[AG-TECH] AG3 venue server on both Windows and Linux (FD4)?
    G.T. Chiang
    gtc25 at cam.ac.uk
    Wed Feb 15 17:27:51 CST 2006
Dear Sebastina and Tom
   i try to use the ID mode and import our own cert (boht signing poluicy
and hostcert) and run venue server. this time the error becomes following.
thakn you very much!!!
[gtniees at agorilla ~]$ VenueServer.py Server:
https://agorilla.niees.group.cam.ac.uk:8000/VenueServer Data Port: 8006
Default Venue Url:
https://agorilla.niees.group.cam.ac.uk:8000/Venues/default Exception in
thread <bound method VenueServer.Checkpoint of
<AccessGrid.VenueServer.VenueServer instance at 0xb72eb1ac>> 300 0:
Traceback (most recent call last):
  File "/usr/lib/python2.4/threading.py", line 442, in __bootstrap
    self.run()
  File
"/usr/lib/python2.4/site-packages/AccessGrid3/AccessGrid/scheduler.py",
line 46, in run
    self._action()
  File
"/usr/lib/python2.4/site-packages/AccessGrid3/AccessGrid/VenueServer.py",
line 763, in Checkpoint
    store = file(self.persistenceFilename, "w")
IOError: [Errno 13] Permission denied: 'VenueServer.dat'
On Feb 15 2006, Thomas D. Uram wrote:
>On 2/15/06 11:44 AM, Sebastian Tabarce wrote:
>> Hi Gen-Tao,
>> If you type "help" at the  (ID mode)> prompt you will see a list of
>> commands that can be used inside the Certificate Manager. I think it's
>> pretty straightforward to figure out what each does. Using those
>> commands you can add certificates, set the default certificate, generate
>> a proxy ....etc. etc.
>> About the other problem, I suppose AGTK 2.x and 3.0 store the
>> certificates and configuration files under the same directory, which is
>> My Documents\%username%\Application Data\AccessGrid and that is why
>> probably you see the same Venues.
>AG2 uses \Documents and Settings\%username%\Application Data\AccessGrid
>AG3 uses \Documents and Settings\%username%\Application Data\AccessGrid3
> The VenueServer takes its configuration from files VenueServer.cfg and
> VenueServer.dat in the current directory, so if you have those files in
> the current directory from AG2, they will be used by the AG3 server.
> There are command-line options for controlling the files used by the
> VenueServer (see VenueServer.py -h).
>> Good luck,
>> Sebastian
>> G.T. Chiang wrote:
>>> Dear All
>>>   since using the Fedora i386. the situation getting better. the
>>> situation now is needing certificate to run venue server. i applied
>>> one. however, i was trying to use our own certificate, i could not
>>> find cert manager as before. if i execute certmgr.py and got this (ID
>>> mode) > . is cert manager working at linux version this moment?
>>>   about windows verson, I had cert on this machine before, and cert
>>> manager is wokring on windows, i import the host and running the venue
>>> server, it seems wroking. however, when i try to use venue management
>>> tool to add to AG3 venue, i saw previous AG2 venues. how this happend?
>>> is taht mean I am still running AG2 venue server?, but i even remove
>>> the AG2 before installing AG3.
>>> Thank you for any suggestion!!
>>> Best Regard!
>>>       gen-tao
>>> On Feb 15 2006, G.T. Chiang wrote:
>>>> Dear All
>>>>   I try to start the venue server on both Windows and Linux. when I
>>>> try to start it, it crash immediately both in windwos and linux, i am
>>>> not sure what exactly happend. i remove previous AG2 and python. and
>>>> it still not working. clinet seems ok in windows, but not in linux
>>>> (Fedora 4). th eerror message of linux is like the following:
>>>>  File "/usr/bin/VenueClient.py", line 21, in ?
>>>>    from wxPython.wx import wxPySimpleApp
>>>>  File
>>>> "/usr/lib/python2.4/site-packages/wx-2.6-gtk2-unicode/wxPython/__i y",
>>>> line 10, in ?
>>>>    import _wx
>>>>  File
>>>> "/usr/lib/python2.4/site-packages/wx-2.6-gtk2-unicode/wxPython/_wx ine
>>>> 3, in ?
>>>>    from _core import *
>>>>  File
>>>> "/usr/lib/python2.4/site-packages/wx-2.6-gtk2-unicode/wxPython/_co
>>>> line 15, in ?
>>>>    import wx._core
>>>>  File
>>>> "/usr/lib/python2.4/site-packages/wx-2.6-gtk2-unicode/wx/__init__. ne
>>>> 42, in ?
>>>>    from wx._core import *
>>>>  File
>>>> "/usr/lib/python2.4/site-packages/wx-2.6-gtk2-unicode/wx/_core.py" 4,
>>>> in ?
>>>>    import _core_
>>>> ImportError:
>>>> cannot open shared object file: No such file or directory
>>>> the library is there, and Log is empty.
>>>> thank you for any suggestion!!
>>>> Best regard!
>>>>                    gen-tao
