[AG-TECH] Bridge Server problmes?
    Thomas D. Uram
    turam at mcs.anl.gov
    Mon Jan 30 12:42:38 CST 2006
Hi Mike:
If your CA and certs from CA are being used on the venue server you're trying
to bridge,
you should not have a problem.  Can you post the bridge.conf file ?
Tom
On 1/30/06 7:52 AM, G.T. Chiang wrote:
> Dear All
>   we are trying to set our bridge server. we are running venues server
> at same mahcines for testing. however, when we start the bridge server
> using BridgeServer.py -c bridge.conf
> it is hanging there, i fi chekc the log it stop at 01/30/06 12:13:07
> -1208039744 Toolkit BridgeServer.py:720 INFO - Send stop message to
> queue processor 01/30/06 12:13:07 -1208039744 Toolkit
> BridgeServer.py:726 INFO Shutdown exiting 01/30/06 12:13:07 95853488
> Toolkit BridgeServer.py:623 INFO RunQueueThread exiting (END)
> we had a notehr machines using the same environment, same AG version and
> OS. it works there. is it due to the host certificate? at this moment,
> we still not get the AG host cert, just send requet. however, we are
> using our CA and signing policy and issue cert to this machine using
> ourself CA. will that be a problme without using AG issued cert?
> or there is anothter part we have to check for running bridge server?
> thakn you so much for any suggestion!
> Best regard!
>               mike
