[AG-TECH] Troubleshooting Configuration of Server Node over LAN
    Thomas D. Uram
    turam at mcs.anl.gov
    Wed Feb 22 01:12:27 CST 2006
Have you made progress on these issues?  I'd like to help where I can.
Tom
On 1/26/06 10:24 AM, Fabrizio.Berdondini at prototipo.it wrote:
> Hello,
> I need some help: I'm trying to configure 2 PCs over a LAN, both with XP
> Pro, to have them acting, respectively, as venueserver and venueclient.
> They both have fixed IPs, which are 192.168.2.214 for the server and
> 192.168.2.218 for the client. The seocond also runs a small node
> (Philips TouCAM, headphone, mic).
> I also configured some venues on the server and gave them access via the
> Lobby default venue.
> When I try to access the venues on the server, however, I receive the
> error "can not connect to venue located at ... etc. etc.". I tried to
> access the venues on the server both referencing it as IP address:
> https://192.168.2.218:8000/Venues/default or network name:
> https://<pcname>:8000/Venues/default.
> I also tried this:
> 1) launched the venue server on the machine at 192.168.2.218
> 2) launched the venue client on the same machine (192.168.2.218) and
> tried to connect to the server, referencing it as: localhost,
> 192.168.2.218:8000, <pcname.domain>:8000,<pcname>:8000: in all four
> cases the connection was successful, meaning that the node/client is
> well configured
> 3) launched venue server on the machina at 192.168.2.214
> 4)  launched the venue client on the same machine (192.168.2.214) and
> 192.168.2.214:8000, <pcname.domain>:8000, <pcname>:8000: in all four
> cases the connection was successful, meaning that also the server seems
> to be well configured and running. I left the venueclient connectet to
> the venue server on the same machine then
> 5) tried to connect the venueclient on 192.168.2.214 to the server at
> 192.168.2.218 and no luck referencing it as 192.168.2.214:8000,
> <pcname.domain>:8000 or <pcname>:8000: I got the error message
> mentionned before
> 6) after getting the error message on the venueclient on 192.168.2.218 I
> looked onto the venueclient on the other machine and... SURPRISE!
>  It seemed I was online and active inside the lobby venue, even if on
> the venueclient on the 192.168.2.218 machine I was indicated as not
> connected to any venue.
> I really have no clue... anyone can help please?
> Thank you very much.
> Faber B.
