Rif: Re: [AG-TECH] AGtk 3 beta1: venue server troubleshooting under Windows XP
    Fabrizio.Berdondini at prototipo.it
    Wed Feb 22 10:18:25 CST 2006
Thank you as always Thomas. I'm trying AGtk 3 beta just for testing it in
preview of a migration to 3.1 when ready. As far as now I was just trying
to understand if the problem I'm having with setting up permissions for
the venues with the 3 beta venueserver was just a problem of mine or
"known bug"...
thanx again
Faber B.
"Thomas D. Uram" <turam at mcs.anl.gov> scritti il 22/02/2006 16.51.29
> Hi:
> I've just found your earlier messages (from 16 Feb) in my quarantine
> folder due to the attachments.  I'll take a look at your logfiles today
> and hopefully be able to help.
> By the way, if you're interested in running a production server,
> I'd recommend you use AG2 right now, since it is well-tested and
> requires client-side certificates.  AG3 does not use client-side
> certificates, so you won't be able to control access to Venues
> yet; that functionality will be added back in for 3.1.
> Tom
> On 2/22/06 9:22 AM, Fabrizio.Berdondini at prototipo.it wrote:
> > Thomas:
> > I found and deleted/re-created many times both the venueserver.dat and
> > .cfg file. I still have the same trouble: the VenueManagementTool
> > doesn't allow me to add roles or personsl. The only existent role is
> > "RegisteredPeople", it's empty and (as mentionned before) I cannot add
> > any person to it nor create other roles.
> > How can I address this problem?
> > Thanx
> > Faber B.
> >  > Fabrizio:
> >  > This issue was addressed in other mail on the list.  Have you
> > resolved it?
> >  > AG3 will use the VenueServer.cfg and VenueServer.dat files in the
> > current
> >  > directory;
> >  > if those files are from AG2, they will still be used.  You can
avoid
> > this by
> >  > starting
> >  > from a different directory, or by moving these files to another
> > directory.
> >  > If you have any more trouble, please do let me know.
> >  > Grazie,
> >  > Tom
> >  > On 2/16/06 10:42 AM, Fabrizio.Berdondini at prototipo.it wrote:
> >  > > I completely removed a previuous installation of AGtk-2.4 from
the
> >  > > machine (win2k) that hosted the venueserver, then installed AGtk
3
> >  > > beta1. When I launched the Venue Server and the Venue Management
> > Tool it
> >  > > showed the same venues configuration I had under AG 2.4... Where
is
> > this
> >  > > information stored? How can I remove it?
> >  > > owner-ag-tech at mcs.anl.gov scritti il 16/02/2006 15.45.18
> >  > >  > By the way, it seems that something's started "moving" on my
AGtk 3
> >  > >  > server: I removed my certificated user (globus Identity
Certificate)
> >  > >  > and installed a "service" certificate. Now I can finally reach
my
> >  > >  > VenueServer via the VenueManagementTool. However there's still
> >  > >  > something strange: I went to the "manage security" tag of my
default
> >  > >  > lobby venue in order to check the status of allowed and
disallowed
> >  > >  > people/actions: in fact the section is empty, there's only a
> >  > >  > "Registered people" entry which contains nothing (no ppl, no
> >  > >  > actions). I tried to add some persons but no luck: I can only
add
> >  > >  > roles but cannot fill them and so I cannot configure any
> >  > >  > people/action... maybe this is the reason why I cannot enter
the
> >  > >  > venue with my client...
> >  > >  > I'll try to "reset" the server configuration and restart the
> >  > >  > service... stay tuned ;-)
> >  > >  > Thanx again for your attention and support,
> >  > >  > Faber B.
> >  > >  > "Thomas D. Uram" <turam at mcs.anl.gov> scritti il 16/02/2006
15.10.45
> >  > >  > > I'm not sure why it didn't get forwarded, but will check.
> >  Meanwhile,
> >  > >  > > you can put them in web space and point at them with a url.
> >  > >  > > Tom
> >  > >  > > On 2/16/06 7:57 AM, Fabrizio.Berdondini at prototipo.it wrote:
> >  > >  > > > It seems I'm no more able to send messages to the mailing
> > list... or
> >  > >  > > > maybe I cannot send it with an attachment. How can I post
my
> >  > > server logs
> >  > >  > > > with a message on the ml? Is there some restriction?
> >  > >  > > > Thanx for suggestions
> >  > >  > > > Faber B.
> >  > >  > > > owner-ag-tech at mcs.anl.gov scritti il 15/02/2006 16.29.18
> >  > >  > > >  > Helllo Fabrizio:
> >  > >  > > >  > Can you send more of your logfile?  (Send to me
> > personally if
> >  > > it's
> >  > >  > > > very big.)
> >  > >  > > >  > This error should not be happening, and I suspect it is
> > somehow
> >  > >  > > > related to
> >  > >  > > >  > server initialization that would be reflected earlier
in the
> >  > > logfile.
> >  > >  > > >  > Since you also had trouble with VenueManagement, you
could
> >  > > also include
> >  > >  > > >  > that logfile.
> >  > >  > > >  > Grazie,
> >  > >  > > >  > Tom
> >  > >  > > >  > On 2/15/06 9:15 AM, Fabrizio.Berdondini at prototipo.it
wrote:
> >  > >  > > >  > > Hello all,
> >  > >  > > >  > > I'm trying to configure venueserver and client on a
WinXP
> >  > > machine in
> >  > >  > > >  > > order to have a look to the new release of AGtk (for
future
> >  > >  > > > migration of
> >  > >  > > >  > > our current server/clients). I installed all the
packages
> >  > >  > indicated on
> >  > >  > > >  > > the download link but I'm not able to connect my
client to
> >  > > the local
> >  > >  > > >  > > venueserver: the server rejects the connection with
the
> >  > > following
> >  > >  > > > message:
> >  > >  > > >  > > 02/15/06 16:11:51 3576 Security
> >  > > authorizationmanager.py:216 DEBUG
> >  > >  > > >  > > Rejecting access from unidentified user as part of
> > Everybody
> >  > > role
> >  > >  > > >  > > 02/15/06 16:11:51 3576 Hosting servicecontainer.py:16
> >  > > ERROR Not
> >  > >  > > >  > > authorized None
> >  > >  > > >  > > 02/15/06 16:12:01 3572 VenueServer     venue.py:235
DEBUG
> >  > > Client
> >  > >  > > > Timeout
> >  > >  > > >  > > Check: 1140016326 vs 1140016321
> >  > >  > > >  > > I tried to modify the default venue
settings/permissions,
> >  > >  > but I wasn't
> >  > >  > > >  > > able to connect to the venueserver via the
> >  > > VenueManagementTool: it
> >  > >  > > >  > > simply tells me that it cannot connect to the
venueserver
> >  > > located at
> >  > >  > > >  > > https://localhost:8000/VenueServer (the address is
correct
> >  > > and if I
> >  > >  > > > try
> >  > >  > > >  > > to reference the venueserver with its IP or its full
> > network
> >  > > name the
> >  > >  > > >  > > VenueManagementTools hangs).
> >  > >  > > >  > > Any suggestion?
> >  > >  > > >  > > Thanx,
> >  > >  > > >  > > Faber B.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20060222/1e11bbea/attachment.htm>
