[AG-TECH] AG3 venue server on both Windows and Linux (FD4)?
G.T. Chiang
gtc25 at cam.ac.uk
Thu Feb 16 03:12:28 CST 2006
Dear Doug
thank you very much!! i am using i386 Fedora packages and it can be
installed. at this moment, when I run venue server, i can not use venue
manager to connect this server using localhost:8000, if i change to IP
address, it works. however, i can not add a new venue. meanwhile, i can not
get in this venuser server using venue client, simply unable to connect (in
same machine without firwall). Do you hvae any suggestion?
gen-tao
On Feb 16 2006, Douglas Kosovic wrote:
>Hi gen-tao,
>> I try to start the venue server on both Windows and Linux. when I try
>> to start it, it crash immediately both in windwos and linux, i am not
>> sure what exactly happend. i remove previous AG2 and python. and it
>> still not working. clinet seems ok in windows, but not in linux (Fedora
>> 4). th eerror message of linux is like the following:
>> File "/usr/lib/python2.4/site-packages/wx-2.6-gtk2-unicode/wx/_core.py"
>> 4, in ?
>> import _core_
>> ImportError: /usr/lib/python2.4/site-packages/wx-2.6-gtk2-unicode/wx/_cor
>> cannot open shared object file: No such file or directory
>> the library is there, and Log is empty.
> I've only seen the misleading "No such file or directory" error message
> when trying to use 32bit Python binary modules with a 64bit Python. The
> Python wrapper of the UCL common library still needs to be made 64bit
> clean before AG3 beta can work on x86-64 FC4.
>Speaking of wxPython, Fedora Extras is going to provide the wxPython/wxGTK
>2.6.3.x RPMs next week, at least according to the Fedora Extras bugzilla
>report:
> https://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=163440
>so I won't need to include a wxPython 2.6.x RPM (rebuilt from the SRPM on
>www.wxpython.org) with the AG3 FC4 yum repository.
>Cheers,
>Doug
