[AG-TECH] AG3 CVS - Files Missing?
    Todd Zimmerman
    toddz at sfu.ca
    Tue Feb 21 18:54:05 CST 2006
Actually, I had the same issue trying to build from cvs on RHEL 4.
GenerateInterfaces.py was trying to run wsdl2py.py - but the python file that zsi produced and put
on my path was /usr/bin/wsdl2py (note - no .py extension).  I removed the .py extensions from the
w2pyExec and w2dExec variables in GenerateInterfaces.py and all was better.
Not sure why the difference but that solved the problem.
Cheers,
Todd
Thomas D. Uram wrote:
> Ashnil:
> Try running AccessGrid/tools/GenerateInterfaces.py.  That will generate
> Python code in AccessGrid/interfaces from the files in AccessGrid/wsdl.
> This should be getting called automatically by CvsSetup.py.  Is it for some
> reason not being called in your case?
> Tom
> On 2/7/06 11:18 PM, Ashnil Kumar wrote:
>> I have recently set up AG3 on Mac OS X 10.3 (using CvsSetup, as I want
>> to look at development in the future rather than just using it now),
>> and when attempting to run from the command line, I have come across a
>> couple of ImportErrors. In both cases, AGTK_LOCATION and PYTHONPATH
>> were correctly set up.
>> AccessGrid/interfaces contains only __init__.py. Are the modules that
>> are not found intentionally not there? The traces are given below.
>> Cheers,
>> Ashnil
>> When running "python VenueClient.py --personalNode"
>> Traceback (most recent call last):
>>   File "VenueClient.py", line 15, in ?
>>     from AccessGrid.hosting import Client
>>   File
>> "/Volumes/Data/mnt/scratch/ag3b/AccessGrid/AccessGrid/hosting/__init__.py",
>> line 134, in ?
>>     SetHostingImpl(__hostingImpl)
>>   File
>> line 70, in SetHostingImpl
>>     s = __import__(nis, globals(), locals(), ["SecureServer",
>>   File
>> "/Volumes/Data/mnt/scratch/ag3b/AccessGrid/AccessGrid/hosting/ZSI/__init__.py",
>> line 24, in ?
>>     from AccessGrid.interfaces.AccessGrid_Types import
>> www_accessgrid_org_v3_0 as AGTypes
>> ImportError: No module named AccessGrid_Types
>> and when running "python VenueServer.py":
>>   File "VenueServer.py", line 25, in ?
>>     from AccessGrid.Toolkit import Service
>>   File
>> "/Volumes/Data/mnt/scratch/ag3b/AccessGrid/AccessGrid/Toolkit.py",
>> line 21, in ?
>>     from AccessGrid.Preferences import Preferences
>>   File
>> "/Volumes/Data/mnt/scratch/ag3b/AccessGrid/AccessGrid/Preferences.py",
>> line 12, in ?
>>     from AccessGrid.interfaces.AGNodeService_client import
>> AGNodeServiceIW
>> ImportError: No module named AGNodeService_client
