more problematic are external firewalls running on routers, typically in
a completely different sphere of control than the machine running AG.  These
tend to be run by people who respond to a request of "Could you please open up
these 5,000 ports to all addresses?" with derisive laughter.  Dealing with
these external firewalls becomes much easier when the AG is restricted to a
small, tightly defined set of ports.
Frank Sweetser fs at wpi.edu  |  For every problem, there is a solution that
WPI Network Engineer          |  is simple, elegant, and wrong. - HL Mencken
    GPG fingerprint = 6174 1257 129E 0D21 D8D4  E8A3 8E39 29E3 E2E8 8CEC
